[QGIS Commit] r12427 - in trunk/qgis/src: app core providers/gpx
providers/ogr
svn_qgis at osgeo.org
Sun Dec 13 07:12:33 EST 2009
Author: jef
Date: 2009-12-13 07:12:32 -0500 (Sun, 13 Dec 2009)
New Revision: 12427
trunk/qgis/src/app/qgsnewconnection.cpp
trunk/qgis/src/core/qgsmaplayer.cpp
trunk/qgis/src/core/qgsmaprenderer.cpp
trunk/qgis/src/providers/gpx/gpsdata.cpp
trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
use QgsDebugMsg
Modified: trunk/qgis/src/app/qgsnewconnection.cpp
--- trunk/qgis/src/app/qgsnewconnection.cpp 2009-12-13 12:08:36 UTC (rev 12426)
+++ trunk/qgis/src/app/qgsnewconnection.cpp 2009-12-13 12:12:32 UTC (rev 12427)
@@ -139,7 +139,7 @@
QgsDataSourceURI uri;
uri.setConnection( txtHost->text(), txtPort->text(), txtDatabase->text(), txtUsername->text(), txtPassword->text(), ( QgsDataSourceURI::SSLmode ) cbxSSLmode->currentIndex() );
- QgsLogger::debug( "PQconnectdb(" + uri.connectionInfo() + ");" );
+ QgsDebugMsg( "PQconnectdb(" + uri.connectionInfo() + ");" );
PGconn *pd = PQconnectdb( uri.connectionInfo().toLocal8Bit().data() );
if ( PQstatus( pd ) == CONNECTION_OK )
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2009-12-13 12:08:36 UTC (rev 12426)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2009-12-13 12:12:32 UTC (rev 12427)
@@ -359,7 +359,7 @@
void QgsMapLayer::invalidTransformInput()
- QgsLogger::warning( "QgsMapLayer::invalidTransformInput() called" );
+ QgsDebugMsg( "called" );
// TODO: emit a signal - it will be used to update legend
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp 2009-12-13 12:08:36 UTC (rev 12426)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp 2009-12-13 12:12:32 UTC (rev 12427)
@@ -180,17 +180,11 @@
dymax = mExtent.yMaximum() + whitespace;
-#ifdef QGISDEBUG
- QString myMessage = "+-------------------MapRenderer--------------------------------+\n";
- myMessage += QString( "Map units per pixel (x,y) : %1, %2\n" ).arg( mapUnitsPerPixelX ).arg( mapUnitsPerPixelY );
- myMessage += QString( "Pixmap dimensions (x,y) : %1, %2\n" ).arg( myWidth ).arg( myHeight );
- myMessage += QString( "Extent dimensions (x,y) : %1, %2\n" ).arg( mExtent.width() ).arg( mExtent.height() );
- myMessage += mExtent.toString();
- std::cout << myMessage.toLocal8Bit().constData() << std::endl; // OK
+ QgsDebugMsg( QString("Map units per pixel (x,y) : %1, %2\n" ).arg( mapUnitsPerPixelX ).arg( mapUnitsPerPixelY ) );
+ QgsDebugMsg( QString("Pixmap dimensions (x,y) : %1, %2\n" ).arg( myWidth ).arg( myHeight ) );
+ QgsDebugMsg( QString("Extent dimensions (x,y) : %1, %2\n" ).arg( mExtent.width() ).arg( mExtent.height() ) );
+ QgsDebugMsg( mExtent.toString() );
-#endif
// update extent
mExtent.setXMinimum( dxmin );
mExtent.setXMaximum( dxmax );
@@ -200,9 +194,7 @@
// update the scale
updateScale();
-#ifdef QGISDEBUG
- QgsLogger::debug( "Scale (assuming meters as map units) = 1", mScale, 1, __FILE__, __FUNCTION__, __LINE__ );
-#endif
+ QgsDebugMsg( QString("Scale (assuming meters as map units) = 1:%1").arg( mScale ) );
newCoordXForm.setParameters( mMapUnitsPerPixel, dxmin, dymin, myHeight );
mRenderContext.setMapToPixel( newCoordXForm );
@@ -221,7 +213,7 @@
if ( mExtent.isEmpty() )
- QgsLogger::debug( "empty extent... not rendering" );
+ QgsDebugMsg( "empty extent... not rendering" );
return;
@@ -343,7 +335,7 @@
if ( !ml )
- QgsLogger::warning( "Layer not found in registry!" );
+ QgsDebugMsg( "Layer not found in registry!" );
continue;
@@ -472,8 +464,9 @@
else
- QgsDebugMsg( "\n\n\nLayer rendered without issues\n\n\n" );
+ QgsDebugMsg( "Layer rendered without issues" );
if ( split )
mRenderContext.setExtent( r2 );
@@ -708,7 +701,7 @@
catch ( QgsCsException &cse )
Q_UNUSED( cse );
- QgsLogger::warning( "Transform error caught in " + QString( __FILE__ ) + ", line " + QString::number( __LINE__ ) );
+ QgsDebugMsg( "Transform error caught" );
extent = QgsRectangle( -DBL_MAX, -DBL_MAX, DBL_MAX, DBL_MAX );
r2 = QgsRectangle( -DBL_MAX, -DBL_MAX, DBL_MAX, DBL_MAX );
@@ -752,7 +745,7 @@
Q_UNUSED( cse );
- QgsDebugMsg( QString( "Transform error caught:%s" ).arg( cse.what() ) );
+ QgsDebugMsg( QString( "Transform error caught: %1" ).arg( cse.what() ) );
else
@@ -773,7 +766,7 @@
- QgsDebugMsg( QString( "Transform error caught: %s" ).arg( cse.what() ) );
throw cse; //let client classes know there was a transformation error
@@ -820,7 +813,7 @@
QgsMapLayer * lyr = registry->mapLayer( *it );
if ( lyr == NULL )
- QgsLogger::warning( "WARNING: layer '" + ( *it ) + "' not found in map layer registry!" );
+ QgsDebugMsg( QString("WARNING: layer '%1' not found in map layer registry!").arg( *it ) );
else
Modified: trunk/qgis/src/providers/gpx/gpsdata.cpp
--- trunk/qgis/src/providers/gpx/gpsdata.cpp 2009-12-13 12:08:36 UTC (rev 12426)
+++ trunk/qgis/src/providers/gpx/gpsdata.cpp 2009-12-13 12:12:32 UTC (rev 12427)
@@ -376,7 +376,7 @@
return 0;
QgsGPSData* data = new QgsGPSData;
- QgsLogger::debug( "Loading file " + fileName );
+ QgsDebugMsg( "Loading file " + fileName );
QgsGPXHandler handler( *data );
bool failed = false;
@@ -412,7 +412,7 @@
dataObjects[fileName] = std::pair<QgsGPSData*, unsigned>( data, 0 );
else
- QgsLogger::debug( fileName + " is already loaded" );
+ QgsDebugMsg( fileName + " is already loaded" );
// return a pointer and increase the reference count for that file name
DataMap::iterator iter = dataObjects.find( fileName );
@@ -429,10 +429,10 @@
if ( iter != dataObjects.end() )
- QgsLogger::debug( "unrefing " + fileName );
+ QgsDebugMsg( "unrefing " + fileName );
if ( --( iter->second.second ) == 0 )
- QgsLogger::debug( "No one's using " + fileName + ", I'll erase it" );
+ QgsDebugMsg( "No one's using " + fileName + ", I'll erase it" );
delete iter->second.first;
dataObjects.erase( iter );
Modified: trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp
--- trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp 2009-12-13 12:08:36 UTC (rev 12426)
+++ trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp 2009-12-13 12:12:32 UTC (rev 12427)
@@ -301,7 +301,7 @@
const QgsTrack* trk;
trk = &( *mTrkIter );
- QgsLogger::debug( "GPX feature track segments: ", trk->segments.size(), __FILE__, __FUNCTION__, __LINE__ );
+ QgsDebugMsg( QString("GPX feature track segments: %1").arg( trk->segments.size() ) );
if ( trk->segments.size() == 0 )
continue;
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-12-13 12:08:36 UTC (rev 12426)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-12-13 12:12:32 UTC (rev 12427)
@@ -1325,7 +1325,7 @@
// NOP, we don't know anything about the current driver
// with regards to a proper file filter string
- QgsLogger::debug( "fileVectorFilters, unknown driver: " + driverName );
+ QgsDebugMsg( "fileVectorFilters, unknown driver: " + driverName );
} // each loaded GDAL driver
@@ -1534,8 +1534,7 @@
break;
default:
- QgsLogger::debug( "Unknown vector type of: ", ( int )( vectortype ), 1,
- __FILE__, __FUNCTION__, __LINE__ );
+ QgsDebugMsg( QString("Unknown vector type of: %1").arg( ( int )( vectortype ) ) );
return false;
break;
