[QGIS Commit] r12633 - in trunk/qgis/src/plugins/grass: modules-6.4 scripts
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Dec 28 09:07:28 EST 2009
Author: pcav
Date: 2009-12-28 09:07:28 -0500 (Mon, 28 Dec 2009)
New Revision: 12633
   trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm
   trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py
Added an option to v.out.ogr.pg - thanks Giovanni Manghi
Modified: trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm	2009-12-28 14:04:16 UTC (rev 12632)
+++ trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm	2009-12-28 14:07:28 UTC (rev 12633)
@@ -10,4 +10,5 @@
 	<option key="port" answer="5432"/>
 	<option key="user"/>
 	<option key="password"/>
+        <flag key="c" answer="off" hidden="no"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py
--- trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py	2009-12-28 14:04:16 UTC (rev 12632)
+++ trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py	2009-12-28 14:07:28 UTC (rev 12633)
@@ -137,8 +137,8 @@
     if user: dsn += " user=" + user
     if password: dsn += " password=" + password
-    if grass.run_command('v.out.ogr', input=input, layer=layer, type=type, format="PostgreSQL", dsn=dsn, olayer=olayer ) != 0:
-        grass.fatal("Cannot export vector to database.")
+    if grass.run_command('v.out.ogr', flags=flags_string, input=input, layer=layer, type=type, format="PostgreSQL", dsn=dsn, olayer=olayer ) != 0:
+         grass.fatal("Cannot export vector to database.")
 if __name__ == "__main__":
     options, flags = grass.parser()
More information about the QGIS-commit mailing list
