[QGIS Commit] r9398 - in trunk/external_plugins/cdp2: . src
src/tests
svn_qgis at osgeo.org
Wed Sep 24 04:21:23 EDT 2008
Author: timlinux
Date: 2008-09-24 04:21:23 -0400 (Wed, 24 Sep 2008)
New Revision: 9398
Added:
trunk/external_plugins/cdp2/src/tests/
trunk/external_plugins/cdp2/src/tests/CMakeLists.txt
trunk/external_plugins/cdp2/src/tests/cdptest.cpp
trunk/external_plugins/cdp2/src/tests/test_data/
trunk/external_plugins/cdp2/CMakeLists.txt
trunk/external_plugins/cdp2/src/CMakeLists.txt
Added simple test framework and use rpath for lib location
Modified: trunk/external_plugins/cdp2/CMakeLists.txt
--- trunk/external_plugins/cdp2/CMakeLists.txt 2008-09-24 01:23:24 UTC (rev 9397)
+++ trunk/external_plugins/cdp2/CMakeLists.txt 2008-09-24 08:21:23 UTC (rev 9398)
@@ -63,14 +63,31 @@
+# Enable the use of RPATH so that the executeable
+# library search paths are relative to the executeable
+# use, i.e. don't skip the full RPATH for the build tree
+SET(CMAKE_SKIP_BUILD_RPATH FALSE)
+# when building, don't use the install RPATH already
+# (but later on when installing)
+SET(CMAKE_BUILD_WITH_INSTALL_RPATH FALSE)
+# the RPATH to be used when installing
+SET(CMAKE_INSTALL_RPATH "${CMAKE_INSTALL_PREFIX}/lib")
+# add the automatically determined parts of the RPATH
+# which point to directories outside the build tree to the install RPATH
+SET(CMAKE_INSTALL_RPATH_USE_LINK_PATH TRUE)
# enable warnings, halt compile on warnings
IF (PEDANTIC AND NOT MSVC)
ADD_DEFINITIONS( -Wall -Werror )
ENDIF (PEDANTIC AND NOT MSVC)
-IF (CMAKE_BUILD_TYPE MATCHES Debug)
- ADD_DEFINITIONS(-DCDP_NO_EXPERIMENTAL)
-ENDIF (CMAKE_BUILD_TYPE MATCHES Debug)
Modified: trunk/external_plugins/cdp2/src/CMakeLists.txt
--- trunk/external_plugins/cdp2/src/CMakeLists.txt 2008-09-24 01:23:24 UTC (rev 9397)
+++ trunk/external_plugins/cdp2/src/CMakeLists.txt 2008-09-24 08:21:23 UTC (rev 9398)
@@ -5,6 +5,6 @@
# SUBDIRS(mac)
#ENDIF(APPLE)
-#IF (ENABLE_TESTS)
-# SUBDIRS(tests)
-#ENDIF (ENABLE_TESTS)
+IF (ENABLE_TESTS)
+ SUBDIRS(tests)
+ENDIF (ENABLE_TESTS)
Added: trunk/external_plugins/cdp2/src/tests/CMakeLists.txt
--- trunk/external_plugins/cdp2/src/tests/CMakeLists.txt (rev 0)
+++ trunk/external_plugins/cdp2/src/tests/CMakeLists.txt 2008-09-24 08:21:23 UTC (rev 9398)
@@ -0,0 +1,75 @@
+SET( QT_USE_QTTEST TRUE )
+# Don't forget to include output directory, otherwise
+# the UI file won't be wrapped!
+INCLUDE_DIRECTORIES(${CMAKE_CURRENT_SOURCE_DIR}
+# binary make output dirs for uics and mocs
+ ${CMAKE_CURRENT_BINARY_DIR}
+ ${CMAKE_CURRENT_BINARY_DIR}/../../
+ ${CMAKE_CURRENT_BINARY_DIR}/../ui
+# source dirs
+ ${CMAKE_CURRENT_SOURCE_DIR}/../../
+ ${CMAKE_CURRENT_SOURCE_DIR}/../lib
+ ${CMAKE_CURRENT_SOURCE_DIR}/../gui
+ ${QT_INCLUDE_DIR}
+ ${GDAL_INCLUDE_DIR}
+#MESSAGE("Test Data Dir: ${TEST_DATA_DIR}")
+ADD_DEFINITIONS(-DTEST_DATA_DIR="\\"${TEST_DATA_DIR}\\"")
+# libraries
+# because of htonl
+IF (WIN32)
+ SET(PLATFORM_LIBRARIES wsock32)
+ENDIF (WIN32)
+# Since the tests are not actually installed, but rather
+# run directly from the build/src/tests dir we need to
+# ensure the omg libs can be found.
+IF (APPLE)
+ # For Mac OS X, the executable must be at the root of the bundle's executable folder
+ SET (CMAKE_INSTALL_NAME_DIR @executable_path/../lib)
+ENDIF (APPLE)
+SET (REQUIRED_LIBS
+ ${QT_QTCORE_LIBRARY}
+ ${QT_QTTEST_LIBRARY}
+ ${QT_QTGUI_LIBRARY}
+ ${QT_QTXML_LIBRARY}
+ ${QT_QTSVG_LIBRARY}
+ ${QT_QTNETWORK_LIBRARY}
+ ${QT_QTMAIN_LIBRARY}
+ cdp_core
+#note for tests we should not include the moc of our
+#qtests in the executable file list as the moc is
+#directly included in the sources
+#and should not be compiled twice. Trying to include
+#them in will cause an error at build time
+# sources
+# cdp test
+SET(CDPTEST_SRCS cdptest.cpp)
+SET(CDPTEST_MOC_CPPS cdptest.cpp)
+QT4_WRAP_CPP(CDPTEST_MOC_SRCS ${CDPTEST_MOC_CPPS})
+ADD_CUSTOM_TARGET(cdptestmoc ALL DEPENDS ${CDPTEST_MOC_SRCS})
+ADD_EXECUTABLE(cdptest ${CDPTEST_SRCS})
+ADD_DEPENDENCIES(cdptest cdptestmoc)
+TARGET_LINK_LIBRARIES(cdptest ${REQUIRED_LIBS})
+INSTALL(TARGETS cdptest RUNTIME DESTINATION ${CDP_TEST_DIR})
+ADD_TEST(cdp ${CDP_TEST_DIR}/cdptest)
+# Put the libs needed into the test dir
+#MESSAGE ("Current Binary Dir: ${CMAKE_CURRENT_BINARY_DIR}")
+IF (WIN32)
+ INSTALL (FILES ${CMAKE_INSTALL_PREFIX}/cdp_core.dll DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+ENDIF (WIN32)
+IF (APPLE)
+ INSTALL (FILES ${CMAKE_BINARY_DIR}/src/lib/libcdp_core.dylib DESTINATION ${CDP_TEST_DIR}/lib/)
+ENDIF (APPLE)
Added: trunk/external_plugins/cdp2/src/tests/cdptest.cpp
--- trunk/external_plugins/cdp2/src/tests/cdptest.cpp (rev 0)
+++ trunk/external_plugins/cdp2/src/tests/cdptest.cpp 2008-09-24 08:21:23 UTC (rev 9398)
@@ -0,0 +1,57 @@
+ * Copyright (C) 2007 by Tim Sutton *
+ * tim at linfiniti.com *
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+ * This program is distributed in the hope that it will be useful, *
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of *
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
+ * GNU General Public License for more details. *
+ * You should have received a copy of the GNU General Public License *
+ * along with this program; if not, write to the *
+ * Free Software Foundation, Inc., *
+ * 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. *
+#include <QtTest/QtTest>
+#include <climatedataprocessorcontroller.h>
+#include <QImage>
+#include <QList>
+class CdpTest: public QObject
+ Q_OBJECT;
+ private slots:
+ /** Regression test for making sure
+ available calcs always computes correctly grid layers */
+ void availableCalcsTest();
+ void initTestCase();// will be called before the first testfunction is executed.
+ void cleanupTestCase();// will be called after the last testfunction was executed.
+ void init(){};// will be called before each testfunction is executed.
+ void cleanup(){};// will be called after every testfunction.
+ private:
+ //add private test vars here
+void CdpTest::initTestCase()
+ QCoreApplication::setOrganizationName("Linfiniti Consulting");
+ QCoreApplication::setOrganizationDomain("linfiniti.com");
+ QCoreApplication::setApplicationName("ClimateDataProcessor");
+void CdpTest::cleanupTestCase()
+void CdpTest::availableCalcsTest()
+QTEST_MAIN(CdpTest)
+#include "moc_cdptest.cxx"
