[QGIS Commit] r10524 - in trunk/qgis: . src/app src/core src/ui
svn_qgis at osgeo.org
Sat Apr 11 05:53:39 EDT 2009
Author: timlinux
Date: 2009-04-11 05:53:39 -0400 (Sat, 11 Apr 2009)
New Revision: 10524
Added:
trunk/qgis/TRANSLATORS
trunk/qgis/src/app/qgsabout.cpp
trunk/qgis/src/core/qgsapplication.cpp
trunk/qgis/src/core/qgsapplication.h
trunk/qgis/src/ui/qgsabout.ui
Added tab for translator acknowledgement to about box
Added: trunk/qgis/TRANSLATORS
--- trunk/qgis/TRANSLATORS (rev 0)
+++ trunk/qgis/TRANSLATORS 2009-04-11 09:53:39 UTC (rev 10524)
@@ -0,0 +1,14 @@
+# The following are people who have contributed to QGIS
+# by doing translation work.
+# Please note that this file is parsed by the about box
+# for the sponsors list, so names should be strictly
+# in the format:
+# name|language
+# This list should be sorted by first name. The
+# website entry is optional.
+# ALWAYS USE UTF-8 WHEN WRITING THIS FILE!
+Werner Macho|German
Modified: trunk/qgis/src/app/qgsabout.cpp
--- trunk/qgis/src/app/qgsabout.cpp 2009-04-11 09:44:05 UTC (rev 10523)
+++ trunk/qgis/src/app/qgsabout.cpp 2009-04-11 09:53:39 UTC (rev 10524)
@@ -104,6 +104,7 @@
listBox1->setCurrentRow( 0 );
// read the SPONSORS file and populate the text widget
QFile sponsorFile( QgsApplication::sponsorsFilePath() );
#ifdef QGISDEBUG
@@ -152,6 +153,56 @@
QgsDebugMsg( QString( "sponsorHTML:%1" ).arg( sponsorHTML.toAscii().constData() ) );
QgsDebugMsg( QString( "txtSponsors:%1" ).arg( txtSponsors->toHtml().toAscii().constData() ) );
+ // read the TRANSLATORS file and populate the text widget
+ QFile translatorFile( QgsApplication::translatorsFilePath() );
+#ifdef QGISDEBUG
+ printf( "Reading translators file %s.............................................\n",
+ translatorFile.fileName().toLocal8Bit().constData() );
+#endif
+ if ( translatorFile.open( QIODevice::ReadOnly ) )
+ QString translatorHTML = ""
+ + tr( "<p>The following have contributing to QGIS"
+ " by translating the user interface or documentation</p>" )
+ + "<hr>"
+ "<table width='100%'>"
+ "<tr><th>" + tr( "Name" ) + "</th>"
+ "<th>" + tr( "Language" ) + "</th></tr>";
+ QString website;
+ QTextStream translatorStream( &translatorFile );
+ // Always use UTF-8
+ translatorStream.setCodec( "UTF-8" );
+ QString sline;
+ while ( !translatorStream.atEnd() )
+ sline = translatorStream.readLine(); // line of text excluding '\n'
+ //ignore the line if it starts with a hash....
+ if ( sline.left( 1 ) == "#" ) continue;
+ QStringList myTokens = sline.split( "|", QString::SkipEmptyParts );
+ if ( myTokens.size() > 1 )
+ website = myTokens[1];
+ else
+ website = " ";
+ translatorHTML += "<tr>";
+ translatorHTML += "<td>" + myTokens[0] + "</td><td>" + website + "</td>";
+ // close the row
+ translatorHTML += "</tr>";
+ translatorHTML += "</table>";
+ QString myStyle = QgsApplication::reportStyleSheet();
+ txtTranslators->clear();
+ txtTranslators->document()->setDefaultStyleSheet( myStyle );
+ txtTranslators->setHtml( translatorHTML );
+ QgsDebugMsg( QString( "translatorHTML:%1" ).arg( translatorHTML.toAscii().constData() ) );
+ QgsDebugMsg( QString( "txtTranslators:%1" ).arg( txtTranslators->toHtml().toAscii().constData() ) );
void QgsAbout::setVersion( QString v )
Modified: trunk/qgis/src/core/qgsapplication.cpp
--- trunk/qgis/src/core/qgsapplication.cpp 2009-04-11 09:44:05 UTC (rev 10523)
+++ trunk/qgis/src/core/qgsapplication.cpp 2009-04-11 09:53:39 UTC (rev 10524)
@@ -169,6 +169,14 @@
return mPkgDataPath + QString( "/doc/SPONSORS" );
+ Returns the path to the sponsors file.
+ @note Added in QGIS 1.1
+const QString QgsApplication::translatorsFilePath()
+ return mPkgDataPath + QString( "/doc/TRANSLATORS" );
Returns the path to the developer image directory.
const QString QgsApplication::developerPath()
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h 2009-04-11 09:44:05 UTC (rev 10523)
+++ trunk/qgis/src/core/qgsapplication.h 2009-04-11 09:53:39 UTC (rev 10524)
@@ -57,6 +57,12 @@
//! Returns the path to the sponsors file.
static const QString sponsorsFilePath();
+ * Returns the path to the sponsors file.
+ * @note This was added in QGIS 1.1
+ static const QString translatorsFilePath();
//! Returns the path to the developer image directory.
static const QString developerPath();
Modified: trunk/qgis/src/ui/qgsabout.ui
--- trunk/qgis/src/ui/qgsabout.ui 2009-04-11 09:44:05 UTC (rev 10523)
+++ trunk/qgis/src/ui/qgsabout.ui 2009-04-11 09:53:39 UTC (rev 10524)
@@ -204,6 +204,16 @@
</item>
</layout>
</widget>
+ <widget class="QWidget" name="tab_3" >
+ <attribute name="title" >
+ <string>Translators</string>
+ </attribute>
+ <layout class="QGridLayout" >
+ <item row="0" column="0" >
+ <widget class="QTextBrowser" name="txtTranslators" />
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
<item row="1" column="0" >
