[QGIS Commit] r10121 - in trunk/qgis/src: app core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Feb 7 07:51:13 EST 2009
Author: wonder
Date: 2009-02-07 07:51:13 -0500 (Sat, 07 Feb 2009)
New Revision: 10121
   trunk/qgis/src/app/qgsoptions.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
Added possibility not to draw vertex markers when a layer is in editing mode
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp	2009-02-07 12:08:07 UTC (rev 10120)
+++ trunk/qgis/src/app/qgsoptions.cpp	2009-02-07 12:51:13 UTC (rev 10121)
@@ -207,6 +207,7 @@
   //vertex marker
   mMarkerStyleComboBox->addItem( tr( "Semi transparent circle" ) );
   mMarkerStyleComboBox->addItem( tr( "Cross" ) );
+  mMarkerStyleComboBox->addItem( tr( "None" ) );
   QString markerStyle = settings.value( "/qgis/digitizing/marker_style", "SemiTransparentCircle" ).toString();
   if ( markerStyle == "SemiTransparentCircle" )
@@ -217,6 +218,10 @@
     mMarkerStyleComboBox->setCurrentIndex( mMarkerStyleComboBox->findText( tr( "Cross" ) ) );
+  else if (markerStyle == "None" )
+    mMarkerStyleComboBox->setCurrentIndex( mMarkerStyleComboBox->findText( tr( "None" ) ) );
   chkDisableAttributeValuesDlg->setChecked( settings.value( "/qgis/digitizing/disable_enter_attribute_values_dialog", false ).toBool() );
@@ -387,6 +392,10 @@
     settings.setValue( "/qgis/digitizing/marker_style", "Cross" );
+  else if ( markerComboText == tr( "None" ) )
+    settings.setValue( "/qgis/digitizing/marker_style", "None" );
   settings.setValue( "/qgis/digitizing/disable_enter_attribute_values_dialog", chkDisableAttributeValuesDlg->isChecked() );
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2009-02-07 12:08:07 UTC (rev 10120)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2009-02-07 12:51:13 UTC (rev 10121)
@@ -808,7 +808,7 @@
     p.setBrush( QColor( 200, 200, 210, 120 ) );
     p.drawEllipse( QRectF( x - 7, y - 7, 14, 14 ) );
-  else
+  else if ( type == QgsVectorLayer::Cross )
     int size = 15;
     int m = ( size - 1 ) / 2;
@@ -3303,10 +3303,14 @@
     return QgsVectorLayer::Cross;
-  else
+  else if ( markerTypeString == "SemiTransparentCircle" )
     return QgsVectorLayer::SemiTransparentCircle;
+  else
+    return QgsVectorLayer::NoMarker;
 void QgsVectorLayer::drawFeature( QPainter* p,
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2009-02-07 12:08:07 UTC (rev 10120)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2009-02-07 12:51:13 UTC (rev 10121)
@@ -465,7 +465,8 @@
     enum VertexMarkerType
       SemiTransparentCircle,
-      Cross
+      Cross,
+      NoMarker  /* added in version 1.1 */
     /** vector layers are not copyable */
More information about the QGIS-commit mailing list
