[QGIS Commit] r10499 - in branches/Version-1_0/src/plugins/grass: .
config
svn_qgis at osgeo.org
Tue Apr 7 11:41:56 EDT 2009
Author: jef
Date: 2009-04-07 11:41:55 -0400 (Tue, 07 Apr 2009)
New Revision: 10499
branches/Version-1_0/src/plugins/grass/config/default.qgc
branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp
merge r10496 and r10497 to 1.0
Modified: branches/Version-1_0/src/plugins/grass/config/default.qgc
--- branches/Version-1_0/src/plugins/grass/config/default.qgc 2009-04-07 13:44:07 UTC (rev 10498)
+++ branches/Version-1_0/src/plugins/grass/config/default.qgc 2009-04-07 15:41:55 UTC (rev 10499)
@@ -68,16 +68,14 @@
</section>
</section>
- <section label=" ">
- </section>
<section label="Config">
<section label="Region">
<section label="Region settings">
<grass name="g.region.save"/>
<grass name="g.region.zoom"/>
<grass name="g.region.multiple.raster"/>
- <grass name="g.region.multiple.vector"/> </section>
+ <grass name="g.region.multiple.vector"/>
+ </section>
<section label="Projection management">
<section label="Print projection information of the current location"> <grass name="g.proj.print"/>
</section>
@@ -98,9 +96,6 @@
</section>
</section>
- </section>
<section label="Raster">
<section label="Develop map">
<section label="Compress raster">
@@ -241,9 +236,6 @@
</section>
</section>
- </section>
<section label="Vector">
<section label="Topology management">
@@ -370,9 +362,6 @@
</section>
</section>
- </section>
<section label="Imagery">
<section label="Develop images and group">
<grass name="i.image.mosaic"/>
@@ -404,9 +393,6 @@
</section>
</section>
- </section>
<section label="Database">
<section label="Database management">
<grass name="db.connect"/>
@@ -438,16 +424,10 @@
</section>
</section>
- </section>
<section label="3d Visualization">
<grass name="nviz"/>
</section>
- </section>
<section label="Help">
<grass name="g.manual"/>
</section>
Modified: branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp
--- branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp 2009-04-07 13:44:07 UTC (rev 10498)
+++ branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp 2009-04-07 15:41:55 UTC (rev 10499)
@@ -171,8 +171,9 @@
#endif
#ifdef WIN32
- if( !QProcess::startDetached( getenv("COMSPEC") ) ) {
- QMessageBox::warning( 0, "Warning", tr("Cannot start command shell (%1)").arg( getenv("COMSPEC") ) );
+ if ( !QProcess::startDetached( getenv( "COMSPEC" ) ) )
+ QMessageBox::warning( 0, "Warning", tr( "Cannot start command shell (%1)" ).arg( getenv( "COMSPEC" ) ) );
return;
#else
@@ -266,6 +267,8 @@
// Go through the sections and modules and add them to the list view
addModules( 0, modulesElem );
+ mModules->topLevelItem( 0 )->setExpanded( true );
file.close();
return true;
@@ -303,7 +306,7 @@
QString label = e.attribute( "label" );
QgsDebugMsg( QString( "label = %1" ).arg( label ) );
item->setText( 0, label );
- item->setExpanded( true );
+ item->setExpanded( false );
addModules( item, e );
