[QGIS Commit] r9982 - trunk/qgis/src/providers/ogr
svn_qgis at osgeo.org
Mon Jan 19 14:16:14 EST 2009
Author: jef
Date: 2009-01-19 14:16:14 -0500 (Mon, 19 Jan 2009)
New Revision: 9982
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
trunk/qgis/src/providers/ogr/qgsogrprovider.h
apply #1446
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-01-19 10:44:56 UTC (rev 9981)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-01-19 19:16:14 UTC (rev 9982)
@@ -189,7 +189,7 @@
case OFTReal: varType = QVariant::Double; break;
// unsupported in OGR 1.3
//case OFTDateTime: varType = QVariant::DateTime; break;
-#if GDAL_VERSION_NUM >= 1400
+#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1400
case OFTString: varType = QVariant::String; break;
#endif
default: varType = QVariant::String; // other unsupported, leave it as a string
@@ -578,31 +578,31 @@
for ( QgsNewAttributesMap::const_iterator iter = attributes.begin(); iter != attributes.end(); ++iter )
- OGRFieldDefnH fielddefn =
- OGR_Fld_Create( mEncoding->fromUnicode( iter.key() ).data(), OFTInteger );
+ OGRFieldDefnH fielddefn = OGR_Fld_Create( mEncoding->fromUnicode( iter.key() ).data(), OFTInteger );
- if ( *iter == "OFTInteger" )
+ if ( *iter == "Integer" )
OGR_Fld_SetType( fielddefn, OFTInteger );
+ OGR_Fld_SetWidth( fielddefn, 10 );
- else if ( *iter == "OFTReal" )
+ else if ( *iter == "Real" )
OGR_Fld_SetType( fielddefn, OFTReal );
- else if ( *iter == "OFTString" )
+ else if ( *iter == "String" )
OGR_Fld_SetType( fielddefn, OFTString );
else
- QgsLogger::warning( "QgsOgrProvider::addAttributes, type not found" );
+ QgsLogger::warning( QString( "QgsOgrProvider::addAttributes, type %1 not found" ).arg( *iter ) );
returnvalue = false;
continue;
if ( OGR_L_CreateField( ogrLayer, fielddefn, TRUE ) != OGRERR_NONE )
- QgsLogger::warning( "QgsOgrProvider.cpp: writing of OFTInteger field failed" );
+ QgsLogger::warning( "QgsOgrProvider.cpp: writing of field failed" );
OGR_Fld_Destroy( fielddefn );
@@ -727,7 +727,7 @@
QString sql = QString( "CREATE SPATIAL INDEX ON %1" ).arg( quotedIdentifier( fi.completeBaseName() ) ); // quote the layer name so spaces are handled
OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), OGR_L_GetSpatialFilter( ogrLayer ), "" );
//find out, if the .qix file is there
- QFile indexfile( fi.path().append( "/").append( fi.completeBaseName() ).append( ".qix" ) );
+ QFile indexfile( fi.path().append( "/" ).append( fi.completeBaseName() ).append( ".qix" ) );
if ( indexfile.exists() )
return true;
@@ -749,7 +749,7 @@
- OGR_L_SyncToDisk( ogrLayer );
+ OGR_L_SyncToDisk( ogrLayer );
QFileInfo fi( dataSourceUri() ); // to get the base name
QString sql = QString( "REPACK %1" ).arg( fi.completeBaseName() ); // don't quote the layer name as it works with spaces in the name and won't work if the name is quoted
OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), NULL, NULL );
@@ -852,9 +852,17 @@
// Ideally this should test for Shapefile type and GDAL >= 1.2.6
// In reality, createSpatialIndex() looks after itself.
- ability |= QgsVectorDataProvider::CreateSpatialIndex;
+ ability |= CreateSpatialIndex;
+#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1600
+ // adding attributes was added in GDAL 1.6
+ if ( ogrDriverName.startsWith( "ESRI" ) )
+ ability |= AddAttributes;
+#endif
// OGR doesn't handle shapefiles without attributes, ie. missing DBFs well, fixes #803
if ( ogrDriverName.startsWith( "ESRI" ) && mAttributeFields.size() == 0 )
@@ -1216,7 +1224,7 @@
OGR_DS_Destroy( dataSource );
QgsDebugMsg( QString( "GDAL Version number %1" ).arg( GDAL_VERSION_NUM ) );
-#if GDAL_VERSION_NUM >= 1310
+#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1310
if ( reference )
OSRRelease( reference );
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.h
--- trunk/qgis/src/providers/ogr/qgsogrprovider.h 2009-01-19 10:44:56 UTC (rev 9981)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.h 2009-01-19 19:16:14 UTC (rev 9982)
@@ -247,6 +247,7 @@
//! Selection rectangle
OGRGeometryH mSelectionRectangle;
/**Adds one feature*/
bool addFeature( QgsFeature& f );
/**Deletes one feature*/
