[QGIS Commit] r12365 - in trunk/qgis/src: core/symbology-ng gui/symbology-ng
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Dec 7 19:08:58 EST 2009
Author: wonder
Date: 2009-12-07 19:08:57 -0500 (Mon, 07 Dec 2009)
New Revision: 12365
   trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
   trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.h
   trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
Symbology-NG: support for additional SVG paths - fix for #2157
Modified: trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp	2009-12-07 23:59:35 UTC (rev 12364)
+++ trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp	2009-12-08 00:08:57 UTC (rev 12365)
@@ -5,9 +5,12 @@
 #include "qgsrendercontext.h"
 #include "qgsapplication.h"
 #include "qgslogger.h"
+#include "qgsproject.h"
 #include <QPainter>
 #include <QSvgRenderer>
+#include <QFileInfo>
+#include <QDir>
 #include <cmath>
@@ -105,11 +108,11 @@
     << QPointF( -half, -sixth )
     << QPointF( -sixth, 0 )
     << QPointF( -half, half )
-    << QPointF( 0, +sixth )
+    << QPointF( 0, + sixth )
     << QPointF( half, half )
-    << QPointF( +sixth, 0 )
+    << QPointF( + sixth, 0 )
     << QPointF( half, -sixth )
-    << QPointF( +sixth, -sixth );
+    << QPointF( + sixth, -sixth );
   else if ( mName == "regular_star" )
@@ -248,7 +251,7 @@
 QgsSvgMarkerSymbolLayerV2::QgsSvgMarkerSymbolLayerV2( QString name, double size, double angle )
-  mName = name;
+  mPath = symbolNameToPath( name );
   mSize = size;
   mAngle = angle;
   mOffset = QPointF( 0, 0 );
@@ -282,11 +285,8 @@
 void QgsSvgMarkerSymbolLayerV2::startRender( QgsRenderContext& context )
-  QString svgPath = QgsApplication::svgPath();
-  QString file = svgPath + "/" + mName;
   QRectF rect( QPointF( -mSize / 2.0, -mSize / 2.0 ), QSizeF( mSize, mSize ) );
-  QSvgRenderer renderer( file );
+  QSvgRenderer renderer( mPath );
   QPainter painter( &mPicture );
   renderer.render( &painter, rect );
@@ -317,7 +317,7 @@
 QgsStringMap QgsSvgMarkerSymbolLayerV2::properties() const
   QgsStringMap map;
-  map["name"] = mName;
+  map["name"] = symbolPathToName( mPath );
   map["size"] = QString::number( mSize );
   map["angle"] = QString::number( mAngle );
   map["offset"] = QgsSymbolLayerV2Utils::encodePoint( mOffset );
@@ -326,7 +326,105 @@
 QgsSymbolLayerV2* QgsSvgMarkerSymbolLayerV2::clone() const
-  QgsSvgMarkerSymbolLayerV2* m = new QgsSvgMarkerSymbolLayerV2( mName, mSize, mAngle );
+  QgsSvgMarkerSymbolLayerV2* m = new QgsSvgMarkerSymbolLayerV2( mPath, mSize, mAngle );
   m->setOffset( mOffset );
   return m;
+QStringList QgsSvgMarkerSymbolLayerV2::listSvgFiles()
+  // copied from QgsMarkerCatalogue - TODO: unify
+  QStringList list;
+  QStringList svgPaths = QgsApplication::svgPaths();
+  for ( int i = 0; i < svgPaths.size(); i++ )
+    QDir dir( svgPaths[i] );
+    foreach( QString item, dir.entryList( QDir::Dirs | QDir::NoDotAndDotDot ) )
+      svgPaths.insert( i + 1, dir.path() + "/" + item );
+    foreach( QString item, dir.entryList( QStringList( "*.svg" ), QDir::Files ) )
+      // TODO test if it is correct SVG
+      list.append( dir.path() + "/" + item );
+  return list;
+QString QgsSvgMarkerSymbolLayerV2::symbolNameToPath( QString name )
+  // copied from QgsSymbol::setNamedPointSymbol - TODO: unify
+  // we might have a full path...
+  if ( QFile( name ).exists() )
+    return QFileInfo( name ).canonicalFilePath();
+  // SVG symbol not found - probably a relative path was used
+    QgsDebugMsg( "SvgPath: " + svgPaths[i] );
+    QFileInfo myInfo( name );
+    QString myFileName = myInfo.fileName(); // foo.svg
+    QString myLowestDir = myInfo.dir().dirName();
+    QString myLocalPath = svgPaths[i] + "/" + myLowestDir + "/" + myFileName;
+    QgsDebugMsg( "Alternative svg path: " + myLocalPath );
+    if ( QFile( myLocalPath ).exists() )
+      QgsDebugMsg( "Svg found in alternative path" );
+      return QFileInfo( myLocalPath ).canonicalFilePath();
+    else if ( myInfo.isRelative() )
+      QFileInfo pfi( QgsProject::instance()->fileName() );
+      QString alternatePath = pfi.canonicalPath() + QDir::separator() + name;
+      if ( pfi.exists() && QFile( alternatePath ).exists() )
+        return QFileInfo( alternatePath ).canonicalFilePath();
+      else
+        QgsDebugMsg( "Svg not found in project path" );
+    else
+      //couldnt find the file, no happy ending :-(
+      QgsDebugMsg( "Computed alternate path but no svg there either" );
+  return QString();
+QString QgsSvgMarkerSymbolLayerV2::symbolPathToName( QString path )
+  // copied from QgsSymbol::writeXML
+  QFileInfo fi( path );
+  if ( !fi.exists() )
+    return path;
+  path = fi.canonicalFilePath();
+    QString dir = QFileInfo( svgPaths[i] ).canonicalFilePath();
+    if ( !dir.isEmpty() && path.startsWith( dir ) )
+      path = path.mid( dir.size() );
+      break;
+  return path;
Modified: trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.h
--- trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.h	2009-12-07 23:59:35 UTC (rev 12364)
+++ trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.h	2009-12-08 00:08:57 UTC (rev 12365)
@@ -62,7 +62,7 @@
-#define DEFAULT_SVGMARKER_NAME         "symbol/Star1.svg"
+#define DEFAULT_SVGMARKER_NAME         "/symbol/Star1.svg"
 #define DEFAULT_SVGMARKER_SIZE         9
 #define DEFAULT_SVGMARKER_ANGLE        0
@@ -77,6 +77,15 @@
     static QgsSymbolLayerV2* create( const QgsStringMap& properties = QgsStringMap() );
+    //! Return a list of all available svg files
+    static QStringList listSvgFiles();
+    //! Get symbol's path from its name
+    static QString symbolNameToPath( QString name );
+    //! Get symbols's name from its path
+    static QString symbolPathToName( QString path );
     // implemented from base classes
     QString layerType() const;
@@ -91,14 +100,14 @@
     QgsSymbolLayerV2* clone() const;
-    QString name() const { return mName; }
-    void setName( QString name ) { mName = name; }
+    QString path() const { return mPath; }
+    void setPath( QString path ) { mPath = path; }
   protected:
     void loadSvg();
-    QString mName;
+    QString mPath;
     QPicture mPicture;
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp	2009-12-07 23:59:35 UTC (rev 12364)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp	2009-12-08 00:08:57 UTC (rev 12365)
@@ -372,43 +372,29 @@
   QStandardItemModel* m = new QStandardItemModel( viewImages );
   viewImages->setModel( m );
   QSvgRenderer renderer;
   QPainter painter;
-  QDir dir( svgPath );
-  QStringList dl = dir.entryList( QDir::Dirs );
-  for ( QStringList::iterator it = dl.begin(); it != dl.end(); ++it )
+  foreach( QString entry, QgsSvgMarkerSymbolLayerV2::listSvgFiles() )
-    if ( *it == "." || *it == ".." ) continue;
+    // render SVG file
+    renderer.load( entry );
+    QPixmap pixmap( renderer.defaultSize() );
+    pixmap.fill();
+    painter.begin( &pixmap );
+    renderer.render( &painter );
+    painter.end();
-    QDir dir2( svgPath + *it );
-    QStringList dl2 = dir2.entryList( QStringList( "*.svg" ), QDir::Files );
-    for ( QStringList::iterator it2 = dl2.begin(); it2 != dl2.end(); ++it2 )
-      // TODO test if it is correct SVG
-      QString entry = *it2;
-      // render SVG file
-      renderer.load( dir2.filePath( *it2 ) );
-      QPixmap pixmap( renderer.defaultSize() );
-      pixmap.fill();
-      painter.begin( &pixmap );
-      renderer.render( &painter );
-      painter.end();
-      // add item
-      QStandardItem* item = new QStandardItem( QIcon( pixmap ), *it + "/" + entry );
-      m->appendRow( item );
+    // add item
+    QStandardItem* item = new QStandardItem( QIcon( pixmap ), QString() );
+    item->setData( entry, Qt::UserRole );
+    item->setToolTip( entry );
+    m->appendRow( item );
 void QgsSvgMarkerSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
   if ( layer->layerType() != "SvgMarker" )
@@ -420,13 +406,18 @@
   // set values
   QStandardItemModel* m = static_cast<QStandardItemModel*>( viewImages->model() );
-  QList<QStandardItem*> items = m->findItems( mLayer->name() );
-  if ( items.count() > 0 )
+  for ( int i = 0; i < m->rowCount(); i++ )
-    QModelIndex idx = items[0]->index();
-    viewImages->selectionModel()->select( idx, QItemSelectionModel::SelectCurrent );
+    QStandardItem* item = m->item( i, 0 );
+    if ( item->data( Qt::UserRole ).toString() == mLayer->path() )
+      viewImages->selectionModel()->select( item->index(), QItemSelectionModel::SelectCurrent );
+      viewImages->selectionModel()->setCurrentIndex( item->index(), QItemSelectionModel::SelectCurrent );
+      break;
   spinSize->setValue( mLayer->size() );
   spinAngle->setValue( mLayer->angle() );
@@ -446,9 +437,8 @@
 void QgsSvgMarkerSymbolLayerV2Widget::setName( const QModelIndex& idx )
-  mLayer->setName( idx.data().toString() );
+  mLayer->setPath( idx.data( Qt::UserRole ).toString() );
-  //mLayer->setName(lstNames->currentItem()->data(Qt::UserRole).toString());
   emit changed();
More information about the QGIS-commit mailing list
