[QGIS Commit] r10681 - in docs/trunk/english_us/user_guide: . plugins_diagram_overlay plugins_oracle_raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Apr 29 00:51:48 EDT 2009
Author: dassau
Date: 2009-04-29 00:51:48 -0400 (Wed, 29 Apr 2009)
New Revision: 10681
Removed:
   docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps
   docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps
   docs/trunk/english_us/user_guide/Makefile
added plugins_diagram_overlay and plugins_oracle_raster folder to make clean section of Makefile, so all created eps files will be removed during 'make clean'
removed committed eps files
Modified: docs/trunk/english_us/user_guide/Makefile
--- docs/trunk/english_us/user_guide/Makefile	2009-04-29 00:33:49 UTC (rev 10680)
+++ docs/trunk/english_us/user_guide/Makefile	2009-04-29 04:51:48 UTC (rev 10681)
@@ -150,6 +150,8 @@
 	(cd ./print_composer_screenies && make clean)
 	(cd ./help_and_support_screenies && make clean)
 	(cd ./operating_system_icons && make clean)
+	(cd ./plugins_diagram_overlay && make clean)
+	(cd ./plugins_oracle_raster && make clean)
 # Update icons from qgis source if necessary
 updateicon:
Deleted: docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps
--- docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps	2009-04-29 00:33:49 UTC (rev 10680)
+++ docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps	2009-04-29 04:51:48 UTC (rev 10681)
@@ -1,364 +0,0 @@
-%!PS-Adobe-3.0 EPSF-3.0
-%%Creator: (ImageMagick)
-%%Title: (diagram_overlay.eps)
-%%CreationDate: (Tue Apr 28 23:39:47 2009)
-%%BoundingBox: 0 0 25 25
-%%HiResBoundingBox: 0 0 25.3164 25
-%%DocumentData: Clean7Bit
-%%LanguageLevel: 1
-%%Pages: 1
-%%EndComments
-%%BeginDefaults
-%%EndDefaults
-%%BeginProlog
-% Display a color image.  The image is displayed in color on
-% Postscript viewers or printers that support color, otherwise
-% it is displayed as grayscale.
-/DirectClassPacket
-  % Get a DirectClass packet.
-  % Parameters:
-  %   red.
-  %   green.
-  %   blue.
-  %   length: number of pixels minus one of this color (optional).
-  currentfile color_packet readhexstring pop pop
-  compression 0 eq
-    /number_pixels 3 def
-    currentfile byte readhexstring pop 0 get
-    /number_pixels exch 1 add 3 mul def
-  } ifelse
-  0 3 number_pixels 1 sub
-    pixels exch color_packet putinterval
-  } for
-  pixels 0 number_pixels getinterval
-} bind def
-/DirectClassImage
-  % Display a DirectClass image.
-  systemdict /colorimage known
-    columns rows 8
-      columns 0 0
-      rows neg 0 rows
-    { DirectClassPacket } false 3 colorimage
-    % No colorimage operator;  convert to grayscale.
-    columns rows 8
-      columns 0 0
-      rows neg 0 rows
-    { GrayDirectClassPacket } image
-  } ifelse
-} bind def
-/GrayDirectClassPacket
-  % Get a DirectClass packet;  convert to grayscale.
-  % Parameters:
-  %   red
-  %   green
-  %   blue
-  color_packet 0 get 0.299 mul
-  color_packet 1 get 0.587 mul add
-  color_packet 2 get 0.114 mul add
-  cvi
-  /gray_packet exch def
-  compression 0 eq
-    /number_pixels 1 def
-    /number_pixels exch 1 add def
-  } ifelse
-  0 1 number_pixels 1 sub
-    pixels exch gray_packet put
-  } for
-} bind def
-/GrayPseudoClassPacket
-  % Get a PseudoClass packet;  convert to grayscale.
-  % Parameters:
-  %   index: index into the colormap.
-  /offset exch 3 mul def
-  /color_packet colormap offset 3 getinterval def
-  cvi
-  compression 0 eq
-  } ifelse
-  } for
-} bind def
-/PseudoClassPacket
-  % Get a PseudoClass packet.
-  % Parameters:
-  compression 0 eq
-  } ifelse
-  } for
-} bind def
-/PseudoClassImage
-  % Display a PseudoClass image.
-  % Parameters:
-  %   class: 0-PseudoClass or 1-Grayscale.
-  currentfile buffer readline pop
-  token pop /class exch def pop
-  class 0 gt
-    token pop /depth exch def pop
-    /grays columns 8 add depth sub depth mul 8 idiv string def
-    columns rows depth
-      columns 0 0
-      rows neg 0 rows
-    { currentfile grays readhexstring pop } image
-    % Parameters:
-    %   colors: number of colors in the colormap.
-    %   colormap: red, green, blue color packets.
-    token pop /colors exch def pop
-    /colors colors 3 mul def
-    /colormap colors string def
-    currentfile colormap readhexstring pop pop
-      columns rows 8
-        columns 0 0
-        rows neg 0 rows
-      { PseudoClassPacket } false 3 colorimage
-      columns rows 8
-        columns 0 0
-        rows neg 0 rows
-      { GrayPseudoClassPacket } image
-    } ifelse
-  } ifelse
-} bind def
-/DisplayImage
-  % Display a DirectClass or PseudoClass image.
-  % Parameters:
-  %   x & y translation.
-  %   x & y scale.
-  %   label pointsize.
-  %   image label.
-  %   image columns & rows.
-  %   class: 0-DirectClass or 1-PseudoClass.
-  %   compression: 0-none or 1-RunlengthEncoded.
-  %   hex color packets.
-  gsave
-  /buffer 512 string def
-  /byte 1 string def
-  /color_packet 3 string def
-  /pixels 768 string def
-  token pop /x exch def
-  token pop /y exch def pop
-  x y translate
-  token pop /pointsize exch def pop
-  /Times-Roman findfont pointsize scalefont setfont
-  x y scale
-  token pop /columns exch def
-  token pop /rows exch def pop
-  token pop /compression exch def pop
-  class 0 gt { PseudoClassImage } { DirectClassImage } ifelse
-  grestore
-} bind def
-%%EndProlog
-%%Page:  1 1
-%%PageBoundingBox: 0 0 25 25
-userdict begin
-DisplayImage
-0 0
-25.3164 25.3164
-12.000000
-32 32
-0
-0
-ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
-ffffffffffff000000000000000000000000ffffffffffffffffffffffffffffffffffff
-ffffffffffffffffffffffffffffffffffff000000010203060F13030709020405060F12
-061013020405030709061013010304000000ffffffffffffffffffffffffffffffffffff
-000000060E110711142253663C94B54EC2EE54D0FF52CBF952CAF854D0FF4FC3EF3D96B8
-235669071216060F12000000ffffffffffffffffffffffffffffffffffffffffffffffff
-ffffffffffffffffffffffffffffffffffff000000050D0F060E11327D9951C8F53C94B5
-2253660A181D03080903080900000003070909161B204E603A90B150C6F33583A1071115
-050D10000000ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
-ffffff000000050C0E1E4A5B4FC5F13582A0071115060F13F30FE6F30FE6F30FE6000000
-3F9CBF000000E8240AE8240A061013050D1031799450C6F3235669040B0D000000ffffff
-ffffffffffffffffffffffffffffffffffffffffffffffff00000004090C2F748E4CBDE8
-112A33050E11F30FE6F30FE6F30FE6F30FE6F30FE60000003F9CBF000000E8240AE8240A
-E8240A76180C050D1006111549B6DF34809D04090B000000ffffffffffffffffffffffff
-ffffffffffffffffff000000040B0D3584A143A6CC071115F30FE6F30FE6F30FE6F30FE6
-F30FE6F30FE6F30FE61B435240A0C4000000E8240AE8240AE8240AE8240A76180D32110E
-050D101C47573A90B1040A0D000000ffffffffffffffffffffffffffffff000000050C0E
-27617748B3DB050D10F30FE6F30FE6F30FE6F30FE6F30FE6F30FE6F30FE6F30FE6061014
-40A0C4061014E8240AE8240AE8240AE8240AE8240AE8240A050D10050C0F255B702D6F88
-050D0F000000ffffffffffffffffffffffff010303112B354FC3EF0A191FF30FE6F30FE6
-F30FE6F30FE6F30FE6F30FE6F30FE6F30FE6F30FE606101441A2C7061014E8240AE8240A
-E8240AE8240AE8240AE8240AE8240AE8240A050D103E9ABD173946030708ffffffffffff
-ffffff00000004090C43A6CC23576B040B0D09161BF30FE6F30FE6F30FE6F30FE6F30FE6
-F30FE6F30FE6F30FE6112D3842A4CA000000E8240AE8240AE8240AE8240AE8240AE8240A
-E8240AE8240AA91D0B07131747B1D9040A0D000000ffffffffffff0102031B435248B3DB
-04090B3F9CBF307691060F12F30FE6F30FE6F30FE6F30FE6F30FE6F30FE6F30FE6215265
-40A0C5000000E8240AE8240AE8240AE8240AE8240AE8240AE8240AE8240AD1210A040B0D
-378AA9215365030708ffffffffffff0610133C94B62254670306080000003F9CBF3F9CBF
-0C1E25000000F30FE6F30FE6F30FE6F30FE6F30FE60D202843A6CC000000E8240AE8240A
-E8240AE8240AE8240AE8240AE8240AE8240AE8240AE8240A09181D41A1C5061013ffffff
-00000003080A52CAF80710140CA4100CA410000000327C983F9CBF2E718B000000F30FE6
-F30FE6F30FE6F30FE60000003F9CBF000000E8240AE8240AE8240AE8240AE8240AE8240A
-E8240AE8240AE8240AE8240A040B0D52CCFA040B0D000000000000132E3945ABD2060E11
-0CA4100CA4100CA4100CA4100C1E253F9CBF3F9CBF0C1E25F30FE6F30FE6F30FE6000000
-3F9CBF000000E8240AE8240AE8240AE8240AE8240AE8240AE8240AE8240AE8240AE8240A
-040B0D43A6CB1738440000000000001D4858398EAE0711150CA4100CA4100CA4100CA410
-0CA4100000003F9CBF3F9CBF255C71000000F30FE60000003F9CBF000000E8240AE8240A
-E8240AE8240AE8240AE8240AE8240AE8240AE8240AE8240A040B0D398DAD215265000000
-000000276278317A950711150CA4100CA4100CA4100CA4100CA4100CA4100000001F4E5F
-3F9CBF3F9CBF00000009161B3F9CBF000000E8240AE8240AE8240AE8240AE8240AE8240A
-E8240AE8240AE8240AE8240A040B0D3179942B6B830103040000002B6B832E718B071115
-0CA4100CA4100CA4100CA4100CA4100CA4100CA4100CA4100000003F9CBF3F9CBF317995
-040B0D2E718B2E728C03090B0000002152653686A40711150CA4100CA4100CA4100CA410
-0CA4100CA4100CA4100CA4100CA4100000003D9ABC3F9CBF3F9CBF317894000000E8240A
-E8240AE8240AE8240AE8240AE8240AE8240AE8240AE8240A040B0D3685A3255C71000000
-0000001739463F9CBF0711150CA4100CA4100CA4100CA4100CA4100CA4100CA4100CA410
-0CA4100CA4100000003B93B43E9BBD3B92B43F9CBF000000E8240AE8240AE8240AE8240A
-E8240AE8240AE8240AE8240A040B0D3E99BC1B435200000000000008131751C9F6071115
-0CA4100CA4100CA4100CA4100CA4100CA4100CA4100CA4100CA4100C1E253F9CBF307792
-0000000000003F9CBF3F9CBF060F12E8240AE8240AE8240AE8240AE8240AE8240AE8240A
-040B0D4FC3EF0B1B21000000ffffff050C0F46ADD41637430CA4100CA4100CA4100CA410
-0CA4100CA4100CA4100CA4100C1E253B93B43077930000000000EB0000EB122D383686A5
-3F9CBF0C1E25000000E8240AE8240AE8240AE8240AE8240A122D374AB8E1040A0Cffffff
-ffffff03080A2A6980398EAE050D0F0CA4100CA4100CA4100CA4100CA410000000163643
-3F9CBF3076910000000000EB0000EB0000EB0000EB040B0D0C1E253F9CBF30779209161B
-E8240AE8240AE8240A060E123583A1307792050D10ffffffffffff000000050B0E4FC4F0
-1027300CA4100CA4100CA4100CA4100000003584A23F9CBF0C1E2509161B0000EB0000EB
-0000EB0000EB0000EB0000EB0000EB0C1E253F9CBF307691000000E8240AE8240A0C1D23
-50C7F4071115000000ffffffffffffffffff040A0C265E7343A6CC040A0D0CA4100CA410
-0000003F9CBF3685A40000000000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB
-0000EB0000EB0000003B92B33F9CBF000000050C0E3F9CBF2C6C85050D10ffffffffffff
-ffffffffffff00000004090B409EC23685A4040B0D0B1C223F9CBF3F9CBF0000000000EB
-0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB000000
-3E9BBD050C0F30779244A8CE040B0E000000ffffffffffffffffffffffffffffff000000
-050D0F48B3DB2B6B833E9BBE3E9ABD0000000000EB0000EB0000EB0000EB0000EB0000EB
-0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB000000255B704BBAE4071114
-000000ffffffffffffffffffffffffffffffffffffffffff01030408151A47B1D93A93B4
-040A0C0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB
-0000EB0000EB0000EB040A0D327B974AB7E00B1B22030708ffffffffffffffffffffffff
-ffffffffffffffffffffffffffffff010304040B0D3C94B646ADD414323E050C0F0000EB
-0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB0000EB050D1010293242A4C9
-409DC1050D10020506ffffffffffffffffffffffffffffffffffffffffffffffffffffff
-ffffffffffff00000004090B1F4D5F4CBCE63E9ABD193E4C04090C04090C04090C04090C
-04090C04090C04090C04090C04090C3B93B44DC0EB23566A04090B000000ffffffffffff
-ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff000000
-03090B04090B255B6F409FC352CAF843A6CB3A90B0337E9A327D993A8FAF42A3C851C9F7
-41A2C6265E74040A0C040A0C000000ffffffffffffffffffffffffffffffffffffffffff
-ffffffffffffffffffffffffffffffffffffffffffffffffffffff000000020506060F12
-04090B132F3A1D485828627828647A1E4A5A14303B040A0D060E11020607000000ffffff
-ffffffffffffffffffffffffffffffffffffffffffffffff000000000000000000000000
-000000000000000000000000ffffffffffffffffffffffffffffffffffffffffffffffff
-end
-%%PageTrailer
-%%Trailer
-%%EOF
Deleted: docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps
--- docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps	2009-04-29 00:33:49 UTC (rev 10680)
+++ docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps	2009-04-29 04:51:48 UTC (rev 10681)
@@ -1,319 +0,0 @@
-%%Title: (oracle_raster.eps)
-%%CreationDate: (Tue Apr 28 23:50:03 2009)
-%%BoundingBox: 0 0 22 22
-%%HiResBoundingBox: 0 0 21.9973 22
-%%LanguageLevel: 1
-%%Pages: 1
-%%EndComments
-%%BeginDefaults
-%%EndDefaults
-%%BeginProlog
-/DirectClassPacket
-  % Parameters:
-  %   red.
-  %   green.
-  %   blue.
-  compression 0 eq
-  } ifelse
-  } for
-} bind def
-/DirectClassImage
-    columns rows 8
-      columns 0 0
-      rows neg 0 rows
-    columns rows 8
-      columns 0 0
-      rows neg 0 rows
-  } ifelse
-} bind def
-  % Parameters:
-  %   red
-  %   green
-  %   blue
-  cvi
-  compression 0 eq
-  } ifelse
-  } for
-} bind def
-  % Parameters:
-  cvi
-  compression 0 eq
-  } ifelse
-  } for
-} bind def
-/PseudoClassPacket
-  % Parameters:
-  compression 0 eq
-  } ifelse
-  } for
-} bind def
-/PseudoClassImage
-  % Parameters:
-  class 0 gt
-      columns 0 0
-      rows neg 0 rows
-    % Parameters:
-      columns rows 8
-        columns 0 0
-        rows neg 0 rows
-      columns rows 8
-        columns 0 0
-        rows neg 0 rows
-    } ifelse
-  } ifelse
-} bind def
-/DisplayImage
-  % Parameters:
-  %   x & y scale.
-  %   image label.
-  gsave
-  x y translate
-  x y scale
-  grestore
-} bind def
-%%EndProlog
-%%Page:  1 1
-%%PageBoundingBox: 0 0 22 22
-userdict begin
-DisplayImage
-0 0
-21.9973 21.9973
-12.000000
-22 22
-0
-0
-ffffffffffffffffffffffffffffffffffffffffffffffff0B56C40A55C30A52C12B55B5
-4A429749388D58328277276Bffffffffffffffffffffffffffffffffffffffffffffffff
-ffffffffffffffffffffffff0B57C50D5DCC1976E92E8EF9868AC7E03750FD0F1CFC0615
-FB0514FA0514F90314FC0211FF0B19FF101Fffffffffffffffffffffffffffffffffffff
-ffffff0B57C5227CE92894FF2693FF6195E2E22740FD1220C2698CA07AADA47EAEB387AC
-B887AB7E5090CB143BFF0917FF1323ffffffffffffffffffffffffffffff0B57C52D81E9
-2C96FF2894FF3E9EFF9D74A8FC101EBB6C9162B1FB60B2FF63B4FB73BDFA84C8FB94C7F6
-1851BAFF2A36FF101Dffffffffffffffffffffffffffffff3A77D18AC8FF2C96FF3A9DFF
-4EA6FF9E6599F411238C8DC65EB3FF5FB2FF63B4FA73BDFA82C7FA92CBFA225EC2ffffff
-FF0413ffffffffffffffffffffffffffffff4981D5A6D7FF2C96FF4AA4FF4EA6FF9E6A9F
-F80D1EA07AAB5EB3FF5FB2FF63B4FA73BDFA82C7FAA8D7FE205DC4FF323EFF0C19ffffff
-ffffffffffffffffffffffff3474CFFFFFFF96CEFF4CA5FF4EA6FF8196D5F21F35F82130
-9F80B38B99D28E9CD09AA2D0CFC0D5A79DCB663B87FF1421FF1322ffffffffffffffffff
-ffffffffffff2B6FCDE3FFFFFFFFFFF4FEFFAFD9FF89C3FBB889AFF42132FA1021F81A29
-FB1D2BFC1E2BF61828F11427F50C1DFF0E1Cffffffffffffffffffffffffffffffffffff
-2A6CCCD3FFFFC4F9FFF6FFFFFAFFFFFAFFFFF6FAFBF0D0D5E891A1CB7594954F88753981
-7238817236816A2E79ffffffffffffffffffffffffffffffffffffffffff36619C8F9EA3
-8A9CA29AA5AA748088849CA4ADE9FF81C8FC56A7F12B87E90A6DE10469E00067E00063E0
-003FBAffffffffffffffffffffffffffffffffffffffffff4C6C9AA8BFC9B5D3DBB8D5E0
-86A6B77C9099ADE7FF81C7FC56A6F12A86E70A6DE10469E00067E00063E0003EB9ffffff
-ffffffffffffffffffffffffffffffffffff5876A3B0CAD4BADDE69ED0E0629AB26F848D
-ACE7FF80C6FB55A5F12A85E70A6DE00469E00067E00063E0003DB8ffffffffffffffffff
-ffffffffffff676D7492979C8392A9B2CED8A2D3E184C6D84E8EA8374551516E8040607C
-589CDC3384DB136FD80669DD0067E00063E0003CB7ffffffffffffffffffffffffffffff
-8F98A1C4D4DBC1D5DEA7C9D582C5D779C2D64A8FAB19739713688C1333485998D43785D9
-1A70D00669DD0067E00063DF0039B6ffffffffffffffffffffffffffffff9CA6AECFE4EC
-B1D8E48FCADB73BED46CBDD441ABCA1397BE0F8EB60B3A545999D73A88DD1C71D30669DD
-0067E00067E00039B4ffffffffffffffffffffffffffffff83949CAAD3E187C8DA8ECCDD
-76C0D65EB7D256B4D027A0C3138FB70B3B545B9BDA3F8CE4267ADF0669DD0067E00067E0
-053DA8ffffffffffffffffffffffffffffff3B5160578DA64588A55E9AB24DAFCC2CA2C4
-3B88A53685A32172940A293E5D9BDB418FE5297DE10669DD0067E00067E01C48A7ffffff
-ffffffffffffffffffffffff121B261A232D192B471E76991799BF0E96BE15729640515D
-5C7C9042617B62A4E44290E7267ADF0669DD0067E00067E03660BEffffffffffffffffff
-ffffffffffffffffffffffff032562106E930E96BE0E96BE106E93777D84ADE7FF80C6FB
-62A4E44290E7267ADF0669DD0067E00067E00026A5ffffffffffffffffffffffffffffff
-ffffffffffff031F510F5A7D107EA6107EA60F5A7D6E757FADE7FF80C6FB62A4E44290E7
-267ADF0669DD0067E02451B80026A5ffffffffffffffffffffffffffffffffffffffffff
-ffffff051D400523511731562B3E587E889AADE7FF80C6FB62A4E44290E7267ADF476DC4
-0026A50026A5ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
-ffffff0033AD0030AC002FAA002DA9002CA8002AA70029A60028A50026A5ffffffffffff
-end
-%%PageTrailer
-%%Trailer
-%%EOF
More information about the QGIS-commit mailing list
