[QGIS Commit] r11320 - docs/branches/1.0.0/french/user_guide
svn_qgis at osgeo.org
Sun Aug 9 10:40:51 EDT 2009
Author: jrm
Date: 2009-08-09 10:40:51 -0400 (Sun, 09 Aug 2009)
New Revision: 11320
docs/branches/1.0.0/french/user_guide/getting_started.tex
corrections du texte
Modified: docs/branches/1.0.0/french/user_guide/getting_started.tex
--- docs/branches/1.0.0/french/user_guide/getting_started.tex 2009-08-09 14:40:18 UTC (rev 11319)
+++ docs/branches/1.0.0/french/user_guide/getting_started.tex 2009-08-09 14:40:51 UTC (rev 11320)
@@ -57,7 +57,7 @@
%database. The projection for the QGIS sample dataset is Alaska Albers Equal
%Area with unit feet. The EPSG code is 2964.
-\subsection{�chantillons de donn\'ees}\label{label_sampledata} \index{data!sample}
+\subsection{\'Echantillons de donn\'ees}\label{label_sampledata} \index{data!sample}
Le guide de l'utilisateur comporte une s\'erie d'exemples bas\'ee sur un \'echantillon de donn\'ees inclu avec QGIS.
@@ -75,11 +75,11 @@
GEOGCS["NAD27",
DATUM["North_American_Datum_1927",
SPHEROID["Clarke 1866",6378206.4,294.978698213898,
-AUTHORITY["EPSG","7008"]], TOWGS84[-3,142,183,0,0,0,0], AUTHORITY["EPSG","6267"]],
+AUTHORITY["EPSG","7008"]], TOWGS84[-3,142,183,0,0,0,0], AUTHORITY["EPSG","6267"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
-AUTHORITY["EPSG","9108"]], AUTHORITY["EPSG","4267"]],
+AUTHORITY["EPSG","9108"]], AUTHORITY["EPSG","4267"]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["standard_parallel_1",55],
PARAMETER["standard_parallel_2",65],
