[QGIS Commit] r9386 - in trunk/external_plugins/cdp2/src: gui ui
svn_qgis at osgeo.org
Tue Sep 23 08:58:08 EDT 2008
Author: timlinux
Date: 2008-09-23 08:58:08 -0400 (Tue, 23 Sep 2008)
New Revision: 9386
trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.cpp
trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.h
trunk/external_plugins/cdp2/src/ui/climatedataprocessorguibase.ui
Added generic methods for getting a file and a dir
Modified: trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.cpp
--- trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.cpp 2008-09-23 12:38:39 UTC (rev 9385)
+++ trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.cpp 2008-09-23 12:58:08 UTC (rev 9386)
@@ -50,35 +50,25 @@
done(1);
-void ClimateDataProcessorGui::on_pbnSelectFile_clicked()
+QString ClimateDataProcessorGui::getFileName(QString theDefaultFile, QString theMessage)
- QSettings mySettings;
- QString myBaseDir = mySettings.value("climateconverter/inputLayersDirectory","/tmp").toString(); //initial dir
- QStringList myFileNameQStringList = QFileDialog::getOpenFileNames(
- this,
- "Select one or more files",
- myBaseDir, //initial dir
- "Climate Climate Data (*.asc *.mea *.dat)" //filters to select
- lstInputFiles->addItems(myFileNameQStringList);
- QFileInfo myFileInfo(myFileNameQStringList.at(0));
- QString myBaseString = myFileInfo.dir().path()+QString("/");
- mySettings.setValue("climateconverter/inputLayersDirectory",myBaseString);
+ QString myFileName = QFileDialog::getOpenFileName(
+ this,
+ theMessage , //caption
+ QFileInfo(theDefaultFile).absolutePath(), //initial dir
+ "Climate Climate Data (*.asc *.mea *.dat)" //filters to select
+ return (myFileName);
-void ClimateDataProcessorGui::on_pbnSelectDir_clicked()
+QString ClimateDataProcessorGui::getDirName(QString theDefaultDir, QString theMessage)
- QString myDir = QFileDialog::getExistingDirectory(
- this,
- "Choose a directory",
- mLastDir);
- mLastDir = myDir;
- leOutputDir->setText(myDir);
+ QString myFileName = QFileDialog::getExistingDirectory(
+ this,
+ theDefaultDir //initial dir
void ClimateDataProcessorGui::on_pbnProcess_clicked()
@@ -146,7 +136,12 @@
void ClimateDataProcessorGui::on_pbnMeanTemp_clicked()
- leMeanTemp->setText("hello world");
+ getFileName(leMeanTemp->text(), tr("Choose the mean temp file"));
+ if (!myFileName.isEmpty())
+ leMeanTemp->setText(myFileName);
void ClimateDataProcessorGui::on_pbnMinTemp_clicked()
Modified: trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.h
--- trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.h 2008-09-23 12:38:39 UTC (rev 9385)
+++ trunk/external_plugins/cdp2/src/gui/climatedataprocessorgui.h 2008-09-23 12:58:08 UTC (rev 9386)
@@ -69,8 +69,23 @@
void accept();
- void on_pbnSelectFile_clicked();
- void on_pbnSelectDir_clicked();
+ /** Helper method to generically get a file name.
+ * @param theDefaultFile - default file used as a basis for path location
+ * @param theMessage - a prompt message to use when asking for the file name
+ * @return QString - containing the users selected filename or empty
+ * if the user cancelled.
+ QString getFileName(QString theDefaultFile, QString theMessage);
+ /** Helper method to generically get a directory.
+ * @param theMessage - a prompt message to use when asking for the dir
+ * @return QString - containing the users selected dir or empty
+ QString getDirName(QString theDefaultDir, QString theMessage);
/** Runs when process button is pressed.
* Does not close the form afterwards.
Modified: trunk/external_plugins/cdp2/src/ui/climatedataprocessorguibase.ui
--- trunk/external_plugins/cdp2/src/ui/climatedataprocessorguibase.ui 2008-09-23 12:38:39 UTC (rev 9385)
+++ trunk/external_plugins/cdp2/src/ui/climatedataprocessorguibase.ui 2008-09-23 12:58:08 UTC (rev 9386)
@@ -349,20 +349,63 @@
<layoutdefault spacing="6" margin="11" />
<tabstops>
<tabstop>leMeanTemp</tabstop>
+ <tabstop>pbnMeanTemp</tabstop>
<tabstop>leMinTemp</tabstop>
+ <tabstop>pbnMinTemp</tabstop>
<tabstop>leMaxTemp</tabstop>
+ <tabstop>pbnMaxTemp</tabstop>
<tabstop>leDiurnalTemp</tabstop>
+ <tabstop>pbnDiurnalTemp</tabstop>
<tabstop>leMeanPrecipitation</tabstop>
+ <tabstop>pbnMeanPrecipitation</tabstop>
<tabstop>leFrostDays</tabstop>
+ <tabstop>pbnFrostDays</tabstop>
<tabstop>leTotalSolarRadiation</tabstop>
+ <tabstop>pbnTotalSolarRad</tabstop>
+ <tabstop>lstVariablesToCalc</tabstop>
<tabstop>cbxSelectAllVars</tabstop>
<tabstop>cboOutputFormat</tabstop>
<tabstop>leOutputPath</tabstop>
+ <tabstop>pbnOutputPath</tabstop>
<tabstop>cbxSwitchMeridian</tabstop>
<tabstop>cbxPseudoColour</tabstop>
+ <tabstop>buttonBox</tabstop>
</tabstops>
<resources>
<include location="../resources/resources.qrc" />
</resources>
- <connections/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>ClimateDataProcessorGuiBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>444</x>
+ <y>668</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>582</x>
+ <y>621</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>538</x>
+ <y>677</y>
+ </hint>
+ <x>582</x>
+ <y>663</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
