[QGIS Commit] r12474 - in trunk/qgis/src/plugins/grass: modules-6.4 modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Dec 15 11:27:43 EST 2009
Author: pcav
Date: 2009-12-15 11:27:42 -0500 (Tue, 15 Dec 2009)
New Revision: 12474
   trunk/qgis/src/plugins/grass/modules-6.4/v.in.geonames.qgm
   trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm
   trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm
More GRASS modules updated
Modified: trunk/qgis/src/plugins/grass/modules-6.4/v.in.geonames.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/v.in.geonames.qgm	2009-12-15 16:06:18 UTC (rev 12473)
+++ trunk/qgis/src/plugins/grass/modules-6.4/v.in.geonames.qgm	2009-12-15 16:27:42 UTC (rev 12474)
@@ -1,7 +1,7 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Import geonames.org country files" module="r.in.geonames">
+<qgisgrassmodule label="Import geonames.org country files" module="v.in.geonames">
 	<file key="input" type="old" filter="TXT (*.txt)" />
 	<option key="output" />
-</qgisgrassmodule>
\ No newline at end of file
+</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm	2009-12-15 16:06:18 UTC (rev 12473)
+++ trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm	2009-12-15 16:27:42 UTC (rev 12474)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import US-NGA GEOnet Names Server (GNS) country file" module="r.in.gns">
+<qgisgrassmodule label="Import US-NGA GEOnet Names Server (GNS) country file" module="v.in.gns">
 	<file key="file" type="old" filter="TXT (*.txt)" />
 	<option key="vect" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm	2009-12-15 16:06:18 UTC (rev 12473)
+++ trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm	2009-12-15 16:27:42 UTC (rev 12474)
@@ -5,6 +5,8 @@
 	<option key="from" typemask="point" layeroption="from_layer"/>
 	<option key="to" typeoption="to_type" layeroption="to_layer"/>
 	<option key="upload"/>
+	<option key="dmax"/>
+	<option key="dmin"/>
 	<field key="column" layer="from" type="integer,double" label="Attribute field" />
 	<option key="output"/>
 </qgisgrassmodule>
More information about the QGIS-commit mailing list
