[QGIS Commit] r10131 - branches/Version-1_0/src/plugins/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Feb 8 13:14:40 EST 2009
Author: jef
Date: 2009-02-08 13:14:40 -0500 (Sun, 08 Feb 2009)
New Revision: 10131
   branches/Version-1_0/src/plugins/grass/qgsgrassmodule.cpp
   branches/Version-1_0/src/plugins/grass/qgsgrassshell.cpp
   branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp
merge r10130 in version 1.0
Modified: branches/Version-1_0/src/plugins/grass/qgsgrassmodule.cpp
--- branches/Version-1_0/src/plugins/grass/qgsgrassmodule.cpp	2009-02-08 18:14:04 UTC (rev 10130)
+++ branches/Version-1_0/src/plugins/grass/qgsgrassmodule.cpp	2009-02-08 18:14:40 UTC (rev 10131)
@@ -87,19 +87,19 @@
   if ( QFile::exists( file ) ) return file;  // full path
-  // Search for module
+#ifdef WIN32
+  // On windows try .bat first
   for ( QStringList::iterator it = mExecPath.begin();
         it != mExecPath.end(); ++it )
-    QString full = *it + "/" + file;
+    QString full = *it + "/" + file + ".bat";
     if ( QFile::exists( full ) )
       return full;
-  // Not found try with .exe
-#ifdef WIN32
+  // .exe next
@@ -109,8 +109,21 @@
       return full;
+  // and then try if it's a script (w/o extension)
 #endif
+  // Search for module
+  for ( QStringList::iterator it = mExecPath.begin();
+        it != mExecPath.end(); ++it )
+    QString full = *it + "/" + file;
+    if ( QFile::exists( full ) )
+      return full;
   return QString();
@@ -131,24 +144,7 @@
     return arguments;
-#if defined(WIN32)
-  QFileInfo fi( exe );
-  if ( fi.isExecutable() )
-    arguments.append( exe );
-  else // script
-    QString cmd = getShortPath( QgsApplication::applicationDirPath() ) + "/msys/bin/sh";
-    arguments.append( cmd );
-    // Important! Otherwise it does not find DLL even if it is in PATH
-    arguments.append( "--login" );
-#else
-#endif
   return arguments;
Modified: branches/Version-1_0/src/plugins/grass/qgsgrassshell.cpp
--- branches/Version-1_0/src/plugins/grass/qgsgrassshell.cpp	2009-02-08 18:14:04 UTC (rev 10130)
+++ branches/Version-1_0/src/plugins/grass/qgsgrassshell.cpp	2009-02-08 18:14:40 UTC (rev 10131)
@@ -183,7 +183,7 @@
     setsid();
     seteuid( 0 );
-    int fd = open(( char* ) slaveName.ascii(), O_RDWR );
+    int fd = ::open(( char* ) slaveName.ascii(), O_RDWR );
     if ( fd < 0 )
       QMessageBox::warning( 0, "Warning", "Cannot open slave file "
Modified: branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp
--- branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp	2009-02-08 18:14:04 UTC (rev 10130)
+++ branches/Version-1_0/src/plugins/grass/qgsgrasstools.cpp	2009-02-08 18:14:40 UTC (rev 10131)
@@ -171,32 +171,9 @@
 #endif
 #ifdef WIN32
-    // Run MSYS if available
-    // Note: I was not able to run cmd.exe and command.com
-    //       with QProcess
-    QString msysPath = appDir() + "/msys/bin/rxvt.exe";
-    QString myArguments = "-backspacekey ^H -sl 2500 -fg white -bg black -sr -fn Courier-16 -tn msys -geometry 80x25 -e    /bin/sh --login -i";
-    QFile file( msysPath );
-    if ( !file.exists() )
-      QMessageBox::warning( 0, tr( "Warning" ),
-                            tr( "Cannot find MSYS (" ) + msysPath + ")" );
+    if( !QProcess::startDetached( getenv("COMSPEC") ) ) {
+      QMessageBox::warning( 0, "Warning", tr("Cannot start command shell (%1)").arg( getenv("COMSPEC") ) );
-    else
-      QProcess *proc = new QProcess( this );
-      //allow msys to exist in a path with spaces
-      msysPath =  "\"" + msysPath + "\""  ;
-      proc->start( msysPath + " " +  myArguments );
-      proc->waitForStarted();
-      if ( proc->state() != QProcess::Running )
-        QMessageBox::warning( 0, "Warning",
-                              "Cannot start MSYS (" + msysPath + ")" );
     return;
 #else
More information about the QGIS-commit mailing list
