[QGIS Commit] r10478 - in trunk/qgis: python/core src/app src/core src/gui src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Apr 5 12:46:13 EDT 2009
Author: wonder
Date: 2009-04-05 12:46:13 -0400 (Sun, 05 Apr 2009)
New Revision: 10478
Added:
   trunk/qgis/python/core/qgstolerance.sip
   trunk/qgis/src/core/qgstolerance.cpp
   trunk/qgis/src/core/qgstolerance.h
   trunk/qgis/python/core/core.sip
   trunk/qgis/python/core/qgssnapper.sip
   trunk/qgis/src/app/qgsmaptoolmovefeature.cpp
   trunk/qgis/src/app/qgsoptions.cpp
   trunk/qgis/src/app/qgsprojectproperties.cpp
   trunk/qgis/src/app/qgssnappingdialog.cpp
   trunk/qgis/src/app/qgssnappingdialog.h
   trunk/qgis/src/core/CMakeLists.txt
   trunk/qgis/src/core/qgssnapper.cpp
   trunk/qgis/src/core/qgssnapper.h
   trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
   trunk/qgis/src/ui/qgsoptionsbase.ui
   trunk/qgis/src/ui/qgssnappingdialogbase.ui
Added possibility to express tolerances for digitising also in pixels in addition to map units. Patch contributed by Richard Kostecky.
Modified: trunk/qgis/python/core/core.sip
--- trunk/qgis/python/core/core.sip	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/python/core/core.sip	2009-04-05 16:46:13 UTC (rev 10478)
@@ -64,6 +64,7 @@
 %Include qgscoordinatereferencesystem.sip
 %Include qgssymbol.sip
 %Include qgssymbologyutils.sip
+%Include qgstolerance.sip
 %Include qgsuniquevaluerenderer.sip
 %Include qgsvectordataprovider.sip
 %Include qgsvectorfilewriter.sip
Modified: trunk/qgis/python/core/qgssnapper.sip
--- trunk/qgis/python/core/qgssnapper.sip	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/python/core/qgssnapper.sip	2009-04-05 16:46:13 UTC (rev 10478)
@@ -65,6 +65,8 @@
       double mTolerance;
       /**What snapping type to use (snap to segment or to vertex)*/
       QgsSnapper::SnappingType mSnapTo;
+      /**What unit is used for tolerance*/
+      QgsTolerance::UnitType mUnitType;
   QgsSnapper(QgsMapRenderer* mapRender);
Added: trunk/qgis/python/core/qgstolerance.sip
--- trunk/qgis/python/core/qgstolerance.sip	                        (rev 0)
+++ trunk/qgis/python/core/qgstolerance.sip	2009-04-05 16:46:13 UTC (rev 10478)
@@ -0,0 +1,42 @@
+class QgsTolerance
+%TypeHeaderCode
+#include <qgstolerance.h>
+%End
+public:
+    /**Type of unit of tolerance value from settings*/
+    enum UnitType
+      /**Map unit value*/
+      MapUnits,
+      /**Pixels unit of tolerance*/
+      Pixels
+    * Static function to get vertex tolerance value from settings
+    * @param mapUnitsPerPixel number of map units per pixel
+    * @return value of vertex tolerance in map units
+    static double vertexSearchRadius( double mapUnitsPerPixel );
+    * Static function to get default tolerance value from settings
+    * @return value of default tolerance in map units
+    static double defaultTolerance( double mapUnitsPerPixel );
+    * Static function to translate tolerance value into current map unit value
+    * @param tolerace tolerance value to be translated
+    * @param units type of units to be translated
+    * @return value of tolerance in map units
+    static double toleranceInMapUnits(double tolerance, double mapUnitsPerPixel, UnitType units = MapUnits);
Modified: trunk/qgis/src/app/qgsmaptoolmovefeature.cpp
--- trunk/qgis/src/app/qgsmaptoolmovefeature.cpp	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/app/qgsmaptoolmovefeature.cpp	2009-04-05 16:46:13 UTC (rev 10478)
@@ -21,6 +21,7 @@
 #include "qgsrubberband.h"
 #include "qgsvectordataprovider.h"
 #include "qgsvectorlayer.h"
+#include "qgstolerance.h"
 #include <QMessageBox>
 #include <QMouseEvent>
 #include <QSettings>
@@ -71,7 +72,7 @@
   //find first geometry under mouse cursor and store iterator to it
   QgsPoint layerCoords = toLayerCoordinates(( QgsMapLayer* )vlayer, e->pos() );
   QSettings settings;
-  double searchRadius = settings.value( "/qgis/digitizing/search_radius_vertex_edit", 10 ).toDouble();
+  double searchRadius = QgsTolerance::vertexSearchRadius( mCanvas->mapUnitsPerPixel() );
   QgsRectangle selectRect( layerCoords.x() - searchRadius, layerCoords.y() - searchRadius,
                            layerCoords.x() + searchRadius, layerCoords.y() + searchRadius );
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/app/qgsoptions.cpp	2009-04-05 16:46:13 UTC (rev 10478)
@@ -22,6 +22,7 @@
 #include "qgisapp.h"
 #include "qgsgenericprojectionselector.h"
 #include "qgscoordinatereferencesystem.h"
 #include <QFileDialog>
@@ -196,6 +197,25 @@
   mDefaultSnapModeComboBox->setCurrentIndex( mDefaultSnapModeComboBox->findData( defaultSnapString ) );
   mDefaultSnappingToleranceSpinBox->setValue( settings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble() );
   mSearchRadiusVertexEditSpinBox->setValue( settings.value( "/qgis/digitizing/search_radius_vertex_edit", 10 ).toDouble() );
+  int index;
+  if (settings.value( "/qgis/digitizing/default_snapping_tolerance_unit", 0 ).toInt() == QgsTolerance::MapUnits)
+    index = mDefaultSnappingToleranceComboBox->findText( tr( "map units" ) );
+  else
+    index = mDefaultSnappingToleranceComboBox->findText( tr( "pixels" ) );
+  mDefaultSnappingToleranceComboBox->setCurrentIndex( index );
+  if (settings.value( "/qgis/digitizing/search_radius_vertex_edit_unit", 0 ).toInt() == QgsTolerance::MapUnits)
+    index = mSearchRadiusVertexEditComboBox->findText( tr( "map units" ) );
+  else
+    index = mSearchRadiusVertexEditComboBox->findText( tr( "pixels" ) );
+  mSearchRadiusVertexEditComboBox->setCurrentIndex( settings.value( "/qgis/digitizing/search_radius_vertex_edit_unit", 0 ).toInt() );
   //vertex marker
   mMarkerStyleComboBox->addItem( tr( "Semi transparent circle" ) );
@@ -374,7 +394,12 @@
   settings.setValue( "/qgis/digitizing/default_snap_mode", defaultSnapModeString );
   settings.setValue( "/qgis/digitizing/default_snapping_tolerance", mDefaultSnappingToleranceSpinBox->value() );
   settings.setValue( "/qgis/digitizing/search_radius_vertex_edit", mSearchRadiusVertexEditSpinBox->value() );
+  settings.setValue( "/qgis/digitizing/default_snapping_tolerance_unit",
+                        (mDefaultSnappingToleranceComboBox->currentIndex() == 0 ? QgsTolerance::MapUnits : QgsTolerance::Pixels ) );
+  settings.setValue( "/qgis/digitizing/search_radius_vertex_edit_unit",
+                        (mSearchRadiusVertexEditComboBox->currentIndex()  == 0 ? QgsTolerance::MapUnits : QgsTolerance::Pixels ) );
   QString markerComboText = mMarkerStyleComboBox->currentText();
   if ( markerComboText == tr( "Semi transparent circle" ) )
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp	2009-04-05 16:46:13 UTC (rev 10478)
@@ -122,11 +122,13 @@
   QStringList layerIdList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingList", &ok );
   QStringList enabledList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingEnabledList", &ok );
   QStringList toleranceList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceList", &ok );
+  QStringList toleranceUnitList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceUnitList", &ok );
   QStringList snapToList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnapToList", &ok );
   QStringList::const_iterator idIter = layerIdList.constBegin();
   QStringList::const_iterator enabledIter = enabledList.constBegin();
   QStringList::const_iterator tolIter = toleranceList.constBegin();
+  QStringList::const_iterator tolUnitIter = toleranceUnitList.constBegin();
   QStringList::const_iterator snapToIter = snapToList.constBegin();
   QgsMapLayer* currentLayer = 0;
@@ -160,6 +162,7 @@
         newEntry.snapTo = 2;
       newEntry.tolerance = tolIter->toDouble();
+      newEntry.toleranceUnit = tolUnitIter->toInt();
       mSnappingLayerSettings.insert( *idIter, newEntry );
@@ -306,11 +309,13 @@
   QStringList snapToList;
   QStringList toleranceList;
   QStringList enabledList;
+  QStringList toleranceUnitList;
   for ( layerEntryIt = mSnappingLayerSettings.constBegin(); layerEntryIt != mSnappingLayerSettings.constEnd(); ++layerEntryIt )
     layerIdList << layerEntryIt.key();
     toleranceList << QString::number( layerEntryIt->tolerance, 'f' );
+    toleranceUnitList << QString::number( (int)layerEntryIt->toleranceUnit );
     if ( layerEntryIt->checked )
       enabledList << "enabled";
@@ -338,6 +343,7 @@
     QgsProject::instance()->writeEntry( "Digitizing", "/LayerSnappingList", layerIdList );
     QgsProject::instance()->writeEntry( "Digitizing", "/LayerSnapToList", snapToList );
     QgsProject::instance()->writeEntry( "Digitizing", "/LayerSnappingToleranceList", toleranceList );
+    QgsProject::instance()->writeEntry( "Digitizing", "/LayerSnappingToleranceUnitList", toleranceUnitList );
     QgsProject::instance()->writeEntry( "Digitizing", "/LayerSnappingEnabledList", enabledList );
Modified: trunk/qgis/src/app/qgssnappingdialog.cpp
--- trunk/qgis/src/app/qgssnappingdialog.cpp	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/app/qgssnappingdialog.cpp	2009-04-05 16:46:13 UTC (rev 10478)
@@ -71,6 +71,12 @@
           snappingToleranceEdit->setValidator( validator );
           mLayerTreeWidget->setItemWidget( newItem, 2, snappingToleranceEdit );
+          //snap to vertex/ snap to segment
+          QComboBox* toleranceUnitsComboBox = new QComboBox( mLayerTreeWidget );
+          toleranceUnitsComboBox->insertItem( 0, tr( "map units" ) );
+          toleranceUnitsComboBox->insertItem( 1, tr( "pixels" ) );
+          mLayerTreeWidget->setItemWidget( newItem, 3, toleranceUnitsComboBox );
           settingIt = settings.find( currentVectorLayer->getLayerID() );
           if ( settingIt != settings.constEnd() )
@@ -89,6 +95,15 @@
               index = snapToComboBox->findText( tr( "to vertex and segment" ) );
             snapToComboBox->setCurrentIndex( index );
+	    if ( settingIt.value().toleranceUnit == 0 )//map units
+              index = toleranceUnitsComboBox->findText( tr( "map units" ) );
+            else
+              index = toleranceUnitsComboBox->findText( tr( "pixels" ) );
+            toleranceUnitsComboBox->setCurrentIndex( index );
             if ( settingIt.value().checked )
               newItem->setCheckState( 0, Qt::Checked );
@@ -103,8 +118,9 @@
     mLayerTreeWidget->resizeColumnToContents( 0 );
-    mLayerTreeWidget->setColumnWidth( 1, 300 );  //hardcoded for now
+    mLayerTreeWidget->setColumnWidth( 1, 200 );  //hardcoded for now
     mLayerTreeWidget->resizeColumnToContents( 2 );
+    mLayerTreeWidget->resizeColumnToContents( 3 );
@@ -127,7 +143,9 @@
   QString layerId;
   QString layerName;
   QString snapToItemText;
+  QString toleranceItemText;
   int snapTo;
+  int toleranceUnit;
   double tolerance;
   bool checked = false;
@@ -144,6 +162,7 @@
     layerId = mLayerIds.at( i );
     checked = ( currentItem->checkState( 0 ) == Qt::Checked );
     snapToItemText = (( QComboBox* )( mLayerTreeWidget->itemWidget( currentItem, 1 ) ) )->currentText();
+    toleranceItemText = (( QComboBox* )( mLayerTreeWidget->itemWidget( currentItem, 3 ) ) )->currentText();
     if ( snapToItemText == tr( "to vertex" ) )
       snapTo = 0;
@@ -156,10 +175,18 @@
       snapTo = 2;
+    if ( toleranceItemText == tr( "map units" ) )
+      toleranceUnit = 0;
+    else //to vertex and segment
+      toleranceUnit = 1;
     tolerance = (( QLineEdit* )( mLayerTreeWidget->itemWidget( currentItem, 2 ) ) )->text().toDouble();
     LayerEntry newEntry;
     newEntry.checked = checked; newEntry.snapTo = snapTo; newEntry.layerName = layerName;
-    newEntry.tolerance = tolerance;
+    newEntry.tolerance = tolerance; newEntry.toleranceUnit = toleranceUnit;
     settings.insert( layerId, newEntry );
Modified: trunk/qgis/src/app/qgssnappingdialog.h
--- trunk/qgis/src/app/qgssnappingdialog.h	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/app/qgssnappingdialog.h	2009-04-05 16:46:13 UTC (rev 10478)
@@ -28,6 +28,7 @@
   int snapTo; //0 = to vertex, 1 = to segment, 2 = to vertex and to segment
   QString layerName;
   double tolerance;
 /**A dialog to enter advanced editing properties, e.g. topological editing, snapping settings
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/core/CMakeLists.txt	2009-04-05 16:46:13 UTC (rev 10478)
@@ -43,6 +43,7 @@
   qgssearchtreenode.cpp
   qgssnapper.cpp
   qgscoordinatereferencesystem.cpp
+  qgstolerance.cpp
   qgsvectordataprovider.cpp
   qgsvectorfilewriter.cpp
   qgsvectorlayer.cpp
Modified: trunk/qgis/src/core/qgssnapper.cpp
--- trunk/qgis/src/core/qgssnapper.cpp	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/core/qgssnapper.cpp	2009-04-05 16:46:13 UTC (rev 10478)
@@ -56,7 +56,9 @@
     //transform point from map coordinates to layer coordinates
     layerCoordPoint = mMapRenderer->mapToLayerCoordinates( snapLayerIt->mLayer, mapCoordPoint );
-    if ( snapLayerIt->mLayer->snapWithContext( layerCoordPoint, snapLayerIt->mTolerance,
+    double tolerance = QgsTolerance::toleranceInMapUnits( snapLayerIt->mTolerance, mMapRenderer->mapUnitsPerPixel(), snapLayerIt->mUnitType );
+    if ( snapLayerIt->mLayer->snapWithContext( layerCoordPoint, tolerance,
          currentResultList, snapLayerIt->mSnapTo ) != 0 )
       //error
Modified: trunk/qgis/src/core/qgssnapper.h
--- trunk/qgis/src/core/qgssnapper.h	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/core/qgssnapper.h	2009-04-05 16:46:13 UTC (rev 10478)
@@ -19,6 +19,7 @@
 #define QGSSNAPPER_H
 #include "qgspoint.h"
 #include <QList>
 #include <QMultiMap>
@@ -86,6 +87,8 @@
       double mTolerance;
     QgsSnapper( QgsMapRenderer* mapRender );
Added: trunk/qgis/src/core/qgstolerance.cpp
--- trunk/qgis/src/core/qgstolerance.cpp	                        (rev 0)
+++ trunk/qgis/src/core/qgstolerance.cpp	2009-04-05 16:46:13 UTC (rev 10478)
@@ -0,0 +1,43 @@
+    qgstolerance.cpp  -  wrapper for tolerance handling
+    begin                : March 2009
+    copyright            : (C) 2009 by Richard Kostecky
+    email                : csf.kostej at gmail dot com
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+#include <QSettings>
+double QgsTolerance::toleranceInMapUnits(double tolerance, double mapUnitsPerPixel, UnitType units)
+  if (units == MapUnits)
+    return tolerance;
+  return tolerance * mapUnitsPerPixel;
+double QgsTolerance::vertexSearchRadius( double mapUnitsPerPixel )
+  QSettings settings;
+  double tolerance = settings.value( "/qgis/digitizing/search_radius_vertex_edit", 10 ).toDouble();
+  UnitType units = (QgsTolerance::UnitType) settings.value( "/qgis/digitizing/search_radius_vertex_edit_unit", 0 ).toInt();
+  return toleranceInMapUnits(tolerance, mapUnitsPerPixel, units);
+double QgsTolerance::defaultTolerance( double mapUnitsPerPixel )
+  double tolerance = settings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
+  UnitType units = (QgsTolerance::UnitType) settings.value( "/qgis/digitizing/default_snapping_tolerance_unit", 0 ).toInt();
Added: trunk/qgis/src/core/qgstolerance.h
--- trunk/qgis/src/core/qgstolerance.h	                        (rev 0)
+++ trunk/qgis/src/core/qgstolerance.h	2009-04-05 16:46:13 UTC (rev 10478)
@@ -0,0 +1,63 @@
+    qgstolerance.h  -  wrapper for tolerance handling
+#ifndef QGSTOLERANCE_H
+#define QGSTOLERANCE_H
+/** \ingroup core
+ * This is the class is providing tolerance value in map unit values.
+ * \note This class has been added in version 1.1.
+class CORE_EXPORT QgsTolerance
+  public:
+    enum UnitType
+      MapUnits,
+      Pixels
+#endif
Modified: trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
--- trunk/qgis/src/gui/qgsmapcanvassnapper.cpp	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/gui/qgsmapcanvassnapper.cpp	2009-04-05 16:46:13 UTC (rev 10478)
@@ -21,8 +21,10 @@
 #include "qgsmaptopixel.h"
 #include "qgsproject.h"
 QgsMapCanvasSnapper::QgsMapCanvasSnapper( QgsMapCanvas* canvas ): mMapCanvas( canvas ), mSnapper( 0 )
   if ( canvas )
@@ -92,13 +94,14 @@
     QgsSnapper::SnapLayer snapLayer;
     snapLayer.mLayer = vlayer;
     snapLayer.mSnapTo = snap_to;
+    snapLayer.mUnitType = QgsTolerance::MapUnits;
     QSettings settings;
     if ( snappingTol < 0 )
       //use search tolerance for vertex editing
-      snapLayer.mTolerance = settings.value( "/qgis/digitizing/search_radius_vertex_edit", 50 ).toDouble();
+      snapLayer.mTolerance = QgsTolerance::vertexSearchRadius(mMapCanvas->mapUnitsPerPixel());
     else
@@ -149,9 +152,10 @@
-    if ( !( layerIdList.size() == enabledList.size() && layerIdList.size() == toleranceList.size() && layerIdList.size() == snapToList.size() ) )
+    if ( !( layerIdList.size() == enabledList.size() && layerIdList.size() == toleranceList.size() && layerIdList.size() == toleranceUnitList.size() && layerIdList.size() == snapToList.size() ) )
       return 1; //lists must have the same size, otherwise something is wrong
@@ -168,10 +172,11 @@
       QStringList::const_iterator layerIt = layerIdList.constBegin();
       QStringList::const_iterator tolIt = toleranceList.constBegin();
+      QStringList::const_iterator tolUnitIt = toleranceUnitList.constBegin();
       QStringList::const_iterator snapIt = snapToList.constBegin();
       QStringList::const_iterator enabledIt = enabledList.constBegin();
-      for ( ; layerIt != layerIdList.constEnd(); ++layerIt, ++tolIt, ++snapIt, ++enabledIt )
+      for ( ; layerIt != layerIdList.constEnd(); ++layerIt, ++tolIt, ++tolUnitIt, ++snapIt, ++enabledIt )
         if (( *enabledIt ) != "enabled" ) //skip layer if snapping is not enabled
@@ -191,6 +196,7 @@
         //tolerance
         snapLayer.mTolerance = tolIt->toDouble();
+        snapLayer.mUnitType = (QgsTolerance::UnitType) tolUnitIt->toInt();
         //segment or vertex
         if (( *snapIt ) == "to_vertex" )
@@ -241,8 +247,9 @@
         snapLayer.mSnapTo = QgsSnapper::SnapToVertex;
-      //default snapping tolerance
-      snapLayer.mTolerance = settings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
+      //default snapping tolerance (returned in map units)
+      snapLayer.mTolerance = QgsTolerance::defaultTolerance(mMapCanvas->mapUnitsPerPixel());
       snapLayers.append( snapLayer );
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui	2009-04-05 16:46:13 UTC (rev 10478)
@@ -659,7 +659,7 @@
             </property>
            </spacer>
           </item>
-          <item row="0" column="4" >
+          <item row="0" column="4" colspan="2" >
            <widget class="QComboBox" name="mDefaultSnapModeComboBox" >
             <property name="sizePolicy" >
              <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
@@ -729,6 +729,40 @@
             </property>
            </widget>
           </item>
+          <item row="1" column="5" >
+           <widget class="QComboBox" name="mDefaultSnappingToleranceComboBox" >
+            <property name="sizePolicy" >
+             <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+              <horstretch>0</horstretch>
+              <verstretch>0</verstretch>
+             </sizepolicy>
+            </property>
+            <item>
+             <property name="text" >
+              <string>map units</string>
+             </property>
+            </item>
+            <item>
+              <string>pixels</string>
+             </property>
+            </item>
+           </widget>
+          </item>
+          <item row="2" column="5" >
+           <widget class="QComboBox" name="mSearchRadiusVertexEditComboBox" >
+            <item>
+             </property>
+            </item>
+            <item>
+             </property>
+            </item>
+           </widget>
+          </item>
          </layout>
         </widget>
        </item>
Modified: trunk/qgis/src/ui/qgssnappingdialogbase.ui
--- trunk/qgis/src/ui/qgssnappingdialogbase.ui	2009-04-05 15:50:24 UTC (rev 10477)
+++ trunk/qgis/src/ui/qgssnappingdialogbase.ui	2009-04-05 16:46:13 UTC (rev 10478)
@@ -13,12 +13,24 @@
    <string>Snapping options</string>
   </property>
   <layout class="QGridLayout" >
-   <property name="margin" >
+   <property name="leftMargin" >
     <number>9</number>
    </property>
-   <property name="spacing" >
+   <property name="topMargin" >
+    <number>9</number>
+   </property>
+   <property name="rightMargin" >
+   </property>
+   <property name="bottomMargin" >
+   </property>
+   <property name="horizontalSpacing" >
     <number>6</number>
    </property>
+   <property name="verticalSpacing" >
+    <number>6</number>
+   </property>
    <item row="0" column="0" >
     <widget class="QTreeWidget" name="mLayerTreeWidget" >
      <column>
@@ -36,6 +48,11 @@
        <string>Tolerance</string>
       </property>
      </column>
+     <column>
+       <string>Units</string>
+      </property>
+     </column>
     </widget>
    </item>
    <item row="1" column="0" >
More information about the QGIS-commit mailing list
