[QGIS Commit] r12591 - trunk/qgis/src/providers/osm
svn_qgis at osgeo.org
Wed Dec 23 07:47:17 EST 2009
Author: wonder
Date: 2009-12-23 07:47:16 -0500 (Wed, 23 Dec 2009)
New Revision: 12591
trunk/qgis/src/providers/osm/osmprovider.cpp
Reuse OSM db file on windows.
For some strange reason it was not considering the same QDateTime to be equal.
Modified: trunk/qgis/src/providers/osm/osmprovider.cpp
--- trunk/qgis/src/providers/osm/osmprovider.cpp 2009-12-23 11:34:07 UTC (rev 12590)
+++ trunk/qgis/src/providers/osm/osmprovider.cpp 2009-12-23 12:47:16 UTC (rev 12591)
@@ -152,7 +152,7 @@
QgsDebugMsg( "Opening sqlite3 database failed, OSM provider cannot be constructed." );
closeDatabase();
return;
// flag determining if OSM file parsing is necessary
bool shouldParse = true;
@@ -161,7 +161,7 @@
shouldParse = false;
// test if db file that belongs to source OSM file already exists and if it has the right version
- if ( shouldParse && databaseExists && isDatabaseCompatibleWithInput( mFileName ) && isDatabaseCompatibleWithProvider() )
+ if ( databaseExists && isDatabaseCompatibleWithInput( mFileName ) && isDatabaseCompatibleWithProvider() )
if ( shouldParse )
@@ -367,7 +367,7 @@
// each OSM database schema carry info on last-modified of file from which database was created;
// if value equals to last-modified of current input file then DB file belongs to current input file
// (in such case we say that "database is compatible with input")
- if ( mOsmFileLastModif == oldOsmFileLastModif )
+ if ( mOsmFileLastModif.toTime_t() == oldOsmFileLastModif.toTime_t() )
sqlite3_finalize( stmtSelectLastModif );
return true;
@@ -1657,11 +1657,8 @@
QgsDebugMsg( "Opening database." );
- QByteArray dbfn_bytes = mDatabaseFileName.toAscii();
- const char *ptr = dbfn_bytes.data();
// open database
- if ( sqlite3_open( ptr, &mDatabase ) != SQLITE_OK )
+ if ( sqlite3_open( mDatabaseFileName.toUtf8().data(), &mDatabase ) != SQLITE_OK )
mError = ( char * ) "Opening SQLite3 database failed.";
sqlite3_close( mDatabase );
