[QGIS Commit] r10194 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Tue Feb 17 14:30:48 EST 2009
Author: dassau
Date: 2009-02-17 14:30:47 -0500 (Tue, 17 Feb 2009)
New Revision: 10194
docs/trunk/english_us/user_guide/grass_integration.tex
fixed wring sample data projection
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex 2009-02-17 17:34:50 UTC (rev 10193)
+++ docs/trunk/english_us/user_guide/grass_integration.tex 2009-02-17 19:30:47 UTC (rev 10194)
@@ -125,7 +125,7 @@
As an an example you find the instructions how the sample GRASS
\filename{LOCATION alaska}, which is projected in Albers Equal Area
-projection with unit meter was created for the QGIS sample dataset. This
+projection with unit feet was created for the QGIS sample dataset. This
sample GRASS \filename{LOCATION alaska} will be used for all examples and
exercises in the following GRASS GIS related chapters. It is useful to
download and install the dataset on your computer \ref{label_sampledata}).
@@ -155,8 +155,8 @@
\button{Next}
\item Define the projection by clicking on the radio button
\radiobuttonon{Projection} to enable the projection list
- \item We are using Albers Equal Area Alaska (meters) projection. Since we
- happen to know that it is represented by the EPSG ID 5000, we enter it in
+ \item We are using Albers Equal Area Alaska (feet) projection. Since we
+ happen to know that it is represented by the EPSG ID 2964, we enter it in
the search box. (Note: If you want to repeat this process for another
\filename{LOCATION} and projection and haven't memorized the EPSG ID,
click on the
