[QGIS Commit] r12585 - trunk/qgis/src/core
svn_qgis at osgeo.org
Tue Dec 22 16:07:34 EST 2009
Author: mhugent
Date: 2009-12-22 16:07:32 -0500 (Tue, 22 Dec 2009)
New Revision: 12585
trunk/qgis/src/core/qgsgeometry.cpp
Test if polygon rings are still inside the outer boundary after reshape and fix a memory leak. Fixes bug #2220
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp 2009-12-22 20:34:20 UTC (rev 12584)
+++ trunk/qgis/src/core/qgsgeometry.cpp 2009-12-22 21:07:32 UTC (rev 12585)
@@ -531,6 +531,7 @@
mGeometrySize = rhs.mGeometrySize;
// deep-copy the GEOS Geometry if appropriate
+ GEOSGeom_destroy( mGeos );
mGeos = rhs.mGeos ? GEOSGeom_clone( rhs.mGeos ) : 0;
mDirtyGeos = rhs.mDirtyGeos;
@@ -5145,22 +5146,49 @@
newOuterRing = GEOSGeom_clone( outerRing );
- GEOSGeometry** newInnerRings = new GEOSGeometry*[nRings];
- for ( int i = 0; i < nRings; ++i )
+ //check if all the rings are still inside the outer boundary
+ QList<GEOSGeometry*> ringList;
+ if ( nRings > 0 )
- if ( lastIntersectingRing == i )
+ GEOSGeometry* outerRingPoly = GEOSGeom_createPolygon( GEOSGeom_clone( newOuterRing ), 0, 0 );
+ if ( outerRingPoly )
- newInnerRings[i] = newRing;
+ GEOSGeometry* currentRing = 0;
+ for ( int i = 0; i < nRings; ++i )
+ if ( lastIntersectingRing == i )
+ currentRing = newRing;
+ else
+ currentRing = GEOSGeom_clone( innerRings[i] );
+ //possibly a ring is no longer contained in the result polygon after reshape
+ if ( GEOSContains( outerRingPoly, currentRing ) == 1 )
+ ringList.push_back( currentRing );
+ else
+ GEOSGeom_destroy( currentRing );
- else
- newInnerRings[i] = GEOSGeom_clone( innerRings[i] );
+ GEOSGeom_destroy( outerRingPoly );
+ GEOSGeometry** newInnerRings = new GEOSGeometry*[ringList.size()];
+ QList<GEOSGeometry*>::const_iterator it = ringList.constBegin();
+ for ( int i = 0; i < ringList.size(); ++i )
+ newInnerRings[i] = ringList.at( i );
delete [] innerRings;
- GEOSGeometry* reshapedPolygon = GEOSGeom_createPolygon( newOuterRing, newInnerRings, nRings );
+ GEOSGeometry* reshapedPolygon = GEOSGeom_createPolygon( newOuterRing, newInnerRings, ringList.size() );
delete[] newInnerRings;
if ( !reshapedPolygon )
