[QGIS Commit] r9969 - branches/Version-1_0/src/gui
svn_qgis at osgeo.org
Tue Jan 13 09:58:36 EST 2009
Author: mhugent
Date: 2009-01-13 09:58:36 -0500 (Tue, 13 Jan 2009)
New Revision: 9969
branches/Version-1_0/src/gui/qgsmapcanvas.cpp
branches/Version-1_0/src/gui/qgsmapcanvasmap.cpp
Applied patch2 for #1016 also for version 1
Modified: branches/Version-1_0/src/gui/qgsmapcanvas.cpp
--- branches/Version-1_0/src/gui/qgsmapcanvas.cpp 2009-01-13 14:58:12 UTC (rev 9968)
+++ branches/Version-1_0/src/gui/qgsmapcanvas.cpp 2009-01-13 14:58:36 UTC (rev 9969)
@@ -811,8 +811,8 @@
int height = lastSize.height();
lastSize = QSize( -1, -1 );
- //set map size before scene size seems to solve the white box problem
- //when moving rubber bands
+ //set map size before scene size helps keep scene indexes updated properly
+ // this was the cause of rubberband artifacts
mMap->resize( QSize( width, height ) );
mScene->setSceneRect( QRectF( 0, 0, width, height ) );
Modified: branches/Version-1_0/src/gui/qgsmapcanvasmap.cpp
--- branches/Version-1_0/src/gui/qgsmapcanvasmap.cpp 2009-01-13 14:58:12 UTC (rev 9968)
+++ branches/Version-1_0/src/gui/qgsmapcanvasmap.cpp 2009-01-13 14:58:36 UTC (rev 9969)
@@ -48,6 +48,8 @@
void QgsMapCanvasMap::resize( QSize size )
+ prepareGeometryChange(); // to keep QGraphicsScene indexes up to date on size change
mPixmap = QPixmap( size );
mImage = QImage( size, QImage::Format_RGB32 ); // temporary image - build it here so it is available when switching from QPixmap to QImage rendering
mCanvas->mapRenderer()->setOutputSize( size, mPixmap.logicalDpiX() );
