[QGIS Commit] r9417 - in docs/trunk/english_us/user_guide: . print_composer_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Sep 28 14:21:36 EDT 2008
Author: dassau
Date: 2008-09-28 14:21:36 -0400 (Sun, 28 Sep 2008)
New Revision: 9417
Added:
   docs/trunk/english_us/user_guide/print_composer.tex
   docs/trunk/english_us/user_guide/print_composer_screenies/
Removed:
   docs/trunk/english_us/user_guide/map_composer.tex
   docs/trunk/english_us/user_guide/map_composer_screenies/
   docs/trunk/english_us/user_guide/Makefile
   docs/trunk/english_us/user_guide/print_composer_screenies/Makefile
   docs/trunk/english_us/user_guide/user_guide.tex
renamed map composer to print composer as in QGIS
updated print composer screenies
Modified: docs/trunk/english_us/user_guide/Makefile
--- docs/trunk/english_us/user_guide/Makefile	2008-09-28 12:35:28 UTC (rev 9416)
+++ docs/trunk/english_us/user_guide/Makefile	2008-09-28 18:21:36 UTC (rev 9417)
@@ -90,8 +90,7 @@
 #	(cd ./working_with_ogc_screenies && make)
 	(cd ./working_with_projections_screenies && make)
 	(cd ./grass_integration_screenies && make)
-#	(cd ./map_composer_screenies && make)
-#	(cd ./map_server_export_screenies && make)
+	(cd ./print_composer_screenies && make)
 #	(cd ./creating_applications_screenies && make)
 #	(cd ./help_and_support_screenies && make)
 	(cd ./operating_system_icons && make)
@@ -141,7 +140,7 @@
 	(cd ./working_with_ogc_screenies && make clean)
 	(cd ./working_with_projections_screenies && make clean)
 	(cd ./grass_integration_screenies && make clean)
-	(cd ./map_composer_screenies && make clean)
+	(cd ./print_composer_screenies && make clean)
 	(cd ./creating_applications_screenies && make clean)
 	(cd ./help_and_support_screenies && make clean)
 	(cd ./operating_system_icons && make clean)
Deleted: docs/trunk/english_us/user_guide/map_composer.tex
--- docs/trunk/english_us/user_guide/map_composer.tex	2008-09-28 12:35:28 UTC (rev 9416)
+++ docs/trunk/english_us/user_guide/map_composer.tex	2008-09-28 18:21:36 UTC (rev 9417)
@@ -1,191 +0,0 @@
-% vim:autoindent:set textwidth=78:
-\section{Map Composer}\label{label_mapcomposer}
-% when the revision of a section has been finalized,
-% comment out the following line:
-\updatedisclaimer
-The map composer provides growing layout and printing
-capabilities. It allows you to add elements such as the QGIS map canvas,
-legend, scalebar, images, and text labels. You can size, group
-and position each element and adjust the properties to create your layout.
-The result can be printed (also to Postscript and PDF), exported as an image,
-or exported to SVG.\footnote{Export to SVG is currently not supported,
-because this functionality is not working with recent QT4 versions.} See a
-list of all buttons below:
-\begin{table}[h]\index{Map composer!tools}
-\centering
-\caption{Map Composer Tools}\label{tab:mapcomposer_tools}\medskip
- \begin{tabular}{|l|p{6.9cm}|l|p{6.9cm}|}
- \hline \textbf{Icon} & \textbf{Purpose} & \textbf{Icon} &
- \textbf{Purpose} \\
- \hline \includegraphics[width=0.7cm]{mActionExportMapServer}
- & Export map composition to an image &
- \includegraphics[width=0.7cm]{mActionSaveAsSVG} & Export map composition
- to SVG \\
- \hline \includegraphics[width=0.7cm]{mActionFilePrint} & Print or
- export as PDF or Postscript &
- \includegraphics[width=0.7cm]{mActionZoomFullExtent} & Zoom to
- full extend \\
- \hline \includegraphics[width=0.7cm]{mActionZoomIn} & Zoom in &
- \includegraphics[width=0.7cm]{mActionZoomOut} & Zoom out \\
- \hline \includegraphics[width=0.7cm]{mActionDraw} & Refresh
- view &
- \includegraphics[width=0.7cm]{mActionAddRasterLayer} & Add
- new map from QGIS map canvas \\
- \hline \includegraphics[width=0.7cm]{mActionSaveMapAsImage} & Add Image to
- map composition &
- \includegraphics[width=0.7cm]{mActionLabel} & Add label to map composition \\
- \hline \includegraphics[width=0.7cm]{mActionAddLegend} & Add new legend to
- map composition &
- \includegraphics[width=0.7cm]{mActionScaleBar} & Add new scalebar to map
- composition\\
- \hline \includegraphics[width=0.7cm]{mActionSelectPan} & Select/Move item in
- map composition &
- \includegraphics[width=0.7cm]{mActionMoveItemContent} & Move content within
- an item \\
- \hline \includegraphics[width=0.7cm]{mActionGroupItems} & Group items of
- map composition &
- \includegraphics[width=0.7cm]{mActionUngroupItems} & Ungroup items of map
- composition \\
- \hline \includegraphics[width=0.7cm]{mActionRaiseItems} & Raise selected
- items in map composition &
- \includegraphics[width=0.7cm]{mActionLowerItems} & Lower selected items
- in map composition \\
- \hline \includegraphics[width=0.7cm]{mActionMoveItemsToTop} & Move selected
- items to top &
- \includegraphics[width=0.7cm]{mActionMoveItemsToBottom} & Move selected
- items to bottom \\
-\hline
-\end{tabular}
-\end{table}
-To access the map composer, click on the \toolbtntwo{mActionFilePrint}{Print}
-button in the toolbar or choose \mainmenuopt{File} > \dropmenuopttwo{mActionFilePrint}{Print}.
-\subsection{Using Map Composer}\label{label_usemapcomposer}
-ies
-To use the map composer, first add the layers you
-want to print to QGIS. The layers should be rendered and symbolized to your
-liking prior to composing the map.
-%\begin{figure}[ht]
-%   \begin{center}
-%   \caption{Map Composer}\label{fig:map_composer_blank}\smallskip
-%   \includegraphics[clip=true, width=14cm]{map_composer_blank09}
-%\end{center}
-%\end{figure}
-Opening the map composer provides you with a blank canvas to which you can add
-the current map view, legend, scalebar, and text. Figure
-\ref{fig:map_composer_blank} shows the initial view of the map composer before
-any elements are added.
-The map composer has two tabs: \tab{General} and \tab{Item}. The General tab
-allows you to set the paper size, orientation, and resolution for the map.
-The Item tab displays the properties for the currently selected map element.
-By selecting an element on the map (eg. legend, scalebar, text, etc.) and
-clicking on the \tab{Item} tab, you can customize the settings.
-You can add multiple elements to the composer. This allows you to have more
-than one map view and legend in the composer. Each element has its own
-properties and in the case of the map, its own extent.
-\subsubsection{Adding a Map to the Composer}
-To add the QGIS map canvas to the map composer, click on the
-%FIXME \toolbtntwo{composer_add_image}{Add a new map}
-button in toolbar. Drag a rectangle on the composer canvas to add the
-map. You can resize the map later by clicking on the \button{Select/move item}
-button, clicking on the map, and dragging one of the handles in the corner of
-the map. With the map selected, you can also resize the map by specifying the
-width and height on the Item properties tab.
-The map is linked to the QGIS map canvas. If you change the view on the map
-canvas by zooming or panning, you can update the map composer view by
-selecting the map in composer and clicking on the \button{Set Extent} button.
-You can also change the composer view by specifying a map scale. To set the
-view to a specific scale:
-\begin{enumerate}
-\item Choose \selectstring{Set}{Scale (calculate extent)}
-\item Enter the scale denominator in the scale box
-\item Press Enter
-\end{enumerate}
-\subsubsection{Adding other Elements to the Composer}
-Already existing QGIS templates can be used to easily load and adapt map
-layouts. To open an existing template, click on the
-%FIXME \toolbtntwo{composer_open_template}{Open Template}
-button. Choose a template and
-customize its appearance.
-To add a logo, north arrow or any  kind of image to the composer, click on
-the
-%FIXME \toolbtntwo{composer_add_image}{Add Image}
-button. The image will
-be placed on the composer canvas and you can move it where you like.
-A legend can be added to the composer canvas and customized to show only the
-desired layers. To add a legend, click on the
-%FIXME \toolbtntwo{composer_add_legend08}{Add Vector Legend}
-button. The legend will be
-placed on the composer canvas and you can move it where you like. Click on
-the \tab{Items} tab to customize the appearance of the legend, including
-which layers are shown.
-To add a scalebar to the composer, click on the
-%FIXME \toolbtntwo{composer_add_scalebar08}{Add Scalebar}
-button. Use the \tab{Item}
-tab to customize the segment size, number of segments, scalebar units, size,
-and font for the scalebar.
-You can add text labels to the composer by clicking on the
-%FIXME \toolbtntwo{composer_add_label}{Add New Label}
-button. Use the \tab{Item} tab
-while the text is selected to customize the settings or change the default text.
-Figure \ref{fig:map_composer_complete} shows the map composer after adding
-each type of map element.
-%\begin{figure}[h]
-%   \begin{center}
-%   \caption{Map Composer with map view, legend, scalebar, and text added}\label{fig:map_composer_complete}\smallskip
-%   \includegraphics[clip=true, width=14cm]{map_composer09}
-%\end{center}
-%\end{figure}
-\subsubsection{Other Features}
-The map composer has navigation tools to zoom in and out. To zoom in, click
-the \button{Zoom in} tool. The map composer canvas will be scaled by a factor to 2. Use
-the scrollbars to adjust the view to the area of interest. Zooming out works
-in a similar fashion.
-If you find the view in an inconsistent state, you can use the \button{Refresh} button
-to redraw the map composer canvas.
-\subsubsection{Creating Output}
-The map composer allows you to print the map to a printer, export to a PNG or
-export to SVG. Each of these functions is available from the composer toolbar.
-To save the composer canvas as a templates, click on the
-%\toolbtntwo{composer_save_template}{Save Template As}
-button. Browse to the directory
-you like and save a template to use it again for another map canvas.
-It is possible to export the result as an image by clicking on the
-%FIXME \toolbtntwo{composer_export_image}{Export as image}
-button.
-To export the composer canvas as an  SVG (Scalable Vector Graphic), click on
-the
-%FIXME \toolbtntwo{composer_export_svg}{Export as SVG}
-button. \textbf{Note:}
-Currently the SVG output is very basic. This is not a QGIS problem, but a
-problem of the underlaying Qt library. This will be sorted out in future versions.
Copied: docs/trunk/english_us/user_guide/print_composer.tex (from rev 9416, docs/trunk/english_us/user_guide/map_composer.tex)
--- docs/trunk/english_us/user_guide/print_composer.tex	                        (rev 0)
+++ docs/trunk/english_us/user_guide/print_composer.tex	2008-09-28 18:21:36 UTC (rev 9417)
@@ -0,0 +1,192 @@
+% vim:autoindent:set textwidth=78:
+\section{Print Composer}\label{label_printcomposer}
+% when the revision of a section has been finalized,
+% comment out the following line:
+\updatedisclaimer
+The print composer provides growing layout and printing
+capabilities. It allows you to add elements such as the QGIS map canvas,
+legend, scalebar, images, and text labels. You can size, group
+and position each element and adjust the properties to create your layout.
+The result can be printed (also to Postscript and PDF), exported as an image,
+or exported to SVG.\footnote{Export to SVG is currently not supported,
+because this functionality is not working with recent QT4 versions.} See a
+list of all buttons in table~\ref{tab:printcomposer_tools} below:
+\begin{table}[h]\index{Print composer!tools}
+\centering
+\caption{Print Composer Tools}\label{tab:printcomposer_tools}\medskip
+ \begin{tabular}{|l|p{6.9cm}|l|p{6.9cm}|}
+ \hline \textbf{Icon} & \textbf{Purpose} & \textbf{Icon} &
+ \textbf{Purpose} \\
+ \hline \includegraphics[width=0.7cm]{mActionExportMapServer}
+ & Export to an image format &
+ \includegraphics[width=0.7cm]{mActionSaveAsSVG} & Export print composition
+ to SVG \\
+ \hline \includegraphics[width=0.7cm]{mActionFilePrint} & Print or
+ export as PDF or Postscript &
+ \includegraphics[width=0.7cm]{mActionZoomFullExtent} & Zoom to
+ full extend \\
+ \hline \includegraphics[width=0.7cm]{mActionZoomIn} & Zoom in &
+ \includegraphics[width=0.7cm]{mActionZoomOut} & Zoom out \\
+ \hline \includegraphics[width=0.7cm]{mActionDraw} & Refresh
+ view &
+ \includegraphics[width=0.7cm]{mActionAddRasterLayer} & Add
+ new map from QGIS map canvas \\
+ \hline \includegraphics[width=0.7cm]{mActionSaveMapAsImage} & Add Image to
+ print composition &
+ \includegraphics[width=0.7cm]{mActionLabel} & Add label to print composition \\
+ \hline \includegraphics[width=0.7cm]{mActionAddLegend} & Add new legend to
+ \includegraphics[width=0.7cm]{mActionScaleBar} & Add new scalebar to print
+ composition\\
+ \hline \includegraphics[width=0.7cm]{mActionSelectPan} & Select/Move item in
+ \includegraphics[width=0.7cm]{mActionMoveItemContent} & Move content within
+ an item \\
+ \hline \includegraphics[width=0.7cm]{mActionGroupItems} & Group items of
+ \includegraphics[width=0.7cm]{mActionUngroupItems} & Ungroup items of print
+ composition \\
+ \hline \includegraphics[width=0.7cm]{mActionRaiseItems} & Raise selected
+ items in print composition &
+ \includegraphics[width=0.7cm]{mActionLowerItems} & Lower selected items
+ in print composition \\
+ \hline \includegraphics[width=0.7cm]{mActionMoveItemsToTop} & Move selected
+ items to top &
+ \includegraphics[width=0.7cm]{mActionMoveItemsToBottom} & Move selected
+ items to bottom \\
+\hline
+\end{tabular}
+\end{table}
+To access the print composer, click on the \toolbtntwo{mActionFilePrint}{Print}
+button in the toolbar or choose \mainmenuopt{File} > \dropmenuopttwo{mActionFilePrint}{Print}.
+\subsection{Using Print Composer}\label{label_useprintcomposer}
+To use the print composer, first add the layers you
+want to print to QGIS. The layers should be rendered and symbolized to your
+liking prior to composing the map (see example in Figure \ref{fig:print_composer_complete}).
+\begin{figure}[ht]
+   \begin{center}
+   \caption{Print Composer}\label{fig:print_composer_blank}\smallskip
+   \includegraphics[clip=true, width=\textwidth]{print_composer_blank}
+\end{center}
+\end{figure}
+Opening the print composer provides you with a blank canvas to which you can add
+the current map view, legend, scalebar, and text. Figure
+\ref{fig:print_composer_blank} shows the initial view of the print composer before
+any elements are added.
+The print composer has two tabs: \tab{General} and \tab{Item}. The General tab
+allows you to set the paper size, orientation, and resolution for the map.
+The Item tab displays the properties for the currently selected map element.
+By selecting an element on the map (eg. legend, scalebar, text, etc.) and
+clicking on the \tab{Item} tab, you can customize the settings.
+You can add multiple elements to the composer. This allows you to have more
+than one map view and legend in the composer. Each element has its own
+properties and in the case of the map, its own extent.
+\subsubsection{Adding a map layout to the Print Composer}
+To add the QGIS map canvas to the print composer, click on the
+%FIXME \toolbtntwo{composer_add_image}{Add a new map}
+button in toolbar. Drag a rectangle on the composer canvas to add the
+map. You can resize the map later by clicking on the \button{Select/move item}
+button, clicking on the map, and dragging one of the handles in the corner of
+the map. With the map selected, you can also resize the map by specifying the
+width and height on the Item properties tab.
+The map is linked to the QGIS map canvas. If you change the view on the map
+canvas by zooming or panning, you can update the print composer view by
+selecting the map in the print composer and clicking on the \button{Set Extent}
+button. You can also change the print composer view by specifying a map scale.
+To set the view to a specific scale:
+\begin{enumerate}
+\item Choose \selectstring{Set}{Scale (calculate extent)}
+\item Enter the scale denominator in the scale box
+\item Press Enter
+\end{enumerate}
+\subsubsection{Adding other Elements to the Print Composer}
+Already existing QGIS templates can be used to easily load and adapt print
+layouts. To open an existing template, click on the
+%FIXME \toolbtntwo{composer_open_template}{Open Template}
+button. Choose a template and
+customize its appearance.
+To add a logo, north arrow or any  kind of image to the composer, click on
+the
+%FIXME \toolbtntwo{composer_add_image}{Add Image}
+button. The image will
+be placed on the composer canvas and you can move it where you like.
+A legend can be added to the composer canvas and customized to show only the
+desired layers. To add a legend, click on the
+%FIXME \toolbtntwo{composer_add_legend08}{Add Vector Legend}
+button. The legend will be
+placed on the composer canvas and you can move it where you like. Click on
+the \tab{Items} tab to customize the appearance of the legend, including
+which layers are shown.
+To add a scalebar to the composer, click on the
+%FIXME \toolbtntwo{composer_add_scalebar08}{Add Scalebar}
+button. Use the \tab{Item}
+tab to customize the segment size, number of segments, scalebar units, size,
+and font for the scalebar.
+You can add text labels to the composer by clicking on the
+%FIXME \toolbtntwo{composer_add_label}{Add New Label}
+button. Use the \tab{Item} tab
+while the text is selected to customize the settings or change the default text.
+Figure \ref{fig:print_composer_complete} shows the print composer after adding
+each type of map element.
+\begin{figure}[h]
+   \begin{center}
+   \caption{Print Composer with map view, legend, scalebar, and text added}
+   \label{fig:print_composer_complete}\smallskip
+   \includegraphics[clip=true, width=\textwidth]{print_composer_complete}
+\end{center}
+\end{figure}
+\subsubsection{Other Features}
+The print composer has navigation tools to zoom in and out. To zoom in, click
+the \button{Zoom in} tool. The print composer canvas will be scaled by a factor to 2. Use
+the scrollbars to adjust the view to the area of interest. Zooming out works
+in a similar fashion.
+If you find the view in an inconsistent state, you can use the \button{Refresh} button
+to redraw the print composer canvas.
+\subsubsection{Creating Output}
+The print composer allows you to print the layout to a printer, export to a PNG or
+export to SVG. Each of these functions is available from the composer toolbar.
+To save the composer canvas as a templates, click on the
+%\toolbtntwo{composer_save_template}{Save Template As}
+button. Browse to the directory
+you like and save a template to use it again for another map canvas.
+It is possible to export the result as an image by clicking on the
+%FIXME \toolbtntwo{composer_export_image}{Export as image}
+button.
+To export the composer canvas as an  SVG (Scalable Vector Graphic), click on
+the
+%FIXME \toolbtntwo{composer_export_svg}{Export as SVG}
+button. \textbf{Note:}
+Currently the SVG output is very basic. This is not a QGIS problem, but a
+problem of the underlaying Qt library. This will be sorted out in future versions.
Property changes on: docs/trunk/english_us/user_guide/print_composer.tex
___________________________________________________________________
Copied: docs/trunk/english_us/user_guide/print_composer_screenies (from rev 9416, docs/trunk/english_us/user_guide/map_composer_screenies)
Property changes on: docs/trunk/english_us/user_guide/print_composer_screenies
Modified: docs/trunk/english_us/user_guide/print_composer_screenies/Makefile
--- docs/trunk/english_us/user_guide/map_composer_screenies/Makefile	2008-09-28 12:35:28 UTC (rev 9416)
+++ docs/trunk/english_us/user_guide/print_composer_screenies/Makefile	2008-09-28 18:21:36 UTC (rev 9417)
@@ -11,20 +11,9 @@
 # JPG=qgis_icon_new_verylarge.eps\
 #	nextfile.eps
-#PNG=map_composer_blank09.eps\
-#	map_composer09.eps\
-#	composer_add_legend08.eps\
-#	composer_add_map08.eps\
-#	composer_add_image.eps\
-#	composer_add_label.eps\
-#	composer_add_scalebar08.eps\
-#	composer_export_image.eps\
-#	composer_export_svg.eps\
-#	composer_open_template.eps\
-#	composer_save_template.eps\
-#	mActionFilePrint.eps\
+PNG=print_composer_blank.eps\
+	print_composer_complete.eps\
 ##### TARGETS #####
 all: $(PNG) $(JPG)
Modified: docs/trunk/english_us/user_guide/user_guide.tex
--- docs/trunk/english_us/user_guide/user_guide.tex	2008-09-28 12:35:28 UTC (rev 9416)
+++ docs/trunk/english_us/user_guide/user_guide.tex	2008-09-28 18:21:36 UTC (rev 9417)
@@ -19,7 +19,7 @@
 \include{working_with_ogc}
 \include{working_with_projections}
 \include{grass_integration}
-\include{map_composer}
+\include{print_composer}
 %first the general intro to plugins
 %then each individual plugin can have a section
 %in the plugins chapter
More information about the QGIS-commit mailing list
