[QGIS Commit] r10578 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Thu Apr 16 15:58:26 EDT 2009
Author: jef
Date: 2009-04-16 15:58:26 -0400 (Thu, 16 Apr 2009)
New Revision: 10578
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
handle broken postgis installations more traceful
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-04-16 15:18:15 UTC (rev 10577)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-04-16 19:58:26 UTC (rev 10578)
@@ -310,6 +310,17 @@
QgsDebugMsg( "Connection to the database was successful" );
Conn *conn = new Conn( pd );
+ /* Check to see if we have working PostGIS support */
+ if ( conn->postgisVersion().isNull() )
+ showMessageBox( tr( "No PostGIS Support!" ),
+ tr( "Your database has no working PostGIS support.\n") );
+ conn->PQfinish();
+ delete conn;
+ return NULL;
connections.insert( conninfo, conn );
/* Check to see if we have GEOS support and if not, warn the user about
@@ -1732,6 +1743,12 @@
QString QgsPostgresProvider::Conn::postgisVersion()
Result result = PQexec( "select postgis_version()" );
+ if( PQntuples( result ) != 1 )
+ QgsDebugMsg( "Retrieval of postgis version failed" );
+ return QString::null;
postgisVersionInfo = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
QgsDebugMsg( "PostGIS version info: " + postgisVersionInfo );
@@ -1740,6 +1757,11 @@
// Get major and minor version
QStringList postgisVersionParts = postgisParts[0].split( ".", QString::SkipEmptyParts );
+ if( postgisVersionParts.size() < 2 )
+ QgsDebugMsg( "Could not parse postgis version" );
postgisVersionMajor = postgisVersionParts[0].toInt();
postgisVersionMinor = postgisVersionParts[1].toInt();
