[QGIS Commit] r10474 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Sun Apr 5 06:51:36 EDT 2009
Author: jef
Date: 2009-04-05 06:51:35 -0400 (Sun, 05 Apr 2009)
New Revision: 10474
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
use ctid as temporary feature id in postgres provider if there is no other primary key available
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-04-05 10:46:08 UTC (rev 10473)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-04-05 10:51:35 UTC (rev 10474)
@@ -450,10 +450,40 @@
try
- int oid = *( int * )PQgetvalue( queryResult, row, 0 );
- if ( swapEndian )
- oid = ntohl( oid ); // convert oid to opposite endian
+ int oid;
+ if ( primaryKeyType != "tid" )
+ oid = *( int * )PQgetvalue( queryResult, row, 0 );
+ if ( swapEndian )
+ oid = ntohl( oid ); // convert oid to opposite endian
+ else if ( PQgetlength( queryResult, row, 0 ) == 6 )
+ char *data = PQgetvalue( queryResult, row, 0 );
+ int block = *( int * )data;
+ int offset = *( short * )( data + sizeof( int ) );
+ if ( swapEndian )
+ block = ntohl( block );
+ offset = ntohs( offset );
+ if ( block > 0xffff )
+ qWarning( "block number %x exceed 16 bit", block );
+ return false;
+ oid = ( block << 16 ) + offset;
+ else
+ qWarning( "expecting 6 bytes for tid (found %d bytes)", PQgetlength( queryResult, row, 0 ) );
+ return false;
feature.setFeatureId( oid );
int col; // first attribute column after geometry
@@ -627,10 +657,23 @@
return true;
+QString QgsPostgresProvider::whereClause( int featureId ) const
+ return QString( "%1=%2" ).arg( quotedIdentifier( primaryKey ) ).arg( featureId );
+ else
+ return QString( "%1='(%2,%3)'" ).arg( quotedIdentifier( primaryKey ) ).arg( featureId >> 16 ).arg( featureId & 0xffff );
bool QgsPostgresProvider::featureAtId( int featureId, QgsFeature& feature, bool fetchGeometry, QgsAttributeList fetchAttributes )
QString cursorName = QString( "qgisfid%1" ).arg( providerId );
- if ( !declareCursor( cursorName, fetchAttributes, fetchGeometry, QString( "%2=%3" ).arg( quotedIdentifier( primaryKey ) ).arg( featureId ) ) )
+ if ( !declareCursor( cursorName, fetchAttributes, fetchGeometry, whereClause( featureId ) ) )
return false;
Result queryResult = connectionRO->PQexec( QString( "fetch forward 1 from %1" ).arg( cursorName ) );
@@ -640,7 +683,7 @@
int rows = PQntuples( queryResult );
if ( rows == 0 )
- QgsDebugMsg( "feature " + QString::number( featureId ) + " not found" );
+ QgsDebugMsg( QString( "feature %1 not found" ).arg( featureId ) );
connectionRO->closeCursor( cursorName );
return false;
@@ -917,11 +960,39 @@
else
+ sql = QString( "SELECT attname FROM pg_attribute WHERE attname='ctid' AND attrelid=regclass(%1)" )
+ .arg( quotedValue( mSchemaTableName ) );
+ Result ctidCheck = connectionRO->PQexec( sql );
+ if ( PQntuples( ctidCheck ) == 1 )
+ sql = QString( "SELECT max(substring(ctid::text from E'\\\\((\\\\d+),\\\\d+\\\\)')::integer) from %1" )
+ .arg( mSchemaTableName );
+ int id = QString( PQgetvalue( ctidCheck, 0, 0 ) ).toInt();
+ if ( id < 0x10000 )
+ // fallback to ctid
+ primaryKey = "ctid";
+ primaryKeyType = "tid";
+ if ( primaryKey.isEmpty() )
showMessageBox( tr( "No suitable key column in table" ),
tr( "The table has no column suitable for use as a key.\n\n"
"Qgis requires that the table either has a column of type\n"
"int4 with a unique constraint on it (which includes the\n"
- "primary key) or has a PostgreSQL oid column.\n" ) );
+ "primary key), has a PostgreSQL oid column or has a ctid\n"
+ "column with a 16bit block number.\n" ) );
else if ( type == "v" ) // the relation is a view
@@ -1739,14 +1810,25 @@
connectionRW->PQexecNR( "BEGIN" );
// Prepare the INSERT statement
- QString insert = QString( "INSERT INTO %1(%2,%3" )
+ QString insert = QString( "INSERT INTO %1(%2" )
- .arg( quotedIdentifier( geometryColumn ) )
- .arg( quotedIdentifier( primaryKey ) ),
- values = QString( ") VALUES (GeomFromWKB($1%1,%2),$2" )
+ .arg( quotedIdentifier( geometryColumn ) ),
+ values = QString( ") VALUES (GeomFromWKB($1%1,%2)" )
.arg( connectionRW->useWkbHex() ? "" : "::bytea" )
.arg( srid );
+ int offset;
+ insert += "," + quotedIdentifier( primaryKey );
+ values += ",$2";
+ offset = 3;
+ else
+ offset = 2;
const QgsAttributeMap &attributevec = flist[0].attributeMap();
QStringList defaultValues;
@@ -1811,11 +1893,11 @@
// value is not unique => add parameter
if ( fit->typeName() == "geometry" )
- values += QString( ",geomfromewkt($%1)" ).arg( defaultValues.size() + 3 );
+ values += QString( ",geomfromewkt($%1)" ).arg( defaultValues.size() + offset );
else
- values += QString( ",$%1" ).arg( defaultValues.size() + 3 );
+ values += QString( ",$%1" ).arg( defaultValues.size() + offset );
defaultValues.append( defVal );
fieldId.append( it.key() );
@@ -1825,7 +1907,7 @@
insert += values + ")";
QgsDebugMsg( QString( "prepare addfeatures: %1" ).arg( insert ) );
- PGresult *stmt = connectionRW->PQprepare( "addfeatures", insert, fieldId.size() + 2, NULL );
+ PGresult *stmt = connectionRW->PQprepare( "addfeatures", insert, fieldId.size() + offset - 1, NULL );
if ( stmt == 0 || PQresultStatus( stmt ) == PGRES_FATAL_ERROR )
throw PGException( stmt );
PQclear( stmt );
@@ -1846,18 +1928,21 @@
QStringList params;
params << geomParam;
- if ( keyDefault.isNull() )
- ++primaryKeyHighWater;
- params << QString::number( primaryKeyHighWater );
- newIds << primaryKeyHighWater;
+ if ( keyDefault.isNull() )
+ ++primaryKeyHighWater;
+ params << QString::number( primaryKeyHighWater );
+ newIds << primaryKeyHighWater;
+ else
+ QByteArray key = paramValue( keyDefault, keyDefault );
+ params << key;
+ newIds << key.toInt();
- else
- QByteArray key = paramValue( keyDefault, keyDefault );
- params << key;
- newIds << key.toInt();
for ( int i = 0; i < fieldId.size(); i++ )
params << paramValue( attributevec[ fieldId[i] ].toString(), defaultValues[i] );
@@ -1868,8 +1953,9 @@
PQclear( result );
- for ( int i = 0; i < flist.size(); i++ )
- flist[i].setFeatureId( newIds[i] );
+ if ( flist.size() == newIds.size() )
+ for ( int i = 0; i < flist.size(); i++ )
+ flist[i].setFeatureId( newIds[i] );
connectionRW->PQexecNR( "DEALLOCATE addfeatures" );
connectionRW->PQexecNR( "COMMIT" );
@@ -1901,10 +1987,8 @@
for ( QgsFeatureIds::const_iterator it = id.begin();it != id.end();++it )
- QString sql = QString( "DELETE FROM %1 WHERE %2=%3" )
- .arg( mSchemaTableName )
- .arg( *it );
+ QString sql = QString( "DELETE FROM %1 WHERE %2" )
+ .arg( mSchemaTableName ).arg( whereClause( *it ) );
QgsDebugMsg( "delete sql: " + sql );
//send DELETE statement and do error handling
@@ -2059,9 +2143,7 @@
- sql += QString( " WHERE %1=%2" )
- .arg( fid );
+ sql += QString( " WHERE %1" ).arg( whereClause( fid ) );
PGresult *result = connectionRW->PQexec( sql );
if ( result == 0 || PQresultStatus( result ) == PGRES_FATAL_ERROR )
@@ -2137,7 +2219,14 @@
QStringList params;
- params << QString( "%1" ).arg( iter.key() );
+ params << QString( "%1" ).arg( iter.key() );
+ else
+ params << QString( "(%1,%2)" ).arg( iter.key() >> 16 ).arg( iter.key() & 0xffff );
PGresult *result = connectionRW->PQexecPrepared( "updatefeatures", params );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2009-04-05 10:46:08 UTC (rev 10473)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2009-04-05 10:51:35 UTC (rev 10474)
@@ -322,6 +322,8 @@
QgsFeature &feature,
const QgsAttributeList &fetchAttributes );
+ QString whereClause( int featureId ) const;
const QgsField &field( int index ) const;
/** Double quote a PostgreSQL identifier for placement in a SQL string.
