[QGIS Commit] r12621 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Sat Dec 26 18:37:50 EST 2009
Author: borysiasty
Date: 2009-12-26 18:37:48 -0500 (Sat, 26 Dec 2009)
New Revision: 12621
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_gui.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
plugin installer update - fix #2247
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-12-26 12:50:54 UTC (rev 12620)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-12-26 23:37:48 UTC (rev 12621)
@@ -15,7 +15,7 @@
return "Plugin Installer"
def version():
- return "Version 1.0.7"
+ return "Version 1.0.8"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-12-26 12:50:54 UTC (rev 12620)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-12-26 23:37:48 UTC (rev 12621)
@@ -311,10 +311,14 @@
for key in repositories.all():
repositories.killConnection(key)
- # display error messages for every unavailable reposioty, except the case if all repositories are unavailable!
+ # display error messages for every unavailable reposioty, unless Shift pressed nor all repositories are unavailable
+ keepQuiet = QgsApplication.keyboardModifiers() == Qt.KeyboardModifiers(Qt.ShiftModifier)
if repositories.allUnavailable() and repositories.allUnavailable() != repositories.allEnabled():
for key in repositories.allUnavailable():
- QMessageBox.warning(self, self.tr("QGIS Python Plugin Installer"), self.tr("Error reading repository:") + " " + key + "\n" + repositories.all()[key]["error"])
+ if not keepQuiet:
+ QMessageBox.warning(self, self.tr("QGIS Python Plugin Installer"), self.tr("Error reading repository:") + " " + key + "\n" + repositories.all()[key]["error"])
+ if QgsApplication.keyboardModifiers() == Qt.KeyboardModifiers(Qt.ShiftModifier):
+ keepQuiet = True
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-12-26 12:50:54 UTC (rev 12620)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-12-26 23:37:48 UTC (rev 12621)
@@ -157,10 +157,14 @@
QApplication.restoreOverrideCursor()
- # display an error message for every unavailable reposioty, except the case if all repositories are unavailable!
- QMessageBox.warning(parent, QCoreApplication.translate("QgsPluginInstaller","QGIS Python Plugin Installer"), QCoreApplication.translate("QgsPluginInstaller","Error reading repository:") + QString(' %s\n%s' % (key,repositories.all()[key]["error"])))
+ if not keepQuiet:
+ QMessageBox.warning(parent, QCoreApplication.translate("QgsPluginInstaller","QGIS Python Plugin Installer"), QCoreApplication.translate("QgsPluginInstaller","Error reading repository:") + QString(' %s\n%s' % (key,repositories.all()[key]["error"])))
+ keepQuiet = True
flags = Qt.WindowTitleHint | Qt.WindowSystemMenuHint | Qt.WindowMaximizeButtonHint
self.guiDlg = QgsPluginInstallerDialog(parent,flags)
