[QGIS Commit] r12554 - trunk/qgis/resources/context_help
svn_qgis at osgeo.org
Sun Dec 20 17:18:34 EST 2009
Author: borysiasty
Date: 2009-12-20 17:18:34 -0500 (Sun, 20 Dec 2009)
New Revision: 12554
Added:
trunk/qgis/resources/context_help/QgsScaleBarPluginGui-pl_PL
trunk/qgis/resources/context_help/QgsSpatiaLiteSourceSelect-pl_PL
trunk/qgis/resources/context_help/QgsScaleBarPluginGui-en_US
context help update from Milena
Modified: trunk/qgis/resources/context_help/QgsScaleBarPluginGui-en_US
--- trunk/qgis/resources/context_help/QgsScaleBarPluginGui-en_US 2009-12-20 22:18:09 UTC (rev 12553)
+++ trunk/qgis/resources/context_help/QgsScaleBarPluginGui-en_US 2009-12-20 22:18:34 UTC (rev 12554)
@@ -1,15 +1,16 @@
-<h3>Scalebar Plugin</h3>
+<h3>Scalebar Plugin</h3>
Draws a scale bar on the map.
<p>
You can control the style and placement, as well as the labeling of the bar.
-QGIS only supports displaying the scale in the same units as your map frame. So if the units of your layers are in meters, you can't create a scale bar in feet. Likewise if you are using decimal degrees, you can't create a scale bar to display distance in meters.
+QGIS only supports displaying the scale in the same units as your map frame. So if the units of your layers are in meters, you can't create a scale bar in feet. Likewise if you are using decimal degrees, you can't create a scale bar to display distance in meters.</p>
+<p>
To add a scale bar:
<ol>
<li>Choose the placement from the <label>Placement</label> drop-down list.</li>
<li>Choose the style from the <label>Scale bar style</label> list.</li>
<li>Select the color for the bar <label>Color of bar</label> or use the default black color.</li>
<li>Set the size of the bar and its label <label>Size of bar</label>. </li>
-<li>Make sure the x <label>Enable scale bar</label> checkbox is checked.</li>
-<li>Optionally choose to automatically snap to a round number when the canvas is resized x <label>Automatically snap to round number on resize</label>.</li>
-<li>Click OK.</li>
+<li>Make sure the <label>Enable scale bar</label> checkbox is checked.</li>
+<li>Optionally choose to automatically snap to a round number when the canvas is resized <label>Automatically snap to round number on resize</label>.</li>
+<li>Click <label>OK</label>.</li>
</ol>
\ No newline at end of file
Added: trunk/qgis/resources/context_help/QgsScaleBarPluginGui-pl_PL
--- trunk/qgis/resources/context_help/QgsScaleBarPluginGui-pl_PL (rev 0)
+++ trunk/qgis/resources/context_help/QgsScaleBarPluginGui-pl_PL 2009-12-20 22:18:34 UTC (rev 12554)
@@ -0,0 +1,16 @@
+<h3>Podziałka</h3>
+Umieszcza na mapie podziałkę liniową.
+<p>
+Możesz ustawić styl podziałki oraz jej położenie, jak również jej opisy.
+QGIS wyświetla skalę jedynie w tych samych jednostkach co jednostki mapy. Jeśli więc jednostki twojej warstwy to metry, nie możesz utworzyć podziałki w stopach; i odpowiednio jeśli dla mapy używasz stopni dziesiętnych, nie możesz utworzyć podziałki w metrach.</p>
+<p>
+Aby dodać podziałkę:
+<ol>
+<li>Wybierz położenie z listy rozwijalnej <label>Umiejscowienie</label>.</li>
+<li>Wybierz styl podziałki z listy <label>Styl podziałki</label>.</li>
+<li>Wybierz kolor podziałki <label>Kolor podziałki</label> lub użyj domyślnego czarnego koloru.</li>
+<li>Ustaw rozmiar podziałki i jej opisów <label>Rozmiar paska</label>. </li>
+<li>Upewnij się, że opcja <label>Włącz podziałkę</label> jest zaznaczona.</li>
+<li>Opcjonalnie wybierz automatyczne zaokrąglanie opisów podziałki przy zmianie wielkości okna <label>Automatycznie zaokrąglaj przy zmianie wielkości okna</label>.</li>
+<li>Kliknij <label>OK</label>.</li>
+</ol>
Added: trunk/qgis/resources/context_help/QgsSpatiaLiteSourceSelect-pl_PL
--- trunk/qgis/resources/context_help/QgsSpatiaLiteSourceSelect-pl_PL (rev 0)
+++ trunk/qgis/resources/context_help/QgsSpatiaLiteSourceSelect-pl_PL 2009-12-20 22:18:34 UTC (rev 12554)
@@ -0,0 +1,5 @@
+<h3>Dodaj tabele SpatiaLite</h3>
+Aby zdefiniować nowe połączenie, kliknij przycisk <label>Nowy</label> i wskaż położenie bazy SpatiaLite na dysku. Baza SpatiaLite jest plikiem o rozszerzeniu <i>.sqlite</i>.<p>
+Następnie kliknij <label>Połącz</label> i wybierz z drzewa warstw te, które chcesz otworzyć w QGIS.<br/>
+Kliknij <label>Dodaj</label>, warstwy zostaną wczytane.<p>
+Połączenie raz zdefiniowane będzie zapamiętane i dostępne do użycia z rozwijalnej listy.
