[QGIS Commit] r11432 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Aug 19 02:27:10 EDT 2009
Author: homann
Date: 2009-08-19 02:27:09 -0400 (Wed, 19 Aug 2009)
New Revision: 11432
   trunk/qgis/i18n/qgis_sv.ts
More translations
Modified: trunk/qgis/i18n/qgis_sv.ts
--- trunk/qgis/i18n/qgis_sv.ts	2009-08-18 21:32:20 UTC (rev 11431)
+++ trunk/qgis/i18n/qgis_sv.ts	2009-08-19 06:27:09 UTC (rev 11432)
@@ -1024,71 +1024,71 @@
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointDistance.ui" line="104"/>
         <source>Summary distance matrix (mean, std. dev., min, max)</source>
-        <translation type="unfinished"></translation>
+        <translation>Summarisk avståndsmatris (medel, std avv, min, max)</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointDistance.ui" line="111"/>
         <source>Use only the nearest (k) target points:</source>
+        <translation>Använd bara de närmaste (k) punkterna:</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointDistance.ui" line="149"/>
         <source>Output distance matrix</source>
+        <translation>Avståndsmatris för utdata</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmGeoprocessing.ui" line="239"/>
         <location filename="../python/plugins/fTools/tools/frmGeoprocessing.ui" line="250"/>
         <location filename="../python/plugins/fTools/tools/frmVisual.ui" line="130"/>
         <source>Use only selected features</source>
+        <translation>Använd bara valda objekt</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointsInPolygon.ui" line="16"/>
         <source>Count Points In Polygons</source>
+        <translation>Räkna punkter i polygoner</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointsInPolygon.ui" line="27"/>
         <location filename="../python/plugins/fTools/tools/frmSumLines.ui" line="90"/>
         <source>Input polygon vector layer</source>
+        <translation>Polygonvektorlager med indata</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointsInPolygon.ui" line="41"/>
         <source>Input point vector layer</source>
+        <translation>Punktvektorlager med indata</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointsInPolygon.ui" line="55"/>
         <source>Output count field name</source>
+        <translation>Fältnamn för beräkningsresultat</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmPointsInPolygon.ui" line="62"/>
         <source>PNTCNT</source>
+        <translation>PNTCNT</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandPoints.ui" line="16"/>
         <source>Generate Random Points</source>
+        <translation>Skapa slumpvisa punkter</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandPoints.ui" line="31"/>
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="25"/>
         <source>Input Boundary Layer</source>
+        <translation>Inlager med gränser</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandPoints.ui" line="46"/>
         <source>Minimum distance between points</source>
+        <translation>Minsta avstånd mellan punkter</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandPoints.ui" line="62"/>
         <source>Sample Size</source>
+        <translation>Sampelstorlek</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandPoints.ui" line="75"/>
@@ -1120,7 +1120,7 @@
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandom.ui" line="16"/>
         <source>Random Selection Tool</source>
+        <translation>Verktyg för slumpmässigt val</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandom.ui" line="25"/>
@@ -1133,25 +1133,25 @@
         <location filename="../python/plugins/fTools/tools/frmRandom.ui" line="35"/>
         <location filename="../python/plugins/fTools/tools/frmSubsetSelect.ui" line="57"/>
         <source>Randomly Select</source>
+        <translation>Välj slumpmässigt</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandom.ui" line="44"/>
         <location filename="../python/plugins/fTools/tools/frmSubsetSelect.ui" line="66"/>
         <source>Number of Features</source>
+        <translation>Antal objekt</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandom.ui" line="78"/>
         <location filename="../python/plugins/fTools/tools/frmSubsetSelect.ui" line="102"/>
         <source>Percentage of Features</source>
+        <translation>Procent av objekt</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRandom.ui" line="98"/>
         <location filename="../python/plugins/fTools/tools/frmSubsetSelect.ui" line="122"/>
         <source>%</source>
-        <translation type="unfinished">%</translation>
+        <translation>%</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmReProject.ui" line="16"/>
@@ -1635,39 +1635,39 @@
     <name>GeoprocessingDialog</name>
     <message>
         <source>Dissolve all</source>
+        <translation>Lös ut alla</translation>
     </message>
     <message>
         <source>Please specify an input layer</source>
+        <translation>Specificera lager med indata</translation>
     </message>
     <message>
         <source>Please specify a difference/intersect/union layer</source>
+        <translation>Specificera vektorlager för differens/skärning/union</translation>
     </message>
     <message>
         <source>Please specify valid buffer value</source>
+        <translation>Specificera giltigt buffertvärde</translation>
     </message>
     <message>
         <source>Please specify dissolve field</source>
+        <translation>Specifiera fält att lösa ut</translation>
     </message>
     <message>
         <source>Please specify output shapefile</source>
+        <translation>Specificera shape-fil för utdata</translation>
     </message>
     <message>
         <source>No features selected, please uncheck &apos;Use selected&apos; or make a selection</source>
+        <translation>Inga objekt valda, ta bort &apos;Använd valda&apos; eller välj objekt</translation>
     </message>
     <message>
         <source>Buffer(s)</source>
+        <translation>Buffert(ar)</translation>
     </message>
     <message>
         <source>Create single minimum convex hull</source>
+        <translation>Skapa en minsta konvex</translation>
     </message>
     <message>
         <source>Create convex hulls based on input field</source>
@@ -1679,65 +1679,71 @@
     </message>
     <message>
         <source>Dissolve</source>
+        <translation>Lös ut</translation>
     </message>
     <message>
         <source>Difference layer</source>
+        <translation>Differenslager</translation>
     </message>
     <message>
         <source>Difference</source>
+        <translation>Differens</translation>
     </message>
     <message>
         <source>Intersect layer</source>
-        <translation type="unfinished">Lager för skärning</translation>
+        <translation>Skärningslager</translation>
     </message>
     <message>
         <source>Intersect</source>
+        <translation>Skärning</translation>
     </message>
     <message>
         <source>Symetrical difference</source>
+        <translation>Symetrisk differans</translation>
     </message>
     <message>
         <source>Clip layer</source>
+        <translation>Klipplager</translation>
     </message>
     <message>
         <source>Clip</source>
+        <translation>Klipp</translation>
     </message>
     <message>
         <source>Union layer</source>
+        <translation>Unionlager</translation>
     </message>
     <message>
         <source>Union</source>
+        <translation>Union</translation>
     </message>
     <message>
         <source>Unable to delete existing shapefile.</source>
+        <translation>Kunde inte ta bort existerande shape-fil.</translation>
     </message>
     <message>
         <source>
 Warnings:</source>
+        <translation>
+Varningar:</translation>
     </message>
     <message>
         <source>
 Some output geometries may be missing or invalid.
 Would you like to add the new layer anyway?</source>
+        <translation>
+Några resulterande geometrier kan saknas eller vara ogiltiga.
+Vill du ändå lägga till det nya lagret?</translation>
     </message>
     <message>
         <source>
 Would you like to add the new layer to the TOC?</source>
+        <translation>
+Vill du lägga till det nya lagret till innehållsförteckningen?</translation>
     </message>
     <message>
         <source>
@@ -4026,7 +4032,7 @@
     <message>
         <location filename="../src/core/qgsdistancearea.cpp" line="721"/>
         <source> sq.deg.</source>
-        <translation> kvadratgrader</translation>
+        <translation> kvadratgrad.</translation>
     </message>
     <message>
         <location filename="../src/core/qgsdistancearea.cpp" line="726"/>
@@ -4593,24 +4599,24 @@
     <message>
         <location filename="../src/python/qgspythonutilsimpl.cpp" line="64"/>
         <source>Couldn&apos;t load SIP module.</source>
-        <translation>Kunde inte läsa in SIP-modul</translation>
+        <translation>Kunde inte läsa in SIP-modul.</translation>
     </message>
     <message>
         <location filename="../src/python/qgspythonutilsimpl.cpp" line="72"/>
         <location filename="../src/python/qgspythonutilsimpl.cpp" line="79"/>
         <source>Python support will be disabled.</source>
-        <translation>Pythonstöd stängs av</translation>
+        <translation>Pythonstöd stängs av.</translation>
     </message>
     <message>
         <source>Couldn&apos;t load PyQt4.</source>
-        <translation>Kunde inte ladda PyQt4</translation>
+        <translation>Kunde inte ladda PyQt4.</translation>
     </message>
     <message>
         <source>Couldn&apos;t load PyQGIS.</source>
-        <translation>Kunde inte ladda PyQGIS</translation>
+        <translation>Kunde inte ladda PyQGIS.</translation>
     </message>
     <message>
         <location filename="../src/python/qgspythonutilsimpl.cpp" line="90"/>
@@ -7564,13 +7570,15 @@
         <location filename="../src/app/qgisapp.cpp" line="1993"/>
         <source>
 This copy of QGIS has been built with SpatiaLite support.</source>
-        <translation>Denna QGIS har byggts med SpatiaLite-stöd</translation>
+        <translation>
+Denna QGIS har byggts med SpatiaLite-stöd.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="1996"/>
         <source>
 This copy of QGIS has been built without SpatiaLite support.</source>
-        <translation>Denna QGIS har inte byggts med SpatiaLite-stöd</translation>
+        <translation>
+Denna QGIS har inte byggts med SpatiaLite-stöd.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="794"/>
@@ -10035,12 +10043,12 @@
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="691"/>
         <source>Qt4 svg code. Of note, text does not appear in the SVG file and there are problems with the map bounding box clipping other items such as the legend or scale bar.&lt;/p&gt;</source>
+        <translation>Qt4 SVG kod. T.ex. syn text inte i SVG-filer och det finns problem med kartans begränsningslinjer som klipper andra saker såsom skala och teckenförklaring.&lt;/p&gt;</translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="696"/>
         <source>Qt4 svg code. In particular, there are problems with layers not being clipped to the map bounding box.&lt;/p&gt;</source>
+        <translation>Qt4 SVG kod. T.ex. är det problem med lager som inte klipps av kartans begränsningslinjer.&lt;/p&gt;</translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="561"/>
@@ -10050,43 +10058,43 @@
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="700"/>
         <source>If you require a vector-based output file from Qgis it is suggested that you try printing to PostScript if the SVG output is not satisfactory.&lt;/p&gt;</source>
+        <translation>Om du behöver en vektorbaserad utskrift från QGIS, föreslår vi att du försöker skriva till PostScript, om du inte är nöjd med resultatet från SVG.&lt;/p&gt;</translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="806"/>
         <source>save template</source>
+        <translation>Spara mall</translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="832"/>
         <source>Save error</source>
+        <translation>Kunde inte spara</translation>
     </message>
     <message>
         <source>Error, could not save file</source>
+        <translation>Kunde inte spara fil</translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="840"/>
         <source>Load template</source>
+        <translation>Läs in mall</translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="853"/>
         <location filename="../src/app/composer/qgscomposer.cpp" line="860"/>
         <source>Read error</source>
+        <translation>Läsfel</translation>
     </message>
     <message>
         <source>Error, could not read file</source>
+        <translation>Kunde inte läsa filen</translation>
     </message>
     <message>
         <source>Content of template file is not valid</source>
+        <translation>Innehållet i mallfilen är ej giltigt</translation>
     </message>
 </context>
 <context>
@@ -10223,17 +10231,17 @@
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="335"/>
         <source>Export as Image...</source>
-        <translation>Exportera som bild</translation>
+        <translation>Exportera som bild...</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="343"/>
         <source>Export as PDF...</source>
+        <translation>Exportera som PDF...</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="351"/>
         <source>Export as SVG...</source>
-        <translation>Exportera som SVG</translation>
+        <translation>Exportera som SVG...</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="359"/>
@@ -10248,138 +10256,138 @@
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="386"/>
         <source>Move Content</source>
-        <translation type="unfinished">Flytta innehåll</translation>
+        <translation>Flytta innehåll</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="389"/>
         <source>Move item content</source>
+        <translation>Flytta elementens innehåll</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="394"/>
         <source>Group</source>
-        <translation type="unfinished">Grupp</translation>
+        <translation>GruppGrupp</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="397"/>
         <source>Group items</source>
-        <translation type="unfinished">Gruppera element</translation>
+        <translation>Gruppera element</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="402"/>
         <source>Ungroup</source>
+        <translation>Ta bort grupp</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="405"/>
         <source>Ungroup items</source>
-        <translation type="unfinished">Ta bort elementens grupp</translation>
+        <translation>Ta bort elementens grupp</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="410"/>
         <source>Raise</source>
-        <translation type="unfinished">Höj</translation>
+        <translation>Höj</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="413"/>
         <source>Raise selected items</source>
-        <translation type="unfinished">Höj valda element</translation>
+        <translation>Höj valda element</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="418"/>
         <source>Lower</source>
+        <translation>Sänk</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="421"/>
         <source>Lower selected items</source>
-        <translation type="unfinished">Sänk valda element</translation>
+        <translation>Sänk valda element</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="426"/>
         <source>Bring to Front</source>
-        <translation type="unfinished">Flytta överst</translation>
+        <translation>Flytta överst</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="429"/>
         <source>Move selected items to top</source>
-        <translation type="unfinished">Flytta valda element överst</translation>
+        <translation>Flytta valda element överst</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="434"/>
         <source>Send to Back</source>
-        <translation type="unfinished">Flytta underst</translation>
+        <translation>Flytta underst</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="437"/>
         <source>Move selected items to bottom</source>
-        <translation type="unfinished">Flytta valda element underst</translation>
+        <translation>Flytta valda element underst</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="442"/>
         <source>Load From template</source>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="447"/>
         <source>Save as template</source>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="452"/>
         <source>Align left</source>
+        <translation>Justera vänster</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="455"/>
         <source>Align selected items left</source>
+        <translation>Justera valda element vänster</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="460"/>
         <source>Align center</source>
+        <translation>Justera mitten</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="463"/>
         <source>Align center horizontal</source>
+        <translation>Justera mitten horisontellt</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="468"/>
         <source>Align right</source>
+        <translation>Justera höger</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="471"/>
         <source>Align selected items right</source>
+        <translation>Justera valda element höger</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="476"/>
         <source>Align top</source>
+        <translation>Justera upp</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="479"/>
         <source>Align selected items to top</source>
+        <translation>Justera valda element upp</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="484"/>
         <location filename="../src/ui/qgscomposerbase.ui" line="487"/>
         <source>Align center vertical</source>
+        <translation>Justera mitten vertikalt</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="492"/>
         <source>Align bottom</source>
+        <translation>Justera ned</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerbase.ui" line="495"/>
         <source>Align selected items bottom</source>
+        <translation>Justera valda element ned</translation>
     </message>
 </context>
 <context>
@@ -10862,12 +10870,12 @@
     <message>
         <location filename="../src/app/composer/qgscomposerpicturewidget.cpp" line="172"/>
         <source>Select new preview directory</source>
-        <translation type="unfinished">Välj nytt bibliotek för förhandsvisning</translation>
+        <translation>Välj nytt bibliotek för förhandsvisning</translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposerpicturewidget.cpp" line="244"/>
         <source>Creating icon for file %1</source>
-        <translation type="unfinished">Skapar ikon för filen %1</translation>
+        <translation>Skapar ikon för filen %1</translation>
     </message>
 </context>
 <context>
@@ -10900,22 +10908,22 @@
     <message>
         <location filename="../src/ui/qgscomposerpicturewidgetbase.ui" line="31"/>
         <source>Search directories</source>
-        <translation type="unfinished">Sökvägar</translation>
+        <translation>Sökvägar</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerpicturewidgetbase.ui" line="50"/>
         <source>Add...</source>
-        <translation type="unfinished">Lägg till ...</translation>
+        <translation>Lägg till ...</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerpicturewidgetbase.ui" line="57"/>
         <source>Remove</source>
-        <translation type="unfinished">Ta bort</translation>
+        <translation>Ta bort</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerpicturewidgetbase.ui" line="83"/>
         <source>Preview</source>
-        <translation type="unfinished">Förhandsvisning</translation>
+        <translation>Förhandsvisning</translation>
     </message>
 </context>
 <context>
@@ -15425,7 +15433,7 @@
         <location filename="../src/plugins/grass/qgsgrassbrowser.cpp" line="269"/>
         <location filename="../src/plugins/grass/qgsgrassbrowser.cpp" line="342"/>
         <source>New name for layer &quot;%1&quot;</source>
+        <translation>Nytt namn för lager &quot;%1&quot;</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/qgsgrassbrowser.cpp" line="284"/>
@@ -19445,22 +19453,22 @@
     <message>
         <location filename="../src/ui/qgslabeldialogbase.ui" line="669"/>
         <source>&amp;Bold</source>
-        <translation>&amp;Fet:</translation>
+        <translation>&amp;Fet</translation>
     </message>
     <message>
         <location filename="../src/ui/qgslabeldialogbase.ui" line="695"/>
         <source>&amp;Italic</source>
-        <translation>&amp;Kursiv:</translation>
+        <translation>&amp;Kursiv</translation>
     </message>
     <message>
         <location filename="../src/ui/qgslabeldialogbase.ui" line="721"/>
         <source>&amp;Underline</source>
-        <translation>&amp;Understruken:</translation>
+        <translation>&amp;Understruken</translation>
     </message>
     <message>
         <location filename="../src/ui/qgslabeldialogbase.ui" line="747"/>
         <source>&amp;Size</source>
-        <translation>&amp;Storlek:</translation>
+        <translation>&amp;Storlek</translation>
     </message>
     <message>
         <location filename="../src/ui/qgslabeldialogbase.ui" line="773"/>
@@ -20154,12 +20162,12 @@
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="651"/>
         <source>User database could not be opened.</source>
-        <translation>Användardatabasen kunde inte öppnas</translation>
+        <translation>Användardatabasen kunde inte öppnas.</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="666"/>
         <source>The style table could not be created.</source>
-        <translation>Stiltabellen kunde inte skapas</translation>
+        <translation>Stiltabellen kunde inte skapas.</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="681"/>
@@ -20169,44 +20177,46 @@
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="698"/>
         <source>The style %1 was updated in the database.</source>
-        <translation>Stilen %1 uppdaterades i databasen</translation>
+        <translation>Stilen %1 uppdaterades i databasen.</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="703"/>
         <source>The style %1 could not be updated in the database.</source>
-        <translation>Stilen %1 kunde inte uppdateras i databasen</translation>
+        <translation>Stilen %1 kunde inte uppdateras i databasen.</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="710"/>
         <source>The style %1 could not be inserted into database.</source>
-        <translation>Stilen %1 kunde inte infogas i databasen</translation>
+        <translation>Stilen %1 kunde inte infogas i databasen.</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="576"/>
         <source>Loading style file %1 failed because:
 %2</source>
+        <translation>Inläsning av mallfil %1 misslyckades:
+%2</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="604"/>
         <source>Could not save symbology because:
 %1</source>
+        <translation>Kunde inte spara symbologi eftersom:
+%1</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="616"/>
         <source>The directory containing your dataset needs to be writeable!</source>
-        <translation type="unfinished">Biblioteket som innehåller din datamängd måste vara skrivbart!</translation>
+        <translation>Biblioteket som innehåller ditt dataset måste vara skrivbart!</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="630"/>
         <source>Created default style file as %1</source>
+        <translation>Skapa standardstil-fil med namn %1</translation>
     </message>
     <message>
         <location filename="../src/core/qgsmaplayer.cpp" line="635"/>
         <source>ERROR: Failed to created default style file as %1. Check file permissions and retry.</source>
+        <translation>FEL: Kunde inte skapa förvald stilfil %1. Kontrollera filrättigheter och försök igen.</translation>
     </message>
 </context>
 <context>
@@ -20214,101 +20224,101 @@
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="49"/>
         <source>Not a vector layer</source>
-        <translation type="unfinished">Inte ett vektorlager</translation>
+        <translation>Inte ett vektorlager</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="50"/>
         <source>The current layer is not a vector layer</source>
-        <translation type="unfinished">Nuvarande lager är inte ett vektorlager</translation>
+        <translation>Nuvarande lager är inte ett vektorlager</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="60"/>
         <source>2.5D shape type not supported</source>
-        <translation type="unfinished">2.5D shape typ stöds ej</translation>
+        <translation>2.5D shape typ stöds ej</translation>
     </message>
     <message>
         <source>Adding features to 2.5D shapetypes is not supported yet</source>
-        <translation type="unfinished">Stödjer ännu ej att lägga till objekt till 2.5D shapefil</translation>
+        <translation>Stödjer ännu ej att lägga till objekt till 2.5D shapefil</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="73"/>
         <source>Layer cannot be added to</source>
-        <translation type="unfinished">Lager kan inte läggas till</translation>
+        <translation>Lager kan inte läggas till</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="74"/>
         <source>The data provider for this layer does not support the addition of features.</source>
-        <translation type="unfinished">Datakälla för detta lager stödjer inte tillägg av objekt.</translation>
+        <translation>Datakälla för detta lager stödjer inte tillägg av objekt.</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="80"/>
         <source>Layer not editable</source>
-        <translation type="unfinished">Lagret kan inte redigeras</translation>
+        <translation>Lagret kan inte redigeras</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="81"/>
         <source>Cannot edit the vector layer. To make it editable, go to the file item of the layer, right click and check &apos;Allow Editing&apos;.</source>
-        <translation type="unfinished">Kan inte redigera vektorlagret. För att göra detta möjligt, högerklicka och fyll i &apos;Tillåt redigering&apos;.</translation>
+        <translation>Kan inte redigera vektorlagret. För att göra detta möjligt, högerklicka och fyll i &apos;Tillåt redigering&apos;.</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="92"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="216"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="224"/>
         <source>Wrong editing tool</source>
-        <translation type="unfinished">Fel redigeringsverktyg</translation>
+        <translation>Fel redigeringsverktyg</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="93"/>
         <source>Cannot apply the &apos;capture point&apos; tool on this vector layer</source>
-        <translation type="unfinished">Kan inte använda &apos;skapa punkt&apos;-verktyget på detta lager</translation>
+        <translation>Kan inte använda &apos;skapa punkt&apos;-verktyget på detta lager</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="113"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="239"/>
         <source>Coordinate transform error</source>
-        <translation type="unfinished">Koordinattransformeringsfel</translation>
+        <translation>Koordinattransformeringsfel</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="114"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="240"/>
         <source>Cannot transform the point to the layers coordinate system</source>
-        <translation type="unfinished">Kan inte transformera punkten till lagrets koordinatsystem</translation>
+        <translation>Kan inte transformera punkten till lagrets koordinatsystem</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="178"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="468"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="485"/>
         <source>Feature added</source>
+        <translation>Objekt lades till</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="217"/>
         <source>Cannot apply the &apos;capture line&apos; tool on this vector layer</source>
-        <translation type="unfinished">Kan inte använda &apos;skapa linje&apos;-verktyget på detta vektorlager</translation>
+        <translation>Kan inte använda &apos;skapa linje&apos;-verktyget på detta vektorlager</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="225"/>
         <source>Cannot apply the &apos;capture polygon&apos; tool on this vector layer</source>
-        <translation type="unfinished">Kan inte använda &apos;skapa polygon&apos;-verktyget på detta vektorlager</translation>
+        <translation>Kan inte använda &apos;skapa polygon&apos;-verktyget på detta vektorlager</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="341"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="437"/>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="452"/>
         <source>Error</source>
-        <translation type="unfinished">Fel</translation>
+        <translation>Fel</translation>
     </message>
     <message>
         <source>Cannot add feature. Unknown WKB type</source>
-        <translation type="unfinished">Kan inte lägga till objekt. Okänd WKB-typ</translation>
+        <translation>Kan inte lägga till objekt. Okänd WKB-typ</translation>
     </message>
     <message>
         <source>Could not remove polygon intersection</source>
-        <translation type="unfinished">Kunde inte ta bort polygonskärning</translation>
+        <translation>Kunde inte ta bort polygonskärning</translation>
     </message>
 </context>
 <context>
@@ -20316,43 +20326,43 @@
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="43"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="44"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="50"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="51"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="70"/>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="135"/>
         <source>Error, could not add island</source>
-        <translation type="unfinished">Fel, kunde inte lägga till ö</translation>
+        <translation>Fel, kunde inte lägga till ö</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="87"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="88"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="104"/>
         <source>Island added</source>
+        <translation>Ö lades till</translation>
     </message>
 </context>
 <context>
@@ -20360,72 +20370,72 @@
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="43"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="44"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="50"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="51"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="66"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="67"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="84"/>
         <source>Ring added</source>
+        <translation>Ring lades till</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="93"/>
         <source>A problem with geometry type occured</source>
-        <translation type="unfinished">Fel med geometrityp inträffade</translation>
+        <translation>Fel med geometrityp inträffade</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="97"/>
         <source>The inserted Ring is not closed</source>
-        <translation type="unfinished">Tillagd ring är inte sluten</translation>
+        <translation>Tillagd ring är inte sluten</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="101"/>
         <source>The inserted Ring is not a valid geometry</source>
-        <translation type="unfinished">Tillagd ring är inte giltig geometri</translation>
+        <translation>Tillagd ring är inte en giltig geometri</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="105"/>
         <source>The inserted Ring crosses existing rings</source>
-        <translation type="unfinished">Tillagd ring skär befintliga ringar</translation>
+        <translation>Tillagd ring skär befintliga ringar</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="109"/>
         <source>The inserted Ring is not contained in a feature</source>
-        <translation type="unfinished">Tillagd ring är inte innesluten i ett objekt</translation>
+        <translation>Tillagd ring är inte innesluten i ett objekt</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="113"/>
         <source>An unknown error occured</source>
-        <translation type="unfinished">Okänt fel inträffade</translation>
+        <translation>Okänt fel inträffade</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="115"/>
         <source>Error, could not add ring</source>
-        <translation type="unfinished">Fel, kunde inte lägga till ring</translation>
+        <translation>Fel, kunde inte lägga till ring</translation>
     </message>
 </context>
 <context>
@@ -20433,7 +20443,7 @@
     <message>
         <location filename="../src/app/qgsmaptooladdvertex.cpp" line="125"/>
         <source>Added vertex</source>
+        <translation>Nod lades till</translation>
     </message>
 </context>
 <context>
@@ -20442,22 +20452,22 @@
         <location filename="../src/app/qgsmaptooldeletepart.cpp" line="101"/>
         <location filename="../src/app/qgsmaptooldeletepart.cpp" line="116"/>
         <source>Delete part</source>
+        <translation>Ta bort del</translation>
     </message>
     <message>
         <source>This isn&apos;t a multipart geometry.</source>
+        <translation>Detta är inte en flerdelad geometri.</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooldeletepart.cpp" line="109"/>
         <source>Part of multipart feature deleted</source>
+        <translation>Del av flerdelad geometri togs bort</translation>
     </message>
     <message>
         <source>Couldn&apos;t remove the selected part.</source>
+        <translation>Kunde inte ta bort vald del.</translation>
     </message>
 </context>
 <context>
@@ -20465,7 +20475,7 @@
     <message>
         <location filename="../src/app/qgsmaptooldeletering.cpp" line="114"/>
         <source>Ring deleted</source>
+        <translation>Ring togs bort</translation>
     </message>
 </context>
 <context>
@@ -20473,7 +20483,7 @@
     <message>
         <location filename="../src/app/qgsmaptooldeletevertex.cpp" line="83"/>
         <source>Vertex deleted</source>
+        <translation>Nod togs bort</translation>
     </message>
 </context>
 <context>
@@ -20585,13 +20595,15 @@
         <source>Could not draw %1 because:
 %2</source>
         <comment>COMMENTED OUT</comment>
+        <translation>Could not draw %1 because:
+%2</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolidentify.cpp" line="421"/>
         <source>Could not identify objects on %1 because:
 %2</source>
+        <translation>Could not identify objects on %1 because:
+%2</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolidentify.cpp" line="495"/>
@@ -20683,12 +20695,12 @@
     <message>
         <location filename="../src/app/qgsmaptoolsimplify.cpp" line="279"/>
         <source>Multipart features are not supported for simplification.</source>
+        <translation>Flerdelade objekt kan inte förenklas.</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsimplify.cpp" line="300"/>
         <source>This feature cannot be simplified. Check if feature has enough vertices to be simplified.</source>
+        <translation>Detta objekt kan inte förenklas. Kontrollera om objektet har tillräckligt med noder för att kunna förenklas.</translation>
     </message>
 </context>
 <context>
@@ -20723,7 +20735,7 @@
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="82"/>
         <source>Features split</source>
+        <translation>Objekt delades</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="87"/>
@@ -20733,32 +20745,32 @@
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="42"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="43"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="49"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="50"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="65"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="66"/>
     </message>
 </context>
 <context>
@@ -20839,7 +20851,8 @@
         <location filename="../src/app/qgsmapserverexport.cpp" line="74"/>
         <source>%1 exists.
 Do you want to overwrite it?</source>
+        <translation>%1 finns redan.
+Vill du skriva över den?</translation>
     </message>
 </context>
 <context>
@@ -22366,36 +22379,36 @@
     <message>
         <location filename="../src/app/qgsoptions.cpp" line="187"/>
         <source>Detected active locale on your system: %1</source>
+        <translation>Hittade aktiv lokalisering för ditt system: %1</translation>
     </message>
     <message>
         <location filename="../src/app/qgsoptions.cpp" line="239"/>
         <location filename="../src/app/qgsoptions.cpp" line="252"/>
         <location filename="../src/app/qgsoptions.cpp" line="476"/>
         <source>None</source>
-        <translation type="unfinished">Ingen</translation>
+        <translation>Ingen</translation>
     </message>
     <message>
         <location filename="../src/app/qgsoptions.cpp" line="217"/>
         <location filename="../src/app/qgsoptions.cpp" line="226"/>
         <source>map units</source>
-        <translation type="unfinished">kartenheter</translation>
+        <translation>kartenheter</translation>
     </message>
     <message>
         <location filename="../src/app/qgsoptions.cpp" line="221"/>
         <location filename="../src/app/qgsoptions.cpp" line="230"/>
         <source>pixels</source>
-        <translation type="unfinished">pixlar</translation>
+        <translation>pixlar</translation>
     </message>
     <message>
         <location filename="../src/app/qgsoptions.cpp" line="262"/>
         <source>Central point (fastest)</source>
+        <translation>Mittpunkt (snabbast)</translation>
     </message>
     <message>
         <location filename="../src/app/qgsoptions.cpp" line="263"/>
         <source>Chain (fast)</source>
+        <translation>Kedja (snabb)</translation>
     </message>
     <message>
         <location filename="../src/app/qgsoptions.cpp" line="264"/>
@@ -22952,7 +22965,7 @@
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="230"/>
         <source>Add PostGIS layers with double click and select in extended mode</source>
+        <translation>Lägg till PostGIS-lager med dubbelklick och välj i utökad mod</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="263"/>
@@ -23002,17 +23015,17 @@
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="482"/>
         <source>Preferred measurements units</source>
+        <translation>Mätenheter som föredras</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="489"/>
         <source>Meters</source>
-        <translation type="unfinished">Meter</translation>
+        <translation>Meter</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="496"/>
         <source>Feet</source>
-        <translation type="unfinished">Feet</translation>
+        <translation>Feet</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="515"/>
@@ -23057,7 +23070,7 @@
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="818"/>
         <source>Show markers only for selected features</source>
+        <translation>Visa markör bara för valda objekt</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="825"/>
@@ -23138,59 +23151,59 @@
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="858"/>
         <source>Enter attribute values</source>
+        <translation>Ange attributvärden</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="864"/>
         <source>Suppress attributes pop-up windows after each created feature</source>
+        <translation>Förhindra att attributfönster visas efter varje skapat objekt</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="1109"/>
         <source>Proxy type</source>
+        <translation>Mellanvärdstyp</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="1132"/>
         <source>Exclude URLs:</source>
+        <translation>Undanta URL:er:</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="1139"/>
         <source>Add</source>
-        <translation type="unfinished">Lägg till</translation>
+        <translation>Lägg till</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="1146"/>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="568"/>
         <source>Overlay</source>
+        <translation>Överlager</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="580"/>
         <source>Position</source>
-        <translation type="unfinished">Position</translation>
+        <translation>Position</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="595"/>
         <source>Placement algorithm:</source>
+        <translation>Placeringsalgoritm:</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="782"/>
         <location filename="../src/ui/qgsoptionsbase.ui" line="796"/>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="787"/>
         <location filename="../src/ui/qgsoptionsbase.ui" line="801"/>
     </message>
 </context>
 <context>
@@ -27907,7 +27920,7 @@
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1476"/>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1479"/>
         <source>Specify the coordinate reference system of the layer&apos;s geometry.</source>
-        <translation type="unfinished">Specificera koordinatsystemet för lagrets geometrier.</translation>
+        <translation>Specificera koordinatsystemet för lagrets geometrier.</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1482"/>
@@ -28740,14 +28753,18 @@
 The error was:
 %2
 </source>
+        <translation>Database gav ett felmeddelande när följande SQL-fråga kördes:
+%1
+Felet var:
+%2</translation>
     </message>
     <message>
         <location filename="../src/plugins/spit/qgsshapefile.cpp" line="450"/>
         <source>The error was:
 %1
 </source>
+        <translation>Felet var:
+%1</translation>
     </message>
 </context>
 <context>
@@ -29245,17 +29262,17 @@
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="112"/>
         <source>Text</source>
+        <translation>Text</translation>
     </message>
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="113"/>
         <source>Double</source>
+        <translation>Double</translation>
     </message>
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="114"/>
         <source>Integer</source>
-        <translation type="unfinished">Heltal</translation>
+        <translation>Heltal</translation>
     </message>
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="237"/>
@@ -29267,7 +29284,9 @@
         <source>SQLite error: %1
 SQL: %2</source>
+        <translation>SQLite fel: %1
+SQL: %2</translation>
     </message>
 </context>
 <context>
@@ -31488,7 +31507,7 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="337"/>
         <source>Legend type</source>
-        <translation>Typ av teckenförklaring:</translation>
+        <translation>Typ av teckenförklaring</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="375"/>
@@ -33474,7 +33493,7 @@
     </message>
     <message>
         <source>Convex hull(s)</source>
-        <translation type="unfinished">Konve</translation>
+        <translation>Konvex</translation>
     </message>
     <message>
More information about the QGIS-commit mailing list
