[QGIS Commit] r12373 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Dec 8 06:22:50 EST 2009
Author: jef
Date: 2009-12-08 06:22:49 -0500 (Tue, 08 Dec 2009)
New Revision: 12373
   trunk/qgis/src/app/qgspgsourceselect.cpp
   trunk/qgis/src/app/qgspgsourceselect.h
save geometry of postgresql selection dialog
Modified: trunk/qgis/src/app/qgspgsourceselect.cpp
--- trunk/qgis/src/app/qgspgsourceselect.cpp	2009-12-08 10:35:07 UTC (rev 12372)
+++ trunk/qgis/src/app/qgspgsourceselect.cpp	2009-12-08 11:22:49 UTC (rev 12373)
@@ -84,17 +84,44 @@
   //for Qt < 4.3.2, passing -1 to include all model columns
   //in search does not seem to work
   mSearchColumnComboBox->setCurrentIndex( 2 );
+  restoreGeometry( settings.value( "/Windows/PgSourceSelect/geometry" ).toByteArray() );
 /** Autoconnected SLOTS **/
 // Slot for adding a new connection
 void QgsPgSourceSelect::on_btnNew_clicked()
-  addNewConnection();
+  QgsNewConnection *nc = new QgsNewConnection( this );
+  if ( nc->exec() )
+    populateConnectionList();
 // Slot for deleting an existing connection
 void QgsPgSourceSelect::on_btnDelete_clicked()
-  deleteConnection();
+  QSettings settings;
+  QString key = "/Postgresql/connections/" + cmbConnections->currentText();
+  QString msg = tr( "Are you sure you want to remove the %1 connection and all associated settings?" )
+                .arg( cmbConnections->currentText() );
+  QMessageBox::StandardButton result = QMessageBox::information( this, tr( "Confirm Delete" ), msg, QMessageBox::Ok | QMessageBox::Cancel );
+  if ( result == QMessageBox::Ok )
+    settings.remove( key + "/host" );
+    settings.remove( key + "/database" );
+    settings.remove( key + "/username" );
+    settings.remove( key + "/password" );
+    settings.remove( key + "/port" );
+    settings.remove( key + "/sslmode" );
+    settings.remove( key + "/save" );
+    settings.remove( key );
+    //if(!success){
+    //  QMessageBox::information(this,"Unable to Remove","Unable to remove the connection " + cmbConnections->currentText());
+    cmbConnections->removeItem( cmbConnections->currentIndex() );  // populateConnectionList();
+    setConnectionListPosition();
 // Slot for performing action when the Add button is clicked
 void QgsPgSourceSelect::addClicked()
@@ -105,7 +132,13 @@
 // Slot for editing a connection
 void QgsPgSourceSelect::on_btnEdit_clicked()
-  editConnection();
+  QgsNewConnection *nc = new QgsNewConnection( this, cmbConnections->currentText() );
+  if ( nc->exec() )
+    nc->saveConnection();
 /** End Autoconnected SLOTS **/
@@ -113,7 +146,9 @@
 // Remember which database is selected
 void QgsPgSourceSelect::on_cmbConnections_activated( int )
-  dbChanged();
+  // Remember which database was selected.
+  settings.setValue( "/PostgreSQL/connections/selected", cmbConnections->currentText() );
 void QgsPgSourceSelect::on_btnBuildQuery_clicked()
@@ -220,6 +255,9 @@
     delete mColumnTypeThread;
     mColumnTypeThread = NULL;
+  settings.setValue( "/Windows/PgSourceSelect/geometry", saveGeometry() );
 void QgsPgSourceSelect::populateConnectionList()
@@ -238,52 +276,6 @@
-void QgsPgSourceSelect::addNewConnection()
-  QgsNewConnection *nc = new QgsNewConnection( this );
-  if ( nc->exec() )
-    populateConnectionList();
-void QgsPgSourceSelect::editConnection()
-  QgsNewConnection *nc = new QgsNewConnection( this, cmbConnections->currentText() );
-  if ( nc->exec() )
-    nc->saveConnection();
-void QgsPgSourceSelect::deleteConnection()
-  QSettings settings;
-  QString key = "/Postgresql/connections/" + cmbConnections->currentText();
-  QString msg = tr( "Are you sure you want to remove the %1 connection and all associated settings?" )
-                .arg( cmbConnections->currentText() );
-  QMessageBox::StandardButton result = QMessageBox::information( this, tr( "Confirm Delete" ), msg, QMessageBox::Ok | QMessageBox::Cancel );
-  if ( result == QMessageBox::Ok )
-    settings.remove( key + "/host" );
-    settings.remove( key + "/database" );
-    settings.remove( key + "/username" );
-    settings.remove( key + "/password" );
-    settings.remove( key + "/port" );
-    settings.remove( key + "/sslmode" );
-    settings.remove( key + "/save" );
-    settings.remove( key );
-    //if(!success){
-    //  QMessageBox::information(this,"Unable to Remove","Unable to remove the connection " + cmbConnections->currentText());
-    cmbConnections->removeItem( cmbConnections->currentIndex() );  // populateConnectionList();
-    setConnectionListPosition();
 QString QgsPgSourceSelect::layerURI( const QModelIndex &index )
   QString schemaName = mTableModel.itemFromIndex( index.sibling( index.row(), QgsDbTableModel::dbtmSchema ) )->text();
@@ -735,14 +727,6 @@
   return full_desc;
-void QgsPgSourceSelect::dbChanged()
-  // Remember which database was selected.
-  settings.setValue( "/PostgreSQL/connections/selected",
-                     cmbConnections->currentText() );
 void QgsPgSourceSelect::setConnectionListPosition()
   QSettings settings;
Modified: trunk/qgis/src/app/qgspgsourceselect.h
--- trunk/qgis/src/app/qgspgsourceselect.h	2009-12-08 10:35:07 UTC (rev 12372)
+++ trunk/qgis/src/app/qgspgsourceselect.h	2009-12-08 11:22:49 UTC (rev 12373)
@@ -109,12 +109,6 @@
     QgsPgSourceSelect( QWidget *parent = 0, Qt::WFlags fl = QgisGui::ModalDialogFlags );
     //! Destructor
     ~QgsPgSourceSelect();
-    //! Opens the create connection dialog to build a new connection
-    void addNewConnection();
-    //! Opens a dialog to edit an existing connection
-    void editConnection();
-    //! Deletes the selected connection
-    void deleteConnection();
     //! Populate the connection list combo box
     void populateConnectionList();
     //! Determines the tables the user selected and closes the dialog
@@ -123,8 +117,6 @@
     QStringList selectedTables();
     //! Connection info (database, host, user, password)
     QString connectionInfo();
-    // Store the selected database
-    void dbChanged();
   public slots:
     void addClicked();
@@ -133,15 +125,19 @@
     * Once connected, available layers are displayed.
     void on_btnConnect_clicked();
+    //! Opens the create connection dialog to build a new connection
     void on_btnNew_clicked();
+    //! Opens a dialog to edit an existing connection
     void on_btnEdit_clicked();
     void on_btnBuildQuery_clicked();
+    //! Deletes the selected connection
     void on_btnDelete_clicked();
     void on_mSearchOptionsButton_clicked();
     void on_mSearchTableEdit_textChanged( const QString & text );
     void on_mSearchColumnComboBox_currentIndexChanged( const QString & text );
     void on_mSearchModeComboBox_currentIndexChanged( const QString & text );
     void setSql( const QModelIndex& index );
+    //! Store the selected database
     void on_cmbConnections_activated( int );
     void setLayerType( QString schema, QString table, QString column,
                        QString type );
@@ -191,7 +187,7 @@
     QgsDbFilterProxyModel mProxyModel;
     QString layerURI( const QModelIndex &index );
-    QPushButton * mAddButton;
+    QPushButton *mAddButton;
More information about the QGIS-commit mailing list
