[QGIS Commit] r10077 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Feb 1 03:03:00 EST 2009
Author: dassau
Date: 2009-02-01 03:03:00 -0500 (Sun, 01 Feb 2009)
New Revision: 10077
   docs/trunk/english_us/user_guide/features_at_a_glance.tex
   docs/trunk/english_us/user_guide/working_with_projections.tex
fix Ticket #991
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex	2009-01-31 20:22:04 UTC (rev 10076)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex	2009-02-01 08:03:00 UTC (rev 10077)
@@ -585,7 +585,8 @@
 that any coordinate in your layer is in degrees. To get correct scale values,
 you can either change this to meter manually in the \tab{General} tab under
 \mainmenuopt{Settings} >\dropmenuopt{Project Properties} or you can select a project
-Coordinate Reference System (CRS) clicking on the \toolbtntwo{mIconProjectionEnabled}{projector}
+Coordinate Reference System (CRS) clicking on the
+\toolbtntwo{mIconProjectionDisabled}{projector}
 icon in the lower right-hand corner of the statusbar. In the last case, the
 units are set to what the project projection specifies, e.g. '+units=m'.
Modified: docs/trunk/english_us/user_guide/working_with_projections.tex
--- docs/trunk/english_us/user_guide/working_with_projections.tex	2009-01-31 20:22:04 UTC (rev 10076)
+++ docs/trunk/english_us/user_guide/working_with_projections.tex	2009-02-01 08:03:00 UTC (rev 10077)
@@ -83,17 +83,18 @@
 \begin{enumerate}
 \item Select \dropmenuopttwo{mActionOptions}{Project Properties} from the
 \mainmenuopt{Settings} menu.
-\item Click on the \toolbtntwo{mIconProjectionEnabled}{projector} icon in the
+\item Click on the \toolbtntwo{mIconProjectionDisabled}{projector} icon in the
 \end{enumerate}
 If you have already loaded a layer, and want to enable OTF projection, the
 best practice is to open the \tab{Coordinate Reference System} tab of the
-\dialog{Project Properties} dialog and find the CRS of the currently loaded
-layer in the list of CRS, and activate the \checkbox{Enable on the fly
-projection} checkbox. All subsequently loaded vector layers will then be OTF
-projected to the defined CRS.
+\dialog{Project Properties} dialog, select the CRS of the currently loaded
+layer, and activate the \checkbox{Enable on the fly projection} checkbox. The
+\toolbtntwo{mIconProjectionEnabled}{projector} icon will show a green hook
+and all subsequently loaded vector layers will be OTF projected to the
+defined CRS.
 The \tab{Coordinate Reference System} tab of the \dialog{Project Properties}
 dialog contains four important components as numbered in Figure
 \ref{fig:projections} and described below.
More information about the QGIS-commit mailing list
