[QGIS Commit] r10670 - in docs/trunk/english_us/user_guide: . appendices
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Apr 28 04:17:20 EDT 2009
Author: dassau
Date: 2009-04-28 04:17:19 -0400 (Tue, 28 Apr 2009)
New Revision: 10670
   docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex
   docs/trunk/english_us/user_guide/appendices/supported_data_formats.tex
   docs/trunk/english_us/user_guide/cited_weblinks.bib
   docs/trunk/english_us/user_guide/help_and_support.tex
Updated section 14 Help, Appendix A Supported Formats, Appendix B GRASS Module list,
and Appendix L Literature
Modified: docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex
--- docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex	2009-04-28 07:42:51 UTC (rev 10669)
+++ docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex	2009-04-28 08:17:19 UTC (rev 10670)
@@ -16,9 +16,9 @@
 \begin{table}[ht]
 \centering
-\caption{GRASS Toolbox: Data import modules}\medskip
+\caption{GRASS Toolbox: Raster and Image data import modules}\medskip
  \begin{tabular}{|p{4cm}|p{12cm}|}
-  \hline \multicolumn{2}{|c|}{\textbf{Data import modules in the GRASS
+  \hline \multicolumn{2}{|c|}{\textbf{Raster and Image data import modules in the GRASS
   Toolbox}} \\
   \hline \textbf{Module name} & \textbf{Purpose} \\
   \hline r.in.arc & Convert an ESRI ARC/INFO ascii raster file (GRID) into a
@@ -31,6 +31,10 @@
   raster map layer \\
   \hline r.in.gdal.loc &  Import GDAL supported raster file into a GRASS
   binary raster map layer and create a fitted location \\
+  \hline r.in.gdal.qgis & Import loaded raster into a GRASS binary raster map
+  layer \\
+  \hline r.in.gdal.qgis.loc &  Import loaded raster file into a GRASS binary
+  raster map layer and create a fitted location \\
   \hline r.in.gridatb & Imports GRIDATB.FOR map file (TOPMODEL) into GRASS
   raster map \\
   \hline r.in.mat  & Import a binary MAT-File(v4) to a GRASS raster  \\
@@ -38,28 +42,19 @@
   in the current directory \\
   \hline r.in.srtm  & Import SRTM HGT files into GRASS \\
   \hline i.in.spotvgt & Import of SPOT VGT NDVI file into a raster map \\
-  \hline v.in.dxf & Import DXF vector layer \\
-  \hline v.in.e00 & Import ESRI E00 file in a vector map \\
-  \hline v.in.garmin & Import vector from gps using gpstrans \\
-  \hline v.in.gpsbabel & Import vector from gps using gpsbabel \\
-  \hline v.in.mapgen & Import MapGen or MatLab vectors in GRASS \\
-  \hline v.in.ogr & Import OGR/PostGIS vector layers \\
-  \hline v.in.ogr.loc & Import OGR/PostGIS vector layers and create a fitted
-  location\\
-  \hline v.in.ogr.all & Import all the OGR/PostGIS vector layers in a given
-  data source \\
-  \hline v.in.ogr.all.loc & Import all the OGR/PostGIS vector layers in a
-  given data source and create a fitted location \\
 \hline
 \end{tabular}
 \end{table}
+\newpage
 \begin{table}[ht]
 \centering
-\caption{GRASS Toolbox: Data export modules}\medskip
+\caption{GRASS Toolbox: Raster and Image data export modules}\medskip
-  \hline \multicolumn{2}{|c|}{\textbf{Data export modules in the GRASS
-  Toolbox}} \\
+  \hline \multicolumn{2}{|c|}{\textbf{Raster and Image data export modules in
+the GRASS
+  Toolbox}} \\
   \hline r.out.gdal.gtiff & Export raster layer to Geo TIFF \\
   \hline r.out.arc & Converts a raster map layer into an ESRI ARCGRID file \\
@@ -79,6 +74,46 @@
   at the pixel resolution of the currently defined region\\
   \hline r.out.vrml &  Export a raster map to the Virtual Reality Modeling
   Language (VRML)\\
+\hline
+\end{tabular}
+\end{table}
+\newpage
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox: Vector data import modules}\medskip
+ \begin{tabular}{|p{4cm}|p{12cm}|}
+  \hline \multicolumn{2}{|c|}{\textbf{Vector data import modules in the GRASS
+Toolbox}} \\
+  \hline \textbf{Module name} & \textbf{Purpose} \\
+  \hline v.in.dxf & Import DXF vector layer \\
+  \hline v.in.e00 & Import ESRI E00 file in a vector map \\
+  \hline v.in.garmin & Import vector from gps using gpstrans \\
+  \hline v.in.gpsbabel & Import vector from gps using gpsbabel \\
+  \hline v.in.mapgen & Import MapGen or MatLab vectors in GRASS \\
+  \hline v.in.ogr & Import OGR/PostGIS vector layers \\
+  \hline v.in.ogr.qgis & Import loaded vector layers into GRASS binary
+  vector map \\
+  \hline v.in.ogr.loc & Import OGR/PostGIS vector layers and create a fitted
+  location \\
+  \hline v.in.ogr.qgis.loc & Import loaded vector layers into GRASS binary
+  vector map and create a fitted location \\
+  \hline v.in.ogr.all & Import all the OGR/PostGIS vector layers in a given
+  data source \\
+  \hline v.in.ogr.all.loc & Import all the OGR/PostGIS vector layers in a
+  given data source and create a fitted location \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox: Vector data export modules}\medskip
+  \hline \multicolumn{2}{|c|}{\textbf{Vector data export modules in the GRASS
+Toolbox}} \\
   \hline v.out.ogr & Export vector layer to various formats (OGR library) \\
   \hline v.out.ogr.gml & Export vector layer to GML \\
   \hline v.out.ogr.postgis & Export vector layer to various formats (OGR
@@ -91,6 +126,8 @@
 \end{tabular}
 \end{table}
+\newpage
 \subsection{GRASS Toolbox data type conversion modules}
 This Section lists all graphical dialogs in the GRASS Toolbox to convert
@@ -113,6 +150,8 @@
 \end{tabular}
 \end{table}
+\newpage
 \subsection{GRASS Toolbox region and projection configuration modules}
 This Section lists all graphical dialogs in the GRASS Toolbox to manage and
Modified: docs/trunk/english_us/user_guide/appendices/supported_data_formats.tex
--- docs/trunk/english_us/user_guide/appendices/supported_data_formats.tex	2009-04-28 07:42:51 UTC (rev 10669)
+++ docs/trunk/english_us/user_guide/appendices/supported_data_formats.tex	2009-04-28 08:17:19 UTC (rev 10670)
@@ -4,32 +4,53 @@
 % comment out the following line:
 % \updatedisclaimer
-\subsection{Supported OGR Formats}\label{appdx_ogr}
+QGIS uses the GDAL/OGR library to read and write vector and raster data
+formats. Note that not all of the format listed below may work in QGIS for
+various reasons. For example, some require external commercial libraries or
+the GDAL installation of your OS was not build to support the format you want
+to use. Only those formats that have been well tested will appear in the list
+of file types when loading a vector or raster into QGIS. Other untested
+formats can be loaded by selecting *.*.
+\subsection{OGR Vector Formats}\label{appdx_ogr}
 \index{OGR!supported formats}
 At the date of this document, the following formats are supported by the OGR
-library. Formats known to work in QGIS are indicated in \textbf{bold}.
+library \cite{OGRweb}. A complete is also available at
+\url{http://www.gdal.org/ogr/ogr_formats.html}.
 \begin{itemize}
-\item \textbf{Arc/Info Binary Coverage}
+\item Arc/Info Binary Coverage
 \item Comma Separated Value (.csv)
 \item DODS/OPeNDAP
-\item \textbf{ESRI Shapefile}
+\item ESRI Personal GeoDatabase
+\item ESRI ArcSDE
+\item ESRI Shapefile
 \item FMEObjects Gateway
+\item GeoJSON
+\item Geoconcept Export
+\item GeoRSS
 \item GML
+\item GMT
+\item GPX
+\item GRASS Vector \footnote{GRASS support is supplied by the QGIS
+GRASS data provider plugin}
+\item Informix DataBlade
+\item INTERLIS
 \item IHO S-57 (ENC)
-\item \textbf{Mapinfo File}
+\item Mapinfo File
 \item Microstation DGN
 \item OGDI Vectors
 \item ODBC
 \item Oracle Spatial
 \item PostgreSQL\footnote{QGIS implements its own PostgreSQL functions. OGR
 should be built without PostgreSQL support}
-\item \textbf{SDTS}
+\item SDTS
 \item SQLite
 \item UK .NTF
 \item U.S. Census TIGER/Line
 \item VRT - Virtual Datasource
+\item X-Plane/Flighgear aeronautical data
 \end{itemize}
 \subsection{GDAL Raster Formats}\label{appdx_gdal}
@@ -37,19 +58,14 @@
 \index{GDAL!supported formats}
 At the date of this document, the following formats are supported by the GDAL
-library. Note that not all of these format may work in QGIS for various
-reasons.
-For example, some require external commercial libraries. Only those formats
-that
-have been well tested will appear in the list of file types when loading a
-raster into QGIS. Other untested formats can be loaded by selecting the
-\textsl{All other files (*)} filter. Formats known to work in QGIS are
-indicated
-in \textbf{bold}.
+library \cite{GDALweb}. A complete is also available at
+\url{http://www.gdal.org/formats_list.html}.
 \begin{itemize}
-\item \textbf{Arc/Info ASCII Grid}
-\item \textbf{Arc/Info Binary Grid (.adf)}
+\item Arc/Info ASCII Grid
+\item ADRG/ARC Digitilized Raster Graphics
+\item Arc/Info Binary Grid (.adf)
+\item Magellan BLX Topo (.blx, .xlb)
 \item Microsoft Windows Device Independent Bitmap (.bmp)
 \item BSB Nautical Chart Format (.kap)
 \item VTP Binary Terrain Format (.bt)
@@ -64,31 +80,39 @@
 \item EOSAT FAST Format
 \item FITS (.fits)
 \item Graphics Interchange Format (.gif)
-\item \textbf{GRASS Rasters}\footnote{GRASS raster support is supplied by the
-QGIS GRASS data provider plugin}
-\item \textbf{TIFF / GeoTIFF (.tif)}
+\item GMT compatible netCDF
+\item GRASS Rasters \footnote{GRASS support is supplied by the QGIS GRASS data provider plugin}
+\item Golden Software Binary Grid
+\item TIFF / BigTIFF / GeoTIFF (.tif)
 \item Hierarchical Data Format Release 4 (HDF4)
-\item \textbf{Erdas Imagine (.img)}
+\item Hierarchical Data Format Release 5 (HDF5)
+\item ILWIS Raster Map (.mpr,.mpl)
+\item Intergraph Raster
+\item Erdas Imagine (.img)
 \item Atlantis MFF2e
 \item Japanese DEM (.mem)
-\item \textbf{JPEG JFIF (.jpg)}
+\item JPEG JFIF (.jpg)
 \item JPEG2000 (.jp2, .j2k)
-\item JPEG2000 (.jp2, .j2k)
 \item NOAA Polar Orbiter Level 1b Data Set (AVHRR)
 \item Erdas 7.x .LAN and .GIS
 \item In Memory Raster
+\item Vexcel MFF
+\item Vexcel MFF2
 \item Atlantis MFF
 \item Multi-resolution Seamless Image Database  MrSID
 \item NITF
 \item NetCDF
 \item OGDI Bridge
+\item Oracle Spatial Georaster
+\item OGC Web Coverage Server
+\item OGC Web Map Server
 \item PCI .aux Labelled
 \item PCI Geomatics Database File
 \item Portable Network Graphics (.png)
 \item Netpbm (.ppm,.pgm)
-\item \textbf{USGS SDTS DEM (*CATD.DDF)}
+\item USGS SDTS DEM (*CATD.DDF)
 \item SAR CEOS
-\item \textbf{USGS ASCII DEM (.dem)}
+\item USGS ASCII DEM (.dem)
 \item X11 Pixmap (.xpm)
 \end{itemize}
Modified: docs/trunk/english_us/user_guide/cited_weblinks.bib
--- docs/trunk/english_us/user_guide/cited_weblinks.bib	2009-04-28 07:42:51 UTC (rev 10669)
+++ docs/trunk/english_us/user_guide/cited_weblinks.bib	2009-04-28 08:17:19 UTC (rev 10670)
@@ -1,57 +1,63 @@
 @booklet {FreeGISweb,
  author = {FreeGIS Project},
  address = {\url{http://www.freegis.org}},
- year = 2006
+ year = 2009
 @booklet {Postgreweb,
  author = {PostgreSQL},
  address = {\url{http://www.postgresql.org/}},
- year = 2006
+ year = 2009
 @booklet {PostGISweb,
  author = {PostGIS},
  address = {\url{http://postgis.refractions.net/}},
- year = 2006
+ year = 2009
 @booklet {GEOSweb,
  author = {GEOS},
  address = {\url{http://geos.refractions.net/}},
- year = 2006
+ year = 2009
 @booklet {PROJweb,
  author = {PROJ.4},
  address = {\url{http://www.remotesensing.org/proj/}},
- year = 2006
+ year = 2009
 @booklet {Qtweb,
  author = {Qt},
- address = {\url{http://www.trolltech.com}},
- year = 2006
+ address = {\url{http://www.qtsoftware.com}},
+ year = 2009
 @booklet {SQliteweb,
  author = {SQlite},
  address = {\url{http://www.sqlite.org}},
- year = 2006
+ year = 2009
 @booklet {GRASSweb,
  author = {GRASS GIS},
  address = {\url{http://grass.osgeo.org}},
- year = 2008
+ year = 2009
 @booklet {OGRweb,
  author = {OGR-Software-Suite},
  address = {\url{http://www.gdal.org/ogr/}},
- year = 2006
+ year = 2009
+ at booklet {GDALweb,
+ author = {GDAL-Software-Suite},
+ address = {\url{http://www.gdal.org}},
+ year = 2009
 @booklet {QGISweb,
  author = {QGIS-Development-Team},
  address = {\url{http://qgis.osgeo.org}},
@@ -60,8 +66,8 @@
 @booklet {QGISwiki,
  author = {QGIS-Wiki},
- address = {\url{http://wiki.qgis.org/qgiswiki/}},
- year = 2006
+ address = {\url{http://www.qgis.org/wiki/}},
+ year = 2009
 @booklet {OGCWMS010101web,
Modified: docs/trunk/english_us/user_guide/help_and_support.tex
--- docs/trunk/english_us/user_guide/help_and_support.tex	2009-04-28 07:42:51 UTC (rev 10669)
+++ docs/trunk/english_us/user_guide/help_and_support.tex	2009-04-28 08:17:19 UTC (rev 10670)
@@ -101,7 +101,7 @@
 You are invited to contribute to the blog after registering yourself!
 \subsection{Wiki}
-Lastly, we maintain a WIKI web site at \url{http://wiki.qgis.org} where you
+Lastly, we maintain a WIKI web site at \url{http://www.qgis.org/wiki} where you
 can find a variety of useful information relating to QGIS development,
 release plans, links to download sites, message translation-hints and so on.
 Check it out, there are some goodies inside!
More information about the QGIS-commit mailing list
