[QGIS Commit] r10503 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org
Tue Apr 7 19:07:09 EDT 2009
Author: cfarmer
Date: 2009-04-07 19:07:09 -0400 (Tue, 07 Apr 2009)
New Revision: 10503
trunk/qgis/python/plugins/fTools/tools/doGeometry.py
udpates to centroid function, should work with any and all projections
Modified: trunk/qgis/python/plugins/fTools/tools/doGeometry.py
--- trunk/qgis/python/plugins/fTools/tools/doGeometry.py 2009-04-07 19:36:40 UTC (rev 10502)
+++ trunk/qgis/python/plugins/fTools/tools/doGeometry.py 2009-04-07 23:07:09 UTC (rev 10503)
@@ -8,859 +8,845 @@
class GeometryDialog(QDialog, Ui_Dialog):
- def __init__(self, iface, function):
- QDialog.__init__(self)
- self.iface = iface
- self.setupUi(self)
- self.myFunction = function
- QObject.connect(self.toolOut, SIGNAL("clicked()"), self.outFile)
- if self.myFunction == 1:
- QObject.connect(self.inShape, SIGNAL("currentIndexChanged(QString)"), self.update)
- self.manageGui()
- self.success = False
- self.cancel_close = self.buttonBox_2.button( QDialogButtonBox.Close )
- self.progressBar.setValue(0)
+ def __init__(self, iface, function):
+ QDialog.__init__(self)
+ self.iface = iface
+ self.setupUi(self)
+ self.myFunction = function
+ QObject.connect(self.toolOut, SIGNAL("clicked()"), self.outFile)
+ if self.myFunction == 1:
+ QObject.connect(self.inShape, SIGNAL("currentIndexChanged(QString)"), self.update)
+ self.manageGui()
+ self.success = False
+ self.cancel_close = self.buttonBox_2.button( QDialogButtonBox.Close )
+ self.progressBar.setValue(0)
- def update(self):
- self.cmbField.clear()
- inputLayer = unicode(self.inShape.currentText())
- if inputLayer != "":
- changedLayer = ftools_utils.getVectorLayerByName(inputLayer)
- changedField = ftools_utils.getFieldList(changedLayer)
- for i in changedField:
- self.cmbField.addItem(unicode(changedField[i].name()))
- self.cmbField.addItem("--- " + self.tr( "Merge all" ) + " ---")
+ def update(self):
+ self.cmbField.clear()
+ inputLayer = unicode(self.inShape.currentText())
+ if inputLayer != "":
+ changedLayer = ftools_utils.getVectorLayerByName(inputLayer)
+ changedField = ftools_utils.getFieldList(changedLayer)
+ for i in changedField:
+ self.cmbField.addItem(unicode(changedField[i].name()))
+ self.cmbField.addItem("--- " + self.tr( "Merge all" ) + " ---")
- def accept(self):
- if self.inShape.currentText() == "":
- QMessageBox.information(self, "Geometry", self.tr( "Please specify input vector layer" ) )
- elif self.outShape.text() == "":
- QMessageBox.information(self, "Geometry", self.tr( "Please specify output shapefile" ) )
- elif self.lineEdit.isVisible() and self.lineEdit.value() <= 0.00:
- QMessageBox.information(self, "Geometry", self.tr( "Please specify valid tolerance value" ) )
- elif self.cmbField.isVisible() and self.cmbField.currentText() == "":
- QMessageBox.information(self, "Geometry", self.tr( "Please specify valid UID field" ) )
- else:
- self.outShape.clear()
- self.geometry( self.inShape.currentText(), self.lineEdit.value(), self.cmbField.currentText() )
+ def accept(self):
+ if self.inShape.currentText() == "":
+ QMessageBox.information(self, "Geometry", self.tr( "Please specify input vector layer" ) )
+ elif self.outShape.text() == "":
+ QMessageBox.information(self, "Geometry", self.tr( "Please specify output shapefile" ) )
+ elif self.lineEdit.isVisible() and self.lineEdit.value() <= 0.00:
+ QMessageBox.information(self, "Geometry", self.tr( "Please specify valid tolerance value" ) )
+ elif self.cmbField.isVisible() and self.cmbField.currentText() == "":
+ QMessageBox.information(self, "Geometry", self.tr( "Please specify valid UID field" ) )
+ else:
+ self.outShape.clear()
+ self.geometry( self.inShape.currentText(), self.lineEdit.value(), self.cmbField.currentText() )
- def outFile(self):
- (self.shapefileName, self.encoding) = ftools_utils.saveDialog(self)
- if self.shapefileName is None or self.encoding is None:
- return
- self.outShape.setText(QString(self.shapefileName))
+ def outFile(self):
+ (self.shapefileName, self.encoding) = ftools_utils.saveDialog(self)
+ if self.shapefileName is None or self.encoding is None:
+ return
+ self.outShape.setText(QString(self.shapefileName))
- def manageGui(self):
- if self.myFunction == 1: # Singleparts to multipart
- self.setWindowTitle( self.tr( "Singleparts to multipart" ) )
- self.lineEdit.setVisible(False)
- self.label.setVisible(False)
- self.label_2.setText( self.tr( "Output shapefile" ) )
- self.cmbField.setVisible(True)
- self.field_label.setVisible(True)
- elif self.myFunction == 2: # Multipart to singleparts
- self.setWindowTitle( self.tr( "Multipart to singleparts" ) )
- self.label_2.setText(self.tr( "Output shapefile" ) )
- self.cmbField.setVisible(False)
- self.field_label.setVisible(False)
- elif self.myFunction == 3: # Extract nodes
- self.setWindowTitle( self.tr( "Extract nodes" ) )
- elif self.myFunction == 4: # Polygons to lines
- self.setWindowTitle( self.tr( "Polygons to lines" ) )
- self.label_3.setText( self.tr( "Input polygon vector layer" ) )
- elif self.myFunction == 5: # Export/Add geometry columns
- self.setWindowTitle( self.tr( "Export/Add geometry columns" ) )
- self.label_3.setText( self.tr( "Input vector layer" ) )
- elif self.myFunction == 6: # Simplify geometries
- self.setWindowTitle( self.tr( "Simplify geometries" ) )
- elif self.myFunction == 7: # Polygon centroids
- self.setWindowTitle( self.tr( "Polygon centroids" ) )
- self.label_2.setText( self.tr( "Output point shapefile" ) )
- self.label.setVisible( False )
- self.lineEdit.setVisible( False )
- self.cmbField.setVisible( False )
- self.field_label.setVisible( False )
- else:
- if self.myFunction == 8: # Delaunay triangulation
- self.setWindowTitle( self.tr( "Delaunay triangulation" ) )
- self.label_3.setText( self.tr( "Input point vector layer" ) )
- else: # Polygon from layer extent
- self.setWindowTitle( self.tr( "Polygon from layer extent" ) )
- self.label_3.setText( self.tr( "Input layer" ) )
- self.label_2.setText( self.tr( "Output polygon shapefile" ) )
- self.resize( 381, 100 )
- myList = []
- self.inShape.clear()
- if self.myFunction == 3 or self.myFunction == 6:
- myList = ftools_utils.getLayerNames( [ QGis.Polygon, QGis.Line ] )
- elif self.myFunction == 4 or self.myFunction == 7:
- myList = ftools_utils.getLayerNames( [ QGis.Polygon ] )
- elif self.myFunction == 8:
- myList = ftools_utils.getLayerNames( [ QGis.Point ] )
- elif self.myFunction == 9:
- myList = ftools_utils.getLayerNames( "all" )
- else:
- myList = ftools_utils.getLayerNames( [ QGis.Point, QGis.Line, QGis.Polygon ] )
- self.inShape.addItems( myList )
- return
+ def manageGui(self):
+ if self.myFunction == 1: # Singleparts to multipart
+ self.setWindowTitle( self.tr( "Singleparts to multipart" ) )
+ self.lineEdit.setVisible(False)
+ self.label.setVisible(False)
+ self.label_2.setText( self.tr( "Output shapefile" ) )
+ self.cmbField.setVisible(True)
+ self.field_label.setVisible(True)
+ elif self.myFunction == 2: # Multipart to singleparts
+ self.setWindowTitle( self.tr( "Multipart to singleparts" ) )
+ self.label_2.setText(self.tr( "Output shapefile" ) )
+ self.cmbField.setVisible(False)
+ self.field_label.setVisible(False)
+ elif self.myFunction == 3: # Extract nodes
+ self.setWindowTitle( self.tr( "Extract nodes" ) )
+ elif self.myFunction == 4: # Polygons to lines
+ self.setWindowTitle( self.tr( "Polygons to lines" ) )
+ self.label_3.setText( self.tr( "Input polygon vector layer" ) )
+ elif self.myFunction == 5: # Export/Add geometry columns
+ self.setWindowTitle( self.tr( "Export/Add geometry columns" ) )
+ self.label_3.setText( self.tr( "Input vector layer" ) )
+ elif self.myFunction == 6: # Simplify geometries
+ self.setWindowTitle( self.tr( "Simplify geometries" ) )
+ elif self.myFunction == 7: # Polygon centroids
+ self.setWindowTitle( self.tr( "Polygon centroids" ) )
+ self.label_2.setText( self.tr( "Output point shapefile" ) )
+ self.label.setVisible( False )
+ self.lineEdit.setVisible( False )
+ self.cmbField.setVisible( False )
+ self.field_label.setVisible( False )
+ else:
+ if self.myFunction == 8: # Delaunay triangulation
+ self.setWindowTitle( self.tr( "Delaunay triangulation" ) )
+ self.label_3.setText( self.tr( "Input point vector layer" ) )
+ else: # Polygon from layer extent
+ self.setWindowTitle( self.tr( "Polygon from layer extent" ) )
+ self.label_3.setText( self.tr( "Input layer" ) )
+ self.label_2.setText( self.tr( "Output polygon shapefile" ) )
+ self.resize( 381, 100 )
+ myList = []
+ self.inShape.clear()
+ if self.myFunction == 3 or self.myFunction == 6:
+ myList = ftools_utils.getLayerNames( [ QGis.Polygon, QGis.Line ] )
+ elif self.myFunction == 4 or self.myFunction == 7:
+ myList = ftools_utils.getLayerNames( [ QGis.Polygon ] )
+ elif self.myFunction == 8:
+ myList = ftools_utils.getLayerNames( [ QGis.Point ] )
+ elif self.myFunction == 9:
+ myList = ftools_utils.getLayerNames( "all" )
+ else:
+ myList = ftools_utils.getLayerNames( [ QGis.Point, QGis.Line, QGis.Polygon ] )
+ self.inShape.addItems( myList )
+ return
-#1: Singleparts to multipart
-#2: Multipart to singleparts
-#3: Extract nodes
-#4: Polygons to lines
-#5: Export/Add geometry columns
-#6: Simplify geometries
-#7: Polygon centroids
+#1: Singleparts to multipart
+#2: Multipart to singleparts
+#3: Extract nodes
+#4: Polygons to lines
+#5: Export/Add geometry columns
+#6: Simplify geometries
+#7: Polygon centroids
#8: Delaunay triangulation
#9: Polygon from layer extent
- def geometry( self, myLayer, myParam, myField ):
- if self.myFunction == 9:
- vlayer = ftools_utils.getMapLayerByName( myLayer )
- else:
- vlayer = ftools_utils.getVectorLayerByName( myLayer )
- error = False
- check = QFile( self.shapefileName )
- if check.exists():
- if not QgsVectorFileWriter.deleteShapeFile( self.shapefileName ):
- QMessageBox.warning( self, "Geoprocessing", self.tr( "Unable to delete existing shapefile." ) )
- return
- self.testThread = geometryThread( self.iface.mainWindow(), self, self.myFunction, vlayer, myParam,
- myField, self.shapefileName, self.encoding )
- QObject.connect( self.testThread, SIGNAL( "runFinished(PyQt_PyObject)" ), self.runFinishedFromThread )
- QObject.connect( self.testThread, SIGNAL( "runStatus(PyQt_PyObject)" ), self.runStatusFromThread )
- QObject.connect( self.testThread, SIGNAL( "runRange(PyQt_PyObject)" ), self.runRangeFromThread )
- self.cancel_close.setText( "Cancel" )
- QObject.connect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
- self.testThread.start()
+ def geometry( self, myLayer, myParam, myField ):
+ if self.myFunction == 9:
+ vlayer = ftools_utils.getMapLayerByName( myLayer )
+ else:
+ vlayer = ftools_utils.getVectorLayerByName( myLayer )
+ error = False
+ check = QFile( self.shapefileName )
+ if check.exists():
+ if not QgsVectorFileWriter.deleteShapeFile( self.shapefileName ):
+ QMessageBox.warning( self, "Geoprocessing", self.tr( "Unable to delete existing shapefile." ) )
+ return
+ self.testThread = geometryThread( self.iface.mainWindow(), self, self.myFunction, vlayer, myParam,
+ myField, self.shapefileName, self.encoding )
+ QObject.connect( self.testThread, SIGNAL( "runFinished(PyQt_PyObject)" ), self.runFinishedFromThread )
+ QObject.connect( self.testThread, SIGNAL( "runStatus(PyQt_PyObject)" ), self.runStatusFromThread )
+ QObject.connect( self.testThread, SIGNAL( "runRange(PyQt_PyObject)" ), self.runRangeFromThread )
+ self.cancel_close.setText( "Cancel" )
+ QObject.connect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
+ self.testThread.start()
- def cancelThread( self ):
- self.testThread.stop()
- def runFinishedFromThread( self, success ):
- if success == "math_error":
- QMessageBox.warning( self, "Geometry", self.tr( "Error processing specified tolerance!" ) + "\n"
- + self.tr( "Please choose larger tolerance..." ) )
- QMessageBox.warning( self, "Geometry", self.tr( "Unable to delete incomplete shapefile." ) )
- else:
- self.cancel_close.setText( "Close" )
- QObject.disconnect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
- if success:
- addToTOC = QMessageBox.question( self, "Geometry", self.tr( "Created output shapefile:" ) + "\n" +
- unicode( self.shapefileName ) + "\n\n" + self.tr( "Would you like to add the new layer to the TOC?" ),
- QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton )
- if addToTOC == QMessageBox.Yes:
- ftools_utils.addShapeToCanvas( unicode( self.shapefileName ) )
- else:
- QMessageBox.warning( self, "Geometry", self.tr( "Error writing output shapefile." ) )
- def runStatusFromThread( self, status ):
- self.progressBar.setValue( status )
+ def cancelThread( self ):
+ self.testThread.stop()
+ def runFinishedFromThread( self, success ):
+ if success == "math_error":
+ QMessageBox.warning( self, "Geometry", self.tr( "Error processing specified tolerance!" ) + "\n"
+ + self.tr( "Please choose larger tolerance..." ) )
+ QMessageBox.warning( self, "Geometry", self.tr( "Unable to delete incomplete shapefile." ) )
+ else:
+ self.cancel_close.setText( "Close" )
+ QObject.disconnect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
+ if success:
+ addToTOC = QMessageBox.question( self, "Geometry", self.tr( "Created output shapefile:" ) + "\n" +
+ unicode( self.shapefileName ) + "\n\n" + self.tr( "Would you like to add the new layer to the TOC?" ),
+ QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton )
+ if addToTOC == QMessageBox.Yes:
+ ftools_utils.addShapeToCanvas( unicode( self.shapefileName ) )
+ else:
+ QMessageBox.warning( self, "Geometry", self.tr( "Error writing output shapefile." ) )
- def runRangeFromThread( self, range_vals ):
- self.progressBar.setRange( range_vals[ 0 ], range_vals[ 1 ] )
+ def runStatusFromThread( self, status ):
+ self.progressBar.setValue( status )
+ def runRangeFromThread( self, range_vals ):
+ self.progressBar.setRange( range_vals[ 0 ], range_vals[ 1 ] )
class geometryThread( QThread ):
- def __init__( self, parentThread, parentObject, function, vlayer, myParam, myField, myName, myEncoding ):
- QThread.__init__( self, parentThread )
- self.parent = parentObject
- self.running = False
- self.vlayer = vlayer
- self.myParam = myParam
- self.myField = myField
- self.myName = myName
- self.myEncoding = myEncoding
+ def __init__( self, parentThread, parentObject, function, vlayer, myParam, myField, myName, myEncoding ):
+ QThread.__init__( self, parentThread )
+ self.parent = parentObject
+ self.running = False
+ self.vlayer = vlayer
+ self.myParam = myParam
+ self.myField = myField
+ self.myName = myName
+ self.myEncoding = myEncoding
- def run( self ):
- self.running = True
- success = self.single_to_multi()
- success = self.multi_to_single()
- success = self.extract_nodes()
- success = self.polygons_to_lines()
- success = self.export_geometry_info()
- success = self.simplify_geometry()
- success = self.polygon_centroids()
- elif self.myFunction == 8: # Delaunay triangulation
- success = self.delaunay_triangulation()
- elif self.myFunction == 9: # Polygon from layer extent
- success = self.layer_extent()
- self.emit( SIGNAL( "runFinished(PyQt_PyObject)" ), success )
- self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
+ def run( self ):
+ self.running = True
+ success = self.single_to_multi()
+ success = self.multi_to_single()
+ success = self.extract_nodes()
+ success = self.polygons_to_lines()
+ success = self.export_geometry_info()
+ success = self.simplify_geometry()
+ success = self.polygon_centroids()
+ elif self.myFunction == 8: # Delaunay triangulation
+ success = self.delaunay_triangulation()
+ elif self.myFunction == 9: # Polygon from layer extent
+ success = self.layer_extent()
+ self.emit( SIGNAL( "runFinished(PyQt_PyObject)" ), success )
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
- def stop(self):
- def single_to_multi( self ):
- vprovider = self.vlayer.dataProvider()
- allAttrs = vprovider.attributeIndexes()
- vprovider.select( allAttrs )
- fields = vprovider.fields()
- writer = QgsVectorFileWriter( self.myName, self.myEncoding,
- fields, vprovider.geometryType(), vprovider.crs() )
- inFeat = QgsFeature()
- outFeat = QgsFeature()
- inGeom = QgsGeometry()
- outGeom = QgsGeometry()
- index = vprovider.fieldNameIndex( self.myField )
- if not index == -1:
- unique = ftools_utils.getUniqueValues( vprovider, int( index ) )
- else:
- unique = range( 0, self.vlayer.featureCount() )
- nFeat = vprovider.featureCount() * len( unique )
- nElement = 0
- self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, nFeat ) )
- if not len( unique ) == self.vlayer.featureCount():
- for i in unique:
- vprovider.rewind()
- multi_feature= []
- first = True
- while vprovider.nextFeature( inFeat ):
- atMap = inFeat.attributeMap()
- idVar = atMap[ index ]
- if idVar.toString().trimmed() == i.toString().trimmed():
- if first:
- atts = atMap
- first = False
- inGeom = QgsGeometry( inFeat.geometry() )
- vType = inGeom.type()
- feature_list = self.extractAsMulti( inGeom )
- multi_feature.extend( feature_list )
- nElement += 1
- self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
- outFeat.setAttributeMap( atts )
- outGeom = QgsGeometry( self.convertGeometry( multi_feature, vType ) )
- outFeat.setGeometry( outGeom )
- writer.addFeature( outFeat )
- del writer
- return True
+ def stop(self):
+ def single_to_multi( self ):
+ vprovider = self.vlayer.dataProvider()
+ allAttrs = vprovider.attributeIndexes()
+ vprovider.select( allAttrs )
+ fields = vprovider.fields()
+ writer = QgsVectorFileWriter( self.myName, self.myEncoding,
+ fields, vprovider.geometryType(), vprovider.crs() )
+ inFeat = QgsFeature()
+ outFeat = QgsFeature()
+ inGeom = QgsGeometry()
+ outGeom = QgsGeometry()
+ index = vprovider.fieldNameIndex( self.myField )
+ if not index == -1:
+ unique = ftools_utils.getUniqueValues( vprovider, int( index ) )
+ else:
+ unique = range( 0, self.vlayer.featureCount() )
+ nFeat = vprovider.featureCount() * len( unique )
+ nElement = 0
+ self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, nFeat ) )
+ if not len( unique ) == self.vlayer.featureCount():
+ for i in unique:
+ vprovider.rewind()
+ multi_feature= []
+ first = True
+ while vprovider.nextFeature( inFeat ):
+ atMap = inFeat.attributeMap()
+ idVar = atMap[ index ]
+ if idVar.toString().trimmed() == i.toString().trimmed():
+ if first:
+ atts = atMap
+ first = False
+ inGeom = QgsGeometry( inFeat.geometry() )
+ vType = inGeom.type()
+ feature_list = self.extractAsMulti( inGeom )
+ multi_feature.extend( feature_list )
+ nElement += 1
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
+ outFeat.setAttributeMap( atts )
+ outGeom = QgsGeometry( self.convertGeometry( multi_feature, vType ) )
+ outFeat.setGeometry( outGeom )
+ writer.addFeature( outFeat )
+ del writer
+ return True
- def multi_to_single( self ):
- nElement = 0
- nElement += 1
- inGeom = inFeat.geometry()
- featList = self.extractAsSingle( inGeom )
- outFeat.setAttributeMap( atMap )
- for i in featList:
- outFeat.setGeometry( i )
- del writer
- return True
+ def multi_to_single( self ):
+ nElement = 0
+ nElement += 1
+ inGeom = inFeat.geometry()
+ featList = self.extractAsSingle( inGeom )
+ outFeat.setAttributeMap( atMap )
+ for i in featList:
+ outFeat.setGeometry( i )
+ del writer
+ return True
- def extract_nodes( self ):
- fields, QGis.WKBPoint, vprovider.crs() )
- nElement = 0
- nElement += 1
- pointList = ftools_utils.extractPoints( inGeom )
- for i in pointList:
- outFeat.setGeometry( outGeom.fromPoint( i ) )
- del writer
- return True
+ def extract_nodes( self ):
+ fields, QGis.WKBPoint, vprovider.crs() )
+ nElement = 0
+ nElement += 1
+ pointList = ftools_utils.extractPoints( inGeom )
+ for i in pointList:
+ outFeat.setGeometry( outGeom.fromPoint( i ) )
+ del writer
+ return True
- def polygons_to_lines( self ):
- fields, QGis.WKBLineString, vprovider.crs() )
- nElement = 0
- self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0)
- while vprovider.nextFeature(inFeat):
- multi = False
- nElement += 1
- if inGeom.isMultipart():
- multi = True
- lineList = self.extractAsLine( inGeom )
- for h in lineList:
- outFeat.setGeometry( outGeom.fromPolyline( h ) )
- del writer
- return True
+ def polygons_to_lines( self ):
+ fields, QGis.WKBLineString, vprovider.crs() )
+ nElement = 0
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0)
+ while vprovider.nextFeature(inFeat):
+ multi = False
+ nElement += 1
+ if inGeom.isMultipart():
+ multi = True
+ lineList = self.extractAsLine( inGeom )
+ for h in lineList:
+ outFeat.setGeometry( outGeom.fromPolyline( h ) )
+ del writer
+ return True
- def export_geometry_info( self ):
- ( fields, index1, index2 ) = self.checkGeometryFields( self.vlayer )
- nElement = 0
- nElement += 1
- ( attr1, attr2 ) = self.simpleMeasure( inGeom )
- outFeat.setGeometry( inGeom )
- outFeat.addAttribute( index1, QVariant( attr1 ) )
- outFeat.addAttribute( index2, QVariant( attr2 ) )
- del writer
- return True
+ def export_geometry_info( self ):
+ ( fields, index1, index2 ) = self.checkGeometryFields( self.vlayer )
+ nElement = 0
+ nElement += 1
+ ( attr1, attr2 ) = self.simpleMeasure( inGeom )
+ outFeat.setGeometry( inGeom )
+ outFeat.addAttribute( index1, QVariant( attr1 ) )
+ outFeat.addAttribute( index2, QVariant( attr2 ) )
+ del writer
+ return True
- def simplify_geometry( self ):
- tolerance = self.myParam
- nElement = 0
- self.measure = QgsDistanceArea()
- nElement += 1
- outGeom = self.extractAsSimple( inGeom, tolerance )
- if outGeom is None:
- return "math_error"
- del writer
- return True
+ def simplify_geometry( self ):
+ tolerance = self.myParam
+ nElement = 0
+ self.measure = QgsDistanceArea()
+ nElement += 1
+ outGeom = self.extractAsSimple( inGeom, tolerance )
+ if outGeom is None:
+ return "math_error"
+ del writer
+ return True
- def polygon_centroids( self ):
- outfeat = QgsFeature()
- nElement = 0
- geom = inFeat.geometry()
- area = QgsDistanceArea()
- A = area.measure( geom )
- multi_geom = QgsGeometry()
- bounding = inFeat.geometry().boundingBox()
- xmin = bounding.xMinimum()
- ymin = bounding.yMinimum()
- xmax = bounding.xMaximum()
- ymax = bounding.yMaximum()
- if geom.type() == 2:
- cx = 0
- cy = 0
- area2 = 0
- if geom.isMultipart():
- multi_geom = geom.asMultiPolygon()
- for k in multi_geom:
- for h in k:
- for i in range(0, len(h) - 1):
- j = (i + 1) % len(h)
- factor = ((h[i].x()-xmin) * (h[j].y()-ymin) - (h[j].x()-xmin) * (h[i].y()-ymin))
- cx = cx + ((h[i].x()-xmin) + (h[j].x()-xmin)) * factor
- cy = cy + ((h[i].y()-ymin) + (h[j].y()-ymin)) * factor
- else:
- multi_geom = geom.asPolygon()
- for i in range(0, len(k) - 1):
- j = (i + 1) % len(k)
- factor = (k[i].x()-xmin) * (k[j].y()-ymin) - (k[j].x()-xmin) * (k[i].y()-ymin)
- cx = cx + ((k[i].x()-xmin) + (k[j].x()-xmin)) * factor
- cy = cy + ((k[i].y()-ymin) + (k[j].y()-ymin)) * factor
- A = A * 6
- factor = 1/A
- cx = cx * factor
- cy = cy * factor
-# if cx < xmin:
-# cx = cx * -1
-# if cy < ymin:
-# cy = cy * -1
-# if cx > xmax:
-# cx = cx * -1
-# if cy > ymax:
-# cy = cy * -1
- cx = cx + xmin
- cy = cy + ymin
- outfeat.setGeometry( QgsGeometry.fromPoint( QgsPoint( cx, cy ) ) )
- outfeat.setAttributeMap( atMap )
- writer.addFeature( outfeat )
- nElement += 1
- del writer
- return True
- def delaunay_triangulation( self ):
- import voronoi
- fields = {
- 0 : QgsField( "POINTA", QVariant.Double ),
- 1 : QgsField( "POINTB", QVariant.Double ),
- 2 : QgsField( "POINTC", QVariant.Double ) }
- fields, QGis.WKBPolygon, vprovider.crs() )
- points = []
- print "here"
- point = inGeom.asPoint()
- points.append( point )
- print "or here"
- triangles = voronoi.computeDelaunayTriangulation( points )
- feat = QgsFeature()
- nFeat = len( triangles )
- nElement = 0
- for triangle in triangles:
- indicies = list( triangle )
- indicies.append( indicies[ 0 ] )
- polygon = []
- step = 0
- for index in indicies:
- vprovider.featureAtId( index, feat, True, allAttrs )
- geom = QgsGeometry( feat.geometry() )
- point = QgsPoint( geom.asPoint() )
- polygon.append( point )
- feat.addAttribute( step, QVariant( index ) )
- step += 1
- geometry = QgsGeometry().fromPolygon( [ polygon ] )
- feat.setGeometry( geometry )
- writer.addFeature( feat )
- nElement += 1
- del writer
- return True
- def layer_extent( self ):
- self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, 0 ) )
- fields = {
- 0 : QgsField( "MINX", QVariant.Double ),
- 1 : QgsField( "MINY", QVariant.Double ),
- 2 : QgsField( "MAXX", QVariant.Double ),
- 3 : QgsField( "MAXY", QVariant.Double ),
- 4 : QgsField( "CNTX", QVariant.Double ),
- 5 : QgsField( "CNTY", QVariant.Double ),
- 6 : QgsField( "AREA", QVariant.Double ),
- 7 : QgsField( "PERIM", QVariant.Double ),
- 8 : QgsField( "HEIGHT", QVariant.Double ),
- 9 : QgsField( "WIDTH", QVariant.Double ) }
+ def polygon_centroids( self ):
+ outfeat = QgsFeature()
+ nElement = 0
+ geom = inFeat.geometry()
+ area = 0.00
+ bounding = inFeat.geometry().boundingBox()
+ xmin = bounding.xMinimum()
+ ymin = bounding.yMinimum()
+ if geom.type() == 2:
+ cx = 0
+ cy = 0
+ factor = 0
+ if geom.isMultipart():
+ polygons = geom.asMultiPolygon()
+ for polygon in polygons:
+ for line in polygon:
+ for i in range(0,len(line)-1):
+ j = (i + 1) % len(line)
+ factor=((line[i].x()-xmin)*(line[j].y()-ymin)-(line[j].x()-xmin)*(line[i].y()-ymin))
+ cx+=((line[i].x()-xmin)+(line[j].x()-xmin))*factor
+ cy+=((line[i].y()-ymin)+(line[j].y()-ymin))*factor
+ area+=factor
+ else:
+ polygon = geom.asPolygon()
+ area+=factor
+ cx/=area*3.00
+ cy/=area*3.00
+ outfeat.setGeometry( QgsGeometry.fromPoint( QgsPoint( cx+xmin, cy+ymin ) ) )
+ outfeat.setAttributeMap( atMap )
+ writer.addFeature( outfeat )
+ nElement += 1
+ del writer
+ return True
+ def delaunay_triangulation( self ):
+ import voronoi
+ fields = {
+ 0 : QgsField( "POINTA", QVariant.Double ),
+ 1 : QgsField( "POINTB", QVariant.Double ),
+ 2 : QgsField( "POINTC", QVariant.Double ) }
+ fields, QGis.WKBPolygon, vprovider.crs() )
+ points = []
+ print "here"
+ point = inGeom.asPoint()
+ points.append( point )
+ print "or here"
+ triangles = voronoi.computeDelaunayTriangulation( points )
+ feat = QgsFeature()
+ nFeat = len( triangles )
+ nElement = 0
+ for triangle in triangles:
+ indicies = list( triangle )
+ indicies.append( indicies[ 0 ] )
+ polygon = []
+ step = 0
+ for index in indicies:
+ vprovider.featureAtId( index, feat, True, allAttrs )
+ geom = QgsGeometry( feat.geometry() )
+ point = QgsPoint( geom.asPoint() )
+ polygon.append( point )
+ feat.addAttribute( step, QVariant( index ) )
+ step += 1
+ geometry = QgsGeometry().fromPolygon( [ polygon ] )
+ feat.setGeometry( geometry )
+ writer.addFeature( feat )
+ nElement += 1
+ del writer
+ return True
+ def layer_extent( self ):
+ self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, 0 ) )
+ fields = {
+ 0 : QgsField( "MINX", QVariant.Double ),
+ 1 : QgsField( "MINY", QVariant.Double ),
+ 2 : QgsField( "MAXX", QVariant.Double ),
+ 3 : QgsField( "MAXY", QVariant.Double ),
+ 4 : QgsField( "CNTX", QVariant.Double ),
+ 5 : QgsField( "CNTY", QVariant.Double ),
+ 6 : QgsField( "AREA", QVariant.Double ),
+ 7 : QgsField( "PERIM", QVariant.Double ),
+ 8 : QgsField( "HEIGHT", QVariant.Double ),
+ 9 : QgsField( "WIDTH", QVariant.Double ) }
- fields, QGis.WKBPolygon, self.vlayer.srs() )
- rect = self.vlayer.extent()
- minx = rect.xMinimum()
- miny = rect.yMinimum()
- maxx = rect.xMaximum()
- maxy = rect.yMaximum()
- height = rect.height()
- width = rect.width()
- cntx = minx + ( width / 2.0 )
- cnty = miny + ( height / 2.0 )
- area = width * height
- perim = ( 2 * width ) + (2 * height )
- rect = [
- QgsPoint( minx, miny ),
- QgsPoint( minx, maxy ),
- QgsPoint( maxx, maxy ),
- QgsPoint( maxx, miny ),
- QgsPoint( minx, miny ) ]
- geometry = QgsGeometry().fromPolygon( [ rect ] )
- feat.setAttributeMap( {
- 0 : QVariant( minx ),
- 1 : QVariant( miny ),
- 2 : QVariant( maxx ),
- 3 : QVariant( maxy ),
- 4 : QVariant( cntx ),
- 5 : QVariant( cnty ),
- 6 : QVariant( area ),
- 7 : QVariant( perim ),
- 8 : QVariant( height ),
- 9 : QVariant( width ) } )
- self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, 100 ) )
- del writer
+ fields, QGis.WKBPolygon, self.vlayer.srs() )
+ rect = self.vlayer.extent()
+ minx = rect.xMinimum()
+ miny = rect.yMinimum()
+ maxx = rect.xMaximum()
+ maxy = rect.yMaximum()
+ height = rect.height()
+ width = rect.width()
+ cntx = minx + ( width / 2.0 )
+ cnty = miny + ( height / 2.0 )
+ area = width * height
+ perim = ( 2 * width ) + (2 * height )
+ rect = [
+ QgsPoint( minx, miny ),
+ QgsPoint( minx, maxy ),
+ QgsPoint( maxx, maxy ),
+ QgsPoint( maxx, miny ),
+ QgsPoint( minx, miny ) ]
+ geometry = QgsGeometry().fromPolygon( [ rect ] )
+ feat.setAttributeMap( {
+ 0 : QVariant( minx ),
+ 1 : QVariant( miny ),
+ 2 : QVariant( maxx ),
+ 3 : QVariant( maxy ),
+ 4 : QVariant( cntx ),
+ 5 : QVariant( cnty ),
+ 6 : QVariant( area ),
+ 7 : QVariant( perim ),
+ 8 : QVariant( height ),
+ 9 : QVariant( width ) } )
+ self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, 100 ) )
+ del writer
- return True
+ return True
- def extractAsSimple( self, geom, tolerance ):
- temp_geom1 = []
- temp_geom2 = []
- if geom.type() == 1:
- multi_geom = geom.asMultiPolyline()
- for i in multi_geom:
- simple = self.simlifyLine( i, 1, tolerance )
- if simple is None:
- return None
- else:
- temp_geom1.append( simple )
- return QgsGeometry().fromMultiPolyline(temp_geom1)
- else:
- multi_geom = self.simplifyLine( geom.asPolyline(), 1, tolerance )
- if multi_geom is None:
- return None
- else:
- return QgsGeometry().fromPolyline(multi_geom)
- elif geom.type() == 2:
- temp_geom2 = []
- for j in i:
- simple = self.simplifyLine( j, 2, tolerance )
- return None
- else:
- temp_geom2.append( simple )
- temp_geom1.append( temp_geom2 )
- return QgsGeometry().fromMultiPolygon( temp_geom1 )
- else:
- simple = self.simplifyLine( i, 2, tolerance )
- return None
- else:
- return QgsGeometry().fromPolygon(temp_geom1)
+ def extractAsSimple( self, geom, tolerance ):
+ temp_geom1 = []
+ temp_geom2 = []
+ if geom.type() == 1:
+ multi_geom = geom.asMultiPolyline()
+ for i in multi_geom:
+ simple = self.simlifyLine( i, 1, tolerance )
+ if simple is None:
+ return None
+ else:
+ temp_geom1.append( simple )
+ return QgsGeometry().fromMultiPolyline(temp_geom1)
+ else:
+ multi_geom = self.simplifyLine( geom.asPolyline(), 1, tolerance )
+ if multi_geom is None:
+ return None
+ else:
+ return QgsGeometry().fromPolyline(multi_geom)
+ elif geom.type() == 2:
+ multi_geom = geom.asMultiPolygon()
+ temp_geom2 = []
+ for j in i:
+ simple = self.simplifyLine( j, 2, tolerance )
+ return None
+ else:
+ temp_geom2.append( simple )
+ temp_geom1.append( temp_geom2 )
+ return QgsGeometry().fromMultiPolygon( temp_geom1 )
+ else:
+ multi_geom = geom.asPolygon()
+ simple = self.simplifyLine( i, 2, tolerance )
+ return None
+ else:
+ return QgsGeometry().fromPolygon(temp_geom1)
- def simplifyLine( self, ln, typ, tol ):
- newline = []
- last = len(ln) - 1
- if typ == 2:
- tml = 0.00
- mid = 1
- for m in range(1 , last):
- ml = self.measure.measureLine(ln[0], ln[m])
- if ml > tml:
- tml = ml
- mid = m
- keep = [0, mid, last]
- try:
- keep.extend( self.recursiveDouglasPeucker( ln, tol, 0, mid) )
- keep.extend( self.recursiveDouglasPeucker( ln, tol, mid, last) )
- except:
- return None
- if len(keep) <= 3:
- return ln
- else:
- keep = [0, last]
- keep.extend( self.recursiveDouglasPeucker( ln, tol, 0, last) )
- keep.sort()
- for i in keep:
- newline.append(ln[i])
- return newline
+ def simplifyLine( self, ln, typ, tol ):
+ newline = []
+ last = len(ln) - 1
+ if typ == 2:
+ tml = 0.00
+ mid = 1
+ for m in range(1 , last):
+ ml = self.measure.measureLine(ln[0], ln[m])
+ if ml > tml:
+ tml = ml
+ mid = m
+ keep = [0, mid, last]
+ try:
+ keep.extend( self.recursiveDouglasPeucker( ln, tol, 0, mid) )
+ keep.extend( self.recursiveDouglasPeucker( ln, tol, mid, last) )
+ except:
+ return None
+ if len(keep) <= 3:
+ return ln
+ else:
+ keep = [0, last]
+ keep.extend( self.recursiveDouglasPeucker( ln, tol, 0, last) )
+ keep.sort()
+ for i in keep:
+ newline.append(ln[i])
+ return newline
- def recursiveDouglasPeucker( self, line, tol, j, k ):
- # recursiveDouglasPeucker based on function
- # by Schuyler Erle <schuyler at nocat.net>
- # Copyright (c) 2005, Frank Warmerdam <warmerdam at pobox.com>
- keep = []
- if k <= j+1: # there is nothing to simplify
- return keep
- # degenerate case
- if self.measure.measureLine( line[ j ], line[ k ]) < tol:
- return keep
- # check for adequate approximation by segment S from v[j] to v[k]
- maxi = j # index of vertex farthest from S
- maxd = 0 # distance squared of farthest vertex
- tline = [ line[ j ], line[ k ] ]
- # test each vertex v[i] for max distance from S
- for i in range( j + 1, k ):
- # compute distance
- #dv = seg.Distance( pts[i] )
- dv = self.shortestDistance( tline, line[ i ] )
- if dv is None:
- return None
- # test with current max distance
- if dv > maxd:
- # v[i] is a new max vertex
- maxi = i
- maxd = dv
- if maxd > tol: # error is worse than the tolerance
- # split the polyline at the farthest vertex from S
- keep.append( maxi ) # mark v[maxi] for the simplified polyline
- # recursively simplify the two subpolylines at v[maxi]
- keep.extend( self.recursiveDouglasPeucker( line, tol, j, maxi ) ) # v[j] to v[maxi]
- keep.extend( self.recursiveDouglasPeucker( line, tol, maxi, k ) ) # v[maxi] to v[k]
+ def recursiveDouglasPeucker( self, line, tol, j, k ):
+ # recursiveDouglasPeucker based on function
+ # by Schuyler Erle <schuyler at nocat.net>
+ # Copyright (c) 2005, Frank Warmerdam <warmerdam at pobox.com>
+ keep = []
+ if k <= j+1: # there is nothing to simplify
+ return keep
+ # degenerate case
+ if self.measure.measureLine( line[ j ], line[ k ]) < tol:
+ return keep
+ # check for adequate approximation by segment S from v[j] to v[k]
+ maxi = j # index of vertex farthest from S
+ maxd = 0 # distance squared of farthest vertex
+ tline = [ line[ j ], line[ k ] ]
+ # test each vertex v[i] for max distance from S
+ for i in range( j + 1, k ):
+ # compute distance
+ #dv = seg.Distance( pts[i] )
+ dv = self.shortestDistance( tline, line[ i ] )
+ if dv is None:
+ return None
+ # test with current max distance
+ if dv > maxd:
+ # v[i] is a new max vertex
+ maxi = i
+ maxd = dv
+ if maxd > tol: # error is worse than the tolerance
+ # split the polyline at the farthest vertex from S
+ keep.append( maxi ) # mark v[maxi] for the simplified polyline
+ # recursively simplify the two subpolylines at v[maxi]
+ keep.extend( self.recursiveDouglasPeucker( line, tol, j, maxi ) ) # v[j] to v[maxi]
+ keep.extend( self.recursiveDouglasPeucker( line, tol, maxi, k ) ) # v[maxi] to v[k]
- # else the approximation is OK, so ignore intermediate vertices
- return keep
+ # else the approximation is OK, so ignore intermediate vertices
+ return keep
- def shortestDistance( self, tline, point):
- try:
- a = self.measure.measureLine( tline[ 1 ], point )
- b = self.measure.measureLine( tline[ 0 ], point)
- c = self.measure.measureLine( tline[ 0 ], tline[ 1 ] )
- if a * b * c == 0.00:
- return 0.00
- x = ( ( a * a + b * b - c * c ) / ( 2.00 * b ) )
- h = math.sqrt( ( a * a ) - ( x * x ) )
- y = ( b - x )
- a3 = ( math.atan( h / x ) )
- if a3 < 0:
- a3 = a3 + math.pi
- elif a3 > math.pi:
- a3 = a3 - math.pi
- a1 = ( math.atan( h / y ) )
- if a1 < 0:
- a1 = a1 + math.pi
- elif a1 > math.pi:
- a1 = a1 - math.pi
- a3 = a3 * ( 180 / math.pi )
- a1 = a1 * (180 / math.pi)
- a2 = ( ( math.pi ) * ( 180 / math.pi ) ) - a1 - a3
- if a3 >= 90.00:
- length = c
- elif a2 >= 90.00:
- length = b
- length = math.sin( a1 ) * b
- return math.fabs( length )
- except:
- return None
+ def shortestDistance( self, tline, point):
+ try:
+ a = self.measure.measureLine( tline[ 1 ], point )
+ b = self.measure.measureLine( tline[ 0 ], point)
+ c = self.measure.measureLine( tline[ 0 ], tline[ 1 ] )
+ if a * b * c == 0.00:
+ return 0.00
+ x = ( ( a * a + b * b - c * c ) / ( 2.00 * b ) )
+ h = math.sqrt( ( a * a ) - ( x * x ) )
+ y = ( b - x )
+ a3 = ( math.atan( h / x ) )
+ if a3 < 0:
+ a3 = a3 + math.pi
+ elif a3 > math.pi:
+ a3 = a3 - math.pi
+ a1 = ( math.atan( h / y ) )
+ if a1 < 0:
+ a1 = a1 + math.pi
+ elif a1 > math.pi:
+ a1 = a1 - math.pi
+ a3 = a3 * ( 180 / math.pi )
+ a1 = a1 * (180 / math.pi)
+ a2 = ( ( math.pi ) * ( 180 / math.pi ) ) - a1 - a3
+ if a3 >= 90.00:
+ length = c
+ elif a2 >= 90.00:
+ length = b
+ length = math.sin( a1 ) * b
+ return math.fabs( length )
+ except:
+ return None
- def simpleMeasure( self, inGeom ):
- if inGeom.wkbType() == QGis.WKBPoint:
- pt = QgsPoint()
- pt = inGeom.asPoint()
- attr1 = pt.x()
- attr2 = pt.y()
- else:
- measure = QgsDistanceArea()
- attr1 = measure.measure(inGeom)
- if inGeom.type() == QGis.Polygon:
- attr2 = self.perimMeasure( inGeom, measure )
- else:
- attr2 = attr1
- return ( attr1, attr2 )
+ def simpleMeasure( self, inGeom ):
+ if inGeom.wkbType() == QGis.WKBPoint:
+ pt = QgsPoint()
+ pt = inGeom.asPoint()
+ attr1 = pt.x()
+ attr2 = pt.y()
+ else:
+ measure = QgsDistanceArea()
+ attr1 = measure.measure(inGeom)
+ if inGeom.type() == QGis.Polygon:
+ attr2 = self.perimMeasure( inGeom, measure )
+ else:
+ attr2 = attr1
+ return ( attr1, attr2 )
- def perimMeasure( self, inGeom, measure ):
- value = 0.00
- poly = inGeom.asMultiPolygon()
- for k in poly:
- for j in k:
- value = value + measure.measureLine( j )
- else:
- poly = inGeom.asPolygon()
- for k in poly:
- value = value + measure.measureLine( k )
- return value
+ def perimMeasure( self, inGeom, measure ):
+ value = 0.00
+ poly = inGeom.asMultiPolygon()
+ for k in poly:
+ for j in k:
+ value = value + measure.measureLine( j )
+ else:
+ poly = inGeom.asPolygon()
+ for k in poly:
+ value = value + measure.measureLine( k )
+ return value
- def checkForField( self, L, e ):
- e = QString( e ).toLower()
- fieldRange = range( 0,len( L ) )
- for item in fieldRange:
- if L[ item ].toLower() == e:
- return True, item
- return False, len( L )
+ def checkForField( self, L, e ):
+ e = QString( e ).toLower()
+ fieldRange = range( 0,len( L ) )
+ for item in fieldRange:
+ if L[ item ].toLower() == e:
+ return True, item
+ return False, len( L )
- def checkGeometryFields( self, vlayer ):
- vprovider = vlayer.dataProvider()
- nameList = []
- fieldList = vprovider.fields()
- geomType = vlayer.geometryType()
- for i in fieldList.keys():
- nameList.append( fieldList[ i ].name().toLower() )
- if geomType == QGis.Polygon:
- plp = "Poly"
- ( found, index1 ) = self.checkForField( nameList, "AREA" )
- if not found:
- field = QgsField( "AREA", QVariant.Double, "double", 10, 6, "Polygon area" )
- index1 = len( fieldList.keys() )
- fieldList[ index1 ] = field
- ( found, index2 ) = self.checkForField( nameList, "PERIMETER" )
- if not found:
- field = QgsField( "PERIMETER", QVariant.Double, "double", 10, 6, "Polygon perimeter" )
- index2 = len( fieldList.keys() )
- fieldList[ index2 ] = field
- elif geomType == QGis.Line:
- plp = "Line"
- (found, index1) = self.checkForField(nameList, "LENGTH")
- if not found:
- field = QgsField("LENGTH", QVariant.Double, "double", 10, 6, "Line length")
- index1 = len(fieldList.keys())
- fieldList[index1] = field
- index2 = index1
- else:
- plp = "Point"
- (found, index1) = self.checkForField(nameList, "XCOORD")
- if not found:
- field = QgsField("XCOORD", QVariant.Double, "double", 10, 6, "Point x coordinate")
- (found, index2) = self.checkForField(nameList, "YCOORD")
- if not found:
- field = QgsField("YCOORD", QVariant.Double, "double", 10, 6, "Point y coordinate")
- index2 = len(fieldList.keys())
- fieldList[index2] = field
- return (fieldList, index1, index2)
+ def checkGeometryFields( self, vlayer ):
+ vprovider = vlayer.dataProvider()
+ nameList = []
+ fieldList = vprovider.fields()
+ geomType = vlayer.geometryType()
+ for i in fieldList.keys():
+ nameList.append( fieldList[ i ].name().toLower() )
+ if geomType == QGis.Polygon:
+ plp = "Poly"
+ ( found, index1 ) = self.checkForField( nameList, "AREA" )
+ if not found:
+ field = QgsField( "AREA", QVariant.Double, "double", 10, 6, "Polygon area" )
+ index1 = len( fieldList.keys() )
+ fieldList[ index1 ] = field
+ ( found, index2 ) = self.checkForField( nameList, "PERIMETER" )
+ if not found:
+ field = QgsField( "PERIMETER", QVariant.Double, "double", 10, 6, "Polygon perimeter" )
+ index2 = len( fieldList.keys() )
+ fieldList[ index2 ] = field
+ elif geomType == QGis.Line:
+ plp = "Line"
+ (found, index1) = self.checkForField(nameList, "LENGTH")
+ if not found:
+ field = QgsField("LENGTH", QVariant.Double, "double", 10, 6, "Line length")
+ index1 = len(fieldList.keys())
+ fieldList[index1] = field
+ index2 = index1
+ else:
+ plp = "Point"
+ (found, index1) = self.checkForField(nameList, "XCOORD")
+ if not found:
+ field = QgsField("XCOORD", QVariant.Double, "double", 10, 6, "Point x coordinate")
+ (found, index2) = self.checkForField(nameList, "YCOORD")
+ if not found:
+ field = QgsField("YCOORD", QVariant.Double, "double", 10, 6, "Point y coordinate")
+ index2 = len(fieldList.keys())
+ fieldList[index2] = field
+ return (fieldList, index1, index2)
- def extractAsLine( self, geom ):
- temp_geom = []
- temp_geom.extend(i)
- else:
- temp_geom = multi_geom
- return temp_geom
- else:
- return []
+ def extractAsLine( self, geom ):
+ multi_geom = QgsGeometry()
+ temp_geom = []
+ temp_geom.extend(i)
+ else:
+ temp_geom = multi_geom
+ return temp_geom
+ else:
+ return []
- def extractAsSingle( self, geom ):
- temp_geom = []
- if geom.type() == 0:
- multi_geom = geom.asMultiPoint()
- temp_geom.append( QgsGeometry().fromPoint ( i ) )
- else:
- temp_geom.append( geom )
- elif geom.type() == 1:
- temp_geom.append( QgsGeometry().fromPolyline( i ) )
- else:
- temp_geom.append( QgsGeometry().fromPolygon( i ) )
- else:
- return temp_geom
- def extractAsMulti( self, geom ):
- temp_geom = []
- return geom.asMultiPoint()
- else:
- return [ geom.asPoint() ]
- return geom.asMultiPolyline()
- else:
- return [ geom.asPolyline() ]
- else:
- return geom.asMultiPolygon()
- else:
- return [ geom.asPolygon() ]
+ def extractAsSingle( self, geom ):
+ temp_geom = []
+ if geom.type() == 0:
+ multi_geom = geom.asMultiPoint()
+ temp_geom.append( QgsGeometry().fromPoint ( i ) )
+ else:
+ temp_geom.append( geom )
+ elif geom.type() == 1:
+ temp_geom.append( QgsGeometry().fromPolyline( i ) )
+ else:
+ temp_geom.append( QgsGeometry().fromPolygon( i ) )
+ else:
+ return temp_geom
+ def extractAsMulti( self, geom ):
+ temp_geom = []
+ return geom.asMultiPoint()
+ else:
+ return [ geom.asPoint() ]
+ return geom.asMultiPolyline()
+ else:
+ return [ geom.asPolyline() ]
+ else:
+ return geom.asMultiPolygon()
+ else:
+ return [ geom.asPolygon() ]
- def convertGeometry( self, geom_list, vType ):
- if vType == 0:
- return QgsGeometry().fromMultiPoint(geom_list)
- elif vType == 1:
- return QgsGeometry().fromMultiPolyline(geom_list)
- else:
- return QgsGeometry().fromMultiPolygon(geom_list)
+ def convertGeometry( self, geom_list, vType ):
+ if vType == 0:
+ return QgsGeometry().fromMultiPoint(geom_list)
+ elif vType == 1:
+ return QgsGeometry().fromMultiPolyline(geom_list)
+ else:
+ return QgsGeometry().fromMultiPolygon(geom_list)
