[QGIS Commit] r10462 - branches/Version-1_0/ms-windows
svn_qgis at osgeo.org
Sat Apr 4 09:52:13 EDT 2009
Author: timlinux
Date: 2009-04-04 09:52:12 -0400 (Sat, 04 Apr 2009)
New Revision: 10462
Added:
branches/Version-1_0/ms-windows/plugins.nsh
branches/Version-1_0/ms-windows/python_plugins.nsh
branches/Version-1_0/ms-windows/ui.nsh
Added nsis scripts to set the registry keys up so that plugins are enabled by default and toolbars lay our nicely in the default install
Added: branches/Version-1_0/ms-windows/plugins.nsh
--- branches/Version-1_0/ms-windows/plugins.nsh (rev 0)
+++ branches/Version-1_0/ms-windows/plugins.nsh 2009-04-04 13:52:12 UTC (rev 10462)
@@ -0,0 +1,26 @@
+############################### reg2nsis begin #################################
+# This NSIS-script was generated by the Reg2Nsis utility #
+# Author : Artem Zankovich #
+# URL : http://aarrtteemm.nm.ru #
+# Usage : You can freely inserts this into your setup script as inline text #
+# or include file with the help of !include directive. #
+# Please don't remove this header. #
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "coordinatecaptureplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "copyrightlabelplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "delimitedtextplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "dxf2shpconverterplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "georefplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "gpsimporterplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "gridmakerplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "interpolationplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "northarrowplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "ogrconverterplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "quickprintplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "scalebarplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "spitplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "wfsplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "grassplugin" "true"
+############################### reg2nsis end #################################
Added: branches/Version-1_0/ms-windows/python_plugins.nsh
--- branches/Version-1_0/ms-windows/python_plugins.nsh (rev 0)
+++ branches/Version-1_0/ms-windows/python_plugins.nsh 2009-04-04 13:52:12 UTC (rev 10462)
@@ -0,0 +1,14 @@
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\PythonPlugins" "plugin_installer" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\PythonPlugins" "fTools" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\PythonPlugins" "mapserver_export" "true"
Added: branches/Version-1_0/ms-windows/ui.nsh
--- branches/Version-1_0/ms-windows/ui.nsh (rev 0)
+++ branches/Version-1_0/ms-windows/ui.nsh 2009-04-04 13:52:12 UTC (rev 10462)
@@ -0,0 +1,18 @@
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "state" 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
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "geometry" 400042007900740065004100720072006100790028000100d900d000cb000000010000000000ff00ff00ff00fc00ff00ff00ff00fc00000000000400b800000000000300220000000000000030000000000000004300000000000200af0000000000020022000000000000000000020000002900
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastVectorFileFilter" "[OGR] ESRI Shapefiles (*.shp *.SHP)"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastVectorFileFilterDir" "C:/Program Files/Quantum GIS/gisdata/ecape"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "encoding" "System"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastRasterFileFilter" "GeoTIFF (*.tif *.TIF)"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastRasterFileFilterDir" "C:/Program Files/Quantum GIS/gisdata/ecape"
