[QGIS Commit] r12518 - trunk/qgis/src/providers/osm
svn_qgis at osgeo.org
Sat Dec 19 10:23:12 EST 2009
Author: wonder
Date: 2009-12-19 10:23:11 -0500 (Sat, 19 Dec 2009)
New Revision: 12518
trunk/qgis/src/providers/osm/osmprovider.cpp
OSM: save correctly the extent of data. Most probably the cause of #2098.
Modified: trunk/qgis/src/providers/osm/osmprovider.cpp
--- trunk/qgis/src/providers/osm/osmprovider.cpp 2009-12-19 14:31:23 UTC (rev 12517)
+++ trunk/qgis/src/providers/osm/osmprovider.cpp 2009-12-19 15:23:11 UTC (rev 12518)
@@ -30,7 +30,7 @@
static const QString TEXT_PROVIDER_KEY = "osm";
static const QString TEXT_PROVIDER_DESCRIPTION = "Open Street Map data provider";
static const QString DATE_TIME_FMT = "dd.MM.yyyy HH:mm:ss";
-static const QString PROVIDER_VERSION = "0.5";
+static const QString PROVIDER_VERSION = "0.5.1";
// supported attributes
const char* QgsOSMDataProvider::attr[] = { "timestamp", "user", "tags" };
@@ -213,14 +213,19 @@
const unsigned char *boundaries_char = sqlite3_column_text( stmtSelectBoundary, 0 );
QString boundaries(( const char * ) boundaries_char );
- // boundaries should be string in following format: "xMin-yMin-xMax-yMax"
- int separ1_pos = boundaries.indexOf( "-" );
- int separ2_pos = boundaries.indexOf( "-", separ1_pos + 1 );
- int separ3_pos = boundaries.indexOf( "-", separ2_pos + 1 );
- xMin = boundaries.left( separ1_pos ).toDouble();
- yMin = boundaries.mid( separ1_pos + 1, separ2_pos - separ1_pos - 1 ).toDouble();
- xMax = boundaries.mid( separ2_pos + 1, separ3_pos - separ2_pos - 1 ).toDouble();
- yMax = boundaries.right( boundaries.size() - separ3_pos - 1 ).toDouble();
+ // boundaries should be string in following format: "xMin:yMin:xMax:yMax"
+ QStringList parts = boundaries.split( QChar( ':' ) );
+ if ( parts.count() == 4 )
+ xMin = parts[0].toDouble();
+ yMin = parts[1].toDouble();
+ xMax = parts[2].toDouble();
+ yMax = parts[3].toDouble();
+ else
+ QgsDebugMsg( "Default area boundary has invalid format." );
@@ -1402,8 +1407,8 @@
yMax = handler->yMax;
// storing boundary information into database
- QString cmd3 = QString( "INSERT INTO meta ( key, val ) VALUES ('default-area-boundaries','%1-%2-%3-%4');" )
- .arg( xMin, 0, 'f', 20 ).arg( yMin, 0, 'f', 20 ).arg( xMax, 0, 'f', 20 ).arg( yMax, 0, 'f', 20 );
+ QString cmd3 = QString( "INSERT INTO meta ( key, val ) VALUES ('default-area-boundaries','%1:%2:%3:%4');" )
+ .arg( xMin, 0, 'f', 10 ).arg( yMin, 0, 'f', 10 ).arg( xMax, 0, 'f', 10 ).arg( yMax, 0, 'f', 10 );
QByteArray cmd_bytes3 = cmd3.toAscii();
const char *ptr3 = cmd_bytes3.data();
