[QGIS Commit] r10139 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Feb 9 04:49:34 EST 2009
Author: dassau
Date: 2009-02-09 04:49:34 -0500 (Mon, 09 Feb 2009)
New Revision: 10139
   docs/trunk/english_us/user_guide/grass_integration.tex
fixed wrong data description
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex	2009-02-09 08:32:52 UTC (rev 10138)
+++ docs/trunk/english_us/user_guide/grass_integration.tex	2009-02-09 09:49:34 UTC (rev 10139)
@@ -225,8 +225,8 @@
 This Section gives an example how to import raster and vector data into the
 \filename{alaska} GRASS \filename{LOCATION} provided by the QGIS alaska
-dataset. Therefore we use a landcover raster map \filename{landcover.tif}
-and a vector polygone Shape \filename{lakes.shp} from the QGIS alaska
+dataset. Therefore we use a landcover raster map \filename{landcover.img}
+and a vector GML File \filename{lakes.gml} from the QGIS alaska
 dataset \ref{label_sampledata}.
 \begin{enumerate}
@@ -238,29 +238,29 @@
   \filename{demo} and click \button{OK}.
   \item Now click the \toolbtntwo{grass_tools}{Open GRASS tools} icon. The
   GRASS Toolbox (see Section \ref{subsec:grass_toolbox}) dialog appears.
-  \item To import the raster map \filename{landcover.tif}, click the module
+  \item To import the raster map \filename{landcover.img}, click the module
   \filename{r.in.gdal} in the \tab{Modules Tree} tab. This GRASS module
   allows to import GDAL supported raster files into a GRASS
   \filename{LOCATION}. The module dialog for \filename{r.in.gdal} appears.
   \item Browse to the folder \filename{raster} in the QGIS alaska dataset
-  and select the file \filename{landcover.tif}.
+  and select the file \filename{landcover.img}.
   \item As raster output name define \filename{landcover\_grass} and click
   \button{Run}. In the \tab{Output} tab you see the currently running GRASS
-  command \filename{r.in.gdal -o input=/path/to/landcover.tif
+  command \filename{r.in.gdal -o input=/path/to/landcover.img
   output=landcover\_grass}.
   \item When it says \textbf{Succesfully finished} click \button{View output}.
   The \filename{landcover\_grass} raster layer is now imported into GRASS and
   will be visualized in the QGIS canvas.
-  \item To import the vector shape \filename{lakes.shp}, click the module
+  \item To import the vector GML file \filename{lakes.gml}, click the module
   \filename{v.in.ogr} in the \tab{Modules Tree} tab. This GRASS module allows
   to import OGR supported vector files into a GRASS \filename{LOCATION}. The
   module dialog for \filename{v.in.ogr} appears.
-  \item Browse to the folder \filename{vmap0\_shapefiles} in the QGIS alaska
-  dataset and select the file \filename{lakes.shp} as OGR file.
+  \item Browse to the folder \filename{gml} in the QGIS alaska
+  dataset and select the file \filename{lakes.gml} as OGR file.
   \item As vector output name define \filename{lakes\_grass} and click
   \button{Run}. You don't have to care about the other options in this
   example. In the \tab{Output} tab you see the currently running GRASS
-  command \filename{v.in.ogr -o dsn=/path/to/lakes.shp output=lakes\_grass}.
+  command \filename{v.in.ogr -o dsn=/path/to/lakes.gml output=lakes\_grass}.
   The \filename{lakes\_grass} vector layer is now imported into GRASS and will
More information about the QGIS-commit mailing list
