[QGIS Commit] r12312 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Dec 2 16:08:13 EST 2009
Author: jef
Date: 2009-12-02 16:08:12 -0500 (Wed, 02 Dec 2009)
New Revision: 12312
   trunk/qgis/src/app/qgsspatialitesourceselect.cpp
fix #2179
Modified: trunk/qgis/src/app/qgsspatialitesourceselect.cpp
--- trunk/qgis/src/app/qgsspatialitesourceselect.cpp	2009-12-02 20:47:39 UTC (rev 12311)
+++ trunk/qgis/src/app/qgsspatialitesourceselect.cpp	2009-12-02 21:08:12 UTC (rev 12312)
@@ -304,40 +304,34 @@
 // Retrieve last used project dir from persistent settings
   sqlite3 *handle;
   QSettings settings;
-  QString fullPath;
   QString lastUsedDir = settings.value( "/UI/lastSpatiaLiteDir", "." ).toString();
   QString myFile = QFileDialog::getOpenFileName( this,
-      tr( "Choose a SpatiaLite/SQLite DB to open" ),
-      lastUsedDir, QObject::tr( "SQLite DB (*.sqlite);;All files (*.*)" ) );
+                   tr( "Choose a SpatiaLite/SQLite DB to open" ),
+                   lastUsedDir, QObject::tr( "SQLite DB (*.sqlite);;All files (*.*)" ) );
   if ( myFile.isEmpty() )
-    QFileInfo myFI( myFile );
-    QString myPath = myFI.path();
-    QString myName = myFI.fileName();
+    return;
-    handle = openSpatiaLiteDb( myFI.canonicalFilePath() );
-    if ( handle )
-      // OK, this one is a valid SpatiaLite DB
-      closeSpatiaLiteDb( handle );
+  QFileInfo myFI( myFile );
+  QString myPath = myFI.path();
+  QString myName = myFI.fileName();
-      // Persist last used SpatiaLite dir
-      settings.setValue( "/UI/lastSpatiaLiteDir", myPath );
-      // inserting this SQLite DB path
-      QString baseKey = "/SpatiaLite/connections/";
-      settings.setValue( baseKey + "selected", myName );
-      baseKey += myName;
-      settings.setValue( baseKey + "/sqlitepath", fullPath );
-  else
-    // if they didn't select anything, just return
+  handle = openSpatiaLiteDb( myFI.canonicalFilePath() );
+  if ( !handle )
     return;
+  // OK, this one is a valid SpatiaLite DB
+  closeSpatiaLiteDb( handle );
+  // Persist last used SpatiaLite dir
+  settings.setValue( "/UI/lastSpatiaLiteDir", myPath );
+  // inserting this SQLite DB path
+  QString baseKey = "/SpatiaLite/connections/";
+  settings.setValue( baseKey + "selected", myName );
+  baseKey += myName;
+  settings.setValue( baseKey + "/sqlitepath", myFI.canonicalFilePath() );
   populateConnectionList();
More information about the QGIS-commit mailing list
