[QGIS Commit] r10220 - in trunk/qgis/mac/xcode: . Qgis.xcodeproj
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Feb 22 16:55:05 EST 2009
Author: kyngchaos
Date: 2009-02-22 16:55:05 -0500 (Sun, 22 Feb 2009)
New Revision: 10220
   trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
   trunk/qgis/mac/xcode/qgis_settings.xcconfig
add geos_c lib to bundling script; remove unused carbon framework; settings cleanup
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2009-02-22 10:12:28 UTC (rev 10219)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2009-02-22 21:55:05 UTC (rev 10220)
@@ -3016,7 +3016,7 @@
 			isa = PBXContainerItemProxy;
 			containerPortal = 20286C28FDCF999611CA2CEA /* Project object */;
 			proxyType = 1;
-			remoteGlobalIDString = 72A07D880F3BDF9C004FC2A4 /* postgresprovider */;
+			remoteGlobalIDString = 72A07D880F3BDF9C004FC2A4;
 			remoteInfo = postgresprovider;
 /* End PBXContainerItemProxy section */
@@ -4976,7 +4976,6 @@
 /* End PBXCopyFilesBuildPhase section */
 /* Begin PBXFileReference section */
-		20286C33FDCF999611CA2CEA /* Carbon.framework */ = {isa = PBXFileReference; lastKnownFileType = wrapper.framework; name = Carbon.framework; path = /System/Library/Frameworks/Carbon.framework; sourceTree = "<absolute>"; };
 		508344B209E5C41E0093A071 /* Qgis.app */ = {isa = PBXFileReference; explicitFileType = wrapper.application; includeInIndex = 0; path = Qgis.app; sourceTree = BUILT_PRODUCTS_DIR; };
 		7209CEF40F4DA70000DAC424 /* r.watershed.qgm */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.xml; name = r.watershed.qgm; path = ../../src/plugins/grass/modules/r.watershed.qgm; sourceTree = SOURCE_ROOT; };
 		7209CEF50F4DA70000DAC424 /* r.watershed.2.png */ = {isa = PBXFileReference; lastKnownFileType = image.png; name = r.watershed.2.png; path = ../../src/plugins/grass/modules/r.watershed.2.png; sourceTree = SOURCE_ROOT; };
@@ -8385,7 +8384,6 @@
 				7209F4B80F3A5434003DC336 /* CoreFoundation.framework */,
 				7209F4B90F3A5434003DC336 /* CoreServices.framework */,
 				7209F03A0F39E6A1003DC336 /* ApplicationServices.framework */,
-				20286C33FDCF999611CA2CEA /* Carbon.framework */,
 			name = "External Frameworks and Libraries";
 			sourceTree = "<group>";
@@ -13613,7 +13611,7 @@
 			runOnlyForDeploymentPostprocessing = 0;
 			shellPath = /bin/sh;
-			shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths.  ***FIXME***\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\tcp -f \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nGDALROOT=\"$GDAL_PREFIX/lib\"\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDALROOT/libgdal.dylib\" ] ; then\n\tcp -f \"$GDALROOT/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tglib=`otool -L \"$GDALROOT/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nPROJROOT=\"$PROJ_PREFIX/lib\"\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJROOT/libproj.dylib\" ] ; then\n\tcp -f \"$PROJROOT/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJROOT/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\tcp -f \"$GEOSROOT/libgeos.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgeos.dylib\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib\"\nfi\n\n# SQLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\tcp -f \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\tcp -f \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tcp -f \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E -m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\nif [ -f \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\" ] ; then\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/gui.so\"\nfi\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n";
+			shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths.  ***FIXME***\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\tcp -f \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nGDALROOT=\"$GDAL_PREFIX/lib\"\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDALROOT/libgdal.dylib\" ] ; then\n\tcp -f \"$GDALROOT/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tglib=`otool -L \"$GDALROOT/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nPROJROOT=\"$PROJ_PREFIX/lib\"\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJROOT/libproj.dylib\" ] ; then\n\tcp -f \"$PROJROOT/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJROOT/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\tcp -f \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\" | grep -E -m 1 \"libgeos_c.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\tcp -f \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\tcp -f \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tcp -f \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E -m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\nif [ -f \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\" ] ; then\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/gui.so\"\nfi\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n";
 			showEnvVarsInLog = 0;
 		729277F00F3A816100D9C992 /* ShellScript */ = {
Modified: trunk/qgis/mac/xcode/qgis_settings.xcconfig
--- trunk/qgis/mac/xcode/qgis_settings.xcconfig	2009-02-22 10:12:28 UTC (rev 10219)
+++ trunk/qgis/mac/xcode/qgis_settings.xcconfig	2009-02-22 21:55:05 UTC (rev 10220)
@@ -13,18 +13,18 @@
 // QGIS version info & config
-// major-minor-micro must be integers for Mac OS X
+// major-minor-patch must be integers for Mac OS X
 QGIS_RELEASE_NAME = Unstable-trunk
 QGIS_VERSION_MAJOR = 1
 QGIS_VERSION_MINOR = 1
 QGIS_VERSION_PATCH = 0
-QGIS_VERSION_BUILD = 20090215
+QGIS_VERSION_BUILD = 20090221
 QGIS_VERSION_FULL = $(QGIS_VERSION_MAJOR).$(QGIS_VERSION_MINOR).$(QGIS_VERSION_PATCH)-$(QGIS_VERSION_BUILD)
 QGIS_VERSION_INT = 10100
 // library version - generally, keep in sync with qgis version
-LIBQGIS_VERSION_MAJOR = 1
-LIBQGIS_VERSION_MINOR = 1
+LIBQGIS_VERSION_MAJOR = $(QGIS_VERSION_MAJOR)
+LIBQGIS_VERSION_MINOR = $(QGIS_VERSION_MINOR)
 LIBQGIS_VERSION_CURRENT = $(LIBQGIS_VERSION_MAJOR).$(LIBQGIS_VERSION_MINOR)
 LIBQGIS_VERSION_COMPAT = $(LIBQGIS_VERSION_MAJOR).0
@@ -32,6 +32,10 @@
 // Qt and other support
+// ***TODO*** - detect current version, only used in bundle script
+QT_FWVER = 4 // the Versions/ folder name
+QT_MVER = 4 // the install_name version
 QTDIR = /Developer/Tools/Qt
 QTMOC = $(QTDIR)/moc
 QTUIC = $(QTDIR)/uic
@@ -57,8 +61,7 @@
 PROJ_FORM = fw // fw or shared
 GEOS_FORM = fw // fw or shared
-// system sqlite3 only on Tiger+
-// could also have source form for in-source copy
+// could also have source form for in-source copy  ***TODO***
 SQLITE_FORM = fw // fw, system, static or shared
 GSL_FORM = shared // static or shared
@@ -73,6 +76,7 @@
 // system Python only on Leopard+
 PYTHON_FORM = fw // fw, system or disabled
+// ***TODO*** "Current" will autodetect version
 PYTHON_VERSION = 2.5 // can't auto-detect here
@@ -83,41 +87,18 @@
 // bundling GRASS doesn't make sense, as a full GRASS install is required
+// Qt always bundled - else Qt plugins will load that cause grief
-//BUNDLE_QT = YES // always - else Qt plugins will load that cause grief
 BUNDLE_GSL = YES
 BUNDLE_PGSQL = YES
 BUNDLE_GPSBABEL = YES
+// frameworks not bundled
+BUNDLE_GDAL = YES
+BUNDLE_GEOS = YES
+BUNDLE_PROJ = YES
+BUNDLE_SQLITE = YES
-// no need to bundle frameworks
-BUNDLE_GDAL = NO
-BUNDLE_GEOS = NO
-BUNDLE_PROJ = NO
-BUNDLE_SQLITE = NO
-// support library versions
-//   if shared libraries are bundled, need to change install_names
-//   and need to know library version as it currently is specified
-//   in the library
-//   check a library version with otool -L /path/to/library
-// ***** need to figure out install_names in script
-GSL_LIBVER = 0
-PGSQL_LIBVER = 5
-QT_FWVER = 4 // the Versions/ folder name
-QT_MVER = 4 // the install_name version
-// these only need to be checked for unix forms
-// since bundling is not set up yet for these, ignore them
-GDAL_LIBVER = 12
-PROJ_LIBVER = 4
-GEOS_LIBVER = 2
-GEOSC_LIBVER = 1 // GEOS has 2 libs, diff versions
-SQLITE_LIBVER = 0
 // locations of user forms of dependencies
 //   only used when the _shared or _static form is used above
 //   or always for some libraries
@@ -130,16 +111,15 @@
 GSL_PREFIX = /usr/local
-// this must match exactly how GRASS was *built*, not where it is currently
-// installed, if it was moved.  ie GRASS.app must be directly in /Applications
-// prefix is the equivalent of the GRASS GISBASE
+// This must match exactly how GRASS was built and installed.
+// If it was moved or renamed, qgis GRASS plugin will not work.
+// Prefix is the equivalent of the GRASS GISBASE
 GRASS_PREFIX_app = /Applications/GRASS-$(GRASS_VERSION).app/Contents/MacOS
 GRASS_PREFIX_unix = /usr/local/grass-$(GRASS_VERSION)
 EXPAT_PREFIX = /usr/local // not used for system expat
-// unix SQLite defaults to system, but that's Tiger+ -only
-//   use custom unix build for Panther-compatibility
+// unix SQLite defaults to system
 SQLITE_PREFIX_shared = /usr
 PGSQL_PREFIX = /usr/local/pgsql
@@ -166,13 +146,13 @@
 // subdirs are relative to MacOS dir, as if MacOS is unix "prefix"
 QGIS_BIN_SUBDIR = bin // leave this alone for now
 QGIS_FW_SUBDIR = ../Frameworks
-QGIS_LIB_SUBDIR = lib
+QGIS_LIB_SUBDIR = lib // qgispython lib MUST be in MacOS/lib
 QGIS_DATA_SUBDIR = ../Resources
 QGIS_PLUGIN_SUBDIR = ../PlugIns/qgis
 HEADER_SEARCH_PATHS = generated
 //LIBRARY_SEARCH_PATHS = $(PROJECT_TARGET_APP_DIR)/../Frameworks
 ALWAYS_SEARCH_USER_PATHS = NO
-USE_HEADERMAP = NO
+USE_HEADERMAP = NO // else headers with same name cause confusion
 DYLIB_CURRENT_VERSION = $(LIBQGIS_VERSION_MAJOR).$(LIBQGIS_VERSION_MINOR)
 DYLIB_COMPATIBILITY_VERSION = $(LIBQGIS_VERSION_MAJOR).0
@@ -209,8 +189,6 @@
 QTDEFS_Release = -DQT_NO_DEBUG
 QT_CXXFLAGS_APP = $(PGSQL_HAVE)
 QT_INC_QT3 = /Library/Frameworks/Qt3Support.framework/Headers
-// old qt: -D_REENTRANT -DQT_THREAD_SUPPORT
-// -I/Library/Frameworks/QtTest.framework/Headers
 QT_LIB_CORE = -framework QtCore
 QT_LIB_GUI = -framework QtGui
 QT_LIB_NET = -framework QtNetwork
@@ -218,11 +196,11 @@
 QT_LIB_SVG = -framework QtSvg
 QT_LIB_SQL = -framework QtSql
 QT_LIB_QT3 = -framework Qt3Support
+// convenience for all Qt:
 QT_LIB = $(QT_LIB_CORE) $(QT_LIB_GUI) $(QT_LIB_NET) $(QT_LIB_XML) $(QT_LIB_SVG) $(QT_LIB_SQL)
-// -framework QtDesigner
 // with a choice of system vs user unix libs, use full path to lib file
-// to avoid possible accidental linking to system lib
+// to avoid possible accidental linking to system lib (ie expat)
 GDAL_PREFIX_fw = /Library/Frameworks/GDAL.framework
 GDAL_PREFIX = $(GDAL_PREFIX_$(GDAL_FORM))
More information about the QGIS-commit mailing list
