[QGIS Commit] r12596 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Dec 23 09:55:17 EST 2009
Author: mhugent
Date: 2009-12-23 09:55:16 -0500 (Wed, 23 Dec 2009)
New Revision: 12596
   trunk/qgis/src/ui/qgscomposermanagerbase.ui
Switch position of add and show button in composer manager
Modified: trunk/qgis/src/ui/qgscomposermanagerbase.ui
--- trunk/qgis/src/ui/qgscomposermanagerbase.ui	2009-12-23 13:54:29 UTC (rev 12595)
+++ trunk/qgis/src/ui/qgscomposermanagerbase.ui	2009-12-23 14:55:16 UTC (rev 12596)
@@ -1,56 +1,55 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<ui version="4.0">
+<ui version="4.0" >
  <class>QgsComposerManagerBase</class>
- <widget class="QDialog" name="QgsComposerManagerBase">
-  <property name="geometry">
+ <widget class="QDialog" name="QgsComposerManagerBase" >
+  <property name="geometry" >
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>333</width>
-    <height>198</height>
+    <width>346</width>
+    <height>203</height>
    </rect>
   </property>
-  <property name="windowTitle">
+  <property name="windowTitle" >
    <string>Composer manager</string>
   </property>
-  <layout class="QGridLayout" name="gridLayout">
-   <item row="0" column="0" rowspan="5">
-    <widget class="QListWidget" name="mComposerListWidget"/>
+  <layout class="QGridLayout" name="gridLayout" >
+   <item rowspan="5" row="0" column="0" >
+    <widget class="QListWidget" name="mComposerListWidget" />
    </item>
-   <item row="0" column="1">
-    <widget class="QPushButton" name="mAddButton">
-     <property name="text">
-      <string>Add</string>
+   <item row="0" column="1" >
+    <widget class="QPushButton" name="mShowPushButton" >
+     <property name="text" >
+      <string>Show</string>
      </property>
     </widget>
    </item>
-   <item row="1" column="1">
-    <widget class="QPushButton" name="mRemoveButton">
+   <item row="1" column="1" >
+    <widget class="QPushButton" name="mRemoveButton" >
       <string>Remove</string>
      </property>
     </widget>
    </item>
-   <item row="2" column="1">
-    <widget class="QPushButton" name="mRenamePushButton">
+   <item row="2" column="1" >
+    <widget class="QPushButton" name="mRenamePushButton" >
       <string>Rename</string>
      </property>
     </widget>
    </item>
-   <item row="3" column="1">
-    <widget class="QPushButton" name="mShowPushButton">
-      <string>Show</string>
+   <item row="3" column="1" >
+    <widget class="QPushButton" name="mAddButton" >
+      <string>Add</string>
      </property>
     </widget>
    </item>
-   <item row="4" column="1">
-    <spacer name="verticalSpacer">
-     <property name="orientation">
+   <item row="4" column="1" >
+    <spacer name="verticalSpacer" >
+     <property name="orientation" >
       <enum>Qt::Vertical</enum>
      </property>
-     <property name="sizeHint" stdset="0">
+     <property name="sizeHint" stdset="0" >
       <size>
        <width>20</width>
        <height>50</height>
@@ -58,12 +57,12 @@
      </property>
     </spacer>
    </item>
-   <item row="5" column="0" colspan="2">
-    <widget class="QDialogButtonBox" name="mButtonBox">
+   <item row="5" column="0" colspan="2" >
+    <widget class="QDialogButtonBox" name="mButtonBox" >
       <enum>Qt::Horizontal</enum>
      </property>
-     <property name="standardButtons">
+     <property name="standardButtons" >
       <set>QDialogButtonBox::Close</set>
      </property>
     </widget>
@@ -78,11 +77,11 @@
    <receiver>QgsComposerManagerBase</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel">
+    <hint type="sourcelabel" >
      <x>251</x>
      <y>193</y>
     </hint>
-    <hint type="destinationlabel">
+    <hint type="destinationlabel" >
      <x>157</x>
      <y>274</y>
     </hint>
@@ -94,11 +93,11 @@
    <slot>reject()</slot>
    <hints>
      <x>251</x>
      <y>193</y>
     </hint>
      <x>286</x>
      <y>274</y>
     </hint>
More information about the QGIS-commit mailing list
