[QGIS Commit] r10180 - branches/vector_overlay_branch/src/plugins/diagram_overlay
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Feb 16 10:44:43 EST 2009
Author: mhugent
Date: 2009-02-16 10:44:43 -0500 (Mon, 16 Feb 2009)
New Revision: 10180
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.h
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramrenderer.h
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.h
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp
   branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h
save also svg diagram types to project
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.cpp	2009-02-16 15:44:43 UTC (rev 10180)
@@ -151,3 +151,11 @@
   //calculate value/pixel ratio
   return (size / scalingValue);
+bool QgsBarDiagramFactory::_writeXML(QDomNode& factory_node, QDomDocument& doc) const
+    QDomElement barWidthElem = doc.createElement("barWidth");
+    QDomText barWidthText = doc.createTextNode(QString::number(mBarWidth));
+    barWidthElem.appendChild(barWidthText);
+    factory_node.appendChild(barWidthElem);
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.h	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsbardiagramfactory.h	2009-02-16 15:44:43 UTC (rev 10180)
@@ -45,6 +45,9 @@
    know if e.g. size has to be calculated proportional to pie area*/
   QgsDiagramFactory::SizeType sizeType() const {return QgsDiagramFactory::HEIGHT;}
+   /**Writes bar with into the project file*/
+  bool _writeXML(QDomNode& factory_node, QDomDocument& doc) const;
  private:
   /**width of one bar (default 5 mm)*/
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h	2009-02-16 15:44:43 UTC (rev 10180)
@@ -90,6 +90,9 @@
   /**Returns the attributes represented in the pies / bars*/
   virtual QgsAttributeList categoryAttributes() const {return QgsAttributeList();}
+  /**Read settings from project file*/
+  virtual bool readXML(const QDomNode& factoryNode) = 0;
  protected:
   /**Size units of diagram items*/
   SizeUnit mSizeUnit;
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramrenderer.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramrenderer.h	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramrenderer.h	2009-02-16 15:44:43 UTC (rev 10180)
@@ -96,7 +96,7 @@
   QList<QgsDiagramItem> mItems;
   /**Describes the type of interpolation (linear by default)*/
   ItemInterpretation mItemInterpretation;
-  /**Factor to multiply the sizes*/
+  /**Factor to multiply the sizes (e.g. used by QGIS mapserver dependent on the current scale)*/
   double mScaleFactor;
   /**Searches the value of the classification attribute(s). Considers that there
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp	2009-02-16 15:44:43 UTC (rev 10180)
@@ -88,5 +88,22 @@
   return mRenderer.load(data);
+bool QgsSVGDiagramFactory::writeXML(QDomNode& overlay_node, QDomDocument& doc) const
+    QDomElement factoryElem = doc.createElement("factory");
+    factoryElem.setAttribute("type", "svg");
+    QDomElement svgPathElem = doc.createElement("svgPath");
+    QDomText svgPathText = doc.createTextNode(mSvgFilePath);
+    svgPathElem.appendChild(svgPathText);
+    factoryElem.appendChild(svgPathElem);
+    overlay_node.appendChild(factoryElem);
+    return true;
+bool QgsSVGDiagramFactory::readXML(const QDomNode& factoryNode)
+    //soon...
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.h	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.h	2009-02-16 15:44:43 UTC (rev 10180)
@@ -49,7 +49,7 @@
   @param height out: the height of the diagram image in pixels*/
   int getDiagramDimensions(int size, const QgsFeature& f, const QgsRenderContext& context, int& width, int& height) const;
-  bool writeXML(QDomNode& overlay_node, QDomDocument& doc) const {return false;} //later...
+  bool writeXML(QDomNode& overlay_node, QDomDocument& doc) const;
   /**Sets the SVG data to be rendered.
    @return true in case of success*/
@@ -57,6 +57,9 @@
   QString svgFilePath() const {return mSvgFilePath;}
+  bool readXML(const QDomNode& factoryNode);
  private:
   mutable QSvgRenderer mRenderer;
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp	2009-02-16 15:44:43 UTC (rev 10180)
@@ -47,11 +47,15 @@
   QDomElement overlayElement = overlay_node.toElement();
+  QDomElement factoryElement = doc.createElement("factory");
+  factoryElement.setAttribute("type", diagramType());
+  overlay_node.appendChild(factoryElement);
   //well known name
   QDomElement wellKnownNameElem = doc.createElement("wellknownname");
   QDomText wknText = doc.createTextNode(mDiagramType);
   wellKnownNameElem.appendChild(wknText);
-  overlayElement.appendChild(wellKnownNameElem);
+  factoryElement.appendChild(wellKnownNameElem);
   //classification fields
   QList<int>::const_iterator scaling_it = mScalingAttributes.constBegin();
@@ -60,7 +64,7 @@
       QDomElement classificationFieldElem = doc.createElement("classificationfield");
       QDomText classFieldText = doc.createTextNode(QString::number(*scaling_it));
       classificationFieldElem.appendChild(classFieldText);
-      overlayElement.appendChild(classificationFieldElem);
+      factoryElement.appendChild(classificationFieldElem);
   //diagram categories
@@ -89,8 +93,12 @@
       currentCategoryElem.appendChild(currentBrushElem);
       currentCategoryElem.appendChild(currentPenElem);
-      overlayElement.appendChild(currentCategoryElem);
+      factoryElement.appendChild(currentCategoryElem);
+  //write subclass specific information
+  _writeXML(factoryElement, doc);
   return true;
@@ -123,3 +131,8 @@
     return categoryAttList;
+bool QgsWKNDiagramFactory::readXML(const QDomNode& factoryNode)
+    return false; //soon...
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h	2009-02-16 15:27:13 UTC (rev 10179)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h	2009-02-16 15:44:43 UTC (rev 10180)
@@ -38,8 +38,11 @@
  public:
   QgsWKNDiagramFactory();
   virtual ~QgsWKNDiagramFactory();
+  /**Writes the wkn diagram information into a <factory> tag*/
+  /**Possibility for wkn subclasses to write specific information into the XML document*/
+  virtual bool _writeXML(QDomNode& factory_node, QDomDocument& doc) const {};
   /**Returns the property described by the size (e.g. diameter or height). This can be important to
   virtual QgsDiagramFactory::SizeType sizeType() const = 0;
@@ -58,6 +61,9 @@
   /**Returns the supported well known names in a list*/
   static void supportedWellKnownNames(std::list<QString>& names);
+  /**Read wkn settings from project file*/
  protected:
   /**Well known diagram name (e.g. pie, bar, line)*/
More information about the QGIS-commit mailing list
