[QGIS Commit] r10103 - in trunk/qgis/python/plugins/fTools: . tools
svn_qgis at osgeo.org
Tue Feb 3 19:59:50 EST 2009
Author: cfarmer
Date: 2009-02-03 19:59:50 -0500 (Tue, 03 Feb 2009)
New Revision: 10103
trunk/qgis/python/plugins/fTools/__init__.py
trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
Fix some issues with spurious intersection results
Modified: trunk/qgis/python/plugins/fTools/__init__.py
--- trunk/qgis/python/plugins/fTools/__init__.py 2009-02-03 23:06:44 UTC (rev 10102)
+++ trunk/qgis/python/plugins/fTools/__init__.py 2009-02-04 00:59:50 UTC (rev 10103)
@@ -21,7 +21,7 @@
return "Tools for vector data analysis and management"
def version():
- return "0.5.3"
+ return "0.5.5"
def qgisMinimumVersion():
return "1.0.0"
Modified: trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
--- trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2009-02-03 23:06:44 UTC (rev 10102)
+++ trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2009-02-04 00:59:50 UTC (rev 10103)
@@ -93,7 +93,7 @@
self.attrib.hide()
self.mergeOutput.hide()
if self.myFunction == 3: # Difference
- self.label_2.setText( self.tr( "Erase layer" ) )
+ self.label_2.setText( self.tr( "Difference layer" ) )
self.setWindowTitle( self.tr( "Difference" ) )
elif self.myFunction == 5: # Intersect
self.label_2.setText( self.tr( "Intersect layer" ) )
@@ -172,7 +172,7 @@
if addToTOC == QMessageBox.Yes:
ftools_utils.addShapeToCanvas( unicode( self.shapefileName ) )
else:
- QMessageBox.warning( self, "Geoprocessing", self.tr( "Error writing output shapefile." ) )
+ QMessageBox.warning( self, "Geoprocessing", self.tr( "GEOS geoprocessing error, please check that all features have a valid geometry" ) )
QObject.disconnect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
def runStatusFromThread( self, status ):
@@ -226,6 +226,7 @@
self.running = False
def buffering( self, useField ):
+ GEOS_EXCEPT = True
vproviderA = self.vlayerA.dataProvider()
allAttrs = vproviderA.attributeIndexes()
vproviderA.select( allAttrs )
@@ -252,12 +253,22 @@
else:
value = self.myParam
inGeom = QgsGeometry( inFeat.geometry() )
- outGeom = QgsGeometry( inGeom.buffer( float( value ), 5 ) )
+ try:
+ outGeom = inGeom.buffer( float( value ), 5 )
+ except:
+ outGeom = QgsGeometry()
+ GEOS_EXCEPT = False
+ break
if first:
tempGeom = QgsGeometry( outGeom )
first = False
else:
- tempGeom = QgsGeometry( tempGeom.combine( outGeom ) )
+ try:
+ tempGeom = tempGeom.combine( outGeom )
+ except:
+ tempGeom = QgsGeometry()
+ break
outFeat.setGeometry( tempGeom )
writer.addFeature( outFeat )
else:
@@ -271,14 +282,20 @@
else:
+ try:
+ except:
+ continue
outFeat.setGeometry( outGeom )
outFeat.setAttributeMap( atMap )
del writer
- return True, True
+ return GEOS_EXCEPT, True
def convex_hull(self, useField ):
allAttrsA = vproviderA.attributeIndexes()
fields = vproviderA.fields()
@@ -314,7 +331,11 @@
hull.extend( points )
if len( hull ) >= 3:
tmpGeom = QgsGeometry( outGeom.fromMultiPoint( hull ) )
- outGeom = QgsGeometry( tmpGeom.convexHull() )
+ try:
+ outGeom = tmpGeom.convexHull()
+ except:
(area, perim) = self.simpleMeasure( outGeom )
outFeat.addAttribute( 0, QVariant( outID ) )
@@ -335,13 +356,18 @@
points = ftools_utils.extractPoints( inGeom )
+ try:
+ except:
del writer
- return True, True
def dissolve( self, useField ):
@@ -367,7 +393,11 @@
else:
tmpInGeom = QgsGeometry( inFeat.geometry() )
tmpOutGeom = QgsGeometry( outFeat.geometry() )
- tmpOutGeom = QgsGeometry( tmpOutGeom.combine( tmpInGeom ) )
+ try:
+ tmpOutGeom = tmpOutGeom.combine( tmpInGeom )
+ except:
+ tmpOutGeom = QgsGeometry()
outFeat.setGeometry( tmpOutGeom )
outFeat.setAttributeMap( attrs )
@@ -395,14 +425,19 @@
else:
+ try:
+ except:
del writer
- return True, True
def difference( self ):
vproviderA.select( allAttrsA )
@@ -432,15 +467,21 @@
for id in intersects:
vproviderB.featureAtId( int( id ), inFeatB , True, allAttrsB )
tmpGeom = QgsGeometry( inFeatB.geometry() )
- if geom.intersects( tmpGeom ):
- geom = geom.difference( tmpGeom )
+ try:
+ if geom.intersects( tmpGeom ):
+ geom = geom.difference( tmpGeom )
+ except:
+ geom = QgsGeometry()
+ break
outFeat.setGeometry( geom )
del writer
- return True, crs_match
+ return GEOS_EXCEPT, crs_match
def intersect( self ):
@@ -470,16 +511,25 @@
- atMapB = inFeatB.attributeMap()
- int_geom = geom.intersection( tmpGeom )
- outFeat.setGeometry( int_geom )
- outFeat.setAttributeMap( ftools_utils.combineVectorAttributes( atMapA, atMapB ) )
- writer.addFeature( outFeat )
+ try:
+ atMapB = inFeatB.attributeMap()
+ int_geom = geom.intersection( tmpGeom )
+ if int_geom.wkbType() == 7:
+ int_com = geom.combine( tmpGeom )
+ int_sym = geom.symDifference( tmpGeom )
+ int_geom = int_com.difference( int_sym )
+ outFeat.setGeometry( int_geom )
+ outFeat.setAttributeMap( ftools_utils.combineVectorAttributes( atMapA, atMapB ) )
+ writer.addFeature( outFeat )
+ except:
+ continue
del writer
def union( self ):
@@ -520,8 +570,18 @@
found = True
- diff_geom = diff_geom.difference( tmpGeom )
+ try:
+ diff_geom = diff_geom.difference( tmpGeom )
+ except:
+ int_geom = QgsGeometry()
+ found = False
+ break
@@ -547,8 +607,13 @@
vproviderA.featureAtId( int( id ), inFeatB , True, allAttrsA )
+ try:
+ except:
+ continue
@@ -556,6 +621,7 @@
def symetrical_difference( self ):
@@ -586,8 +652,13 @@
+ try:
+ except:
+ continue
outFeat.setAttributeMap( atMapA )
@@ -603,15 +674,21 @@
+ try:
+ except:
+ continue
del writer
def clip( self ):
@@ -641,13 +718,21 @@
- geom= geom.intersection( tmpGeom )
- outFeat.setGeometry( geom )
- outFeat.setAttributeMap( atMap )
+ try:
+ outFeat.setAttributeMap( atMap )
+ except:
+ continue
del writer
def checkParameter( self, layer, param ):
if self.myFunction == 1:
