[QGIS Commit] r10213 - docs/branches/1.0.0/italian/user_guide
svn_qgis at osgeo.org
Fri Feb 20 06:36:12 EST 2009
Author: santini
Date: 2009-02-20 06:36:11 -0500 (Fri, 20 Feb 2009)
New Revision: 10213
docs/branches/1.0.0/italian/user_guide/plugins_coordinate_capture.tex
IT translation for coordinate_capture_plugin chapter
Modified: docs/branches/1.0.0/italian/user_guide/plugins_coordinate_capture.tex
--- docs/branches/1.0.0/italian/user_guide/plugins_coordinate_capture.tex 2009-02-20 09:59:21 UTC (rev 10212)
+++ docs/branches/1.0.0/italian/user_guide/plugins_coordinate_capture.tex 2009-02-20 11:36:11 UTC (rev 10213)
@@ -1,43 +1,33 @@
% vim: set textwidth=78 autoindent:
-\subsection{Coordinate Capture Plugin}
+\subsection{Plugin di Cattura delle Coordinate}
% when the revision of a section has been finalized,
% comment out the following line:
% \updatedisclaimer
-The coordinate capture plugin is easy to use and provides the
-capability to display coordinates on the map canvas for two
-selected Coordinate Reference Systems (CRS). You can click a
-certain point and copy the coordinates to the clipboard or you
-use the mouse tracking functionality
+Il plugin di Cattura delle Coordinate è facile da usare e offre la capacità di mostrare sulla mappa le coordinate per due Sistemi di Riferimento tramite Coordinate (Coordinate Reference Systems - CRS). Basta cliccare un certo punto e copiare le coordinate negli appunti o usare la funzionalità di tracciatura del mouse.
\begin{figure}[ht]
\begin{center}
- \caption{Coordinate Cature Plugin \nixcaption}\label{fig:coordinate_capture_dialog}\smallskip
+ \caption{Plugin di cattura delle Coordinate\nixcaption}\label{fig:coordinate_capture_dialog}\smallskip
\includegraphics[clip=true]{coordinate_capture_dialog}
\end{center}
\end{figure}
\begin{enumerate}
- \item Start QGIS, select \dropmenuopttwo{mActionOptions}{Project Properties} from
- the \mainmenuopt{Settings} menu and click on the \tab{Projection} tab. As an alternative you
- you can also click on the \toolbtntwo{mIconProjectionEnabled}{projector} icon in the lower
- right-hand corner of the statusbar.
- \item Click on the \checkbox{Enable on the fly projection} checkbox and select the projected
- coordinate system \filename{"NAD27/Alaska Albers"} with EPSG 2964 (see also
- Section \ref{label_projections}).
- \item Load the \filename{alaska.shp} vector layer from the qgis sample dataset.
- \item Load the coordinate capture plugin in the Plugin Manager (see Section
- \ref{sec:load_core_plugin}) and click on the \toolbtntwo{coordinate_capture}{Coordinate Capture}
- icon. The cordinate capture dialog appears as shown in Figure \ref{fig:coordinate_capture_dialog}.
- \item Click on the \toolbtntwo{geographic}{Click to the select the CRS to use for coordinate display}
- icon and select Geographic Coordinate System \filename{WGS84} (EPSG 4326).
- \item You can now click anywhere on the map canvas and the plugin will show the
- \filename{"NAD27/Alaska Albers"} and \filename{WGS84} coordinates for your selected points as shown in
- Figure \ref{fig:coordinate_capture_dialog}.
- \item To enable mouse coordinate tracking click the \toolbtntwo{tracking}{mouse tracking} icon.
- \item You can also copy selected coordinates to the clipboard.
+ \item Lanciare QGIS, selezionare \dropmenuopttwo{mActionOptions}{Proprietà Progetto} dal menu
+ \mainmenuopt{Impostazioni} e scegliere la tab \tab{Sistema Riferimento Spaziale (SRS)}. In alternativa, cliccare l'icona \toolbtntwo{mIconProjectionEnabled}{Stato SRS} nell'angolo in basso a destra della barra di stato.
+ \item Selezionare \checkbox{Abilita la modifica immediata SRS Information}
+ \filename{"NAD27/Alaska Albers"} con EPSG 2964 (vedi anche la Sezione \ref{label_projections}).
+ \item Caricare il layer vettoriale \filename{alaska.shp} dal set di dati campione QGIS.
+ \item Caricare il plugin di Cattura di Coordinate nel Gestore dei Plugins (vedere la Sezione
+ \ref{sec:load_core_plugin}) e selezionare l'icona \toolbtntwo{coordinate_capture}{Cattura delle Coordinate}. Compare una finestra di dialogo della Cattura di Coordinate come mostrato in Figura \ref{fig:coordinate_capture_dialog}.
+ \item Selezionare l'icona \toolbtntwo{geographic}{Clicca per selezionare il SRS da usare durante la visualizzazione delle coordinate}, espandere la lista Sistemi di Coordinate Geografiche e scegliere \filename{WGS84} (EPSG 4326).
+ \item Ora si può cliccare ovunque sulla mappa e il plugin mostrerà le coordinate
+ \filename{"NAD27/Alaska Albers"} e \filename{WGS84} per il punto selezionato come mostrato nella Figura \ref{fig:coordinate_capture_dialog}.
+ \item Per abilitare la tracciatura mouse delle coordinate selezionare l'icona \toolbtntwo{tracking}{tracciatura mouse}.
+ \item Si possono anche copiare le coordinate selezionate negli appunti.
\end{enumerate}
\newpage
