[QGIS Commit] r9985 - in trunk/qgis/src: core providers/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jan 19 20:11:06 EST 2009
Author: wonder
Date: 2009-01-19 20:11:06 -0500 (Mon, 19 Jan 2009)
New Revision: 9985
   trunk/qgis/src/core/qgsfeature.cpp
   trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
Fixed #1427 - memory leak when overwriting feature with a new feature.
Changed grass provider to avoid copying (reuse QgsFeature instance as in other providers)
Modified: trunk/qgis/src/core/qgsfeature.cpp
--- trunk/qgis/src/core/qgsfeature.cpp	2009-01-19 20:39:02 UTC (rev 9984)
+++ trunk/qgis/src/core/qgsfeature.cpp	2009-01-20 01:11:06 UTC (rev 9985)
@@ -61,9 +61,14 @@
   mAttributes =  rhs.mAttributes;
   mValid =  rhs.mValid;
   mTypeName = rhs.mTypeName;
+  // make sure to delete the old geometry (if exists)
+  if (mGeometry && mOwnsGeometry)
+    delete mGeometry;
   mGeometry = 0;
   mOwnsGeometry = false;
   if ( rhs.mGeometry )
     setGeometry( *rhs.mGeometry );
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2009-01-19 20:39:02 UTC (rev 9984)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2009-01-20 01:11:06 UTC (rev 9985)
@@ -293,7 +293,7 @@
   int cat, type, id;
   unsigned char *wkb;
   int wkbsize;
   QgsDebugMsgLevel( "entered.", 3 );
   if ( isEdited() || isFrozen() || !mValid )
@@ -318,7 +318,7 @@
   QgsDebugMsg( QString( "cat = %1 type = %2 id = %3" ).arg( cat ).arg( type ).arg( id ) );
 #endif
-  feature = QgsFeature( id );
+  feature.setFeatureId(id);
   // TODO int may be 64 bits (memcpy)
   if ( type & ( GV_POINTS | GV_LINES ) ) /* points or lines */
More information about the QGIS-commit mailing list
