[QGIS Commit] r10599 - branches/Version-1_0/src/core
svn_qgis at osgeo.org
Sun Apr 19 06:33:52 EDT 2009
Author: jef
Date: 2009-04-19 06:33:52 -0400 (Sun, 19 Apr 2009)
New Revision: 10599
branches/Version-1_0/src/core/qgsrunprocess.cpp
merge r10533 to version 1.0
Modified: branches/Version-1_0/src/core/qgsrunprocess.cpp
--- branches/Version-1_0/src/core/qgsrunprocess.cpp 2009-04-19 10:30:28 UTC (rev 10598)
+++ branches/Version-1_0/src/core/qgsrunprocess.cpp 2009-04-19 10:33:52 UTC (rev 10599)
@@ -47,9 +47,6 @@
// inside the capture if() statement.
connect( mProcess, SIGNAL( finished( int, QProcess::ExitStatus ) ), this, SLOT( processExit( int, QProcess::ExitStatus ) ) );
- // start the process!
- mProcess->start( action );
// Use QgsMessageOutput for displaying output to user
// It will delete itself when the dialog box is closed.
mOutput = QgsMessageOutput::createMessageOutput();
@@ -64,6 +61,9 @@
connect( mOutputObj, SIGNAL( destroyed() ), this, SLOT( dialogGone() ) );
+ // start the process!
+ mProcess->start( action );
else
@@ -134,6 +134,8 @@
// class being called after it has been deleted (Qt seems not to be
// disconnecting them itself)
+ mOutput = 0;
disconnect( mProcess, SIGNAL( error( QProcess::ProcessError ) ), this, SLOT( processError( QProcess::ProcessError ) ) );
disconnect( mProcess, SIGNAL( readyReadStandardOutput() ), this, SLOT( stdoutAvailable() ) );
disconnect( mProcess, SIGNAL( readyReadStandardError() ), this, SLOT( stderrAvailable() ) );
@@ -146,7 +148,7 @@
if ( err == QProcess::FailedToStart )
- QgsMessageOutput* output = QgsMessageOutput::createMessageOutput();
+ QgsMessageOutput* output = mOutput ? mOutput : QgsMessageOutput::createMessageOutput();
output->setMessage( tr( "Unable to run command" ) + mCommand, QgsMessageOutput::MessageText );
// Didn't work, so no need to hang around
die();
