[QGIS Commit] r12411 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Dec 11 14:27:18 EST 2009
Author: jef
Date: 2009-12-11 14:27:15 -0500 (Fri, 11 Dec 2009)
New Revision: 12411
   trunk/qgis/src/app/qgsmaptooladdisland.cpp
fix #2266
Modified: trunk/qgis/src/app/qgsmaptooladdisland.cpp
--- trunk/qgis/src/app/qgsmaptooladdisland.cpp	2009-12-11 17:29:02 UTC (rev 12410)
+++ trunk/qgis/src/app/qgsmaptooladdisland.cpp	2009-12-11 19:27:15 UTC (rev 12411)
@@ -40,14 +40,16 @@
   if ( !vlayer )
-    QMessageBox::information( 0, tr( "Not a vector layer" ),
+    QMessageBox::information( 0,
+                              tr( "Not a vector layer" ),
                               tr( "The current layer is not a vector layer" ) );
     return;
   if ( !vlayer->isEditable() )
-    QMessageBox::information( 0, tr( "Layer not editable" ),
+                              tr( "Layer not editable" ),
                               tr( "Cannot edit the vector layer. To make it editable, go to the file item "
                                   "of the layer, right click and check 'Allow Editing'." ) );
     return;
@@ -58,11 +60,11 @@
   QString selectionErrorMsg;
   if ( nSelectedFeatures < 1 )
-    selectionErrorMsg = "No feature selected. Please select a feature with the selection tool or in the attribute table";
+    selectionErrorMsg = tr( "No feature selected. Please select a feature with the selection tool or in the attribute table" );
   else if ( nSelectedFeatures > 1 )
-    selectionErrorMsg = "Several features are selected. Please select only one feature to which an island should be added.";
+    selectionErrorMsg = tr( "Several features are selected. Please select only one feature to which an island should be added." );
   if ( !selectionErrorMsg.isEmpty() )
@@ -84,7 +86,8 @@
   else if ( error == 2 )
     //problem with coordinate transformation
-    QMessageBox::information( 0, tr( "Coordinate transform error" ),
+                              tr( "Coordinate transform error" ),
                               tr( "Cannot transform the point to the layers coordinate system" ) );
     return;
@@ -110,27 +113,27 @@
       if ( errorCode == 1 )
-        errorMessage = "Selected feature is not a multipolygon";
+        errorMessage = tr( "Selected feature is not a multipolygon" );
       else if ( errorCode == 2 )
-        errorMessage = "New ring is not a valid geometry";
+        errorMessage = tr( "New ring is not a valid geometry" );
       else if ( errorCode == 3 )
-        errorMessage = "New polygon ring not disjoint with existing polygons";
+        errorMessage = tr( "New polygon ring not disjoint with existing polygons" );
       else if ( errorCode == 4 )
-        errorMessage = "No feature selected. Please select a feature with the selection tool or in the attribute table";
+        errorMessage = tr( "No feature selected. Please select a feature with the selection tool or in the attribute table" );
       else if ( errorCode == 5 )
-        errorMessage = "Several features are selected. Please select only one feature to which an island should be added.";
+        errorMessage = tr( "Several features are selected. Please select only one feature to which an island should be added." );
       else if ( errorCode == 6 )
-        errorMessage = "Selected geometry could not be found";
+        errorMessage = tr( "Selected geometry could not be found" );
       QMessageBox::critical( 0, tr( "Error, could not add island" ), errorMessage );
More information about the QGIS-commit mailing list
