[QGIS Commit] r10535 - in trunk/qgis/src: core core/pal core/spatialite plugins/diagram_overlay providers/spatialite
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Apr 11 15:52:01 EDT 2009
Author: jef
Date: 2009-04-11 15:52:01 -0400 (Sat, 11 Apr 2009)
New Revision: 10535
   trunk/qgis/src/core/pal/feature.cpp
   trunk/qgis/src/core/pal/pointset.cpp
   trunk/qgis/src/core/pal/problem.cpp
   trunk/qgis/src/core/pal/rtree.hpp
   trunk/qgis/src/core/pal/util.h
   trunk/qgis/src/core/qgspalobjectpositionmanager.cpp
   trunk/qgis/src/core/spatialite/spatialite.c
   trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
   trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
fix various warnings
Modified: trunk/qgis/src/core/pal/feature.cpp
--- trunk/qgis/src/core/pal/feature.cpp	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/core/pal/feature.cpp	2009-04-11 19:52:01 UTC (rev 10535)
@@ -558,7 +558,7 @@
       int it;
       double dlx, dly; // delta from label center and bottom-left corner
-      double alpha; // rotation for the label
+      double alpha = 0.0; // rotation for the label
       double px, py;
       double dx;
       double dy;
Modified: trunk/qgis/src/core/pal/pointset.cpp
--- trunk/qgis/src/core/pal/pointset.cpp	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/core/pal/pointset.cpp	2009-04-11 19:52:01 UTC (rev 10535)
@@ -347,7 +347,7 @@
       double startX, startY;
       double stopX, stopY;
-      bool seg_complete;
+      bool seg_complete = false;
       Crossing *crossing;
       startX = x[0];
@@ -712,7 +712,8 @@
             b = tmp;
           // split shape into two new shape
-          if (( newShape = shape->extractPath( path_a, nbPtPathA, nbBboxPoint, bbx, bby, b, a, ( b->pt + 1 ) % shape->nbPoints ) ) )
+	  newShape = shape->extractPath( path_a, nbPtPathA, nbBboxPoint, bbx, bby, b, a, ( b->pt + 1 ) % shape->nbPoints );
+          if ( newShape )
             if ( path_a == -1 ) // new shape inside => push into shapes_final
@@ -724,7 +725,8 @@
-          if (( newShape = shape->extractPath( path_b, nbPtPathB, nbBboxPoint, bbx, bby, a, b, ( a->pt + 1 ) % shape->nbPoints ) ) )
+          newShape = shape->extractPath( path_b, nbPtPathB, nbBboxPoint, bbx, bby, a, b, ( a->pt + 1 ) % shape->nbPoints );
+          if ( newShape )
             if ( path_b == -1 )
@@ -1052,7 +1054,7 @@
       // retainedPt = deppest point in hole
       // bestArea = area of triangle HoleS->holeE->retainedPoint
       bestArea = sqrt( bestArea );
-      double cx, cy, dx, dy, ex, ey, fx, fy, seg_length, ptx, pty, fptx = 0, fpty = 0;
+      double cx, cy, dx, dy, ex, ey, fx, fy, seg_length, ptx = 0, pty = 0, fptx = 0, fpty = 0;
       int ps = -1, pe = -1, fps = -1, fpe = -1;
       if ( retainedPt >= 0 && bestArea > labelArea ) // there is a hole so we'll cut the shape in two new shape (only if hole area is bigger than twice labelArea)
Modified: trunk/qgis/src/core/pal/problem.cpp
--- trunk/qgis/src/core/pal/problem.cpp	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/core/pal/problem.cpp	2009-04-11 19:52:01 UTC (rev 10535)
@@ -59,8 +59,8 @@
 #include "util.h"
 #include "priorityqueue.h"
+#define UNUSED(x)	(void)x;
 namespace pal
@@ -720,7 +720,6 @@
   bool subPartCallback( LabelPosition *lp, void *ctx )
-    int lpid = lp->id;
     int *isIn = (( SubPartContext* ) ctx )->isIn;
     LinkedList<int> *queue = (( SubPartContext* ) ctx )->queue;
@@ -1749,7 +1748,7 @@
 #ifdef _DEBUG_FULL_
           std::cout << "catch int " << i << std::endl;
 #else
-          i;
+          UNUSED(i);
 #endif
           while ( conflicts->size() > 0 )
             conflicts->pop_front();
@@ -2053,7 +2052,7 @@
 #ifdef _DEBUG_FULL_
           std::cout << "catch Cycle in chain" << std::endl;
 #else
-          i;
+          UNUSED(i);
 #endif
@@ -2197,7 +2196,8 @@
       seed = ( it % probSize ) + borderSize;
-      if (( current_chain = chain( part, seed ) ) )
+      current_chain = chain( part, seed );
+      if ( current_chain )
         /* we accept a modification only if the seed is not tabu or
Modified: trunk/qgis/src/core/pal/rtree.hpp
--- trunk/qgis/src/core/pal/rtree.hpp	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/core/pal/rtree.hpp	2009-04-11 19:52:01 UTC (rev 10535)
@@ -1355,7 +1355,7 @@
 // Search in an index tree or subtree for all data retangles that overlap the argument rectangle.
     RTREE_TEMPLATE
-    bool RTREE_QUAL::Search (Node* a_node, Rect* a_rect, int& a_foundCount, bool a_resultCallback (DATATYPE a_data, void* a_context), void* a_context) {
+    bool RTREE_QUAL::Search (Node* a_node, Rect* a_rect, int& a_foundCount, bool (*a_resultCallback)(DATATYPE a_data, void* a_context), void* a_context) {
         ASSERT (a_node);
         ASSERT (a_node->m_level >= 0);
         ASSERT (a_rect);
@@ -1374,7 +1374,7 @@
                     DATATYPE& id = a_node->m_branch[index].m_data;
                     // NOTE: There are different ways to return results.  Here's where to modify
-                    if (&a_resultCallback) {
+                    if (a_resultCallback) {
                         ++a_foundCount;
                         if (!a_resultCallback (id, a_context)) {
                             return false; // Don't continue searching
Modified: trunk/qgis/src/core/pal/util.h
--- trunk/qgis/src/core/pal/util.h	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/core/pal/util.h	2009-04-11 19:52:01 UTC (rev 10535)
@@ -157,8 +157,13 @@
           case pal::FOOT:
             return (( x / double( dpi ) )*12 ) * scale;
           case pal::DEGREE:
-            double iw = degree2meter( delta_canvas_width ) * 39.3700787;
-            return ( x * delta_canvas_width * scale ) / ( iw * dpi );
+              double iw = degree2meter( delta_canvas_width ) * 39.3700787;
+              return ( x * delta_canvas_width * scale ) / ( iw * dpi );
+	  default:
+            fprintf( stderr, "Target unit undefined\n" );
+	    return 0.0;
         break;
       case pal::METER:
@@ -169,8 +174,13 @@
           case pal::FOOT:
             return x / 0.3048;
           case pal::DEGREE:
-            double mw = degree2meter( delta_canvas_width );
-            return ( x * delta_canvas_width ) / mw;
+              double mw = degree2meter( delta_canvas_width );
+              return ( x * delta_canvas_width ) / mw;
+	  default:
+	    return 0.0;
         break;
       case pal::FOOT:
@@ -181,27 +191,39 @@
           case pal::METER:
             return x*0.3048;
           case pal::DEGREE:
-            return ( x * delta_canvas_width ) / iw;
+              return ( x * delta_canvas_width ) / iw;
+	  default:
+	    return 0.0;
         break;
       case pal::DEGREE:
         switch ( to )
           case pal::PIXEL:
-            fprintf( stderr, "Degree to pixel not yet implemented" );
+            fprintf( stderr, "Degree to pixel not yet implemented\n" );
             break;
           case pal::METER:
-            fprintf( stderr, "Degree to meter not yet implemented" );
+            fprintf( stderr, "Degree to meter not yet implemented\n" );
             break;
           case pal::FOOT:
-            fprintf( stderr, "Degree to foot not yet implemented" );
+            fprintf( stderr, "Degree to foot not yet implemented\n" );
             break;
+	  default:
+	    return 0.0;
         break;
+      default:
+	fprintf( stderr, "Source unit undefined" );
+	return 0.0;
-    fprintf( stderr, "Unable to convert. Unknown units" );
+    fprintf( stderr, "Unable to convert. Unknown units\n" );
     return 0.0;
Modified: trunk/qgis/src/core/qgspalobjectpositionmanager.cpp
--- trunk/qgis/src/core/qgspalobjectpositionmanager.cpp	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/core/qgspalobjectpositionmanager.cpp	2009-04-11 19:52:01 UTC (rev 10535)
@@ -67,7 +67,6 @@
   //register the labeling objects in the layer
-  QgsVectorOverlay* currentOverlay = 0;
   int objectNr = 0;
   QList<QgsVectorOverlay*>::const_iterator overlayIt = overlays.begin();
   for ( ; overlayIt != overlays.end(); ++overlayIt )
@@ -114,6 +113,8 @@
     case QGis::Degrees:
       mapUnits = pal::DEGREE;
       break;
+    default:
+      return;
   mPositionEngine.setMapUnit( mapUnits );
   std::list<pal::Label*>* resultLabelList = mPositionEngine.labeller( renderContext.rendererScale(), bbox, &stat, true );
Modified: trunk/qgis/src/core/spatialite/spatialite.c
--- trunk/qgis/src/core/spatialite/spatialite.c	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/core/spatialite/spatialite.c	2009-04-11 19:52:01 UTC (rev 10535)
@@ -1502,13 +1502,11 @@
     char utf8buf[65536];
 #if defined(__MINGW32__) || defined(_WIN32)
     const char *pBuf;
-    int len;
-    int utf8len;
 #else /* not MINGW32 - WIN32 */
     char *pBuf;
+#endif
     size_t len;
     size_t utf8len;
-#endif
     char *pUtf8buf;
     iconv_t cvt = iconv_open (toCs, fromCs);
     if (cvt == (iconv_t) - 1)
@@ -1554,13 +1552,11 @@
     char *utf8buf = 0;
     const char *pBuf;
-    int len;
-    int utf8len;
 #else
     char *pBuf;
+#endif
     size_t len;
     size_t utf8len;
-#endif
     int maxlen = buflen * 4;
     char *pUtf8buf;
     *err = 0;
@@ -2727,10 +2723,10 @@
     type = exifImportU16 (blob + offset + 2, endian_mode, endian_arch);
     count = exifImportU32 (blob + offset + 4, endian_mode, endian_arch);
     tag = malloc (sizeof (gaiaExifTag));
-    tag->Gps = gps;
+    tag->Gps = (char) gps;
     tag->TagId = tag_id;
     tag->Type = type;
-    tag->Count = count;
+    tag->Count = (unsigned short) count;
     memcpy (tag->TagOffset, blob + offset + 8, 4);
     tag->ByteValue = NULL;
     tag->StringValue = NULL;
@@ -4228,14 +4224,11 @@
     double y;
     double dist;
     int ind;
-    for (ind = 0; ind < vert; ind++)
+    gaiaGetPoint (coords, 0, &xx1, &yy1);
+    for (ind = 1; ind < vert; ind++)
-	  if (ind == 0)
-		gaiaGetPoint (coords, ind, &xx1, &yy1);
-	  else
 		gaiaGetPoint (coords, ind, &xx2, &yy2);
 		x = xx1 - xx2;
 		y = yy1 - yy2;
@@ -4243,7 +4236,6 @@
 		lung += dist;
 		xx1 = xx2;
 		yy1 = yy2;
     return lung;
@@ -4371,10 +4363,6 @@
 	  if (y > maxy)
 	      maxy = y;
-    if (x < minx || x > maxx)
-	goto end;		/* outside the bounding box (x axis) */
-    if (y < miny || y > maxy)
-	goto end;		/* outside the bounding box (y axis) */
     for (i = 0, j = cnt - 1; i < cnt; j = i++)
 /* The definitive reference is "Point in Polyon Strategies" by
@@ -4383,14 +4371,13 @@
 /  incorrect.
 	  if ((((vert_y[i] <= pt_y) && (pt_y < vert_y[j]))
-	       || ((vert_y[j] <= pt_y) && (y < vert_y[i])))
+	       || ((vert_y[j] <= pt_y) && (pt_y < vert_y[i])))
 	      && (pt_x <
 		  (vert_x[j] - vert_x[i]) * (pt_y - vert_y[i]) / (vert_y[j] -
 								  vert_y[i]) +
 		  vert_x[i]))
 	      isInternal = !isInternal;
-  end:
     free (vert_x);
     free (vert_y);
     return isInternal;
@@ -6277,21 +6264,18 @@
 	  /* checks for points */
 	  return 0;
-	  point = point->Next;
     line = geom->FirstLinestring;
     while (line)
 	  /* checks for linestrings */
 	  return 0;
-	  line = line->Next;
     polyg = geom->FirstPolygon;
     while (polyg)
 	  /* checks for polygons */
 	  return 0;
-	  polyg = polyg->Next;
     return 1;
@@ -9514,8 +9498,8 @@
     *(buf_shp + 2) = 1;
     *(buf_shp + 3) = 1;
     gaiaExport32 (buf_shp + 4, dbf_recno, GAIA_LITTLE_ENDIAN, endian_arch);	/* exports # records in this DBF */
-    gaiaExport16 (buf_shp + 8, dbf_size, GAIA_LITTLE_ENDIAN, endian_arch);	/* exports the file header size */
-    gaiaExport16 (buf_shp + 10, dbf_reclen, GAIA_LITTLE_ENDIAN, endian_arch);	/* exports the record length */
+    gaiaExport16 (buf_shp + 8, (short) dbf_size, GAIA_LITTLE_ENDIAN, endian_arch);	/* exports the file header size */
+    gaiaExport16 (buf_shp + 10, (short) dbf_reclen, GAIA_LITTLE_ENDIAN, endian_arch);	/* exports the record length */
     fwrite (buf_shp, 1, 32, fl_dbf);
@@ -10531,8 +10515,8 @@
     type = gaiaImport32 (blob + 39, little_endian, endian_arch);
     geo = gaiaAllocGeomColl ();
     geo->Srid = gaiaImport32 (blob + 2, little_endian, endian_arch);
-    geo->endian_arch = endian_arch;
-    geo->endian = little_endian;
+    geo->endian_arch = (char) endian_arch;
+    geo->endian = (char) little_endian;
     geo->blob = blob;
     geo->size = size;
     geo->offset = 43;
@@ -10956,8 +10940,8 @@
     type = gaiaImport32 (blob + 1, little_endian, endian_arch);
     geo->Srid = -1;
     geo->blob = blob;
     geo->size = size;
     geo->offset = 5;
@@ -11360,7 +11344,7 @@
 		unsigned int *consumed)
 /* decoding a POLYGON Geometry from FGF  */
-    gaiaPolygonPtr pg;
+    gaiaPolygonPtr pg = NULL;
     gaiaRingPtr rng;
     int rings;
     int ir;
@@ -13638,27 +13622,25 @@
     char buf[256];
     double x;
     double y;
-    double lastX;
-    double lastY;
+    double lastX = 0.0;
+    double lastY = 0.0;
     int iv;
     for (iv = 0; iv < points; iv++)
 	  gaiaGetPoint (coords, iv, &x, &y);
 	  gaiaOutCheckBuffer (buffer, size);
+	  sprintf (buf_x, "%.*f", precision, x - lastX);
+	  gaiaOutClean (buf_x);
+	  sprintf (buf_y, "%.*f", precision, lastY - y);
+	  gaiaOutClean (buf_y);
 	  if (iv == 0)
-		sprintf (buf_x, "%.*f", precision, x);
-		gaiaOutClean (buf_x);
-		sprintf (buf_y, "%.*f", precision, y * -1);
-		gaiaOutClean (buf_y);
 		sprintf (buf, "M %s %s l ", buf_x, buf_y);
 	  else
-		sprintf (buf_x, "%.*f", precision, (x - lastX));
-		sprintf (buf_y, "%.*f", precision, (y - lastY) * -1);
 		sprintf (buf, "%s %s ", buf_x, buf_y);
 	  lastX = x;
@@ -14008,10 +13990,10 @@
     unsigned char *p_blob = NULL;
     int n_bytes = 0;
     int srid;
-    int geom_srid;
+    int geom_srid = -1;
     const unsigned char *type;
     int xtype;
-    int geom_type;
+    int geom_type = -1;
     int ret;
     if (sqlite3_value_type (argv[0]) == SQLITE_BLOB
 	|| sqlite3_value_type (argv[0]) == SQLITE_NULL)
@@ -14752,8 +14734,8 @@
 	  len = strlen ((char *) colname);
 	  curr_idx->ColumnName = malloc (len + 1);
 	  strcpy (curr_idx->ColumnName, (char *) colname);
-	  curr_idx->ValidRtree = index;
-	  curr_idx->ValidCache = cached;
+	  curr_idx->ValidRtree = (char) index;
+	  curr_idx->ValidCache = (char) cached;
 	  curr_idx->Next = NULL;
 	  if (!first_idx)
 	      first_idx = curr_idx;
@@ -21133,8 +21115,10 @@
 	  int_value = sqlite3_value_int (argv[0]);
 	  x = int_value;
-    else
+    else {
 	sqlite3_result_null (context);
+	return;
     tang = tan (x);
     if (tang == 0.0)
@@ -21164,8 +21148,11 @@
 	  x = int_value;
     else
-	sqlite3_result_null (context);
-    x = x * 57.29577951308232;
+	  sqlite3_result_null (context);
+	  return;
+    x *= 57.29577951308232;
     sqlite3_result_double (context, x);
@@ -21267,8 +21254,8 @@
 / or NULL if any error is encountered
     int int_value;
-    double x;
-    double b;
+    double x = 0.0;
+    double b = 1.0;
     double log1;
     double log2;
     errno = 0;
@@ -22373,7 +22360,7 @@
 spatialite_init (int verbose)
 /* used when SQLite initializes SpatiaLite via statically linked lib */
-    sqlite3_auto_extension ((void *) init_static_spatialite);
+    sqlite3_auto_extension ( (void (*)(void)) init_static_spatialite);
     if (verbose)
 	  printf ("SpatiaLite version ..: %s", spatialite_version ());
@@ -22863,9 +22850,7 @@
 math_llabs (sqlite3_int64 value)
 /* replacing the C99 llabs() function */
-    double dbl = value;
-    sqlite3_int64 int_value = fabs (dbl);
-    return (int_value);
+  return value<0 ? -value : value;
 SPATIALITE_DECLARE double
@@ -24403,8 +24388,6 @@
 	  *ppVTab = (sqlite3_vtab *) p_vt;
 	  return SQLITE_OK;
-	  *pzErr = sqlite3_mprintf ("%s", p_vt->Shp->LastError);
-	  return SQLITE_ERROR;
     if (p_vt->Shp->
 	Shape == 3
@@ -25699,7 +25682,7 @@
     int ia;
     int index;
     char code[256];
-    int nodeId;
+    int nodeId = -1;
     int arcs;
     NetworkNodePtr pN;
     NetworkArcPtr pA;
@@ -27968,13 +27951,13 @@
 	  /* parsing the file, one char at each time */
 	  if (c == '\r' && !is_string)
-		last = c;
+		last = (char) c;
 		continue;
 	  if (c == field_separator && !is_string)
 		/* insering a field into the fields tmp array */
-		last = c;
+		last = (char) c;
 		*p = '\0';
 		len = strlen (buffer);
 		if (len)
@@ -27993,7 +27976,7 @@
 		if (is_string)
 		      is_string = 0;
-		      last = c;
+		      last = (char) c;
 		else
@@ -28003,7 +27986,7 @@
 		continue;
-	  last = c;
+	  last = (char) c;
 	  if (c == '\n' && !is_string)
 		/* inserting the row into the text buffer */
@@ -28032,7 +28015,7 @@
 		fld = 0;
 		continue;
-	  *p++ = c;
+	  *p++ = (char) c;
     fclose (in);
 /* checking if the text file really seems to contain a table */
@@ -28207,7 +28190,7 @@
 	  return NULL;
 /* ok, we can now go to prepare the rows array */
-    text->rows = malloc (sizeof (struct text_row *) * text->n_rows);
+    text->rows = malloc (sizeof (struct row_buffer *) * text->n_rows);
     ir = 0;
     row = text->first;
     while (row)
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
--- trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp	2009-04-11 19:52:01 UTC (rev 10535)
@@ -86,8 +86,6 @@
       std::list<unsigned char*>::iterator bufferIt;
       std::list<int>::iterator sizeIt;
-      int multifeaturecounter = 0;
       while ( theProvider->nextFeature( currentFeature ) )
         //todo: insert more objects for multipart features
@@ -195,7 +193,7 @@
   for ( int i = 0; i < classificationFieldList.size(); ++i )
     bool conversionSuccess = false;
-    int classificationField = classificationFieldList.at( i ).toElement().text().toInt( &conversionSuccess );
+    classificationFieldList.at( i ).toElement().text().toInt( &conversionSuccess );
     if ( conversionSuccess )
       classAttrList.push_back( classificationFieldList.at( i ).toElement().text().toInt() );
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2009-04-11 19:41:20 UTC (rev 10534)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2009-04-11 19:52:01 UTC (rev 10535)
@@ -42,7 +42,7 @@
 QMap < QString, QgsSpatiaLiteProvider::SqliteHandles * >QgsSpatiaLiteProvider::SqliteHandles::handles;
 QgsSpatiaLiteProvider::QgsSpatiaLiteProvider( QString const &uri ): QgsVectorDataProvider( uri ),
-    geomType( QGis::WKBUnknown ), mSrid( -1 ), spatialIndexRTree( false ), spatialIndexMbrCache( false ), sqliteHandle( NULL ), sqliteStatement( NULL )
+    geomType( QGis::WKBUnknown ), mSrid( -1 ), spatialIndexRTree( false ), sqliteHandle( NULL ), spatialIndexMbrCache( false ), sqliteStatement( NULL )
   QgsDataSourceURI mUri = QgsDataSourceURI( uri );
@@ -346,7 +346,6 @@
 bool QgsSpatiaLiteProvider::nextFeature( QgsFeature & feature )
-  char xSql[1024];
   char geomName[128];
   feature.setValid( false );
More information about the QGIS-commit mailing list
