[QGIS Commit] r10485 - in trunk/qgis/src: core core/pal plugins/diagram_overlay
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 6 08:52:57 EDT 2009
Author: jef
Date: 2009-04-06 08:52:56 -0400 (Mon, 06 Apr 2009)
New Revision: 10485
   trunk/qgis/src/core/pal/geomfunction.cpp
   trunk/qgis/src/core/pal/layer.h
   trunk/qgis/src/core/pal/pal.h
   trunk/qgis/src/core/pal/problem.cpp
   trunk/qgis/src/core/pal/util.cpp
   trunk/qgis/src/core/pal/util.h
   trunk/qgis/src/core/qgscentralpointpositionmanager.cpp
   trunk/qgis/src/core/qgsoverlayobject.cpp
   trunk/qgis/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp
   trunk/qgis/src/plugins/diagram_overlay/qgsdiagramrenderer.h
fix msvc build errors
Modified: trunk/qgis/src/core/pal/geomfunction.cpp
--- trunk/qgis/src/core/pal/geomfunction.cpp	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/pal/geomfunction.cpp	2009-04-06 12:52:56 UTC (rev 10485)
@@ -274,7 +274,7 @@
     bool computeLineSegIntersection (double x1, double y1, double x2, double y2,  // 1st line
                                  double x3, double y3, double x4, double y4,  // 2nd segment
                                  double *x, double *y) {
-        double cp1, cp2, cp3, cp4;
+        double cp1, cp2;
         cp1 = cross_product (x1, y1, x2, y2, x3, y3);
         cp2 = cross_product (x1, y1, x2, y2, x4, y4);
Modified: trunk/qgis/src/core/pal/layer.h
--- trunk/qgis/src/core/pal/layer.h	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/pal/layer.h	2009-04-06 12:52:56 UTC (rev 10485)
@@ -53,7 +53,7 @@
     class Pal;
     class SimpleMutex;
-    struct Feat;
+    class Feat;
      * \brief A layer of spacial entites
Modified: trunk/qgis/src/core/pal/pal.h
--- trunk/qgis/src/core/pal/pal.h	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/pal/pal.h	2009-04-06 12:52:56 UTC (rev 10485)
@@ -40,6 +40,9 @@
 #include <list>
 #include <iostream>
+#ifdef _MSC_VER
+#include <time.h>
+#endif
 // TODO ${MAJOR} ${MINOR} etc instead of 0.2
Modified: trunk/qgis/src/core/pal/problem.cpp
--- trunk/qgis/src/core/pal/problem.cpp	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/pal/problem.cpp	2009-04-06 12:52:56 UTC (rev 10485)
@@ -1317,7 +1317,7 @@
             std::cout << "    Conflictual..." << std::endl;
 #endif
             int feat, rfeat;
-            bool sub = ctx->featWrap;
+            bool sub = ctx->featWrap!=NULL;
             feat = lp->probFeat;
             if (sub) {
@@ -1578,6 +1578,8 @@
                 } catch (int i) {
 #ifdef _DEBUG_FULL_
                     std::cout << "catch int " << i << std::endl;
+#else
+                    i;
 #endif
                     while (conflicts->size() > 0)
                         conflicts->pop_front();
@@ -1838,6 +1840,8 @@
                 } catch (int i) {
 #ifdef _DEBUG_FULL_
                     std::cout << "catch Cycle in chain" << std::endl;
+#else
+                    i;
 #endif
Modified: trunk/qgis/src/core/pal/util.cpp
--- trunk/qgis/src/core/pal/util.cpp	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/pal/util.cpp	2009-04-06 12:52:56 UTC (rev 10485)
@@ -247,8 +247,6 @@
     void extractXYCoord (Feat *f) {
         int i, j;
-        double phi, lambda;
         //Projection *proj = pal->proj;
         const GEOSCoordSequence *coordSeq;
Modified: trunk/qgis/src/core/pal/util.h
--- trunk/qgis/src/core/pal/util.h	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/pal/util.h	2009-04-06 12:52:56 UTC (rev 10485)
@@ -58,7 +58,8 @@
      * \brief For translating feature from GEOS to Pal
-    typedef struct Feat {
+    class Feat {
+      public:
         const GEOSGeometry *geom;
         const char *id;
         int type;
@@ -72,7 +73,7 @@
         int nbHoles;
         PointSet **holes;
-    } Feat;
Modified: trunk/qgis/src/core/qgscentralpointpositionmanager.cpp
--- trunk/qgis/src/core/qgscentralpointpositionmanager.cpp	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/qgscentralpointpositionmanager.cpp	2009-04-06 12:52:56 UTC (rev 10485)
@@ -182,8 +182,8 @@
         currentPosition+= sizeof(int);
-        double x[numberOfPoints];
-        double y[numberOfPoints];
+        double *x = new double[numberOfPoints];
+        double *y = new double[numberOfPoints];
         for(int i = 0; i < numberOfPoints; ++i)
@@ -197,7 +197,11 @@
         double centroidX, centroidY;
-        if(calculatePolygonCentroid(x, y, numberOfPoints, centroidX, centroidY) != 0)
+        int res = calculatePolygonCentroid(x, y, numberOfPoints, centroidX, centroidY);
+        delete [] x;
+        delete [] y;
+        if( res != 0)
             return 1;
Modified: trunk/qgis/src/core/qgsoverlayobject.cpp
--- trunk/qgis/src/core/qgsoverlayobject.cpp	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/core/qgsoverlayobject.cpp	2009-04-06 12:52:56 UTC (rev 10485)
@@ -40,6 +40,7 @@
   mPositions = other.positions();
   mRotation = other.rotation();
   mGeometry = new QgsGeometry(*(other.geometry()));
+  return *this;
 GEOSGeometry* QgsOverlayObject::getGeosGeometry()
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp
--- trunk/qgis/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp	2009-04-06 12:52:56 UTC (rev 10485)
@@ -158,4 +158,5 @@
     QDomText barWidthText = doc.createTextNode(QString::number(mBarWidth));
     barWidthElem.appendChild(barWidthText);
     factory_node.appendChild(barWidthElem);
+    return true;
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsdiagramrenderer.h
--- trunk/qgis/src/plugins/diagram_overlay/qgsdiagramrenderer.h	2009-04-06 11:53:45 UTC (rev 10484)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsdiagramrenderer.h	2009-04-06 12:52:56 UTC (rev 10485)
@@ -30,9 +30,9 @@
 class QImage;
 //structure that describes a renderer entry
-struct QgsDiagramItem
+class QgsDiagramItem
+public:
   QVariant value;
   int size;
More information about the QGIS-commit mailing list
