[QGIS Commit] r11252 - trunk/qgis/i18n
svn_qgis at osgeo.org
Sun Aug 2 11:32:45 EDT 2009
Author: jef
Date: 2009-08-02 11:32:44 -0400 (Sun, 02 Aug 2009)
New Revision: 11252
trunk/qgis/i18n/qgis_de.ts
update german translation
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2009-08-02 15:29:02 UTC (rev 11251)
+++ trunk/qgis/i18n/qgis_de.ts 2009-08-02 15:32:44 UTC (rev 11252)
@@ -871,7 +871,7 @@
</message>
<message>
<source>Storno</source>
- <translation></translation>
+ <translation>Abbruch</translation>
</message>
</context>
<context>
@@ -5148,7 +5148,7 @@
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="66"/>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="82"/>
- <source>Enter the action here. This can be any program, script or command that is available on your system. When the action is invoked any set of characters that start with a % and then have the name of a field will be replaced by the value of that field. The special characters %% will be replaced by the value of the field that was selected. Double quote marks group text into single arguments to the program, script or command. Double quotes will be ignored if preceeded by a backslash</source>
+ <source>Enter the action here. This can be any program, script or command that is available on your system. When the action is invoked any set of characters that start with a % and then have the name of a field will be replaced by the value of that field. The special characters %% will be replaced by the value of the field that was selected. Double quote marks group text into single arguments to the program, script or command. Double quotes will be ignored if prefixed with a backslash</source>
<translation>Geben Sie hier die Aktion ein. Dies kann jedes Programm, Skript oder Kommando sein, dass in Ihrem System verfügbar ist. Wenn die Aktion ausgeführt wird jeder durch % eingeleiteter Feldname durch den Feldwert ersetzt. Die besondere Zeichenfolge %% wird durch den Wert des gewählten Felds ersetzt. Mit Anführungszeichen können mehrere Wörter zu einem Argument der Aktion zusammengefaßt werden. Für mit Backslash (\) eingeleitete Anführungszeichen gilt dies nicht.</translation>
</message>
<message>
@@ -14255,7 +14255,7 @@
</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;">
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';">This is the list of all layers available in the datasource of the active layer. You can select the layers to load. The layers will be loaded when you press "OK".</p>
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';"></p>
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';">The layer name is format dependant. Consult the OGR documentation or the documentation of your data format to determine the nature of the included information.</p>
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';">The layer name is format dependent. Consult the OGR documentation or the documentation of your data format to determine the nature of the included information.</p>
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif';"><span style=" font-weight:600;">Be advised: </span>selecting an already opened layer will not generate an error message and the layer will end up loaded twice!</p></body></html></source>
<translation><html><head><meta name="qrichtext" content="1" /><style type="text/css">
