[QGIS Commit] r10575 - trunk/qgis/src/app
svn_qgis at osgeo.org
Wed Apr 15 23:48:47 EDT 2009
Author: gsherman
Date: 2009-04-15 23:48:46 -0400 (Wed, 15 Apr 2009)
New Revision: 10575
trunk/qgis/src/app/qgsattributeactiondialog.cpp
Added warning when attempting to create an attribute action without
specifying both a name and and the action to perform. Fixes bug #1596
Modified: trunk/qgis/src/app/qgsattributeactiondialog.cpp
--- trunk/qgis/src/app/qgsattributeactiondialog.cpp 2009-04-15 23:53:30 UTC (rev 10574)
+++ trunk/qgis/src/app/qgsattributeactiondialog.cpp 2009-04-16 03:48:46 UTC (rev 10575)
@@ -26,6 +26,7 @@
#include <QFileDialog>
#include <QHeaderView>
+#include <QMessageBox>
QgsAttributeActionDialog::QgsAttributeActionDialog( QgsAttributeAction* actions,
@@ -178,32 +179,45 @@
void QgsAttributeActionDialog::insert( int pos )
- // Get the action details and insert into the table at the given
- // position. Name needs to be unique, so make it so if required.
+ // Check to see if the action name and the action have been specified
+ // before proceeding
- // If the new action name is the same as the action name in the
- // given pos, don't make the new name unique (because we're
- // replacing it).
+ if ( actionName->text().isEmpty() || actionAction->text().isEmpty() )
+ QMessageBox::warning( this, tr( "Missing Information" ),
+ tr( "To create an attribute action, you must provide both a name and the action to perform." ) );
- int numRows = attributeActionTable->rowCount();
- QString name;
- if ( pos < numRows && actionName->text() == attributeActionTable->item( pos, 0 )->text() )
- name = actionName->text();
- else
- name = uniqueName( actionName->text() );
- if ( pos >= numRows )
- // Expand the table to have a row with index pos
- insertRow( pos, name, actionAction->text(), captureCB->isChecked() );
else
- // Update existing row
- attributeActionTable->item( pos, 0 )->setText( name );
- attributeActionTable->item( pos, 1 )->setText( actionAction->text() );
- attributeActionTable->item( pos, 2 )->setCheckState(
- captureCB->isChecked() ? Qt::Checked : Qt::Unchecked );
+ // Get the action details and insert into the table at the given
+ // position. Name needs to be unique, so make it so if required.
+ // If the new action name is the same as the action name in the
+ // given pos, don't make the new name unique (because we're
+ // replacing it).
+ int numRows = attributeActionTable->rowCount();
+ QString name;
+ if ( pos < numRows && actionName->text() == attributeActionTable->item( pos, 0 )->text() )
+ name = actionName->text();
+ else
+ name = uniqueName( actionName->text() );
+ if ( pos >= numRows )
+ // Expand the table to have a row with index pos
+ insertRow( pos, name, actionAction->text(), captureCB->isChecked() );
+ else
+ // Update existing row
+ attributeActionTable->item( pos, 0 )->setText( name );
+ attributeActionTable->item( pos, 1 )->setText( actionAction->text() );
+ attributeActionTable->item( pos, 2 )->setCheckState(
+ captureCB->isChecked() ? Qt::Checked : Qt::Unchecked );
