[QGIS Commit] r12404 - trunk/qgis/src/providers/spatialite
svn_qgis at osgeo.org
Fri Dec 11 05:25:43 EST 2009
Author: jef
Date: 2009-12-11 05:25:43 -0500 (Fri, 11 Dec 2009)
New Revision: 12404
trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
fix #2250
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-12-10 23:49:36 UTC (rev 12403)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-12-11 10:25:43 UTC (rev 12404)
@@ -225,7 +225,7 @@
const QString & fieldname = fld.name();
sql += ", \"";
sql += fieldname;
- sql += "\"";
+ sql += "\"";
if ( fetchGeometry )
@@ -526,7 +526,7 @@
sql += ", \"";
sql += fieldname;
- sql += "\"";
+ sql += "\"";
@@ -872,14 +872,12 @@
uniqueValues.append( QString( "%1" ).arg( sqlite3_column_double( stmt, 0 ) ) );
break;
case SQLITE_TEXT:
- txt = ( const char * ) sqlite3_column_text( stmt, 0 );
- uniqueValues.append( txt );
+ uniqueValues.append( QString::fromUtf8(( const char * ) sqlite3_column_text( stmt, 0 ) ) );
break;
default:
- txt = "";
+ uniqueValues.append( "" );
break;
else
@@ -952,7 +950,7 @@
sql += ", \"";
sql += fieldname;
- sql += "\"";
+ sql += "\"";
values += ", ?";
@@ -1033,7 +1031,7 @@
// performing actual row insert
ret = sqlite3_step( stmt );
- if ( ret == SQLITE_DONE || ret == SQLITE_ROW )
+ if ( ret == SQLITE_DONE || ret == SQLITE_ROW )
numberFeatures++;
@@ -1254,29 +1252,29 @@
sql += ",";
else
first = false;
- QVariant::Type type = siter->type();
- if ( siter->toString().isEmpty() )
- // assuming to be a NULL value
- type = QVariant::Invalid;
- if ( type == QVariant::Invalid )
- // binding a NULL value
- sql += QString( "\"%1\"=NULL" ).arg( fieldName );
- else if ( type == QVariant::Int || type == QVariant::Double )
- // binding a NUMERIC value
- sql += QString( "\"%1\"=%2" ).arg( fieldName ).arg( siter->toString() );
- else
- // binding a TEXT value
- sql += QString( "\"%1\"=%2" ).arg( fieldName ).arg( quotedValue( siter->toString() ) );
+ QVariant::Type type = siter->type();
+ if ( siter->toString().isEmpty() )
+ // assuming to be a NULL value
+ type = QVariant::Invalid;
+ if ( type == QVariant::Invalid )
+ // binding a NULL value
+ sql += QString( "\"%1\"=NULL" ).arg( fieldName );
+ else if ( type == QVariant::Int || type == QVariant::Double )
+ // binding a NUMERIC value
+ sql += QString( "\"%1\"=%2" ).arg( fieldName ).arg( siter->toString() );
+ else
+ // binding a TEXT value
+ sql += QString( "\"%1\"=%2" ).arg( fieldName ).arg( quotedValue( siter->toString() ) );
sql += QString( " WHERE ROWID=%1" ).arg( fid );
