[QGIS Commit] r9925 - trunk/qgis/doc
svn_qgis at osgeo.org
Mon Jan 5 02:37:33 EST 2009
Author: dassau
Date: 2009-01-05 02:37:32 -0500 (Mon, 05 Jan 2009)
New Revision: 9925
Removed:
trunk/qgis/doc/userguide.pdf
trunk/qgis/doc/index.html
removed old userguide pdf and changed user guide paragraph in index.html.
It now links to the current manual and translations in the internet.
Modified: trunk/qgis/doc/index.html
--- trunk/qgis/doc/index.html 2009-01-04 13:47:11 UTC (rev 9924)
+++ trunk/qgis/doc/index.html 2009-01-05 07:37:32 UTC (rev 9925)
@@ -121,16 +121,7 @@
</ol>
</dd>
</dt>
- <dl><dt><span class="subheader">Installation Guide
- <dd>How to build and install QGIS. The guide is available as part of the
- <a href="userguide.pdf">User Guide</a>.</dd>
- </dt>
- </dl>
- <dl><dt><span class="subheader">User Guide
- <dd>The definitive guide to using QGIS (be sure to read this!). The User Guide is available in
- <a href="userguide.pdf">pdf</a> format.</dd>
- </dt>
- </dl>
- All documents are installed in the qgis share/doc subdirectory. Updates and translations of the manual are provided at <a href="http://download.osgeo.org/qgis/doc/manual/">http://download.osgeo.org/qgis/doc/manual/</a>
+ <dl><dt><span class="subheader">User, Installation and Coding Guide
+ <dd>The QGIS manual is the definitive guide to using QGIS including installation and coding instructions (be sure to read this!). A current version of the QGIS manual and translations are provided at <a href="http://qgis.osgeo.org/documentation/manuals.html">http://qgis.osgeo.org/documentation/manuals.html</a>. Older versions are available at <a href="http://download.osgeo.org/qgis/doc/manual/">http://download.osgeo.org/qgis/doc/manual/</a>."
</body>
</html>
Deleted: trunk/qgis/doc/userguide.pdf
(Binary files differ)
