[QGIS Commit] r12654 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Wed Dec 30 12:25:59 EST 2009
Author: aghisla
Date: 2009-12-30 12:25:58 -0500 (Wed, 30 Dec 2009)
New Revision: 12654
docs/trunk/english_us/user_guide/foreword.tex
docs/trunk/english_us/user_guide/preamble.tex
docs/trunk/english_us/user_guide/title.tex
updated release name in title - list of new features in foreword - list of authors' formatting corrected in preamble
Modified: docs/trunk/english_us/user_guide/foreword.tex
--- docs/trunk/english_us/user_guide/foreword.tex 2009-12-30 16:52:45 UTC (rev 12653)
+++ docs/trunk/english_us/user_guide/foreword.tex 2009-12-30 17:25:58 UTC (rev 12654)
@@ -157,19 +157,21 @@
Installer (See Section \ref{sec:plugins}).
\end{itemize}
-\minisec{What's new in version ~\CURRENT}
+\subsubsection{What's new in version \CURRENT}
These are the most relevant additions and improvements:
\begin{itemize}
- \item Attribute table significant speedup
- \item Advanced Editing toolbar
- \item Configuring shortcuts from main window
- \item Merging features
- \item eVis plugin
- \item OSM plugin
- \item New GRASS shell
- \item Composer can export to PDF as well
+ \item Advanced symbology engine (was Symbology-NG branch) in addition to old engine
+ \item Labeling plugin (part of new symbology engine)
+ \item User interface cleanups to copyright, delim text and n-arrow plugins, and map composer interface
+ \item 'Tools' menu renamed to 'Vector'
+ \item Added 'newgis' theme which is a revision by Anita Graser of the original GIS theme by Robert Szczepanek
+ \item Added 'Configure shortcuts' dialog
+ \item Added 'Export to PDF' feature to map composer menu
+ \item Added support to user-specific SVG path in the map composer
+ \item Possibility to add/remove attributes also in attribute table. Small modification to attribute table such that adding / removing columns is visible
+ \item Field Calculator
+ \item New analysis tools: Zonal statistics, TIN interpolation and Overlay analyzer
\end{itemize}
Modified: docs/trunk/english_us/user_guide/preamble.tex
--- docs/trunk/english_us/user_guide/preamble.tex 2009-12-30 16:52:45 UTC (rev 12653)
+++ docs/trunk/english_us/user_guide/preamble.tex 2009-12-30 17:25:58 UTC (rev 12654)
@@ -63,13 +63,13 @@
\begin{tabular}{p{4cm} p{4cm} p{4cm} p{4cm}}
Tara Athan & Radim Blazek & Godofredo Contreras & Claudia A. Engel \\
Otto Dassau & Martin Dobias & Peter Ersts & J\"urgen E. Fischer \\
-Anne Ghisla & Stephan Holl & N. Horning & Marco Hugentobler & Magnus Homann \\
-K. Koy & Lars Luthman & Gavin Macaulay & Werner Macho \\
-Carson J.Q. Farmer & Tyler Mitchell & Brendan Morely & Gary E. Sherman \\
-Tim Sutton & David Willis \\
+Anne Ghisla & Stephan Holl & N. Horning & Marco Hugentobler \\
+Magnus Homann & K. Koy & Lars Luthman & Gavin Macaulay\\
+Werner Macho & Carson J.Q. Farmer & Tyler Mitchell & Brendan Morely\\
+Gary E. Sherman & Tim Sutton & David Willis \\
\end{tabular}
-\vspace{1cm}
+\vspace{0.8cm}
With thanks to Tisham Dhar for preparing the initial msys (MS Windows)
environment documentation, to Tom Elwertowski and William Kyngesburye for
Modified: docs/trunk/english_us/user_guide/title.tex
--- docs/trunk/english_us/user_guide/title.tex 2009-12-30 16:52:45 UTC (rev 12653)
+++ docs/trunk/english_us/user_guide/title.tex 2009-12-30 17:25:58 UTC (rev 12654)
@@ -15,7 +15,7 @@
\Large{User Guide} \\
\vspace{0.5cm}
%\includegraphics[clip=true, scale=0.4]{splash}
-\Large{Version ~\CURRENT \textsl{'Mimas'}}
+\Large{Version ~\CURRENT \textsl{'Enceladus'}}
\end{center}
\end{titlepage}
