[QGIS Commit] r9402 - in docs/trunk/english_us/user_guide: .
plugins_screenies
svn_qgis at osgeo.org
Wed Sep 24 08:03:21 EDT 2008
Author: dassau
Date: 2008-09-24 08:03:21 -0400 (Wed, 24 Sep 2008)
New Revision: 9402
Added:
docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_dialog.png
docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_qgs.png
docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_test.png
docs/trunk/english_us/user_guide/core_plugins.tex
docs/trunk/english_us/user_guide/grass_integration.tex
docs/trunk/english_us/user_guide/plugins_mapserver_export.tex
docs/trunk/english_us/user_guide/plugins_screenies/Makefile
updated and tested section mapserver export plugin
Modified: docs/trunk/english_us/user_guide/core_plugins.tex
--- docs/trunk/english_us/user_guide/core_plugins.tex 2008-09-24 11:13:56 UTC (rev 9401)
+++ docs/trunk/english_us/user_guide/core_plugins.tex 2008-09-24 12:03:21 UTC (rev 9402)
@@ -46,6 +46,9 @@
\includegraphics[width=0.7cm]{interpolation}
& Interpolation \index{plugins!Interpolation}& Interpolation on base of vertices of a vector layer\\
\hline
+\includegraphics[width=0.7cm]{mapserver_export}
+& MapServer Export Plugin \index{plugins!MapServer Export}& Export a saved QGIS project file to a MapServer map file \\
+\hline
\includegraphics[width=0.7cm]{north_arrow}
& North Arrow \index{plugins!north arrow}& Add a north arrow to the map canvas\\
\hline
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex 2008-09-24 11:13:56 UTC (rev 9401)
+++ docs/trunk/english_us/user_guide/grass_integration.tex 2008-09-24 12:03:21 UTC (rev 9402)
@@ -113,7 +113,7 @@
\begin{figure}[ht]
\begin{center}
-\caption{GRASS data organized in the alaska LOCATION (adapted from Neteler \&
+\caption{GRASS data in the alaska LOCATION (adapted from Neteler \&
Mitasova 2007 \cite{neteler_mitasova07})}\label{fig:grass_location}\smallskip
\includegraphics[clip=true]{grass_location}
\end{center}
Modified: docs/trunk/english_us/user_guide/plugins_mapserver_export.tex
--- docs/trunk/english_us/user_guide/plugins_mapserver_export.tex 2008-09-24 11:13:56 UTC (rev 9401)
+++ docs/trunk/english_us/user_guide/plugins_mapserver_export.tex 2008-09-24 12:03:21 UTC (rev 9402)
@@ -2,57 +2,80 @@
% when the revision of a section has been finalized,
% comment out the following line:
-\updatedisclaimer
+%\updatedisclaimer
You can use QGIS to ``compose'' your map by adding and arranging layers,
-symbolizing them, and customizing the colors and then create a map file
-for the UMN MapServer. In order to use the MapServer Export plugin, you
-must have Python installed on your system and QGIS must have been compiled
-with support for it.
+symbolizing them, customizing the colors and then create a map file
+for MapServer. In order to use the MapServer Export plugin, you
+must have Python >= 2.4 installed on your system and QGIS must have been
+compiled with support for it. All binary packages include Python Support.
-The MapServer Export plugin in QGIS \CURRENT is an Python Plugin, that is
-automatically loaded into the \filename{Plugin Manager}.
+The MapServer Export plugin in QGIS \CURRENT is a Python Plugin, that is
+automatically loaded into the \filename{Plugin Manager} as a core plugin
+(see Section~\ref{sec:core_plugins}).
\subsubsection{Creating the Project File}
-To create a MapServer map file:
+The MapServer Export Plugin operates on a saved QGIS project file and
+\textbf{not} on the current contents of the map canvas and legend. This
+has been a source of confusion for a number of people. As described below,
+before you start using the MapServer Export Plugin, you need to arrange
+the raster and vector layers you want to use in MapServer and save this
+status in a QGIS project file
+\begin{figure}[ht]
+\begin{center}
+ \caption{Arrange raster and vector layers for QGIS project file \nixcaption}
+ \label{fig:mapserver_export_qgs}\smallskip
+ \includegraphics[clip=true, width=13cm]{mapserver_export_qgs}
+\end{center}
+\end{figure}
+In this example we show the four steps to get us to the point where we are
+ready to create the MapServer map file. We use raster and vector files from
+the QGIS sample dataset \label{label_sampledata}.
\begin{enumerate}
-\item Add your layers to QGIS
-\item Symbolize your layers, setting the renderer and colors
-\item Arrange the layers in the order you want them to appear in MapServer
-\item Save your work to a QGIS project file
+\item Add the raster layer \filename{landcover.tif} clicking on the
+\toolbtntwo{mActionAddRasterLayer}{Add Raster Layer} icon.
+\item Add the vector Shapefiles \filename{lakes.shp, majrivers.shp} and
+\filename{airports.shp} from the QGIS sample dataset clicking on the
+\toolbtntwo{mActionAddNonDbLayer}{Add Vector Layer} icon.
+\item Change the colors and symbolize the data as you like (see
+Figure~\ref{fig:mapserver_export_qgs})
+\item Save a new project named \filename{mapserverproject.qgs} using
+\mainmenuopt{File} > \dropmenuopttwo{mActionFileSave}{Save Project}.
\end{enumerate}
-This gets us to the point where we are ready to create the map file.
-\begin{Tip}\caption{\textsc{MapServer Export Requires a QGIS Project File}}
-\qgistip{This has been a source of confusion for a number of people. The
-MapServer export tool operates on a saved QGIS project file,
-\textbf{not} the current contents of the map canvas and legend. When
-using the tool, you need to specify a QGIS project file as input.
-\end{Tip}
\subsubsection{Creating the Map File}
-The exporter tool (\filename{msexport}) is installed in your QGIS binary directory and can be used independently of QGIS.
+The tool \filename{msexport} to export a QGIS project file to a MapServer map
+file is installed in your QGIS binary directory and can be used independently of QGIS.
+From QGIS you need to load the MapServer Export Plugin first with the Plugin Manager.
+Click \mainmenuopt{Plugins} > \dropmenuopt{Manage Plugins...} to open the Plugin Manager,
+choose MapServer export Plugin and click \button{OK}. Now start the
+\toolbtntwo{mapserver_export}{MapServer Export} dialog (see
+Figure~\ref{fig:mapserver_export_dialog}) clicking the icon in the toolbar menu.
-From QGIS you can start the exporter by choosing \mainmenuopt{File} > \dropmenuopt{Export to MapServer Map...}.
+\begin{figure}[ht]
+\begin{center}
+ \caption{Export to MapServer Dialog \nixcaption}
+ \label{fig:mapserver_export_dialog}\smallskip
+ \includegraphics[clip=true, width=10cm]{mapserver_export_dialog}
+\end{center}
+\end{figure}
-Here is a summary of the input fields:
\begin{description}
\item [Map file] \mbox{}\\
-Enter the name for the map file to be created. You can use the button at the right to browse for the directory where you want the map file created.
+Enter the name for the map file to be created. You can use the button at the
+right to browse for the directory where you want the map file created.
\item [Qgis project file] \mbox{}\\
-Enter the full path to the QGIS project file (.qgs) you want to export. You can use the button at the right to browse for the QGIS project file.
+Enter the full path to the QGIS project file (.qgs) you want to export. You can
+use the button at the right to browse for the QGIS project file.
\item [Map Name] \mbox{}\\
A name for the map. This name is prefixed to all images generated by the mapserver.
\item [Map Width] \mbox{}\\
Width of the output image in pixels.
\item [Map Height] \mbox{}\\
Height of the output image in pixels.
\item [Map Units] \mbox{}\\
@@ -67,78 +90,63 @@
Full path to the MapServer footer file to be used with the map file
\end{description}
-Only the Map file and QGIS project file inputs are required to create a
-map file, however you may end up with a non-functional map file, depending
-on your intended use. Although QGIS is good at creating a map file from
-your project file, it may require some tweaking to get the results you
-want - but it's still way better than writing a map file from scratch.
+Only the \filename{Map file} and \filename{QGIS project file} inputs are
+required to create a map file, however you may end up with a non-functional
+map file, depending on your intended use. Although QGIS is good at creating
+a map file from your project file, it may require some tweaking to get the
+results you want. But let's create a map file using the project file
+\filename{mapserverproject.qgs} we just created
+(see Figure~\ref{fig:mapserver_export_dialog}):
-\minisec{Creating a Map File}
-Let's create a map file using the shape files \filename{alaska}, \filename{lakes}
-and \filename{rivers} layers from the qgis\_sample\_data:
\begin{enumerate}
- \item Load the \filename{alaska}, \filename{rivers} and \filename{lakes}
- layers into QGIS
- \item Change the colors and symbolize the data as you like
- \item Save the project using \mainmenuopt{File} >
- \dropmenuopttwo{mActionFileSave}{Save Project}.
- \item Open the exporter by clicking mainmenuopt{File} > \dropmenuopt{Export
- to MapServer Map...}.
- \item Enter a name for your new map file
- \item Browse and find the project file you just saved
- \item Enter a name for the map
- \item Enter 600 for the width and 400 for the height
- \item Our layers are in decimal degrees so we don't need to change the
- units
- \item Choose ``png'' for the image type
- \item Click \button{OK} to generate the map file
+ \item Open the MapServer Export Plugin clicking the
+ \toolbtntwo{mapserver_export}{MapServer Export} icon.
+ \item Enter the name \filename{qgisproject.map} for your new map file.
+ \item Browse and find the QGIS project file \filename{mapserverproject.qgs}
+ you just saved.
+ \item Enter a name \filename{MyMap} for the map.
+ \item Enter \filename{600} for the width and \filename{400} for the height.
+ \item Our layers are in meters so we change the units to meters.
+ \item Choose ``png'' for the image type.
+ \item Click \button{OK} to generate the new map file \filename{qgisproject.map}.
+ QGIS displays the success of your efforts.
\end{enumerate}
-%\begin{figure}[ht]
-%\begin{center}
-% \caption{Export to MapServer map module in QGIS}\label{fig:mapserver_export}\smallskip
-% \includegraphics[clip=true, width=0.8\textwidth]{mapserver_export}
-%\end{center}
-%\end{figure}
-You'll notice there is no feedback on the success of your efforts. This
-is an enhancement scheduled for the next version.
You can view the map file in an text editor or visualizer. If you
take a look, you'll notice that the export tool adds the metadata needed
to enable our map file for WMS.
\subsubsection{Testing the Map File}
-Let's test our work by using the \filename{shp2img} command to create an image
-from the map file. The \filename{shp2img} utility is part of MapServer,
-but is also distributed with FWTools. To create an image from our map:
+We can now test our work using the \filename{shp2img} tool to create an image
+from the map file. The \filename{shp2img} utility is part of MapServer and FWTools.
+To create an image from our map:
\begin{itemize}
\item Open a terminal window
\item If you didn't save your map file in your home directory, change to
- the directory where you saved it
-\item Run \filename{shp2img}
-\item View the created image
+ the folder where you saved it
+\item Run \filename{shp2img -m qgisproject.map -o mapserver\_test.png} and
+ display the image
\end{itemize}
-Assuming our map file was named \filename{mapserver\_test.map}, the
-\filename{shp2img} command is:
+This creates a PNG with all the layers included in the QGIS project file.
+In addition, the extent of the PNG will be the same as when we saved the
+project. As you can see in Figure~\ref{fig:mapserver_export_test}, all
+inforamtion except the airport symbols are included.
-\begin{verbatim}
-\end{verbatim}
+\begin{figure}[ht]
+\begin{center}
+ \caption{Test PNG created by shp2img with all MapServer Export layers \nixcaption}
+ \label{fig:mapserver_export_test}\smallskip
+ \includegraphics[clip=true, width=12cm]{mapserver_export_test}
+\end{center}
+\end{figure}
-This creates a PNG for us to view, containing all the layers that were on
-when we saved the QGIS project. In addition, the extent of the PNG will be the same as
-when we saved the project.
If you plan to use the map file to serve WMS requests, you probably don't
have to tweak anything. If you plan to use it with a mapping template or a
custom interface, you may have a bit of manual work to do. To see how easy
it is to go from QGIS to serving maps on the web, take a look at
-Christopher Schmidt's 5 minute flash video.
+Christopher Schmidt's 5 minute flash video. He used QGIS version 0.8, but it
+is still useful.
\footnote{\url{http://openlayers.org/presentations/mappingyourdata/}}
Modified: docs/trunk/english_us/user_guide/plugins_screenies/Makefile
--- docs/trunk/english_us/user_guide/plugins_screenies/Makefile 2008-09-24 11:13:56 UTC (rev 9401)
+++ docs/trunk/english_us/user_guide/plugins_screenies/Makefile 2008-09-24 12:03:21 UTC (rev 9402)
@@ -13,7 +13,10 @@
PNG=pluginmanager.eps\
plugininstaller.eps\
+ mapserver_export_qgs.eps\
+ mapserver_export_dialog.eps\
+ mapserver_export_test.eps\
##### TARGETS #####
all: $(PNG) $(JPG)
Added: docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_dialog.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_dialog.png
___________________________________________________________________
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_qgs.png
Property changes on: docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_qgs.png
Added: docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_test.png
Property changes on: docs/trunk/english_us/user_guide/plugins_screenies/mapserver_export_test.png
