[QGIS Commit] r10618 - trunk/qgis/i18n
svn_qgis at osgeo.org
Wed Apr 22 07:23:38 EDT 2009
Author: borysiasty
Date: 2009-04-22 07:23:38 -0400 (Wed, 22 Apr 2009)
New Revision: 10618
trunk/qgis/i18n/qgis_pl_PL.ts
Polish translation update
Modified: trunk/qgis/i18n/qgis_pl_PL.ts
--- trunk/qgis/i18n/qgis_pl_PL.ts 2009-04-22 08:37:17 UTC (rev 10617)
+++ trunk/qgis/i18n/qgis_pl_PL.ts 2009-04-22 11:23:38 UTC (rev 10618)
@@ -143,7 +143,7 @@
</message>
<message>
<source>Coordinate in your selected CRS</source>
- <translation>Współrzędne w wybranym układzie</translation>
+ <translation>Współrzędne w wybranym układzie współrzędnych</translation>
</message>
<message>
<source>Coordinate in map canvas coordinate reference system</source>
@@ -252,22 +252,25 @@
</message>
<message>
<source>fTools About</source>
- <translation type="unfinished"></translation>
+ <translation>O fTools</translation>
</message>
<message>
<source>fTools</source>
+ <translation>fTools</translation>
</message>
<message>
<source>Version x.x-xxxxxx</source>
+ <translation>Wersja x.x-xxxxxx</translation>
</message>
<message>
<source><html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
</style></head><body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal;">
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p></body></html></source>
+ <translation><html><head><meta name="qrichtext" content="1" /><style type="text/css">
+p, li { white-space: pre-wrap; }
+</style></head><body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal;">
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p></body></html></translation>
</message>
<message>
<source>Help</source>
@@ -275,7 +278,7 @@
</message>
<message>
<source>Web</source>
+ <translation>Sieć</translation>
</message>
<message>
<source>Close</source>
@@ -283,11 +286,11 @@
</message>
<message>
<source>Extract Nodes</source>
+ <translation>Wydobądź węzły</translation>
</message>
<message>
<source>Input line or polygon vector layer</source>
+ <translation>Wejściowa linia lub poligon warstwy wektorowej</translation>
</message>
<message>
<source>Tolerance</source>
@@ -295,15 +298,15 @@
</message>
<message>
<source>Unique ID field</source>
+ <translation>Kolumna z unikalnym ID</translation>
</message>
<message>
<source>Output point shapefile</source>
+ <translation>Wyjściowy shapefile (punkty)</translation>
</message>
<message>
<source>Geoprocessing</source>
+ <translation>Geoprocesing</translation>
</message>
<message>
<source>Input vector layer</source>
@@ -311,15 +314,15 @@
</message>
<message>
<source>Intersect layer</source>
+ <translation type="unfinished">Warstwa iloczynu</translation>
</message>
<message>
<source>Buffer distance</source>
+ <translation>Wielkość bufora</translation>
</message>
<message>
<source>Buffer distance field</source>
+ <translation type="unfinished">Pole wielkości bufora</translation>
</message>
<message>
<source>Dissolve field</source>
@@ -331,19 +334,19 @@
</message>
<message>
<source>Output shapefile</source>
+ <translation>Wyjściowy shapefile</translation>
</message>
<message>
<source>Locate Line Intersections</source>
+ <translation type="unfinished">Znajdź przecięcia linii</translation>
</message>
<message>
<source>Input line layer</source>
+ <translation type="unfinished">Wejściowa warstwa wektorowa (linia)</translation>
</message>
<message>
<source>Input unique ID field</source>
+ <translation>Pole z unikalnym ID</translation>
</message>
<message>
<source>Intersect line layer</source>
@@ -355,115 +358,115 @@
</message>
<message>
<source>Output Shapefile</source>
</message>
<message>
<source>Join Attributes</source>
+ <translation type="unfinished">Atrybuty join</translation>
</message>
<message>
<source>Target vector layer</source>
+ <translation>Docelowa warstwa wektorowa</translation>
</message>
<message>
<source>Target join field</source>
+ <translation type="unfinished">Docelowe pole join</translation>
</message>
<message>
<source>Join data</source>
+ <translation type="unfinished">Dane join</translation>
</message>
<message>
<source>Join vector layer</source>
+ <translation type="unfinished">Warstwa wektorowa join</translation>
</message>
<message>
<source>Join dbf table</source>
+ <translation type="unfinished">Tabela dbf join</translation>
</message>
<message>
<source>Join field</source>
+ <translation type="unfinished">Pole join</translation>
</message>
<message>
<source>Output table</source>
+ <translation>Tabela wyjściowa</translation>
</message>
<message>
<source>Only keep matching records</source>
+ <translation>Zachowaj tylko pasujące rekordy</translation>
</message>
<message>
<source>Keep all records (includeing non-matching target records)</source>
+ <translation>Zachowaj wszystkie rekordy (wraz z niepasującymi)</translation>
</message>
<message>
<source>Generate Centroids</source>
+ <translation type="unfinished">Generuj centroidy</translation>
</message>
<message>
<source>Weight field</source>
+ <translation type="unfinished">Pole wagi</translation>
</message>
<message>
<source>Number of standard deviations</source>
+ <translation>Liczba odchyleń standardowych</translation>
</message>
<message>
<source>Std. Dev.</source>
+ <translation>Odchyl. Stand.</translation>
</message>
<message>
<source>Create Distance Matrix</source>
+ <translation type="unfinished">Stwórz macierz odległości</translation>
</message>
<message>
<source>Input point layer</source>
+ <translation type="unfinished">Wejściowa warstwa (punkty)</translation>
</message>
<message>
<source>Target point layer</source>
+ <translation type="unfinished">Warstwa docelowa (punkty)</translation>
</message>
<message>
<source>Target unique ID field</source>
+ <translation type="unfinished">Docelowe pole z unikalnym ID</translation>
</message>
<message>
<source>Output matrix type</source>
+ <translation type="unfinished">Typ macierzy wyjściowej</translation>
</message>
<message>
<source>Linear (N*k x 3) distance matrix</source>
+ <translation type="unfinished">Liniowa (N*k x 3) macierz odległości</translation>
</message>
<message>
<source>Standard (N x T) distance matrix</source>
+ <translation type="unfinished">Standardowa (N x T) macierz odległości</translation>
</message>
<message>
<source>Summary distance matrix (mean, std. dev., min, max)</source>
+ <translation type="unfinished">Zbiorcza macierz odległości (średnia, odchyl. stand., min., max.)</translation>
</message>
<message>
<source>Use only the nearest (k) target points:</source>
+ <translation type="unfinished">Użyj tylko (k) najbliższe punkty docelowe:</translation>
</message>
<message>
<source>Output distance matrix</source>
+ <translation type="unfinished">Wyjściowa macierz odległości</translation>
</message>
<message>
<source>Count Points In Polygons</source>
+ <translation type="unfinished">Policz punkty w poligonach</translation>
</message>
<message>
<source>Input polygon vector layer</source>
+ <translation type="unfinished">Wejściowa warstwa wektorowa (poligon)</translation>
</message>
<message>
<source>Input point vector layer</source>
+ <translation type="unfinished">Wejściowa warstwa wektorowa (punkt)</translation>
</message>
<message>
<source>Output count field name</source>
@@ -471,63 +474,63 @@
</message>
<message>
<source>PNTCNT</source>
+ <translation type="unfinished">PNTCNT</translation>
</message>
<message>
<source>Generate Random Points</source>
+ <translation>Generuj losowe punkty</translation>
</message>
<message>
<source>Input Boundary Layer</source>
+ <translation>Wejściowa warstwa granic</translation>
</message>
<message>
<source>Minimum distance between points</source>
+ <translation>Minimalna odległość pomiędzy punktami</translation>
</message>
<message>
<source>Sample Size</source>
+ <translation>Rozmiar próbki</translation>
</message>
<message>
<source>Unstratified Sampling Design (Entire layer)</source>
+ <translation>Proste próbkowanie (cała warstwa)</translation>
</message>
<message>
<source>Use this number of points</source>
+ <translation>Użyj tej liczby punktów</translation>
</message>
<message>
<source>Stratified Sampling Design (Individual polygons)</source>
+ <translation>Szczegółowe próbkowanie (poszczególne poligony)</translation>
</message>
<message>
<source>Use this density of points</source>
+ <translation>Użyj tej gęstości punktów</translation>
</message>
<message>
<source>Use value from input field</source>
+ <translation>Użyj wartości z pola wejściowego</translation>
</message>
<message>
<source>Random Selection Tool</source>
+ <translation>Narzędzie losowego wyboru</translation>
</message>
<message>
<source>Input Vector Layer</source>
+ <translation>Wejściowa warstwa wektorowa</translation>
</message>
<message>
<source>Randomly Select</source>
+ <translation>Wybierz losowo</translation>
</message>
<message>
<source>Number of Features</source>
+ <translation>Liczba obiektów</translation>
</message>
<message>
<source>Percentage of Features</source>
+ <translation>Procent obiektów</translation>
</message>
<message>
<source>%</source>
@@ -535,67 +538,67 @@
</message>
<message>
<source>Projection Management Tool</source>
+ <translation type="unfinished">Zarządzanie odwzorowaniami</translation>
</message>
<message>
<source>Input spatial reference system</source>
+ <translation type="unfinished">Wejściowy układ współrzędnych</translation>
</message>
<message>
<source>Output spatial reference system</source>
+ <translation type="unfinished">Wyjściowy układ współrzędnych</translation>
</message>
<message>
<source>Use predefined spatial reference system</source>
+ <translation type="unfinished">Wykorzystaj predefiniowany układ współrzędnych </translation>
</message>
<message>
<source>Choose</source>
+ <translation>Wybierz</translation>
</message>
<message>
<source>Import spatial reference system from existing layer</source>
+ <translation type="unfinished">Importuj układ współrzędnych z istniejącej warstwy</translation>
</message>
<message>
<source>Import spatial reference system:</source>
+ <translation type="unfinished">Importuj układ współrzędnych:</translation>
</message>
<message>
<source>Generate Regular Points</source>
+ <translation type="unfinished">Generuj regularne punkty</translation>
</message>
<message>
<source>Input Coordinates</source>
+ <translation type="unfinished">Podaj współrzędne</translation>
</message>
<message>
<source>X Min</source>
+ <translation>X Min</translation>
</message>
<message>
<source>Y Min</source>
+ <translation>Y Min</translation>
</message>
<message>
<source>X Max</source>
+ <translation>X Max</translation>
</message>
<message>
<source>Y Max</source>
+ <translation>Y Max</translation>
</message>
<message>
<source>Grid Spacing</source>
+ <translation>Skok siatki</translation>
</message>
<message>
<source>Use this point spacing</source>
+ <translation>Użyj tego wyrówniania punktów</translation>
</message>
<message>
<source>Apply random offset to point spacing</source>
+ <translation>Zastosuj losowe wyrównanie punktów</translation>
</message>
<message>
<source>Initial inset from corner (LH side)</source>
@@ -603,19 +606,19 @@
</message>
<message>
<source>Spatial Join</source>
+ <translation type="unfinished">Przestrzenne join</translation>
</message>
<message>
<source>Attribute Summary</source>
+ <translation>Podsumowanie atrybutów</translation>
</message>
<message>
<source>Take attributes of first located feature</source>
+ <translation>Pobierz atrybuty z pierwszego obiektu</translation>
</message>
<message>
<source>Take summary of intersecting features</source>
+ <translation>Pobierz podsumowanie przecinających się obiektów</translation>
</message>
<message>
<source>Mean</source>
@@ -635,7 +638,7 @@
</message>
<message>
<source>Output Shapefile:</source>
+ <translation>Wyjściowy Shapefile:</translation>
</message>
<message>
<source>Random Selection From Within Subsets</source>
@@ -647,31 +650,31 @@
</message>
<message>
<source>Sum Line Length In Polygons</source>
+ <translation>Zsumuj długości linii w poligonach</translation>
</message>
<message>
<source>Output summed length field name</source>
+ <translation type="unfinished">Pole wyjściowej sumarycznej długości</translation>
</message>
<message>
<source>LENGTH</source>
+ <translation type="unfinished">DŁUGOŚĆ</translation>
</message>
<message>
<source>Input line vector layer</source>
+ <translation type="unfinished">Wejściowa warstwa wektorowa (linie)</translation>
</message>
<message>
<source>Grid extent</source>
+ <translation>Zasięg siatki</translation>
</message>
<message>
<source>Update extents from layer</source>
+ <translation>Aktualizuj zasięg z warstwy</translation>
</message>
<message>
<source>Update extents from canvas</source>
+ <translation>Aktualizuj zasięg z obszaru mapy</translation>
</message>
<message>
<source>Parameters</source>
@@ -683,7 +686,7 @@
</message>
<message>
<source>Lock 1:1 ratio</source>
+ <translation type="unfinished">Blokuj proporcje 1:1</translation>
</message>
<message>
<source>Y</source>
@@ -691,66 +694,66 @@
</message>
<message>
<source>Output grid as polygons</source>
+ <translation>Wyjściowa siatka jako poligony</translation>
</message>
<message>
<source>Output grid as lines</source>
+ <translation>Wyjściowa siatka jako linie</translation>
</message>
<message>
<source>Vector Split</source>
+ <translation type="unfinished">Podział wektora</translation>
</message>
<message>
<source>Output folder</source>
+ <translation>Kartoteka wyjściowa</translation>
</message>
<message>
<source>List Unique Values</source>
+ <translation>Wyświel unikalne wartości</translation>
</message>
<message>
<source>Target field</source>
+ <translation>Docelowe pole</translation>
</message>
<message>
<source>Unique values list</source>
+ <translation>Lista unikalnych wartości</translation>
</message>
<message>
<source>Unique value count</source>
+ <translation>Liczba unikalnych wartości</translation>
</message>
</context>
<context>
<name>GeometryDialog</name>
<message>
<source>Merge all</source>
+ <translation>Połącz wszystko</translation>
</message>
<message>
<source>Please specify input vector layer</source>
+ <translation>Podaj wejściową warstwę wektorową</translation>
</message>
<message>
<source>Please specify output shapefile</source>
+ <translation>Podaj wyjściowy shapefile</translation>
</message>
<message>
<source>Please specify valid tolerance value</source>
+ <translation>Podaj prawidłowy zakres tolerancji</translation>
</message>
<message>
<source>Please specify valid UID field</source>
+ <translation>Podaj prawidłowe pole UID</translation>
</message>
<message>
<source>Created output shapefile</source>
+ <translation>Stwórz wyjściowy shapefile</translation>
</message>
<message>
<source>Would you like to add the new layer to the TOC?</source>
+ <translation>Czy chesz dodać wynikową warstwę do mapy?</translation>
</message>
<message>
<source>Singleparts to multipart</source>
@@ -758,7 +761,7 @@
</message>
<message>
</message>
<message>
<source>Multipart to singleparts</source>
@@ -766,19 +769,19 @@
</message>
<message>
<source>Extract nodes</source>
</message>
<message>
<source>Polygons to lines</source>
+ <translation>Poligony na linie</translation>
</message>
<message>
+ <translation>Wejściowa warstwa wektorowa (poligony)</translation>
</message>
<message>
<source>Export/Add geometry columns</source>
+ <translation>Eksportuj/dodaj kolumnę geometrii</translation>
</message>
<message>
@@ -786,35 +789,35 @@
</message>
<message>
<source>Simplify geometries</source>
+ <translation>Uprość geometrię</translation>
</message>
<message>
<source>Polygon centroids</source>
+ <translation>Centroidy poligonów</translation>
</message>
<message>
</message>
<message>
<source>Error processing specified tolerance!</source>
+ <translation>Błąd przy przetwarzaniu zadanej tolerancji!</translation>
</message>
<message>
<source>Please choose larger tolerance...</source>
+ <translation>Wybierz proszę większą tolerancję...</translation>
</message>
<message>
<source>Function not found</source>
+ <translation>Nie znaleziono funkcji</translation>
</message>
<message>
<source>Error writing output shapefile</source>
+ <translation>Błąd zapisu do wyjściowego shapefile</translation>
</message>
<message>
<source>Unable to delete existing layer...</source>
+ <translation>Nie można usunąć istniejącej warstwy...</translation>
</message>
</context>
<context>
@@ -825,15 +828,15 @@
</message>
<message>
<source>Please specify an input layer</source>
+ <translation>Podaj warstwę wejściową</translation>
</message>
<message>
<source>Please specify a difference/intersect/union layer</source>
+ <translation>Podaj warstwę różnicy/iloczynu/sumy</translation>
</message>
<message>
<source>Please specify valid buffer value</source>
+ <translation>Podaj poprawną wartość bufora</translation>
</message>
<message>
<source>Please specify dissolve field</source>
@@ -841,35 +844,35 @@
</message>
<message>
+ <translation>Podaj wyjściowy plik shapefile</translation>
</message>
<message>
<source>Unable to create geoprocessing result.</source>
+ <translation>Nie można utworzyć wyniku geoprocesingu.</translation>
</message>
<message>
+ <translation>Twórz wyjściowy shapefile</translation>
</message>
<message>
</message>
<message>
<source>Buffer(s)</source>
+ <translation>Bufor(y)</translation>
</message>
<message>
<source>Create single minimum convex hull</source>
+ <translation type="unfinished">Twórz pojedynczą minimalną otoczkę wypukłą</translation>
</message>
<message>
<source>Create convex hulls based on input field</source>
+ <translation type="unfinished">Twórz otoczki wypukłe na bazie danych z pól</translation>
</message>
<message>
<source>Convex hull(s)</source>
+ <translation type="unfinished">Otoczka(i) wypukła(e)</translation>
</message>
<message>
<source>Dissolve</source>
@@ -877,7 +880,7 @@
</message>
<message>
<source>Erase layer</source>
+ <translation>Wyczyść warstwę</translation>
</message>
<message>
<source>Difference</source>
@@ -885,19 +888,19 @@
</message>
<message>
+ <translation>Warstwa iloczynu</translation>
</message>
<message>
<source>Intersect</source>
+ <translation>Iloczyn</translation>
</message>
<message>
<source>Difference layer</source>
+ <translation>Warstwa różnicy</translation>
</message>
<message>
<source>Symetrical difference</source>
+ <translation>Różnica symetryczna</translation>
</message>
<message>
<source>Clip layer</source>
@@ -909,11 +912,11 @@
</message>
<message>
<source>Union layer</source>
+ <translation>Warstwa sumy</translation>
</message>
<message>
<source>Union</source>
+ <translation>Suma</translation>
</message>
</context>
<context>
@@ -1088,7 +1091,7 @@
<name>OracleConnectGuiBase</name>
<message>
<source>Create Oracle Connection</source>
+ <translation>Utwórz połączenie Oracle</translation>
</message>
<message>
<source>OK</source>
@@ -1108,7 +1111,7 @@
</message>
<message>
<source>Database instance</source>
+ <translation>Instancja bazy danych</translation>
</message>
<message>
<source>Username</source>
@@ -1552,7 +1555,7 @@
</message>
<message>
<source>PostgreSQL Geoprocessing</source>
- <translation>PostgreSQL</translation>
+ <translation>PostgreSQL Geoprocesing</translation>
</message>
<message>
<source>Quick Print</source>
@@ -1604,7 +1607,7 @@
</message>
<message>
<source>Capture mouse coordinates in different CRS</source>
- <translation>Przechwyć współrzędne myszy w innym układzie</translation>
+ <translation>Przechwyć współrzędne myszy w innym układzie współrzędnych</translation>
</message>
<message>
<source>Dxf2Shp Converter</source>
@@ -1730,23 +1733,23 @@
</message>
<message>
<source>Georeferencer GDAL</source>
+ <translation>Georeferencer GDAL</translation>
</message>
<message>
<source>Adding projection info to rasters using GDAL</source>
+ <translation>Dodawanie do rastrów informacji o odwzorowaniu używając GDAL</translation>
</message>
<message>
<source>SQLite DB (*.sqlite);;All files (*.*)</source>
+ <translation>SQLite DB (*.sqlite);;Wszystkie pliki (*.*)</translation>
</message>
<message>
<source>Oracle Spatial GeoRaster</source>
+ <translation>Oracle Spatial GeoRaster</translation>
</message>
<message>
<source>Access Oracle Spatial GeoRaster</source>
+ <translation>Dostęp do Oracle Spatial GeoRaster</translation>
</message>
</context>
<context>
@@ -3046,7 +3049,7 @@
</message>
<message>
<source>Delete features</source>
+ <translation>Usuń obiekty</translation>
</message>
<message numerus="yes">
<source>Delete %n feature(s)?</source>
@@ -3059,138 +3062,140 @@
</message>
<message>
<source>Add SpatiaLite Layer...</source>
+ <translation>Dodaj warstwę SpatiaLite...</translation>
</message>
<message>
<source>L</source>
<comment>Add a SpatiaLite Layer</comment>
+ <translation>L</translation>
</message>
<message>
<source>Add a SpatiaLite Layer</source>
+ <translation>Dodaj warstwę SpatiaLite</translation>
</message>
<message>
<source>
This copy of QGIS has been built with SpatiaLite support.</source>
+ <translation>
+Ta wersja QGIS została skompilowana ze wsparciem SpatiaLite.</translation>
</message>
<message>
<source>
This copy of QGIS has been built without SpatiaLite support.</source>
+ <translation>
+Ta wersja QGIS została skompilowana bez wsparcia SpatiaLite.</translation>
</message>
<message>
<source>Zoom Next</source>
+ <translation>Następny widok</translation>
</message>
<message>
<source>Zoom to Forward Extent</source>
+ <translation>Przejdź do następnego widoku</translation>
</message>
<message>
<source>Whats new in Version 1.1.0?</source>
+ <translation>Co nowego w wersji 1.1.0?</translation>
</message>
<message>
<source>Please note that this is a release in our 'unstable' release series. As such it contains new features and extends the programmatic interface over QGIS 1.0.x. If stability and long term support is more important to you than cool new and untested features, we recommend that you use a copy of QGIS from our stable 1.0.x release series.</source>
+ <translation>Zważ, że ta wersja należy do serii 'niestabilnej'. Jako taka zawiera nowe fukcje i rozszerzenia programistyczne w porównaniu do wersji QGIS 1.0.x. Jeśli stabilność i długoterminowe wsparcie - a nie nowości i nieprzetestowane do końca funkcje - są dla Ciebie priorytetem, polecamy użycie stabilnej wersji QGIS 1.0.x.</translation>
</message>
<message>
<source>This release includes many bug fixes and enhancements over the QGIS 1.0.0 release. In addition we have added the following new features:</source>
+ <translation>W tej wersji poprawiono wiele błędów i oraz wprowadzono udoskonalenia w porównaniu do wersji QGIS 1.0.0. Dodaliśmy przy tym następujące fukncje:</translation>
</message>
<message>
<source>Updates to translations.</source>
+ <translation>Aktualizacje tłumaczeń.</translation>
</message>
<message>
<source>Improvements and polishing of the Python plugin installer. Switch to the new official QGIS repository.</source>
+ <translation>Udoskonalenie i ulepszenie instalatora wtyczek. Przejście na nowe, oficjalne repozytorium QGIS.</translation>
</message>
<message>
<source>Improvements to themes so that plugins and other parts of the GUI are better supported when switching themes. Addition of the new GIS icon theme.</source>
+ <translation>Udoskonalenia w obsłudze motywów. Wtyczki i inne elementy GUI lepiej obsługują przełączanie motywów. Dodano też nowy motyw ikon GIS.</translation>
</message>
<message>
<source>Improvements to Debian packaging to better support Debian standard requirements.</source>
+ <translation>Udoskonalenie pakietów Debiana i lepsze wsparcie jego standardów.</translation>
</message>
<message>
<source>Support usb: as a GPS device under Linux.</source>
+ <translation>Obsługa usb: jako urządzenia GPS w Linuksie.</translation>
</message>
<message>
<source>WMS plugin now supports sorting and shows nested layers as a tree. WMS provider also support 24bit png images now. The WMS plugin also now provides a search interface for finding WMS servers.</source>
+ <translation>Wtyczka WMS obsługuje teraz sortowanie i prezenuje warstwy zagnieżdżone w postaci drzewa. Źródło danych WMS obsługuje również 24-bitowe obrazy png. Wtyczka WMS udostępnia też mechanizm wyszukiwania serwerów WMS.</translation>
</message>
<message>
<source>Added svg point symbols from Matt Amos (with his permission).</source>
+ <translation>Dodano symbole punktów SVG (za zgodą autora - Matt Amos).</translation>
</message>
<message>
<source>Improvements to proxy support and support of proxy in WFS provider. The WFS provider now also shows progress information as it is fetching data.</source>
+ <translation>Udoskonalenie obsługi proxy oraz proxy dla WFS. Źródło danych WFS pokazuje teraz również informacje o postępie pozyskiwania danych.</translation>
</message>
<message>
<source>Improvements to PostGIS client support. Massive speedups in PostGIS layer rendering can now be achieved by disabling SSL in the connection editor. Support for usage of ctid column as primary key (softens the requirement for integer primary keys)</source>
+ <translation>Udoskonalenie w działaniu klienta PostGIS. Znaczące przyspieszenie renderowania warstw PostGIS może być teraz osiągnięte przez wyłączenie SSL w edytorze połączeń. Obsługiwane jest użycie kolumny ctid jako klucza głównego (złagodzono wymóg użycia klucza głównego typu całkowitego)</translation>
</message>
<message>
<source>Mapserver Export improvements for continuous color support.</source>
+ <translation>Udoskonalenie obsługi koloru w eksporcie do Mapservera.</translation>
</message>
<message>
<source>Added tools menu - the fTools plugin is now part of the core QGIS plugins and will always be installed by default.</source>
+ <translation>Dodano menu narzędzi - wtyczka fTools jest teraz częścią integralną wtyczek QGIS i będzie domyślnie instalowana.</translation>
</message>
<message>
<source>Improvements to the print composer including object alignment options. It is also now possible to print maps as postcript raster or vector. For python programmers, the composer classes now have python bindings.</source>
+ <translation>Udoskonalenie asystenta wydruku obejmujące opcje wyrównania obiektów. Możliwe jest teraz drukowanie map jako rastrów lub wektorów postscript. Dla potrzeb programowania, klasy asystenta są teraz dostępne z poziomu Pythona.</translation>
</message>
<message>
<source>When using File - Save as image, the saved image is now georeferenced.</source>
+ <translation>Przy zapisie obrazów (Plik - Zapisz jako obraz), zapisywany obraz ma teraz georeferencję.</translation>
</message>
<message>
<source>Projection selector now includes quick selection of recently used CRS's.</source>
+ <translation>Wybór odzworowania zawiera teraz szybki wybór ostatnio używanych układów współrzędnych.</translation>
</message>
<message>
<source>Continuous color renderer supports point symbols now too.</source>
+ <translation>Renderowanie ciągłych kolorów obsługuje teraz również symbole punktowe.</translation>
</message>
<message>
<source>Improved CMake support for building against dependencies from OSGEO4W (Windows only). Addition of an XCode project of developers building under OSX.</source>
+ <translation>Ulepszona obsługa CMake do kompilacji z OSGEO4W (tylko Windows). Dodanie projektu XCode do kompilacji pod OSX.</translation>
</message>
<message>
<source>Updates and cleanups to the GRASS toolbox.</source>
+ <translation>Uaktualnienie i uporządkowanie narzędzi GRASS.</translation>
</message>
<message>
<source>Changes in open vector dialog to support all drivers available in ogr including database and protocol drivers. This brings with it support for SDE, Oracle Spatial, ESRI personal geodatabase and many more OGR supported data stores. Note that in some cases accessing these may require third party libraries to be on your system.</source>
+ <translation>Zmiany w oknie dialogowym otwierania warstw wektorowych w celu wsparcia wszystkich dostępnych sterowników OGR włączając bazy danych i sterowniki protokołów. Obsługa SDE, Oracle Spatial, ERSI personal geodatabase i wielu innych formatów OGR. W niektórych przypadkach może to wymagać bibliotek firm trzecich dostępnych w systemie.</translation>
</message>
<message>
<source>The middle mouse button can now be used for panning. </source>
+ <translation>Środkowy klawisz myszy może być teraz używany do przesuwania widoku.</translation>
</message>
<message>
<source>A new, faster attribute table implementation.</source>
+ <translation>Nowa, szybsza implementacja tabeli atrybutów.</translation>
</message>
<message>
<source>Numerous cleanups to the user interface.</source>
+ <translation>Liczne usprawnienia interfejsu użytkownika.</translation>
</message>
<message>
<source>A new provider was added for spatiallite - a geodatabase-in-a-file implementation based on the SQLITE database.</source>
+ <translation>Dodano nowe źródło danych dla SpatiaLite - plikowej implementacji przestrzennej bazy danych bazującej na SQLite.</translation>
</message>
<message>
<source>Vector overlay support that can draw pie and bar charts over vector layers based on attribute data.</source>
+ <translation>Obsługa nakładanych warstw wektorowych do rysowania wykresów kołowych i słupkowych na podstawie atrybutów.</translation>
</message>
</context>
<context>
@@ -3283,7 +3288,7 @@
</message>
<message>
<source><p>The following have contributed to QGIS by translating the user interface or documentation</p></source>
+ <translation><p>Te osoby przyczyniły się do przetłumaczenia interfejsu użytkownika lub dokumentacji QGIS</p></translation>
</message>
<message>
<source>Language</source>
@@ -3291,7 +3296,7 @@
</message>
<message>
<source>Names</source>
+ <translation>Osoby</translation>
</message>
<message>
<source>Translators</source>
@@ -3329,11 +3334,11 @@
</message>
<message>
<source>Missing Information</source>
+ <translation>Brak informacji</translation>
</message>
<message>
<source>To create an attribute action, you must provide both a name and the action to perform.</source>
+ <translation>Aby utworzyć akcję musisz podać zarówno nazwę jak i akcję do wykonania.</translation>
</message>
</context>
<context>
@@ -4004,11 +4009,11 @@
</message>
<message>
<source>Qt4 svg code. Of note, text does not appear in the SVG file and there are problems with the map bounding box clipping other items such as the legend or scale bar.</p></source>
+ <translation>Kod SVG Qt4. W pliku SVG nie pojawia się tekst oraz występują problemy gdy granica mapy przecina inne obiekty takie jak legenda czy skala.</p></translation>
</message>
<message>
<source>Qt4 svg code. In particular, there are problems with layers not being clipped to the map bounding box.</p></source>
+ <translation>Kod SVG Qt4. W szczególności są problemy z warstwami nie przyciętymi do granic mapy.</p></translation>
</message>
<message>
<source><p>If you require a vector-based output file from Qgis it is suggested that you try printing to PostScript if the SVG output is not satisfactory.</p></source>
@@ -4219,47 +4224,47 @@
</message>
<message>
<source>Align left</source>
+ <translation>Wyrównaj do lewej</translation>
</message>
<message>
<source>Align selected items left</source>
+ <translation>Wyrównaj wybrane obiekty do lewej</translation>
</message>
<message>
<source>Align center</source>
+ <translation>Wyrównaj do środka</translation>
</message>
<message>
<source>Align center horizontal</source>
+ <translation>Wyrównaj do środka w poziomie</translation>
</message>
<message>
<source>Align right</source>
+ <translation>Wyrównaj do prawej</translation>
</message>
<message>
<source>Align selected items right</source>
+ <translation>Wyrównaj wybrane obiekty do prawej</translation>
</message>
<message>
<source>Align top</source>
+ <translation>Wyrównaj do góry</translation>
</message>
<message>
<source>Align selected items to top</source>
+ <translation>Wyrównaj wybrane obiekty do góry</translation>
</message>
<message>
<source>Align center vertical</source>
+ <translation>Wyrównaj do środka w pionie</translation>
</message>
<message>
<source>Align bottom</source>
+ <translation>Wyrównaj do dołu</translation>
</message>
<message>
<source>Align selected items bottom</source>
+ <translation>Wyrównaj wybrane obiekty do dołu</translation>
</message>
</context>
<context>
@@ -4510,11 +4515,11 @@
</message>
<message>
<source>Select new preview directory</source>
+ <translation>Wybierz nową kartotekę do podglądu</translation>
</message>
<message>
<source>Creating icon for file %1</source>
+ <translation>Tworzenie ikony dla pliku %1</translation>
</message>
</context>
<context>
@@ -4541,7 +4546,7 @@
</message>
<message>
<source>Search directories</source>
+ <translation>Szukaj w kartotekach</translation>
</message>
<message>
<source>Add...</source>
@@ -4666,7 +4671,7 @@
</message>
<message>
<source>Box</source>
- <translation>Prostokąt</translation>
+ <translation>Pojemnik</translation>
</message>
<message>
<source>Preview</source>
@@ -4792,11 +4797,11 @@
</message>
<message>
<source>Dots</source>
- <translation type="unfinished">Kropkowany</translation>
+ <translation>Kropkowany</translation>
</message>
<message>
<source>Crosses</source>
+ <translation>Siatkowy</translation>
</message>
</context>
<context>
@@ -8658,11 +8663,11 @@
<name>QgsItemPositionDialogBase</name>
<message>
<source>Set item position</source>
+ <translation>Ustal pozycję obiektu</translation>
</message>
<message>
<source>Item reference point</source>
+ <translation>Punkt odniesienia obiektu</translation>
</message>
<message>
<source>Coordinates</source>
@@ -8678,7 +8683,7 @@
</message>
<message>
<source>Set Position</source>
+ <translation>Ustal pozycję</translation>
</message>
<message>
@@ -9103,7 +9108,7 @@
<name>QgsLinearlyScalingDialog</name>
<message>
<source>Millimeter</source>
+ <translation>Milimetr</translation>
</message>
<message>
<source>Map units</source>
@@ -9118,7 +9123,7 @@
</message>
<message>
<source>Scale linearly between 0 and the following attribute value/ diagram size:</source>
+ <translation>Skaluj liniowo pomiędzy 0 a daną wartością atrybutu/ rozmiarem diagramu:</translation>
</message>
<message>
<source>find maximum Value:</source>
@@ -9827,19 +9832,19 @@
</message>
<message>
<source>prefer</source>
+ <translation>preferuj</translation>
</message>
<message>
<source>require</source>
+ <translation>wymagaj</translation>
</message>
<message>
<source>allow</source>
+ <translation>zezwól</translation>
</message>
<message>
<source>disable</source>
+ <translation>wyłącz</translation>
</message>
</context>
<context>
@@ -10165,7 +10170,7 @@
</message>
<message>
<source>Sub layers list</source>
+ <translation>Lista podwarstw</translation>
</message>
<message>
@@ -10176,7 +10181,14 @@
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';">The layer name is format dependant. Consult the OGR documentation or the documentation of your data format to determine the nature of the included information.</p>
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';"></p>
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';"><span style=" font-weight:600;">Be advised: </span>selecting an already opened layer will not generate an error message and the layer will end up loaded twice!</p></body></html></source>
+</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;">
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';">To jest lista wszystkich warstw dostępnych w źródle danych aktywnej warstwy. Wybierz warstwy do wczytania. Warstwy zostaną wczytane po naciśnięciu "OK".</p>
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';"></p>
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';">Nazwa warstwy jest zależna od formatu. Sprawdź w dokumentacji OGR lub dokumentacji formatu Twoich danych format zawartych danych.</p>
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';"><span style=" font-weight:600;">Ostrożnie: </span>wybierając już otwartą warstwę nie zostanie wyświetlony komunikat o błędzie a warstwa zostanie wczytana dwukrotnie!</p></body></html></translation>
</message>
<message>
<source>1</source>
@@ -10497,31 +10509,31 @@
</message>
<message>
<source>map units</source>
+ <translation>jednostki mapy</translation>
</message>
<message>
<source>pixels</source>
+ <translation>pikseli</translation>
</message>
<message>
<source>Central point (fastest)</source>
+ <translation>Central point (najszybszy)</translation>
</message>
<message>
<source>Chain (fast)</source>
+ <translation>Chain (szybki)</translation>
</message>
<message>
<source>Popmusic tabu chain (slow)</source>
+ <translation>Popmusic tabu chain (wolny)</translation>
</message>
<message>
<source>Popmusic tabu (slow)</source>
+ <translation>Popmusic tabu (wolny)</translation>
</message>
<message>
<source>Popmusic chain (very slow)</source>
+ <translation>Popmusic chain (bardzo wolny)</translation>
</message>
</context>
<context>
@@ -10816,11 +10828,11 @@
</message>
<message>
<source>Enter attribute values</source>
+ <translation>Wprowadź wartość atrybutu</translation>
</message>
<message>
<source>Suppress attributes pop-up windows after each created feature</source>
+ <translation>Nie pytaj o atrybuty po utworzeniu każdego obiektu</translation>
</message>
<message>
<source>Proxy type</source>
@@ -10840,7 +10852,7 @@
</message>
<message>
<source>Overlay</source>
+ <translation>Nakładki</translation>
</message>
<message>
<source>Position</source>
@@ -10863,15 +10875,15 @@
<name>QgsOraclePlugin</name>
<message>
<source>Select GeoRaster</source>
+ <translation>Wybierz GeoRaster</translation>
</message>
<message>
<source>Open a Oracle Spatial GeoRaster</source>
+ <translation>Otwórz Oracle Spatial GeoRaster</translation>
</message>
<message>
<source>&Oracle Spatial</source>
+ <translation>&Oracle Spatial</translation>
</message>
</context>
<context>
@@ -10886,7 +10898,7 @@
</message>
<message>
<source>Password for %1/<password>@%2</source>
+ <translation>Hasło dla %1/<password>@%2</translation>
</message>
<message>
<source>Please enter your password:</source>
@@ -10894,11 +10906,11 @@
</message>
<message>
<source>Open failed</source>
+ <translation>Otwarcie nie powiodło się</translation>
</message>
<message>
<source>The connection to %1 failed. Please verify your connection parameters. Make sure you have the GDAL GeoRaster plugin installed.</source>
+ <translation>Połączenie do %1 nie powiodło się. Zweryfikuj parametry połączenia. Upewnij się, że masz zainstalowaną wtyczkę GDAL GeoRaster.</translation>
</message>
</context>
<context>
@@ -12094,27 +12106,27 @@
</message>
<message>
<source>Select GCPs file</source>
+ <translation>Wybierz plik z punktami referencyjnymi</translation>
</message>
<message>
<source>GCPs points (*.points)</source>
+ <translation>Punkty referencyjne (*.points)</translation>
</message>
<message>
<source>Information</source>
+ <translation>Informacja</translation>
</message>
<message>
<source>GCPs was not loaded.</source>
+ <translation>Nie załadowano punktów referencyjnych.</translation>
</message>
<message>
<source>Error!</source>
+ <translation>Błąd!</translation>
</message>
<message>
<source><p>Modified raster file exists! Overwrite it?</p></source>
+ <translation><p>Zmodyfikowany plik rastrowy istnieje! Nadpisać go?</p></translation>
</message>
<message>
<source>World file exists</source>
@@ -12122,39 +12134,39 @@
</message>
<message>
<source>Polynomial 1</source>
+ <translation>Wielomian 1</translation>
</message>
<message>
<source><p>A Polynomial transform requires changing the raster layer.</p><p>The changed raster will be saved in a new file and a world file will be generated for this new file instead.</p><p>Are you sure that this is what you want?</p></source>
+ <translation><p>Transformacja wielomianowa wymaga modyfikacji warstwy rastrowej.</p><p>Zmieniony raster zostanie zapisany w nowym pliku, do którego zostanie też wygenerowany plik world.</p><p>Czy na pewno chcesz wykonać tę operację?</p></translation>
</message>
<message>
<source>Requires at least 3 points</source>
+ <translation>Wymaga przynajmniej 3 punktów</translation>
</message>
<message>
<source>Polynomial 2</source>
+ <translation>Wielomian 2</translation>
</message>
<message>
<source>Requires at least 6 points</source>
+ <translation>Wymaga przynajmniej 6 punktów</translation>
</message>
<message>
<source>Polynomial 3</source>
+ <translation>Wielomian 3</translation>
</message>
<message>
<source>Requires at least 10 points</source>
+ <translation>Wymaga przynajmniej 10 punktów</translation>
</message>
<message>
<source>Thin plate spline (TPS)</source>
+ <translation>Funkcja cienkiej płytki (TPS)</translation>
</message>
<message>
<source>Failed to compute GCP transform: Transform is not solvable.</source>
+ <translation>Nie można obliczyć transformacji GCP: transformacja jest nierozwiązywalna.</translation>
</message>
<message>
<source>Choose a raster file</source>
@@ -12237,11 +12249,11 @@
</message>
<message>
<source>Save GCPs</source>
+ <translation>Zapisz punkty</translation>
</message>
<message>
<source>Load GCPs</source>
+ <translation>Wczytaj punkty</translation>
</message>
</context>
<context>
@@ -12631,15 +12643,15 @@
</message>
<message>
<source>CRS ID : 100000</source>
+ <translation>ID UW : 100000</translation>
</message>
<message>
<source>CRS ID : 3344</source>
+ <translation>ID UW : 3344</translation>
</message>
<message>
<source>CRS ID : whatever</source>
+ <translation>ID UW : cokolwiek</translation>
</message>
</context>
<context>
@@ -12897,15 +12909,15 @@
</message>
<message>
<source>Retrieving stats for %1</source>
+ <translation>Pobieranie statystyk dla %1</translation>
</message>
<message>
<source>Calculating stats for %1</source>
+ <translation>Obliczanie statystyk dla %1</translation>
</message>
<message>
<source>Retrieving using %1</source>
+ <translation>Pobieranie przy pomocy %1</translation>
</message>
</context>
<context>
@@ -13149,17 +13161,17 @@
<message>
<source><h3>Multiband Image Notes</h3><p>This is a multiband image. You can choose to render it as grayscale or color (RGB). For color images, you can associate bands to colors arbitarily. For example, if you have a seven band landsat image, you may choose to render it as:</p><ul><li>Visible Blue (0.45 to 0.52 microns) - not mapped</li><li>Visible Green (0.52 to 0.60 microns) - not mapped</li></li>Visible Red (0.63 to 0.69 microns) - mapped to red in image</li><li>Near Infrared (0.76 to 0.90 microns) - mapped to green in image</li><li>Mid Infrared (1.55 to 1.75 microns) - not mapped</li><li>Thermal Infrared (10.4 to 12.5 microns) - not mapped</li><li>Mid Infrared (2.08 to 2.35 microns) - mapped to blue in image</li></ul></source>
<comment>COMMENTED OUT</comment>
+ <translation><h3>Uwagi o obrazowaniu multispektralnym</h3><p>To jest obraz multispektralny. Możesz wybrać renderowanie w skali szarości lub w kolorze (RGB). Dla obrazów kolorowych, możesz dowolnie powiązać kanały z kolorami. Mając na przykład siedem kanałów obrazu Landsat możesz zdefiniować renderowanie jako:</p><ul><li>niebieski (0.45 do 0.52 µm) - nie mapowany</li><li>zielony (0.52 do 0.60 µm) - nie mapowane</li></li>czerwony (0.63 do 0.69 µm) - mapowany jako czerwony</li><li>bliska podczerwień (0.76 do 0.90 µm) - mapowany jako zielony</li><li>średnia podczerwień (1.55 do 1.75 µm) - nie mapowana</li><li>podczerwień termalna (10.4 do 12.5 µm) - nie mapowana</li><li>średnia podczerwień (2.08 do 2.35 µm) - mapowana jako niebieski</li></ul></translation>
</message>
<message>
<source><h3>Paletted Image Notes</h3> <p>This image uses a fixed color palette. You can remap these colors in different combinations e.g.</p><ul><li>Red - blue in image</li><li>Green - blue in image</li><li>Blue - green in image</li></ul></source>
+ <translation><h3>Uwagi o palecie obrazu</h3> <p>Ten obraz używa stałej palety kolorów. Możesz przemapować te kolory na inne kombinacje, np.</p><ul><li>czerwony = niebieski na obrazie</li><li>zielony = niebieski na obrazie</li><li>niebieski = zielony na obrazie</li></ul></translation>
</message>
<message>
<source><h3>Grayscale Image Notes</h3> <p>You can remap these grayscale colors to a pseudocolor image using an automatically generated color ramp.</p></source>
+ <translation><h3>Uwagi o skali szarości</h3> <p>Możesz przemapować skalę szarości na obraz w pseudokolorach używając automatycznej procedury.</p></translation>
</message>
<message>
<source>Default R:%1 G:%2 B:%3</source>
@@ -13658,15 +13670,15 @@
<name>QgsSVGDiagramFactoryWidget</name>
<message>
<source>Select svg file</source>
+ <translation>Wybierz plik svg</translation>
</message>
<message>
</message>
<message>
</message>
</context>
<context>
@@ -13677,7 +13689,7 @@
</message>
<message>
</message>
<message>
@@ -13972,7 +13984,7 @@
</message>
<message>
<source>You must select at least one leaf layer first.</source>
+ <translation>Musisz najpierw wybrać co najmniej jedną warstwę podrzędną.</translation>
</message>
<message>
<source>The %1 connection already exists. Do you want to overwrite it?</source>
@@ -14346,7 +14358,9 @@
<source>Failure while connecting to: %1
%2</source>
+ <translation>Błąd przy łączeniu z: %1
+%2</translation>
</message>
</context>
<context>
@@ -14357,7 +14371,7 @@
</message>
<message>
<source>RegExp</source>
- <translation type="unfinished">RegExp</translation>
+ <translation>RegExp</translation>
</message>
<message>
<source>All</source>
@@ -14377,21 +14391,23 @@
</message>
<message>
<source>SpatiaLite DB Open Error</source>
+ <translation>Błąd otwarcia bazy SpatiaLite</translation>
</message>
<message>
%2</source>
+ <translation>Nieudane połączenie z: %1
+%2</translation>
</message>
<message>
<source>seems to be a valid SQLite DB, but not a SpatiaLite's one ...</source>
+ <translation>wydaje się być poprawną bazą SQLite, lecz nie bazą SpatiaLite ...</translation>
</message>
<message>
<source>unknown error cause</source>
+ <translation>nieznana przyczyna błędu</translation>
</message>
<message>
<source> @ </source>
@@ -14399,7 +14415,7 @@
</message>
<message>
<source>Choose a SpatiaLite/SQLite DB to open</source>
+ <translation>Wybierz bazę SpatiaLite/SQLite do otwarcia</translation>
</message>
<message>
<source>Confirm Delete</source>
@@ -14411,17 +14427,19 @@
</message>
<message>
<source>You must select a table in order to add a Layer.</source>
+ <translation>Musisz wybrać tabelę aby dodać warstwę.</translation>
</message>
<message>
<source>SpatiaLite getTableInfo Error</source>
+ <translation>Błąd SpatiaLite getTableInfo</translation>
</message>
<message>
<source>Failure exploring tables from: %1
%2</source>
+ <translation>Nieudane przeglądanie tabel z: %1
+%2</translation>
</message>
<message>
<source>Are you sure you want to remove the %1 connection and all associated settings?</source>
@@ -15074,7 +15092,7 @@
</message>
<message>
<source>Unknown renderer</source>
+ <translation>Nieznany renderer</translation>
</message>
</context>
<context>
@@ -15882,7 +15900,7 @@
<name>SelectGeoRasterBase</name>
<message>
<source>Select Oracle Spatial GeoRaster</source>
+ <translation>Wybierz Oracle Spatial GeoRaster</translation>
</message>
<message>
<source>Server Connections</source>
@@ -15926,7 +15944,7 @@
</message>
<message>
<source>Subdatasets</source>
- <translation type="unfinished">Podzbiory danych</translation>
+ <translation>Podzbiory danych</translation>
</message>
<message>
@@ -15949,79 +15967,79 @@
<name>VisualDialog</name>
<message>
</message>
<message>
<source>Please specify input field</source>
+ <translation>Podaj pole wejściowe</translation>
</message>
<message>
<source>Check geometry validity</source>
+ <translation>Sprawdź poprawność geometrii</translation>
</message>
<message>
<source>Geometry errors</source>
+ <translation>Błędy geometrii</translation>
</message>
<message>
<source>Total encountered errors</source>
+ <translation>Łącznie znalezionych błędów</translation>
</message>
<message>
<source>List unique values</source>
</message>
<message>
<source>Unique values:</source>
+ <translation>Unikalne wartości:</translation>
</message>
<message>
<source>Total unique values:</source>
+ <translation>Łącznie unikalnych wartości:</translation>
</message>
<message>
<source>Basics statistics</source>
+ <translation>Podstawowe statystyki</translation>
</message>
<message>
<source>Statistics output</source>
+ <translation>Wydruk statystyk</translation>
</message>
<message>
<source>Nearest neighbour analysis</source>
+ <translation>Analiza najbliższego sąsiedztwa</translation>
</message>
<message>
<source>Nearest neighbour statistics</source>
+ <translation>Statystyki najbliższego sąsiedztwa</translation>
</message>
<message>
<source>Observed mean distance : </source>
+ <translation>Faktyczna średnia odległość:</translation>
</message>
<message>
<source>Expected mean distance : </source>
+ <translation>Oczekiwana średnia odległość:</translation>
</message>
<message>
<source>Nearest neighbour index : </source>
+ <translation>Wskaźnik najbliższego sąsiedztwa:</translation>
</message>
<message>
<source>Feature %1 contains an unnested hole</source>
+ <translation>Obiekt %1 zawiera niepoprawny pierścień</translation>
</message>
<message>
<source>Feature %1 is not closed</source>
+ <translation>Obiekt %1 nie jest domknięty</translation>
</message>
<message>
<source>Feature %1 is self intersecting</source>
+ <translation>Obiekt %1 zawiera wewnętrzne przecięcia</translation>
</message>
<message>
<source>Feature %1 has incorrect node ordering</source>
+ <translation>Obiekt %1 posiada niepoprawną kolejność węzłów</translation>
</message>
</context>
<context>
@@ -16127,111 +16145,111 @@
<name>fTools</name>
<message>
<source>Quantum GIS version detected: </source>
+ <translation>Wykryta wersję Quantum GIS:</translation>
</message>
<message>
<source>This version of fTools requires at least QGIS version 1.0.0</source>
+ <translation>Ta wersja fTools wymaga przynajmniej QGIS w wersji 1.0.0</translation>
</message>
<message>
<source>Plugin will not be enabled.</source>
+ <translation>Nie można włączyć wtyczki.</translation>
</message>
<message>
<source>&Tools</source>
+ <translation>&Narzędzia</translation>
</message>
<message>
<source>&Analysis Tools</source>
+ <translation>Narzędzia &analizy</translation>
</message>
<message>
<source>Distance matrix</source>
+ <translation>Macierz odległości</translation>
</message>
<message>
<source>Sum line lengths</source>
+ <translation>Łączna długość linii</translation>
</message>
<message>
<source>Points in polygon</source>
+ <translation>Punktów w poligonie</translation>
</message>
<message>
<source>Basic statistics</source>
</message>
<message>
</message>
<message>
</message>
<message>
<source>Mean coordinate(s)</source>
+ <translation>Średnie współrzędne</translation>
</message>
<message>
<source>Line intersections</source>
+ <translation>Przecięcia linii</translation>
</message>
<message>
<source>&Sampling Tools</source>
+ <translation>Narzędzia &próbkowania</translation>
</message>
<message>
<source>Random selection</source>
+ <translation>Losowy wybór</translation>
</message>
<message>
<source>Random selection within subsets</source>
+ <translation>Losowy wybór w podzbiorach</translation>
</message>
<message>
<source>Random points</source>
+ <translation>Losowe punkty</translation>
</message>
<message>
<source>Regular points</source>
+ <translation>Regularne punkty</translation>
</message>
<message>
<source>Vector grid</source>
+ <translation>Siatka wektorowa</translation>
</message>
<message>
<source>Select by location</source>
+ <translation>Wybór przez lokalizację</translation>
</message>
<message>
<source>&Geoprocessing Tools</source>
+ <translation>Narzędzia &geoprocesingu</translation>
</message>
<message>
+ <translation>Otoczka wypukła</translation>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
<source>Clip</source>
+ <translation>Przytnij</translation>
</message>
<message>
@@ -16239,31 +16257,31 @@
</message>
<message>
+ <translation>Różnica</translation>
</message>
<message>
<source>G&eometry Tools</source>
+ <translation>Narzędzia g&eometrii</translation>
</message>
<message>
+ <translation>Eksportuj/dodaj kolumny geometrii</translation>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
@@ -16275,35 +16293,35 @@
</message>
<message>
</message>
<message>
<source>&Data Management Tools</source>
+ <translation type="unfinished">Narzędzia zarządzania &danymi</translation>
</message>
<message>
<source>Export to new projection</source>
+ <translation type="unfinished">Eksportuj do nowego odwzorowania</translation>
</message>
<message>
<source>Define current projection</source>
+ <translation type="unfinished">Zdefiniuj nowe odwzorowanie</translation>
</message>
<message>
<source>Join attributes</source>
</message>
<message>
<source>Join attributes by location</source>
+ <translation type="unfinished">Atrybuty join przez lokalizację</translation>
</message>
<message>
<source>Split vector layer</source>
+ <translation type="unfinished">Podziel warstwę wektorową</translation>
</message>
<message>
<source>About fTools</source>
</message>
</context>
<context>
