[QGIS Commit] r12430 - in trunk/qgis: resources/context_help
src/core
svn_qgis at osgeo.org
Sun Dec 13 07:45:21 EST 2009
Author: borysiasty
Date: 2009-12-13 07:45:21 -0500 (Sun, 13 Dec 2009)
New Revision: 12430
trunk/qgis/resources/context_help/QgsBookmarks-en_US
trunk/qgis/resources/context_help/QgsBookmarks-es_ES
trunk/qgis/resources/context_help/QgsBookmarks-pl_PL
trunk/qgis/resources/context_help/QgsDelimitedTextPluginGui-en_US
trunk/qgis/src/core/qgsapplication.cpp
Yet further update for context help from Milena
Modified: trunk/qgis/resources/context_help/QgsBookmarks-en_US
--- trunk/qgis/resources/context_help/QgsBookmarks-en_US 2009-12-13 12:36:48 UTC (rev 12429)
+++ trunk/qgis/resources/context_help/QgsBookmarks-en_US 2009-12-13 12:45:21 UTC (rev 12430)
@@ -1,22 +1,34 @@
<h3>Spatial Bookmarks</h3>
-Spatial Bookmarks allow you to "bookmark" a geographic location and return to it later.
+Spatial Bookmarks allow you to "bookmark" a geographic location and return to it later.
+<p>
+<a href="#creating">Creating a Bookmark</a><br/>
+<a href="#working">Working with Bookmarks</a><br/>
+<a href="#zooming">Zooming to a Bookmark</a><br/>
+<a href="#deleting">Deleting to a Bookmark</a><br/>
+<a name="creating">
<h4>Creating a Bookmark</h4>
+</a>
To create a bookmark:
<ol>
-<li>Zoom or pan to the area of interest
-<li>Click on the <i>Create a new geospatial bookmark</i> or type Ctrl-B
-<li>Enter a descriptive name for the bookmark (up to 255 characters)
-<li>Click <i>OK</i> to add the bookmark or <i>Cancel</i> to exit without adding the bookmark
+<li>Zoom or pan to the area of interest.
+<li>Click on the <label>New bookmark</label> or type Ctrl-B.
+<li>Enter a descriptive name for the bookmark (up to 255 characters).
+<li>Click <label>OK</label> to add the bookmark or <label>Cancel</label> to exit without adding the bookmark.
</ol>
Note that you can have multiple bookmarks with the same name.
+<a name="working">
<h4>Working with Bookmarks</h4>
-To use or manage bookmarks, click on the <i>Show geospatial bookmarks</i> button or choose <i>Geospatial Bookmarks</i> from the <i>View</i> menu. The bookmarks dialog allows you to zoom to or delete a bookmark. You can not edit the bookmark name or coordinates.
+</a>
+To use or manage bookmarks, click on the <label>Show bookmarks</label> button or choose <label>Show Bookmarks</label> from the <label>View</label> menu. The bookmarks dialog allows you to zoom to or delete a bookmark. You can not edit the bookmark name or coordinates.
+<a name="zooming">
<h5>Zooming to a Bookmark</h5>
-From the Bookmarks dialog, select the desired bookmark by clicking on it, then click the <i>Zoom To</i> button.
+</a>
+From the Geospatial Bookmarks dialog, select the desired bookmark by clicking on it, then click the <label>Zoom to</label> button.
<p>
You can also zoom to a bookmark by double-clicking on it.
+<a name="deleting">
<h5>Deleting a Bookmark</h5>
-To delete a bookmark from the Bookmarks dialog, click on it then click the <i>Delete</i> button. Confirm your choice by clicking <i>Yes</i> or cancel the delete by clicking <i>No</i>.
+</a>
+To delete a bookmark from the Bookmarks dialog, click on it then click the <label>Delete</label> button. Confirm your choice by clicking <label>OK</label> or cancel the delete by clicking <label>Cancel</label>.
Modified: trunk/qgis/resources/context_help/QgsBookmarks-es_ES
--- trunk/qgis/resources/context_help/QgsBookmarks-es_ES 2009-12-13 12:36:48 UTC (rev 12429)
+++ trunk/qgis/resources/context_help/QgsBookmarks-es_ES 2009-12-13 12:45:21 UTC (rev 12430)
@@ -1,22 +1,34 @@
<h3>Marcadores espaciales</h3>
Los marcadores espaciales le permiten "marcar" una localización geográfica y volver a ella más tarde.
+<p>
+<a href="#creating">Crear una marcador</a><br/>
+<a href="#working">Trabajar con marcadores</a><br/>
+<a href="#zooming">Zum a un marcador</a><br/>
+<a href="#deleting">Borrar un marcador</a><br/>
<h4>Crear una marcador</h4>
+</a>
Para crear un marcador:
<ol>
<li>Haga zum o desplácese al área de interés.
-<li>Pulse en <i>Nuevo marcador</i> o teclee Ctrl-M.
+<li>Pulse en <label>Nuevo marcador</label> o teclee Ctrl-M.
<li>Introduzca un nombre descriptivo para el marcador (hasta 255 caracteres).
-<li>Pulse <i>Aceptar</i> para añadir el marcador o <i>Cancelar</i> para salir sin añadirlo.
+<li>Pulse <label>Aceptar</label> para añadir el marcador o <label>Cancelar</label> para salir sin añadirlo.
</ol>
Tenga en cuenta que puede tener múltiples marcadores con el mismo nombre.
+<a name="working">
<h4>Trabajar con marcadores</h4>
-Para usar o administrar marcadores, pulse el botón <i>Mostrar marcadores</i> o seleccione <i>Mostrar marcadores</i> del menú <i>Ver</i>. El diálogo de marcadores le permite hacer zum a un marcador o borrarlo. No puede editar el nombre o las coordenadas del marcador.
+</a>
+Para usar o administrar marcadores, pulse el botón <label>Mostrar marcadores</label> o seleccione <label>Mostrar marcadores</label> del menú <label>Ver</label>. El diálogo de marcadores le permite hacer zum a un marcador o borrarlo. No puede editar el nombre o las coordenadas del marcador.
+<a name="zooming">
<h5>Zum a un marcador</h5>
-En el diálogo de marcadores, seleccione el marcador deseado haciendo clic en él y luego pulse el botón <i>Zum a</i>.
+</a>
+En el diálogo de marcadores, seleccione el marcador deseado haciendo clic en él y luego pulse el botón <label>Zum a</label>.
<p>
También puede hacer zum a un marcador haciendo doble clic en él.
<h5>Borrar un marcador</h5>
-Para borrar un marcador del diálogo de marcadores, haga clic en el botón <i>Borrar</i>. Confirme su elección haciendo clic en <i>Sí</i> o cancele el borrado haciendo clic en <i>No</i>.
+</a>
+Para borrar un marcador del diálogo de marcadores, haga clic en el botón <label>Borrar</label>. Confirme su elección haciendo clic en <label>Aceptar</label> o cancele el borrado haciendo clic en <label>Cancelar</label>.
Modified: trunk/qgis/resources/context_help/QgsBookmarks-pl_PL
--- trunk/qgis/resources/context_help/QgsBookmarks-pl_PL 2009-12-13 12:36:48 UTC (rev 12429)
+++ trunk/qgis/resources/context_help/QgsBookmarks-pl_PL 2009-12-13 12:45:21 UTC (rev 12430)
@@ -1,21 +1,33 @@
<h3>Zakładki przestrzenne</h3>
Zakładki przestrzenne pozwalają zapamiętać lokalizację geograficzną w oknie mapy i później do niej wrócić.
+<p>
+<a href="#creating">Tworzenie zakładek</a><br/>
+<a href="#working">Praca z zakładkami</a><br/>
+<a href="#zooming">Przybliżanie się do zakładki</a><br/>
+<a href="#deleting">Usuwanie zakładki</a><br/>
<h4>Tworzenie zakładek</h4>
+</a>
Aby utworzyć zakładkę:
<ol>
-<li>Przybliż lub przesuń się do interesującego Cię obszaru mapy
-<li>Kliknij <i>Nowa zakładka</i> lub wciśnij Ctrl+B
-<li>Wprowadź opisową nazwę zakładki (do 255 znaków)
-<li>Kliknij <i>OK</i> aby dodać zakładkę, lub <i>Anuluj</i> aby wyjść bez dodania zakładki.
+<li>Przybliż lub przesuń się do interesującego Cię obszaru mapy.
+<li>Kliknij <label>Nowa zakładka</label> lub wciśnij Ctrl+B.
+<li>Wprowadź opisową nazwę zakładki (do 255 znaków).
+<li>Kliknij <label>OK</label> aby dodać zakładkę, lub <label>Anuluj</label> aby wyjść bez dodania zakładki.
</ol>
Zauważ, że możesz mieć wiele zakładek o tej samej nazwie.
+<a name="working">
<h4>Praca z zakładkami</h4>
-W celu skorzystania z istniejących zakładek lub zarządzania nimi, kliknij przycisk <i>Pokaż zakładki</i> lub wybierz <i>Pokaż zakładki</i> z menu <i>Widok</i>. Okno dialogowe pozwala na przywołanie zapamiętanego obszaru w oknie mapy lub usunięcie zakładki. Nie ma możliwości edytowania nazwy ani współrzędnych zakładki.
+</a>
+W celu skorzystania z istniejących zakładek lub zarządzania nimi, kliknij przycisk <label>Pokaż zakładki</label> lub wybierz <label>Pokaż zakładki</label> z menu <label>Widok</label>. Okno dialogowe pozwala na przywołanie zapamiętanego obszaru w oknie mapy lub usunięcie zakładki. Nie ma możliwości edytowania nazwy ani współrzędnych zakładki.
+<a name="zooming">
<h5>Przybliżanie się do zakładki</h5>
-Z okna dialogowego Zakładki wybierz pożądaną zakładkę klikając na niej, następnie kliknij przycisk <i>Powiększ do</i>.
+</a>
+Z okna dialogowego Zakładki wybierz pożądaną zakładkę klikając na niej, następnie kliknij przycisk <label>Powiększ do</label>.
<p>
Możesz także przybliżyć się do zakładki dwukrotnie klikając na jej nazwie.
<h5>Usuwanie zakładki</h5>
-Aby usunąć zakładkę z okna Zakładki, kliknij na jej nazwie, a następnie wybierz przycisk <i>Usuń</i>. Potwierdź swój wybór, klikając <i>OK</i> lub cofnij go, klikając <i>Anuluj</i>.
+</a>
+Aby usunąć zakładkę z okna Zakładki, kliknij na jej nazwie, a następnie wybierz przycisk <label>Usuń</label>. Potwierdź swój wybór, klikając <label>OK</label> lub cofnij go, klikając <label>Anuluj</label>.
Modified: trunk/qgis/resources/context_help/QgsDelimitedTextPluginGui-en_US
--- trunk/qgis/resources/context_help/QgsDelimitedTextPluginGui-en_US 2009-12-13 12:36:48 UTC (rev 12429)
+++ trunk/qgis/resources/context_help/QgsDelimitedTextPluginGui-en_US 2009-12-13 12:45:21 UTC (rev 12430)
@@ -1 +1,35 @@
<h3>Delimited Text Layer Plugin</h3>
+Loads and displays delimited text files containing x,y coordinates.
+<p>
+<p>
+<a href="#re">Requirements</a><br/>
+<a href="#example">Example of a valid text file</a><br/>
+<a href="#notes">Notes</a><br/>
+<a name="re">
+<h4>Requirements</h4>
+</a>
+To view a delimited text file as layer, the text file must contain:
+<ol>
+<li>A delimited header row of field names. This must be the first line in the text file.</li>
+<li>The header row must contain an X and Y field. These fields can have any name.</li>
+<li>The <B>x</B> and <B>y</B> coordinates must be specified as a number. The coordinate system is not important.</li>
+</ol>
+<a name="example">
+<h4>Example of a valid text file</h4>
+</a>
+X;Y;ELEV<br/>
+-300120;7689960;13<br/>
+-654360;7562040;52<br/>
+1640;7512840;3<br/>
+[...]<br/>
+<a name="notes">
+<h4>Notes</h4>
+</a>
+<ol>
+<li>The example text file uses <b>;</b> as delimiter. Any character can be used to delimit the fields.</li>
+<li>The first row is the header row. It contains the fields X, Y and ELEV.</li>
+<li>No quotes (") are used to delimit text fields.</li>
+<li>The x coordinates are contained in the X field.</li>
+<li>The y coordinates are contained in the Y field.</li>
+</ol>
\ No newline at end of file
Modified: trunk/qgis/src/core/qgsapplication.cpp
--- trunk/qgis/src/core/qgsapplication.cpp 2009-12-13 12:36:48 UTC (rev 12429)
+++ trunk/qgis/src/core/qgsapplication.cpp 2009-12-13 12:45:21 UTC (rev 12430)
@@ -392,7 +392,7 @@
"border: 1px solid #6c6c6c;"
".overview{ font: 1.82em; font-weight: bold;}"
- "BODY{ background: white;"
+ "body{ background: white;"
" color: black;"
" font-family: arial,sans-serif;"
@@ -428,10 +428,8 @@
" font-size: small;"
" text-align: right;"
- "a{ background-color: white;"
- " color: #729FCF;"
+ "a{ color: #729FCF;"
- " font-weight: normal;"
"label{ background-color: #FFFFCC;"
